Want MPU6050 Value through BLE
I get MPU6050 Accelerometer value zero when I using BLE. MAy be I am not abIing to read the register value.Here I attached my code
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_twi.h"
#include "mpu6050.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */\
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
/*static uint8_t val = 20;
uint16_t sttt = sizeof(val);
uint32_t ble_nus_data_send(ble_nus_t *p_nus, uint8_t val, uint16_t sttt, uint16_t m_conn_handle);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT://------------------------------------------------------------>>>PROBLEM
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;//THIS IS A STUCTURE
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
/*********************************************Accel_value********************************************************************************************************************/
/*Accelarometer value*/
 static int8_t AccValue[3];
static void Acc_Val_read ()
   int len = sizeof(AccValue)/sizeof(uint8_t);
   ble_nus_data_send(&m_nus,&AccValue, &len, m_conn_handle);//Send data to ble
   nrf_delay_ms(1000);
   NRF_LOG_FLUSH();
/**@brief Application main function.
    bool erase_bonds;
//static int8_t AccValue[3];
   // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    advertising_start();
    nrf_delay_ms(100);
    // Start execution.
    //printf("\r\nUART started.\r\n");
    //NRF_LOG_INFO("Debug logging for UART over RTT started.");
   twi_master_init(); // initialize the twi
   nrf_delay_ms(50); // give some delay
   mpu6050_init();
   nrf_delay_ms(100);
    while(mpu6050_init() == false) // wait until MPU6050 sensor is successfully initialized
      NRF_LOG_INFO("MPU_6050 initialization failed!!!"); // if it failed to initialize then print a message
      nrf_delay_ms(1000);
    NRF_LOG_INFO("MPU6050 Init Successfully!!!");
    NRF_LOG_INFO("Reading Values from ACC & GYRO"); // display a message to let the user know that the device is starting to read the values
    nrf_delay_ms(1000);
    // Enter main loop.
    for (;;)
         idle_state_handle();
         nrf_delay_ms(1000);
          Acc_Val_read ();
          NRF_LOG_INFO("ACC Values:  x = %d  y = %d  z = %d", AccValue[0], AccValue[1], AccValue[2]); // display the read values
  • Hi there,
    You should include your MPU code so that everyone can see if anything happened in that code. For the attached code, at the first glance I didn't see anything wrong as you're using ble_nus example to send MPU values through BLE.
    I would highly recommend checking this source which provides you codes for MPU and how it was combined with BLE code. Gluck!
    Martinsbl/nrf5-mpu-examples (github.com)
  • here I attached my main file
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    //Initializing TWI0 instance
    #define TWI_INSTANCE_ID     0
    // A flag to indicate the transfer state
    static volatile bool m_xfer_done = false;
    // Create a Handle for the twi communication
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    //Event Handler
    void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
        //Check the event to see what type of event occurred
        switch (p_event->type)
            //If data transmission or receiving is finished
    	case NRF_DRV_TWI_EVT_DONE:
            m_xfer_done = true;//Set the flag
            // do nothing
    //Initialize the TWI as Master device
    void twi_master_init(void)
        // Configure the settings for twi communication
        const nrf_drv_twi_config_t twi_config = {
           .scl                = TWI_SCL_M,  //SCL Pin
           .sda                = TWI_SDA_M,  //SDA Pin
           .frequency          = NRF_DRV_TWI_FREQ_400K, //Communication Speed
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH, //Interrupt Priority(Note: if using Bluetooth then select priority carefully)
           .clear_bus_init     = false //automatically clear bus
        //A function to initialize the twi communication
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
        //Enable the TWI Communication
        nrf_drv_twi_enable(&m_twi);
       A function to write a Single Byte to MPU6050's internal Register
    bool mpu6050_register_write(uint8_t register_address, uint8_t value)
        uint8_t tx_buf[MPU6050_ADDRESS_LEN+1];
        //Write the register address and data into transmit buffer
        tx_buf[0] = register_address;
        tx_buf[1] = value;
        //Set the flag to false to show the transmission is not yet completed
        //Transmit the data over TWI Bus
        err_code = nrf_drv_twi_tx(&m_twi, MPU6050_ADDRESS, tx_buf, MPU6050_ADDRESS_LEN+1, false);
        //Wait until the transmission of the data is finished
        while (m_xfer_done == false)
        // if there is no error then return true else return false
        if (NRF_SUCCESS != err_code)
            return false;
        return true;
      A Function to read data from the MPU6050
    bool mpu6050_register_read(uint8_t register_address, uint8_t * destination, uint8_t number_of_bytes)
        //Set the flag to false to show the receiving is not yet completed
        // Send the Register address where we want to write the data
        err_code = nrf_drv_twi_tx(&m_twi, MPU6050_ADDRESS, &register_address, 1, true);
        //Wait for the transmission to get completed
        while (m_xfer_done == false){}
        // If transmission was not successful, exit the function with false as return value
            return false;
        //set the flag again so that we can read data from the MPU6050's internal register
        // Receive the data from the MPU6050
        err_code = nrf_drv_twi_rx(&m_twi, MPU6050_ADDRESS, destination, number_of_bytes);
        //wait until the transmission is completed
        // if data was successfully read, return true else return false
            return false;
        return true;
      A Function to verify the product id
      (its a basic test to check if we are communicating with the right slave, every type of I2C Device has
      a special WHO_AM_I register which holds a specific value, we can read it from the MPU6050 or any device
      to confirm we are communicating with the right device)
    bool mpu6050_verify_product_id(void)
        uint8_t who_am_i; // create a variable to hold the who am i value
        // Note: All the register addresses including WHO_AM_I are declared in
        // MPU6050.h file, you can check these addresses and values from the
        // datasheet of your slave device.
        if (mpu6050_register_read(ADDRESS_WHO_AM_I, &who_am_i, 1))
            if (who_am_i != MPU6050_WHO_AM_I)
                return false;
                return true;
            return false;
      Function to initialize the mpu6050
    bool mpu6050_init(void)
      bool transfer_succeeded = true;
      //Check the id to confirm that we are communicating with the right device
      transfer_succeeded &= mpu6050_verify_product_id();
      if(mpu6050_verify_product_id() == false)
    	return false;
      // Set the registers with the required values, see the datasheet to get a good idea of these values
      (void)mpu6050_register_write(MPU_PWR_MGMT1_REG , 0x00);
      (void)mpu6050_register_write(MPU_SAMPLE_RATE_REG , 0x07); //setting sample rate
      (void)mpu6050_register_write(MPU_CFG_REG , 0x06);
      (void)mpu6050_register_write(MPU_INT_EN_REG, 0x00);
      (void)mpu6050_register_write(MPU_GYRO_CFG_REG , 0x18);
      (void)mpu6050_register_write(MPU_ACCEL_CFG_REG,0x00);
      return transfer_succeeded;
      Read the Gyro values from the MPU6050's internal Registers
    bool MPU6050_ReadGyro(int16_t *pGYRO_X , int16_t *pGYRO_Y , int16_t *pGYRO_Z )
      uint8_t buf[6];
      bool ret = false;
      if(mpu6050_register_read(MPU6050_GYRO_OUT,  buf, 6) == true)
        *pGYRO_X = (buf[0] << 8) | buf[1];
        if(*pGYRO_X & 0x8000) *pGYRO_X-=65536;
        *pGYRO_Y= (buf[2] << 8) | buf[3];
        if(*pGYRO_Y & 0x8000) *pGYRO_Y-=65536;
        *pGYRO_Z = (buf[4] << 8) | buf[5];
        if(*pGYRO_Z & 0x8000) *pGYRO_Z-=65536;
        ret = true;
      return ret;
      A Function to read accelerometer's values from the internal registers of MPU6050
    bool MPU6050_ReadAcc( int16_t *pACC_X , int16_t *pACC_Y , int16_t *pACC_Z )
      uint8_t buf[6];
      bool ret = false;
      if(mpu6050_register_read(MPU6050_ACC_OUT, buf, 6) == true)
        mpu6050_register_read(MPU6050_ACC_OUT, buf, 6);
        *pACC_X = (buf[0] << 8) | buf[1];
        if(*pACC_X & 0x8000) *pACC_X-=65536;
        *pACC_Y= (buf[2] << 8) | buf[3];
        if(*pACC_Y & 0x8000) *pACC_Y-=65536;
        *pACC_Z = (buf[4] << 8) | buf[5];
        if(*pACC_Z & 0x8000) *pACC_Z-=65536;
        ret = true;
      return ret;
    Looking at your code in the original post, the array AccValue that you print the members of are never set. It is 0 as that is the default value for static variables, and as you never change it, that is what you write. You need to actually read the sensor data and copy that to AccValue before logging it. (in fact, the only mpu6050_* function you call in the code from the original post is mpu6050_init(), and you never try to read as far as I can see.)
  • Can you please tell what to modify in my code...or what function should I call...is it  MPU6050_ReadAcc() function?
  • That is the only function you have that reads accelerometers values, so yes - that must be called.
