Unable to run 'sensorclient', 'sensorserver' and anyother example application
I use VScode to run my nrf applications. I user nrf52840DK and want to run basic examples 'sensorclient' and 'sensorserver' examples.
The below error shows when I try to build any other application. I tried building different application but facing same issue. Please help me to solve this issue. Unable to build any application
When I build the application I get these errors,
// below shown is the error//
conflicting types for 'strcpy'
conflicting types for 'strncpy'
conflicting types for 'strcat'
// end of error
Below is the code for string conversion from zephyr toolchain.
/* string.c - common string routines */
 * Copyright (c) 2014 Wind River Systems, Inc.
#include <string.h>
#include <stdint.h>
#include <sys/types.h>
 * @brief Copy a string
 * @return pointer to destination buffer <d>
char *strcpy(char *ZRESTRICT d, const char *ZRESTRICT s)
	char *dest = d;
	while (*s != '\0') {
		*d = *s;
		d++;
		s++;
	*d = '\0';
	return dest;
 * @brief Copy part of a string
char *strncpy(char *ZRESTRICT d, const char *ZRESTRICT s, size_t n)
	char *dest = d;
	while ((n > 0) && *s != '\0') {
		*d = *s;
		s++;
		d++;
		n--;
	while (n > 0) {
		*d = '\0';
		d++;
		n--;
	return dest;
 * @brief String scanning operation
 * @return pointer to 1st instance of found byte, or NULL if not found
char *strchr(const char *s, int c)
	char tmp = (char) c;
	while ((*s != tmp) && (*s != '\0')) {
		s++;
	return (*s == tmp) ? (char *) s : NULL;
 * @return pointer to last instance of found byte, or NULL if not found
char *strrchr(const char *s, int c)
	char *match = NULL;
	do {
		if (*s == (char)c) {
			match = (char *)s;
	} while (*s++);
	return match;
 * @brief Get string length
 * @return number of bytes in string <s>
size_t strlen(const char *s)
	size_t n = 0;
		s++;
		n++;
	return n;
 * @brief Get fixed-size string length
 * @return number of bytes in fixed-size string <s>
size_t strnlen(const char *s, size_t maxlen)
	size_t n = 0;
	while (*s != '\0' && n < maxlen) {
		s++;
		n++;
	return n;
 * @brief Compare two strings
 * @return negative # if <s1> < <s2>, 0 if <s1> == <s2>, else positive #
int strcmp(const char *s1, const char *s2)
	while ((*s1 == *s2) && (*s1 != '\0')) {
		s1++;
		s2++;
	return *s1 - *s2;
 * @brief Compare part of two strings
int strncmp(const char *s1, const char *s2, size_t n)
	while ((n > 0) && (*s1 == *s2) && (*s1 != '\0')) {
		s1++;
		s2++;
		n--;
	return (n == 0) ? 0 : (*s1 - *s2);
 * @brief Separate `str` by any char in `sep` and return NULL terminated
 * sections. Consecutive `sep` chars in `str` are treated as a single
 * separator.
 * @return pointer to NULL terminated string or NULL on errors.
char *strtok_r(char *str, const char *sep, char **state)
	char *start, *end;
	start = str ? str : *state;
	/* skip leading delimiters */
	while (*start && strchr(sep, *start)) {
		start++;
	if (*start == '\0') {
		*state = start;
		return NULL;
	/* look for token chars */
	end = start;
	while (*end && !strchr(sep, *end)) {
		end++;
	if (*end != '\0') {
		*end = '\0';
		*state = end + 1;
	} else {
		*state = end;
	return start;
char *strcat(char *ZRESTRICT dest, const char *ZRESTRICT src)
	strcpy(dest + strlen(dest), src);
	return dest;
char *strncat(char *ZRESTRICT dest, const char *ZRESTRICT src,
	      size_t n)
	char *orig_dest = dest;
	size_t len = strlen(dest);
	dest += len;
	while ((n-- > 0) && (*src != '\0')) {
		*dest++ = *src++;
	*dest = '\0';
	return orig_dest;
 * @brief Compare two memory areas
 * @return negative # if <m1> < <m2>, 0 if <m1> == <m2>, else positive #
int memcmp(const void *m1, const void *m2, size_t n)
	const char *c1 = m1;
	const char *c2 = m2;
	if (!n) {
		return 0;
	while ((--n > 0) && (*c1 == *c2)) {
		c1++;
		c2++;
	return *c1 - *c2;
 * @brief Copy bytes in memory with overlapping areas
void *memmove(void *d, const void *s, size_t n)
	char *dest = d;
	const char *src  = s;
	if ((size_t) (dest - src) < n) {
		 * The <src> buffer overlaps with the start of the <dest> buffer.
		 * Copy backwards to prevent the premature corruption of <src>.
		while (n > 0) {
			n--;
			dest[n] = src[n];
	} else {
		/* It is safe to perform a forward-copy */
		while (n > 0) {
			*dest = *src;
			dest++;
			src++;
			n--;
	return d;
 * @return pointer to start of destination buffer
void *memcpy(void *ZRESTRICT d, const void *ZRESTRICT s, size_t n)
	/* attempt word-sized copying only if buffers have identical alignment */
	unsigned char *d_byte = (unsigned char *)d;
	const unsigned char *s_byte = (const unsigned char *)s;
#if !defined(CONFIG_MINIMAL_LIBC_OPTIMIZE_STRING_FOR_SIZE)
	const uintptr_t mask = sizeof(mem_word_t) - 1;
	if ((((uintptr_t)d ^ (uintptr_t)s_byte) & mask) == 0) {
		/* do byte-sized copying until word-aligned or finished */
		while (((uintptr_t)d_byte) & mask) {
			if (n == 0) {
				return d;
			*(d_byte++) = *(s_byte++);
			n--;
		/* do word-sized copying as long as possible */
		mem_word_t *d_word = (mem_word_t *)d_byte;
		const mem_word_t *s_word = (const mem_word_t *)s_byte;
		while (n >= sizeof(mem_word_t)) {
			*(d_word++) = *(s_word++);
			n -= sizeof(mem_word_t);
		d_byte = (unsigned char *)d_word;
		s_byte = (unsigned char *)s_word;
	/* do byte-sized copying until finished */
	while (n > 0) {
		n--;
	return d;
 * @brief Set bytes in memory
 * @return pointer to start of buffer
void *memset(void *buf, int c, size_t n)
	/* do byte-sized initialization until word-aligned or finished */
	unsigned char *d_byte = (unsigned char *)buf;
	unsigned char c_byte = (unsigned char)c;
	while (((uintptr_t)d_byte) & (sizeof(mem_word_t) - 1)) {
		if (n == 0) {
			return buf;
		*(d_byte++) = c_byte;
		n--;
	/* do word-sized initialization as long as possible */
	mem_word_t c_word = (mem_word_t)c_byte;
	c_word |= c_word << 8;
	c_word |= c_word << 16;
#if Z_MEM_WORD_T_WIDTH > 32
	c_word |= c_word << 32;
		*(d_word++) = c_word;
	/* do byte-sized initialization until finished */
	while (n > 0) {
		n--;
	return buf;
 * @brief Scan byte in memory
 * @return pointer to start of found byte
void *memchr(const void *s, int c, size_t n)
	if (n != 0) {
		const unsigned char *p = s;
		do {
			if (*p++ == (unsigned char)c) {
				return ((void *)(p - 1));
		} while (--n != 0);
	return NULL;
    Can you provide me with which SDK version you are using? And which steps you have taken?
    Have you made any modifications to the examples you are testing?
    I assume you want to use bluetooth mesh?
    I'm a bit confused by this. Are you able to build the "sensorclient" and "sensorserver" examples without errors? What do you mean by "error when try to build any other application" and "Unable to build any application"? Can you elaborate?
  • I am using VScode to build my application and I use nRD Connect SDK v2.0.0. I just opened a sample and tried to run it and faced the error. Yes I was trying to compile examples related to BLE mesh.
    No I was not able to build the "sensorclient" and "sensorserver" example without error. The error I got was,
    // end of error
    I solved this error by rollingback to older version of nRF Connect SDK v1.9.1. After rollback to older version I was able to run the example. I doubt the v2.0.0 is a new version and is not a stable one.
    Shiva
    Sorry for the late response. We have had summer holiday period in Norway so staffing have been low.
    Do you still see this issue when running nRF Connect SDK v2.0.0?
