fstorage hang at sd_app_evt_wait()
Nordic DevZone
Nordic DevZone
I try to using nrf_fstorage_write() to write data to fstorage and then waiting writting finish. But it hang at sd_app_evt_wait().fstorage.h
#include "app_timer.h"
#include "error.h"
#include "fds_flash.h"
#include "fstorage.h"
#include "nrf_delay.h"
#include "nrf_fstorage.h"
#include "nrf_fstorage_sd.h"
#include "nrf_fstorage_nvmc.h"
#include "nrf_log.h"
#include "nrf_soc.h"
#include "spi_flash.h"
#define FSTORAGE_PAGE_NUM    3
#define FSTORAGE_WAIT_CNT    1000
static bool _gFstorageInitialized = false;
static bool _gFstorageEraseDone   = true;
static bool _gFstorageWriteDone   = true;
static bool _gFstoragePageDirty   = true;
static void _fstorageEvtHandler(nrf_fstorage_evt_t * p_evt);
NRF_FSTORAGE_DEF(nrf_fstorage_t _gFstorage) =
    /* Set a handler for fstorage events. */
    .evt_handler = _fstorageEvtHandler,
    /* These below are the boundaries of the flash space assigned to this instance of fstorage.
     * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
     * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
     * last page of flash available to write data. */
    .start_addr = 0x7D000,
    .end_addr   = 0x80000,
static void _fstorageEvtHandler(nrf_fstorage_evt_t * pEvt) {
    NRF_LOG_DEBUG("Evt e\n");
    switch (pEvt->id) {
        case NRF_FSTORAGE_EVT_WRITE_RESULT:
            NRF_LOG_DEBUG("Evt w\n");
            if (pEvt->result != NRF_SUCCESS) {
               NRF_LOG_WARNING("fstorage writing failed %d bytes at address 0x%x.",
                            pEvt->len, pEvt->addr);
            } else {
                NRF_LOG_DEBUG("NRF_FSTORAGE_EVT_WRITE_RESULT ok");
        } break;
        case NRF_FSTORAGE_EVT_ERASE_RESULT:
            NRF_LOG_DEBUG("Evt er\n");
                NRF_LOG_WARNING("fstorage erased failed %d page from address 0x%x.",
            } else {
                NRF_LOG_DEBUG("NRF_FSTORAGE_EVT_ERASE_RESULT ok");
                _gFstoragePageDirty = false;
        } break;
     NRF_LOG_DEBUG("Evt x\n");
static uint32_t _fstorageGetEndAddr(void) {
    const uint32_t bootloaderAddr = BOOTLOADER_ADDRESS;
    const uint32_t pageSz         = NRF_FICR->CODEPAGESIZE;
    const uint32_t codeSz         = NRF_FICR->CODESIZE;
    return (bootloaderAddr != 0xFFFFFFFF ?
            bootloaderAddr : (codeSz * pageSz));
static uint32_t _fstorageGetStartAddr(void) {
    const uint32_t eraseUnit = _gFstorage.p_flash_info->erase_unit;
    const uint32_t endAddr = _fstorageGetEndAddr();
    uint32_t startAddr;
    if (bootloaderAddr == 0xFFFFFFFF) {
        startAddr = endAddr - FDS_VIRTUAL_PAGES * eraseUnit;
    } else {
        startAddr = bootloaderAddr - FSTORAGE_PAGE_NUM * eraseUnit;
    NRF_LOG_DEBUG("endAddr=0x%x", endAddr);
    NRF_LOG_DEBUG("startAddr=0x%x", startAddr);
    return startAddr;
static bool _fstorageIsEraseNeeded(void) {
    return _gFstoragePageDirty;
static uint32_t _fstorageRoundUpU32(const uint32_t len) {
    if (len % sizeof(uint32_t)) {
        return (len + sizeof(uint32_t) - (len % sizeof(uint32_t)));
    return len;
static void power_manage(void)
#ifdef SOFTDEVICE_PRESENT
    (void) sd_app_evt_wait();
#else
    __WFE();
int _fstorageWait(const uint32_t timeOutCnt) {
#if 0
    NRF_LOG_DEBUG("timeOutCnt=%u\n", timeOutCnt);
    const uint32_t startCnt   = app_timer_cnt_get();
    NRF_LOG_DEBUG("startCnt=%u\n", startCnt);
    uint32_t endCnt;
    uint32_t diffCnt;
    do {
        endCnt           = app_timer_cnt_get();
        diffCnt          = app_timer_cnt_diff_compute(endCnt, startCnt);
        if (diffCnt >= timeOutCnt) {
            NRF_LOG_WARNING("_fstorage wait timeout\n");
            return ERROR_FSTORAGE_WAIT_TIMEOUT;
        if (_gFstorageEraseDone && _gFstorageWriteDone) {
    } while (true);
    NRF_LOG_DEBUG("endCnt=%u\n", endCnt);
#else
    while (nrf_fstorage_is_busy(&_gFstorage))
        power_manage();
		return 0;
int _fstorageRead(const uint32_t addr, const uint32_t len, uint8_t* data) {
    if (!_gFstorageInitialized) {
        return ERROR_FSTORAGE_UNINITIALIZED;
    const ret_code_t errCode = nrf_fstorage_read(&_gFstorage, addr, data, len);
    if (errCode != NRF_SUCCESS) {
        NRF_LOG_WARNING("nrf_fstorage_read() failed 0x%x\n", errCode);
        return ERROR_FSTORAGE_READ_FAIL;
    return 0;
int _fstorageWrite(const uint32_t addr, const uint32_t len, void const* pData) {
    if (!_gFstorageEraseDone) {
        return ERROR_FSTORAGE_ERASE_ON_GOING;
    if (!_gFstorageWriteDone) {
        return ERROR_FSTORAGE_WRITE_ON_GOING;
    _gFstorageWriteDone = false;
    const uint32_t wlen = _fstorageRoundUpU32(len);
    const ret_code_t retCode = nrf_fstorage_write(&_gFstorage, addr, pData, wlen, NULL);
    if (retCode != NRF_SUCCESS) {
        NRF_LOG_WARNING("nrf_fstorage_write() failed 0x%x", retCode);
        return ERROR_FSTORAGE_WRITE_FAIL;
    _fstorageWait(FSTORAGE_WAIT_CNT);
    return 0;
int fstorageInit(void) {
    const ret_code_t errCode = nrf_fstorage_init(&_gFstorage, &nrf_fstorage_sd, NULL);
        NRF_LOG_WARNING("nrf_fstorage_init() failed 0x%x", errCode);
        return ERROR_FSTORAGE_INITIALIZE_FAIL;
    _gFstorageInitialized = true;
    return 0;
int fstorageErase(const uint32_t addr, const uint32_t pagesCnt) {
    _gFstorageEraseDone = false;
    const ret_code_t errCode = nrf_fstorage_erase(&_gFstorage, addr, pagesCnt, NULL);
        NRF_LOG_WARNING("nrf_fstorage_erase() failed 0x%x", errCode);
        return ERROR_FSTORAGE_ERASE_FAIL;
    return 0;
int fstorageEraseFDS(void) {
    uint32_t addr;
        addr = endAddr - FDS_VIRTUAL_PAGES * eraseUnit;
    } else {
        addr = bootloaderAddr - FDS_VIRTUAL_PAGES * eraseUnit;
    const uint32_t pagesCnt  = FDS_VIRTUAL_PAGES;
        NRF_LOG_WARNING("nrf_fstorage_erase() failed 0x%x\n", errCode);
    return 0;
int fstorageReadRecord(const uint32_t addr, record_t* pRecord) {
    uint8_t data[RECORD_LEN] = {0};
    if (_fstorageRead(addr, RECORD_LEN, data) != 0) {
        return ERROR_FDS_READ_FAIL;
    data2Record(data, pRecord);
    return 0;
int fstorageUpdateRecord(const record_data_type_t type, const record_t* pRecord) {
    const uint32_t addr = _fstorageGetStartAddr();
    NRF_LOG_DEBUG("type=%d, add=0x%x\n", type, addr);
    switch (type) {
        case RECORD_DATA_TYPE_START:
            NRF_LOG_DEBUG("RECORD_DATA_TYPE_START E\n");
            if (_fstorageIsEraseNeeded()) {
                NRF_LOG_DEBUG("fstorageErase() E\n");
                fstorageErase(addr, 1);
            NRF_LOG_DEBUG("fstorageWriteRecord() E\n");
            record_t record;
            record.offsetStart = 0;
            record.offsetEnd   = 0;
            fstorageWriteRecord(addr, &record);
            NRF_LOG_DEBUG("RECORD_DATA_TYPE_START x\n");
        case RECORD_DATA_TYPE_END:
            NRF_LOG_DEBUG("RECORD_DATA_TYPE_END E\n");
            record_t record;
            NRF_LOG_DEBUG("fstorageReadRecord() E\n");
            if (fstorageReadRecord(addr, &record) != 0) {
            NRF_LOG_DEBUG("fstorageReadRecord() x\n");
            NRF_LOG_DEBUG("record.offsetStart=0x%x", record.offsetStart);
            NRF_LOG_DEBUG("record.offsetEnd=0x%x",   record.offsetEnd);
            record.offsetEnd = pRecord->offsetEnd;
            NRF_LOG_DEBUG("RECORD_DATA_TYPE_END X");
    return 0;
int fstorageWriteRecord(const uint32_t addr, record_t* pRecord) {
    record2Data(pRecord, data);
    if (_fstorageWrite(addr, RECORD_LEN, data) != 0) {
    return 0;
return 0;
    snowuyl said:
    The following is error messages after defining define "DEBUG" and "DEBUG_NRF". But I can't find useful information.
    Aha, that is odd. It could be that there is an issue with the logger somehow. Instead of digging into that you can find the information another way, by setting a breakpoint in app_error_fault_handler() in components/libraries/util/app_error_weak.c and finding the filename, line number and error code there by inspecting the p_info.
  •  I test again and can generate the following messages.
     ponents\libraries\timer\app_timer2.c:181
     0> PC at: 0x000346AF
     0> <error> app: End of error report
     * Copyright (c) 2018 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #include "nrf_atfifo.h"
    #include "nrf_sortlist.h"
    #if APP_TIMER_WITH_PROFILER
    #if APP_TIMER_CONFIG_USE_SCHEDULER
    #include "app_scheduler.h"
    #include <stddef.h>
    #define NRF_LOG_MODULE_NAME APP_TIMER_LOG_NAME
    #if APP_TIMER_CONFIG_LOG_ENABLED
    #define NRF_LOG_LEVEL       APP_TIMER_CONFIG_LOG_LEVEL
    #define NRF_LOG_INFO_COLOR  APP_TIMER_CONFIG_INFO_COLOR
    #define NRF_LOG_DEBUG_COLOR APP_TIMER_CONFIG_DEBUG_COLOR
    #else //APP_TIMER_CONFIG_LOG_ENABLED
    #define NRF_LOG_LEVEL       0
    #endif //APP_TIMER_CONFIG_LOG_ENABLED
    NRF_LOG_MODULE_REGISTER();
    #include "drv_rtc.h"
     * Maximum possible relative value is limited by safe window to detect cases when requested
     * compare event has already occured.
    #define APP_TIMER_SAFE_WINDOW APP_TIMER_TICKS(APP_TIMER_SAFE_WINDOW_MS)
    #define APP_TIMER_RTC_MAX_VALUE   (DRV_RTC_MAX_CNT - APP_TIMER_SAFE_WINDOW)
    static drv_rtc_t m_rtc_inst = DRV_RTC_INSTANCE(1);
    static uint8_t m_max_user_op_queue_utilization;     /**< Maximum observed timer user operations queue utilization. */
    static uint8_t m_current_user_op_queue_utilization; /**< Currently observed timer user operations queue utilization. */
    #endif /* APP_TIMER_WITH_PROFILER */
     * @brief Timer requests types.
    typedef enum
        TIMER_REQ_START,
        TIMER_REQ_STOP,
        TIMER_REQ_STOP_ALL
    } app_timer_req_type_t;
     * @brief Operation request structure.
    typedef struct
        app_timer_req_type_t type;    /**< Request type. */
        app_timer_t *        p_timer; /**< Timer instance. */
    } timer_req_t;
    static app_timer_t * volatile mp_active_timer; /**< Timer currently handled by RTC driver. */
    static bool                   m_global_active; /**< Flag used to globally disable all timers. */
    static uint64_t m_base_counter;
    static uint64_t m_stamp64;
    /* Request FIFO instance. */
    NRF_ATFIFO_DEF(m_req_fifo, timer_req_t, APP_TIMER_CONFIG_OP_QUEUE_SIZE);
    /* Sortlist instance. */
    static bool compare_func(nrf_sortlist_item_t * p_item0, nrf_sortlist_item_t *p_item1);
    NRF_SORTLIST_DEF(m_app_timer_sortlist, compare_func); /**< Sortlist used for storing queued timers. */
     * @brief Return current 64 bit timestamp
    static uint64_t get_now(void)
        uint64_t now = m_base_counter + drv_rtc_counter_get(&m_rtc_inst);
        /* it is possible that base was not updated and overflow occured, in that case 'now' will be
         * 24bit value behind. Additional timestamp updated on every 24 bit period is used to detect
         * that case. Apart from that 'now' should never be behind previously read timestamp.
        if (now < m_stamp64) {
            now += (DRV_RTC_MAX_CNT + 1);
        return now;
     * @brief Function used for comparing items in sorted list.
    static inline bool compare_func(nrf_sortlist_item_t * p_item0, nrf_sortlist_item_t *p_item1)
        app_timer_t * p0 = CONTAINER_OF(p_item0, app_timer_t, list_item);
        app_timer_t * p1 = CONTAINER_OF(p_item1, app_timer_t, list_item);
        uint64_t p0_end = p0->end_val;
        uint64_t p1_end = p1->end_val;
        return (p0_end <= p1_end) ? true : false;
    static void scheduled_timeout_handler(void * p_event_data, uint16_t event_size)
        ASSERT(event_size == sizeof(app_timer_event_t));
        app_timer_event_t const * p_timer_event = (app_timer_event_t *)p_event_data;
        p_timer_event->timeout_handler(p_timer_event->p_context);
     * @brief Function called on timer expiration
     * If end value is not reached it is assumed that it was partial expiration and time is put back
     * into the list. Otherwise function calls user handler if timer was not stopped before. If timer
     * is in repeated mode then timer is rescheduled.
     * @param p_timer Timer instance.
     * @return True if reevaluation of sortlist needed (becasue it was updated).
    static bool timer_expire(app_timer_t * p_timer)
        ASSERT(p_timer->handler);
        bool ret = false;
        if ((m_global_active == true) && (p_timer != NULL) && (p_timer->active))
            if (get_now() >= p_timer->end_val) {
                /* timer expired */
                if (p_timer->repeat_period == 0)
                    p_timer->active = false;
                app_timer_event_t timer_event;
                timer_event.timeout_handler = p_timer->handler;
                timer_event.p_context       = p_timer->p_context;
                uint32_t err_code = app_sched_event_put(&timer_event,
                                                        sizeof(timer_event),
                                                        scheduled_timeout_handler);
        #else
                NRF_LOG_DEBUG("Timer expired (context: %d)", (uint32_t)p_timer->p_context)
                p_timer->handler(p_timer->p_context);
                /* check active flag as it may have been stopped in the user handler */
                if ((p_timer->repeat_period) && (p_timer->active))
                    p_timer->end_val += p_timer->repeat_period;
                    nrf_sortlist_add(&m_app_timer_sortlist, &p_timer->list_item);
                    ret = true;
                ret = true;
        return ret;
     * @brief Function is configuring RTC driver to trigger timeout interrupt for given timer.
     * It is possible that RTC driver will indicate that timeout already occured. In that case timer
     * expires and function indicates that RTC was not configured.
     * @param [in,out] p_rerun Flag indicating that sortlist reevaluation is required.
     * @return True if RTC was successfully configured, false if timer already expired and RTC was not
     *         configured.
    static bool rtc_schedule(app_timer_t * p_timer, bool * p_rerun)
        ret_code_t ret = NRF_ERROR_TIMEOUT;
        *p_rerun = false;
        int64_t remaining = (int64_t)(p_timer->end_val - get_now());
        if (remaining > 0) {
            uint32_t cc_val = ((uint32_t)remaining > APP_TIMER_RTC_MAX_VALUE) ?
                    (app_timer_cnt_get() + APP_TIMER_RTC_MAX_VALUE) : p_timer->end_val;
            ret = drv_rtc_windowed_compare_set(&m_rtc_inst, 0, cc_val, APP_TIMER_SAFE_WINDOW);
            NRF_LOG_DEBUG("Setting CC to 0x%08x (err: %d)", cc_val & DRV_RTC_MAX_CNT, ret);
            if (ret == NRF_SUCCESS)
                return true;
            drv_rtc_compare_disable(&m_rtc_inst, 0);
        if (ret == NRF_ERROR_TIMEOUT)
            *p_rerun = timer_expire(p_timer);
            NRF_LOG_ERROR("Unexpected error: %d", ret);
            ASSERT(0);
        return false;
    static inline app_timer_t * sortlist_pop(void)
        nrf_sortlist_item_t * p_next_item = nrf_sortlist_pop(&m_app_timer_sortlist);
        return p_next_item ? CONTAINER_OF(p_next_item, app_timer_t, list_item) : NULL;
    static inline app_timer_t * sortlist_peek(void)
        nrf_sortlist_item_t const * p_next_item = nrf_sortlist_peek(&m_app_timer_sortlist);
     * @brief Function for deactivating all timers which are in the sorted list (active timers).
    static void sorted_list_stop_all(void)
        app_timer_t * p_next;
        do
            p_next = sortlist_pop();
            if (p_next)
                p_next->active = false;
        } while (p_next);
     * @brief Function for handling RTC counter overflow.
     * Increment base counter used to calculate 64 bit timestamp.
    static void on_overflow_evt(void)
        NRF_LOG_DEBUG("Overflow EVT");
        m_base_counter += (DRV_RTC_MAX_CNT + 1);
     * #brief Function for handling RTC compare event - active timer expiration.
    static void on_compare_evt(drv_rtc_t const * const  p_instance)
        if (mp_active_timer)
            /* If assert fails it suggests that safe window should be increased. */
            ASSERT(app_timer_cnt_diff_compute(drv_rtc_counter_get(p_instance),
                                              mp_active_timer->end_val & RTC_COUNTER_COUNTER_Msk) < APP_TIMER_SAFE_WINDOW);
            NRF_LOG_INST_DEBUG(mp_active_timer->p_log, "Compare EVT");
            UNUSED_RETURN_VALUE(timer_expire(mp_active_timer));
            mp_active_timer = NULL;
            NRF_LOG_WARNING("Compare event but no active timer (already stopped?)");
     * @brief Channel 1 is triggered in the middle of 24 bit period to updated control timestamp in
     * place where there is no risk of overflow.
    static void on_compare1_evt(drv_rtc_t const * const  p_instance)
        m_stamp64 = get_now();
     * @brief Function updates RTC.
     * Function is called at the end of RTC interrupt when all new user request and/or timer expiration
     * occured. It configures RTC if there is any pending timer, reconfigures if the are timers with
     * shorted timeout than active one or stops RTC if there is no active timers.
    static void rtc_update(drv_rtc_t const * const  p_instance)
        while(1)
            app_timer_t * p_next = sortlist_peek();
            bool rtc_reconf = false;
            if (p_next) //Candidate for active timer
                if (mp_active_timer == NULL)
                    //There is no active timer so candidate will become active timer.
                    rtc_reconf = true;
                else if (p_next->end_val < mp_active_timer->end_val)
                    //Candidate has shorter timeout than current active timer. Candidate will replace active timer.
                    //Active timer is put back into sorted list.
                    rtc_reconf = true;
                    if (mp_active_timer->active)
                        NRF_LOG_INST_DEBUG(mp_active_timer->p_log, "Timer preempted.");
                        nrf_sortlist_add(&m_app_timer_sortlist, &mp_active_timer->list_item);
                if (rtc_reconf)
                    bool rerun;
                    NRF_LOG_INST_DEBUG(p_next->p_log, "Activating timer (CC:%d/%08x).", p_next->end_val, p_next->end_val);
                    if (rtc_schedule(p_next, &rerun))
                        if (!APP_TIMER_KEEPS_RTC_ACTIVE && (mp_active_timer == NULL))
                            drv_rtc_start(p_instance);
                        mp_active_timer = p_next;
                        if (rerun == false)
                            //RTC was successfully updated and sortlist was not updated. Function can be terminated.
                        //If RTC driver indicated that timeout already occured a new candidate will be taken from sorted list.
                        NRF_LOG_INST_DEBUG(p_next->p_log,"Timer expired before scheduled to RTC.");
                    //RTC will not be updated. Function can terminate.
            else //No candidate for active timer.
                    drv_rtc_stop(p_instance);
     * @brief Function for processing user requests.
     * Function is called only in the context of RTC interrupt.
    static void timer_req_process(drv_rtc_t const * const  p_instance)
        nrf_atfifo_item_get_t fifo_ctx;
        timer_req_t *         p_req = nrf_atfifo_item_get(m_req_fifo, &fifo_ctx);
        while (p_req)
            switch (p_req->type)
                case TIMER_REQ_START:
                    if (!p_req->p_timer->active)
                        p_req->p_timer->active = true;
                        nrf_sortlist_add(&m_app_timer_sortlist, &(p_req->p_timer->list_item));
                        NRF_LOG_INST_DEBUG(p_req->p_timer->p_log,"Start request (expiring at %d/0x%08x).",
                                                      p_req->p_timer->end_val, p_req->p_timer->end_val);
                case TIMER_REQ_STOP:
                    if (p_req->p_timer == mp_active_timer)
                        bool found = nrf_sortlist_remove(&m_app_timer_sortlist, &(p_req->p_timer->list_item));
                        if (!found)
                             NRF_LOG_INFO("Timer not found on sortlist (stopping expired timer).");
                    NRF_LOG_INST_DEBUG(p_req->p_timer->p_log,"Stop request.");
                case TIMER_REQ_STOP_ALL:
                    sorted_list_stop_all();
                    m_global_active = true;
                    NRF_LOG_INFO("Stop all request.");
            CRITICAL_REGION_ENTER();
            UNUSED_RETURN_VALUE(nrf_atfifo_item_free(m_req_fifo, &fifo_ctx));
            if (m_max_user_op_queue_utilization < m_current_user_op_queue_utilization)
                m_max_user_op_queue_utilization = m_current_user_op_queue_utilization;
            --m_current_user_op_queue_utilization;
            CRITICAL_REGION_EXIT();
    static void rtc_irq(drv_rtc_t const * const  p_instance)
        if (drv_rtc_overflow_pending(p_instance))
            on_overflow_evt();
        if (drv_rtc_compare_pending(p_instance, 0))
            on_compare_evt(p_instance);
        if (drv_rtc_compare_pending(p_instance, 1))
            on_compare1_evt(p_instance);
        timer_req_process(p_instance);
        rtc_update(p_instance);
     * @brief Function for triggering processing user requests.
     * @note All user requests are processed in a single context - RTC interrupt.
    static inline void timer_request_proc_trigger(void)
        drv_rtc_irq_trigger(&m_rtc_inst);
     * @brief Function for putting user request into the request queue
    static ret_code_t timer_req_schedule(app_timer_req_type_t type, app_timer_t * p_timer)
        nrf_atfifo_item_put_t fifo_ctx;
        timer_req_t * p_req;
        p_req = nrf_atfifo_item_alloc(m_req_fifo, &fifo_ctx);
        if (p_req)
            ++m_current_user_op_queue_utilization;
        if (p_req)
            p_req->type    = type;
            p_req->p_timer = p_timer;
            if (nrf_atfifo_item_put(m_req_fifo, &fifo_ctx))
                timer_request_proc_trigger();
                NRF_LOG_WARNING("Scheduling interrupted another scheduling.");
            return NRF_SUCCESS;
            return NRF_ERROR_NO_MEM;
    ret_code_t app_timer_init(void)
        ret_code_t err_code;
        drv_rtc_config_t config = {
            .prescaler          = APP_TIMER_CONFIG_RTC_FREQUENCY,
            .interrupt_priority = APP_TIMER_CONFIG_IRQ_PRIORITY
        err_code = NRF_ATFIFO_INIT(m_req_fifo);
        if (err_code != NRFX_SUCCESS)
            return err_code;
        err_code = drv_rtc_init(&m_rtc_inst, &config, rtc_irq);
            return err_code;
        drv_rtc_overflow_enable(&m_rtc_inst, true);
        drv_rtc_compare_set(&m_rtc_inst, 1, DRV_RTC_MAX_CNT >> 1, true);
        if (APP_TIMER_KEEPS_RTC_ACTIVE)
            drv_rtc_start(&m_rtc_inst);
        return err_code;
    ret_code_t app_timer_create(app_timer_id_t const *      p_timer_id,
                                app_timer_mode_t            mode,
                                app_timer_timeout_handler_t timeout_handler)
        ASSERT(p_timer_id);
        ASSERT(timeout_handler);
        if (timeout_handler == NULL)
            return NRF_ERROR_INVALID_PARAM;
        app_timer_t * p_t = (app_timer_t *) *p_timer_id;
        p_t->handler = timeout_handler;
        p_t->repeat_period = (mode == APP_TIMER_MODE_REPEATED) ? 1 : 0;
        return NRF_SUCCESS;
    ret_code_t app_timer_start(app_timer_t * p_timer, uint32_t timeout_ticks, void * p_context)
        ASSERT(p_timer);
        app_timer_t * p_t = (app_timer_t *) p_timer;
        if (p_t->active)
            return NRF_SUCCESS;
        p_t->p_context = p_context;
        p_t->end_val = get_now() + timeout_ticks;
        if (p_t->repeat_period)
            p_t->repeat_period = timeout_ticks;
        return timer_req_schedule(TIMER_REQ_START, p_t);
    ret_code_t app_timer_stop(app_timer_t * p_timer)
        ASSERT(p_timer);
        p_t->active = false;
        return timer_req_schedule(TIMER_REQ_STOP, p_t);
    ret_code_t app_timer_stop_all(void)
        //block timer globally
        m_global_active = false;
        return timer_req_schedule(TIMER_REQ_STOP_ALL, NULL);
    uint8_t app_timer_op_queue_utilization_get(void)
        return m_max_user_op_queue_utilization;
    uint32_t app_timer_cnt_diff_compute(uint32_t   ticks_to,
                                        uint32_t   ticks_from)
        return ((ticks_to - ticks_from) & RTC_COUNTER_COUNTER_Msk);
    uint32_t app_timer_cnt_get(void)
        return drv_rtc_counter_get(&m_rtc_inst);
    void app_timer_pause(void)
        drv_rtc_stop(&m_rtc_inst);
    void app_timer_resume(void)
  • # SEGGER J-Link RTT Viewer V6.32i Terminal Log File
    # Compiled: 15:22:50 on Jul 24 2018
    # Logging started @ 24 Jun 2022 17:31:09
     0> <debug> nrf_ble_gatt: Requesting to update ATT MTU to 185 bytes on connection 0x0.
     0> <info> app: Connected.
     0> <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 527 bytes.
     0> <debug> nrf_ble_gatt: Updating ATT MTU to 185 bytes (desired: 185) on connection 0x0.
     0> <debug> nrf_ble_gatt: ATT MTU updated to 185 bytes on connection 0x0 (response).
     0> <debug> nrf_ble_gatt: Peer on connection 0x0 requested a data length of 251 bytes.
     0> <debug> nrf_ble_gatt: Updating data length to 27 on connection 0x0.
     0> <debug> nrf_ble_gatt: Data length updated to 27 on connection 0x0.
     0> <debug> nrf_ble_gatt: max_rx_octets: 27
     0> <debug> nrf_ble_gatt: max_tx_octets: 27
     0> <debug> nrf_ble_gatt: max_rx_time: 2120
     0> <debug> nrf_ble_gatt: max_tx_time: 2120
     0> <info> app: Received data from BLE NUS. Writing data on UART.
     0> <debug> app:  4D                     |M
     0> <info> app: M
     0> <debug> app: length=1
     0> <debug> app: data[0]=0x4D
     0> <debug> app: data[1]=0x0
     0> <debug> app: data[2]=0x0
     0> <debug> app: data[3]=0x0
     0> <debug> app: data[4]=0x0
     0> <debug> app: data[5]=0x0
     0> <debug> app: data[6]=0x0
     0> <info> app:
     0>
     0> <debug> app:  45                     |E
     0> <info> app: E
     0> <debug> app: data[1]=0x45
     0> <info> app:
     0>
     0> <debug> app:  41                     |A
     0> <info> app: A
     0> <debug> app: data[2]=0x41
     0> <info> app:
     0>
     0> <debug> app:  53                     |S
     0> <info> app: S
     0> <debug> app: data[3]=0x53
     0> <info> app:
     0>
     0> <debug> app:  55                     |U
     0> <info> app: U
     0> <debug> app: data[4]=0x55
     0> <info> app:
     0>
     0> <debug> app:  52                     |R
     0> <info> app: R
     0> <debug> app: data[5]=0x52
     0> <info> app:
     0>
     0> <info> app: E
     0> <debug> app: data[6]=0x45
     0> <info> app:
     0>
     0> <debug> app: endAddr=0x7FFFF
     0> <debug> app: startAddr=0x7F000
     0> <debug> app: type=0, addr=0x7F000
     0>
     0> <debug> app: state=0
     0>
     0> <debug> app: START E
     0>
     0> <warning> app: nrf_fstorage_erase() e
     0>
     0> <warning> app: nrf_fstorage_erase() x
     0>
     0> <debug> app: pm e
     0>
     0> <debug> app: pm x
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0>
     0> ponents\libraries\timer\app_timer2.c:181
