Enable pwm with button click
I would like to start a pwm signal on PIN 15 while BUTTON_1 or BUTTON_2 is pressed. If BUTTON_1 or BUTTON_2 is released, than there should be no signal(low) on PIN 15.
Setup is:
-SoftDevice 8.0
-SDK 8.1
-nRF51DK
There is a related post to this topic: devzone.nordicsemi.com/.../
The problem is, if I comment out app_pwm_enable(&PWM1); in the PWMinit function then I cannot connect to the board and the buttons are also not working.
If I enable the pwm in the PWMinit function, then the pwm will start immediately. But the pwm should only start when BUTTON_1 or BUTTON_2 are pressed.
static void PWMinit(void)
  app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(9000L, 15);
  pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
  app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
void pwm_stop(void)
   app_pwm_disable(&PWM1);
   nrf_drv_gpiote_out_task_disable(15);
   nrf_gpio_pin_clear(15);
void pwm_start(void)
    nrf_drv_gpiote_out_task_enable(15);
    while (app_pwm_channel_duty_set(&PWM1, 0, 50) == NRF_ERROR_BUSY);
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    if(button_action == APP_BUTTON_PUSH)
	    switch (pin_no)
            case 	Switch_up:
								pwm_start();
								nrf_gpio_pin_set(23);
					case 	Switch_down:
								pwm_start();
								nrf_gpio_pin_set(24);
    else if (button_action == APP_BUTTON_RELEASE)
        switch (pin_no)
            case 	Switch_up:
								pwm_stop();
								nrf_gpio_pin_clear(23);
					case 	Switch_down:
								pwm_stop();
								nrf_gpio_pin_clear(24);
Motorsteurung.zip
  • The problem is, if I comment out app_pwm_enable(&PWM1); in the PWMinit function then I cannot connect to the board and the buttons are also not working.
    The reason for this is that after you remove app_pwm_enable from PWMinit, you still have not commented out PWMDutySet in the next line. Since you are waiting for the ready_flag inside PWNDutySet, it will never return.
    I see that PWM_start is called not only from button_handler but also from adc_sampling_timeout_handler, auf_write_handler and ab_write_handler. I commented it out in all except button handler and then i can turn on pwm using button1 and turn off using button2
    image description
    image description
