Low Power Mode using app uart example
Hello ,
I on the DK nRF52840, I wanted to manage the sleep mode and measure the current consumed by the microcontroller.
I started with example uart, I cut the PCB track courting solder bridge SB40 and I soldered a 10 Ω resistor .
the current measured with oscilloscope 0.216A (
I measure the voltage between the resistance and i divide by 10 ).
, and once the microcontroller goes to sleep, I measure 0.241A, which means that the microphone does not go into sleep mode . can you help me please .
why it doesn't go to sleep ?
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup uart_example_main main.c
 * @ingroup uart_example
 * @brief UART Example Application main file.
 * This file contains the source code for a sample application using UART.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_pwr_mgmt.h"
#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
uint8_t cr;
void uart_deinit(void)
   app_uart_close();
   NRF_UART0->TASKS_STOPTX = 1 ;
   NRF_UART0->TASKS_STOPRX = 1 ;
   NRF_UART0->ENABLE = UART_ENABLE_ENABLE_Disabled << UART_ENABLE_ENABLE_Pos; ;
   *(uint32_t volatile *)0x40002FFC = 0 ;
   *(uint32_t volatile *)0x40002FFC ;
   *(uint32_t volatile *)0x40002FFC = 1 ;
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    else if(p_event->evt_type == APP_UART_DATA_READY)
    else if( p_event->evt_type == APP_UART_TX_EMPTY)
        if (cr == 'q' || cr == 'Q')
            printf(" \r\nExit!\r\n");
            /* Disable the UART0 peripheral */
            uart_deinit();
            while (true)
                /* Going to sleep */
                nrf_pwr_mgmt_run();
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
          NRF_UART_BAUDRATE_115200
#else
          NRF_UARTE_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
    printf("\r\nUART example started.\r\n");
    while (true)
        while (app_uart_get(&cr) != NRF_SUCCESS);
        while (app_uart_put(cr) != NRF_SUCCESS);
  • Hi Lora,
    Yes, that is a measurement result which is in the right ballpark. The blinky example is as simple as possible, so the CPU never goes to sleep, so it will consume some mA (see the CPU running current consumption scenario).
    Einar
  • Hi  ,
    I want to manage the sleep mode specially from the system ON wake-up mode to wake up with an interrupt or event rx.
    actually i used libuarte library using DMA to wake up when i get data on the uart.
    could you look with why i don't go to sleep or do you have an example of libuarte + low power mode (system on mode )
    Thank you for your help .
    Best regards.
     * Copyright (c) 2018 - 2021, Nordic Semiconductor ASA
    /** @file
     * @defgroup libuarte_example_main main.c
     * @ingroup libuarte_example
     * @brief Libuarte Example Application main file.
     * This file contains the source code for a sample application using libuarte.
    #include <stdint.h>
    #include <stdio.h>
    #include "nrf_libuarte_async.h"
    #include "nrf_drv_clock.h"
    #include <bsp.h>
    #include "nrf_log_ctrl.h"
    #include "nrf_queue.h"
    NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
    static uint8_t GOING_TO_SLEEP[] = "Going to Sleep \r\n";
    static uint8_t length_sleep = sizeof(GOING_TO_SLEEP);
    static uint8_t WAKEUP[] = "Wakeup \r\n";
    static uint8_t length_wakeup = sizeof(WAKEUP);
    static volatile bool m_loopback_phase;
    typedef struct {
        uint8_t * p_data;
        uint32_t length;
    } buffer_t;
    uint8_t u8wakeupOK = false;
    NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
    void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
        nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
        ret_code_t ret;
        switch (p_evt->type)
            case NRF_LIBUARTE_ASYNC_EVT_ERROR:
                bsp_board_led_invert(0);
            case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
                ret = nrf_libuarte_async_tx(p_libuarte,p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
                if (ret == NRF_ERROR_BUSY)
                    buffer_t buf = {
                        .p_data = p_evt->data.rxtx.p_data,
                        .length = p_evt->data.rxtx.length,
                    ret = nrf_queue_push(&m_buf_queue, &buf);
                    APP_ERROR_CHECK(ret);
                bsp_board_led_invert(1);
                m_loopback_phase = true;
                u8wakeupOK = true;
            case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
                if (m_loopback_phase)
                    nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
                    if (!nrf_queue_is_empty(&m_buf_queue))
                        buffer_t buf;
                        ret = nrf_queue_pop(&m_buf_queue, &buf);
                        UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
                bsp_board_led_invert(2);
    void libuart_disabled()
        nrf_libuarte_async_uninit(&libuarte);
        *(volatile uint32_t *)0x40002FFC = 0;
        *(volatile uint32_t *)0x40002FFC;
        *(volatile uint32_t *)0x40002FFC = 1;
    void clock_disable(void)
        nrf_drv_clock_uninit();
        nrf_drv_clock_lfclk_release();
    void uart_config(void)
        ret_code_t err_code;
        nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = NRF_GPIO_PIN_MAP(1,2),
            .rx_pin     = NRF_GPIO_PIN_MAP(1,3),
            .baudrate   = NRF_UARTE_BAUDRATE_115200,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_LOW
        err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
        nrf_libuarte_async_enable(&libuarte);
    /**@brief Function for initializing low-frequency clock.
    void lfclk_config(void)
        ret_code_t err_code = nrf_drv_clock_init();
        lfclk_config();
        ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
        uart_config();
        err_code = nrf_libuarte_async_tx(&libuarte, GOING_TO_SLEEP, length_sleep);
        libuart_disabled();
        // Clear the internal event register.
        __SEV();
        __WFE();
        // Wait for an event.
        __WFE();
        uart_config();
        err_code = nrf_libuarte_async_tx(&libuarte, WAKEUP, length_wakeup);
        while(1);
    You have a simple while(1); at the end of your main loop, which causes the CPU to spend time doing nothing. To put the CPU in sleep mode you should instead make your main loop look something like this:
        while(1)
            __SEV();
            __WFE();
            __WFE();
    (Note that if you had been using a SoftDevice you should use sd_app_evt_wait() instead of WFE).
    Note that even though the CPU sleeps (after WFE) the HF clock and UARTE peripheral ect will consume a significant amount of current while the UART is enabled, so you probably want to disable libuarte as well when you no longer need it (using nrf_libuarte_async_uninit()).
  • Hi
    Thank you for your help and your feedback .
    low power consumption modes on nRF52
    System Mode ON :
    System on, no RAM retention, wake on any event.
    UART ON and LED ON:
    consumption measured with the multimeter: 0.97 mA
    I receive and send the data and the consumption measured is: 0.97 mA ( I think that the microcontroller does not go into sleep )
    UART DISABLED and LED OFF:
    -- I send data but I do not receive anything
    -- I measure 0mv on the multimeter
    when I wake up I have to reconfigure the clocks, uart, led .. but I have no idea, do you have an example please?
    Should I configure uart , led .. on receiving event NRF_LIBUARTE_ASYNC_EVT_RX_DATA ?
    Thank you .
    Best regards
    /** @file
    #include <stdint.h>
    #include <stdio.h>
    #include <bsp.h>
    typedef struct {
        uint8_t * p_data;
        uint32_t length;
    } buffer_t;
        ret_code_t ret;
                    buffer_t buf = {
                u8wakeupOK = true;
                        buffer_t buf;
            .timeout_us = 100,
        lfclk_config();
        uart_config();
        libuart_disabled();
        while(1)
          __SEV();
          __WFE();
          __WFE();
    Lora
