Low Power Mode using app uart example
Hello ,
I on the DK nRF52840, I wanted to manage the sleep mode and measure the current consumed by the microcontroller.
I started with example uart, I cut the PCB track courting solder bridge SB40 and I soldered a 10 Ω resistor .
the current measured with oscilloscope 0.216A (
I measure the voltage between the resistance and i divide by 10 ).
, and once the microcontroller goes to sleep, I measure 0.241A, which means that the microphone does not go into sleep mode . can you help me please .
why it doesn't go to sleep ?
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup uart_example_main main.c
 * @ingroup uart_example
 * @brief UART Example Application main file.
 * This file contains the source code for a sample application using UART.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf.h"
#include "bsp.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_pwr_mgmt.h"
#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
#define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
uint8_t cr;
void uart_deinit(void)
   app_uart_close();
   NRF_UART0->TASKS_STOPTX = 1 ;
   NRF_UART0->TASKS_STOPRX = 1 ;
   NRF_UART0->ENABLE = UART_ENABLE_ENABLE_Disabled << UART_ENABLE_ENABLE_Pos; ;
   *(uint32_t volatile *)0x40002FFC = 0 ;
   *(uint32_t volatile *)0x40002FFC ;
   *(uint32_t volatile *)0x40002FFC = 1 ;
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    else if(p_event->evt_type == APP_UART_DATA_READY)
    else if( p_event->evt_type == APP_UART_TX_EMPTY)
        if (cr == 'q' || cr == 'Q')
            printf(" \r\nExit!\r\n");
            /* Disable the UART0 peripheral */
            uart_deinit();
            while (true)
                /* Going to sleep */
                nrf_pwr_mgmt_run();
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
          NRF_UART_BAUDRATE_115200
#else
          NRF_UARTE_BAUDRATE_115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
    printf("\r\nUART example started.\r\n");
    while (true)
        while (app_uart_get(&cr) != NRF_SUCCESS);
        while (app_uart_put(cr) != NRF_SUCCESS);
    Lora said:
    when I wake up I have to reconfigure the clocks, uart, led .. but I have no idea, do you have an example please?
    Should I configure uart , led .. on receiving event NRF_LIBUARTE_ASYNC_EVT_RX_DATA ?
    You will not get events from libuarte (like NRF_LIBUARTE_ASYNC_EVT_RX_DATA) event when the UART / libuarte is disabled(), so as long as you need to communicate over UART, it needs to be enabled. If you always needs to be able to receive data on UART, it needs to always be enabled, and you will never be able to go to a very low power mode (even if the CPU sleeps, the HF clock needs to run for the UART peripheral, GPIOTE and PPI.
    If possible, what you can do it to call nrf_libuarte_async_uninit() when you don't need UART communication, and call nrf_libuarte_async_init()etc. when you need it again. From a UART perspective, there is not anything else you need to do.
    What to do with your LEDs etc. is application specific. Lighting a LED consumes a lot of current, so generally you do not want to do use that more than necessary. That also applies to all other resources. All this is highly application specific though so I cannot provide very specific advice, other than to make sure you only enable peripherals etc when you need them, and disable them when not needed.
