fstorage hang at sd_app_evt_wait()
Nordic DevZone
Nordic DevZone
I try to using nrf_fstorage_write() to write data to fstorage and then waiting writting finish. But it hang at sd_app_evt_wait().fstorage.h
#include "app_timer.h"
#include "error.h"
#include "fds_flash.h"
#include "fstorage.h"
#include "nrf_delay.h"
#include "nrf_fstorage.h"
#include "nrf_fstorage_sd.h"
#include "nrf_fstorage_nvmc.h"
#include "nrf_log.h"
#include "nrf_soc.h"
#include "spi_flash.h"
#define FSTORAGE_PAGE_NUM    3
#define FSTORAGE_WAIT_CNT    1000
static bool _gFstorageInitialized = false;
static bool _gFstorageEraseDone   = true;
static bool _gFstorageWriteDone   = true;
static bool _gFstoragePageDirty   = true;
static void _fstorageEvtHandler(nrf_fstorage_evt_t * p_evt);
NRF_FSTORAGE_DEF(nrf_fstorage_t _gFstorage) =
    /* Set a handler for fstorage events. */
    .evt_handler = _fstorageEvtHandler,
    /* These below are the boundaries of the flash space assigned to this instance of fstorage.
     * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
     * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
     * last page of flash available to write data. */
    .start_addr = 0x7D000,
    .end_addr   = 0x80000,
static void _fstorageEvtHandler(nrf_fstorage_evt_t * pEvt) {
    NRF_LOG_DEBUG("Evt e\n");
    switch (pEvt->id) {
        case NRF_FSTORAGE_EVT_WRITE_RESULT:
            NRF_LOG_DEBUG("Evt w\n");
            if (pEvt->result != NRF_SUCCESS) {
               NRF_LOG_WARNING("fstorage writing failed %d bytes at address 0x%x.",
                            pEvt->len, pEvt->addr);
            } else {
                NRF_LOG_DEBUG("NRF_FSTORAGE_EVT_WRITE_RESULT ok");
        } break;
        case NRF_FSTORAGE_EVT_ERASE_RESULT:
            NRF_LOG_DEBUG("Evt er\n");
                NRF_LOG_WARNING("fstorage erased failed %d page from address 0x%x.",
            } else {
                NRF_LOG_DEBUG("NRF_FSTORAGE_EVT_ERASE_RESULT ok");
                _gFstoragePageDirty = false;
        } break;
     NRF_LOG_DEBUG("Evt x\n");
static uint32_t _fstorageGetEndAddr(void) {
    const uint32_t bootloaderAddr = BOOTLOADER_ADDRESS;
    const uint32_t pageSz         = NRF_FICR->CODEPAGESIZE;
    const uint32_t codeSz         = NRF_FICR->CODESIZE;
    return (bootloaderAddr != 0xFFFFFFFF ?
            bootloaderAddr : (codeSz * pageSz));
static uint32_t _fstorageGetStartAddr(void) {
    const uint32_t eraseUnit = _gFstorage.p_flash_info->erase_unit;
    const uint32_t endAddr = _fstorageGetEndAddr();
    uint32_t startAddr;
    if (bootloaderAddr == 0xFFFFFFFF) {
        startAddr = endAddr - FDS_VIRTUAL_PAGES * eraseUnit;
    } else {
        startAddr = bootloaderAddr - FSTORAGE_PAGE_NUM * eraseUnit;
    NRF_LOG_DEBUG("endAddr=0x%x", endAddr);
    NRF_LOG_DEBUG("startAddr=0x%x", startAddr);
    return startAddr;
static bool _fstorageIsEraseNeeded(void) {
    return _gFstoragePageDirty;
static uint32_t _fstorageRoundUpU32(const uint32_t len) {
    if (len % sizeof(uint32_t)) {
        return (len + sizeof(uint32_t) - (len % sizeof(uint32_t)));
    return len;
static void power_manage(void)
#ifdef SOFTDEVICE_PRESENT
    (void) sd_app_evt_wait();
#else
    __WFE();
int _fstorageWait(const uint32_t timeOutCnt) {
#if 0
    NRF_LOG_DEBUG("timeOutCnt=%u\n", timeOutCnt);
    const uint32_t startCnt   = app_timer_cnt_get();
    NRF_LOG_DEBUG("startCnt=%u\n", startCnt);
    uint32_t endCnt;
    uint32_t diffCnt;
    do {
        endCnt           = app_timer_cnt_get();
        diffCnt          = app_timer_cnt_diff_compute(endCnt, startCnt);
        if (diffCnt >= timeOutCnt) {
            NRF_LOG_WARNING("_fstorage wait timeout\n");
            return ERROR_FSTORAGE_WAIT_TIMEOUT;
        if (_gFstorageEraseDone && _gFstorageWriteDone) {
    } while (true);
    NRF_LOG_DEBUG("endCnt=%u\n", endCnt);
#else
    while (nrf_fstorage_is_busy(&_gFstorage))
        power_manage();
		return 0;
int _fstorageRead(const uint32_t addr, const uint32_t len, uint8_t* data) {
    if (!_gFstorageInitialized) {
        return ERROR_FSTORAGE_UNINITIALIZED;
    const ret_code_t errCode = nrf_fstorage_read(&_gFstorage, addr, data, len);
    if (errCode != NRF_SUCCESS) {
        NRF_LOG_WARNING("nrf_fstorage_read() failed 0x%x\n", errCode);
        return ERROR_FSTORAGE_READ_FAIL;
    return 0;
int _fstorageWrite(const uint32_t addr, const uint32_t len, void const* pData) {
    if (!_gFstorageEraseDone) {
        return ERROR_FSTORAGE_ERASE_ON_GOING;
    if (!_gFstorageWriteDone) {
        return ERROR_FSTORAGE_WRITE_ON_GOING;
    _gFstorageWriteDone = false;
    const uint32_t wlen = _fstorageRoundUpU32(len);
    const ret_code_t retCode = nrf_fstorage_write(&_gFstorage, addr, pData, wlen, NULL);
    if (retCode != NRF_SUCCESS) {
        NRF_LOG_WARNING("nrf_fstorage_write() failed 0x%x", retCode);
        return ERROR_FSTORAGE_WRITE_FAIL;
    _fstorageWait(FSTORAGE_WAIT_CNT);
    return 0;
int fstorageInit(void) {
    const ret_code_t errCode = nrf_fstorage_init(&_gFstorage, &nrf_fstorage_sd, NULL);
        NRF_LOG_WARNING("nrf_fstorage_init() failed 0x%x", errCode);
        return ERROR_FSTORAGE_INITIALIZE_FAIL;
    _gFstorageInitialized = true;
    return 0;
int fstorageErase(const uint32_t addr, const uint32_t pagesCnt) {
    _gFstorageEraseDone = false;
    const ret_code_t errCode = nrf_fstorage_erase(&_gFstorage, addr, pagesCnt, NULL);
        NRF_LOG_WARNING("nrf_fstorage_erase() failed 0x%x", errCode);
        return ERROR_FSTORAGE_ERASE_FAIL;
    return 0;
int fstorageEraseFDS(void) {
    uint32_t addr;
        addr = endAddr - FDS_VIRTUAL_PAGES * eraseUnit;
    } else {
        addr = bootloaderAddr - FDS_VIRTUAL_PAGES * eraseUnit;
    const uint32_t pagesCnt  = FDS_VIRTUAL_PAGES;
        NRF_LOG_WARNING("nrf_fstorage_erase() failed 0x%x\n", errCode);
    return 0;
int fstorageReadRecord(const uint32_t addr, record_t* pRecord) {
    uint8_t data[RECORD_LEN] = {0};
    if (_fstorageRead(addr, RECORD_LEN, data) != 0) {
        return ERROR_FDS_READ_FAIL;
    data2Record(data, pRecord);
    return 0;
int fstorageUpdateRecord(const record_data_type_t type, const record_t* pRecord) {
    const uint32_t addr = _fstorageGetStartAddr();
    NRF_LOG_DEBUG("type=%d, add=0x%x\n", type, addr);
    switch (type) {
        case RECORD_DATA_TYPE_START:
            NRF_LOG_DEBUG("RECORD_DATA_TYPE_START E\n");
            if (_fstorageIsEraseNeeded()) {
                NRF_LOG_DEBUG("fstorageErase() E\n");
                fstorageErase(addr, 1);
            NRF_LOG_DEBUG("fstorageWriteRecord() E\n");
            record_t record;
            record.offsetStart = 0;
            record.offsetEnd   = 0;
            fstorageWriteRecord(addr, &record);
            NRF_LOG_DEBUG("RECORD_DATA_TYPE_START x\n");
        case RECORD_DATA_TYPE_END:
            NRF_LOG_DEBUG("RECORD_DATA_TYPE_END E\n");
            record_t record;
            NRF_LOG_DEBUG("fstorageReadRecord() E\n");
            if (fstorageReadRecord(addr, &record) != 0) {
            NRF_LOG_DEBUG("fstorageReadRecord() x\n");
            NRF_LOG_DEBUG("record.offsetStart=0x%x", record.offsetStart);
            NRF_LOG_DEBUG("record.offsetEnd=0x%x",   record.offsetEnd);
            record.offsetEnd = pRecord->offsetEnd;
            NRF_LOG_DEBUG("RECORD_DATA_TYPE_END X");
    return 0;
int fstorageWriteRecord(const uint32_t addr, record_t* pRecord) {
    record2Data(pRecord, data);
    if (_fstorageWrite(addr, RECORD_LEN, data) != 0) {
    return 0;
return 0;
