examples of simple peripheral/central ble transmission nrf52 series
I am very familiar with PICs and some atmega stuff, just graduated university ee and the project I am working on requires transmitting very small amounts of data continuously via ble protocol. Actually transmitting real time gyroscope data. Nrf modules seemed the easiest/cheapest for our purpose and decided we would most likely end up going with someones 52 series module. I have been playing around awhile with the nordic 52 development board however I am finding the learning curve fairly steep with zephyr. I can do basic stuff, gpio, pwm, interrupts etc but am struggling with bluetooth. Would it be possible to get an example of a central device and peripheral device with a custom service and characteristic 128, that simply sends or receives 24 or more bits of data at a time.   I'm really trying to learn this and just feel myself lost, thanks.  I have been through many of the peripheral and central zephyr examples.
  • after much experimenting I seem to be getting this error from the second example.
  • ////this is .h
    #include <zephyr.h>
    #include <logging/log.h>
    #include <bluetooth/bluetooth.h>
    #include <bluetooth/uuid.h>
    #include <bluetooth/gatt.h>
    #include <bluetooth/hci.h>
    #define MY_SERVICE_UUID 0xd4, 0x86, 0x48, 0x24, 0x54, 0xB3, 0x43, 0xA1, \
    			            0xBC, 0x20, 0x97, 0x8F, 0xC3, 0x76, 0xC2, 0x75
    #define RX_CHARACTERISTIC_UUID  0xA6, 0xE8, 0xC4, 0x60, 0x7E, 0xAA, 0x41, 0x6B, \
    			                    0x95, 0xD4, 0x9D, 0xCC, 0x08, 0x4F, 0xCF, 0x6A
    #define TX_CHARACTERISTIC_UUID  0xED, 0xAA, 0x20, 0x11, 0x92, 0xE7, 0x43, 0x5A, \
    			                    0xAA, 0xE9, 0x94, 0x43, 0x35, 0x6A, 0xD4, 0xD3
    /** @brief Callback type for when new data is received. */
    typedef void (*data_rx_cb_t)(uint8_t *data, uint8_t length);
    /** @brief Callback struct used by the my_service Service. */
    struct my_service_cb
    	/** Data received callback. */
    	data_rx_cb_t    data_rx_cb;
    int my_service_init(void);
    void my_service_send(struct bt_conn *conn, const uint8_t *data, uint16_t len);
  • ///main file
     * Copyright (c) 2012-2014 Wind River Systems, Inc.
    #include <zephyr.h>
    #include <dk_buttons_and_leds.h>
    #include "remote.h"
    #define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
    static K_SEM_DEFINE(ble_init_ok, 0, 1);
    static const struct bt_data ad[] =
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    static const struct bt_data sd[] =
    	BT_DATA_BYTES(BT_DATA_UUID128_ALL, MY_SERVICE_UUID),
    struct bt_conn *my_connection;
    static void connected(struct bt_conn *conn, uint8_t err)
    	struct bt_conn_info info;
    	my_connection = conn;
    	if (err)
    		printk("Connection failed (err %u)\n", err);
    		return;
    	else if(bt_conn_get_info(conn, &info))
    		printk("Could not parse connection info\n");
    		printk("Connection established!		\n\
    		Connected to: %s					\n\
    		Role: %u							\n\
    		Connection interval: %u				\n\
    		Slave latency: %u					\n\
    		Connection supervisory timeout: %u	\n"
    		, addr, info.role, info.le.interval, info.le.latency, info.le.timeout);
    	printk("Disconnected (reason %u)\n", reason);
    static bool le_param_req(struct bt_conn *conn, struct bt_le_conn_param *param)
    	//If acceptable params, return true, otherwise return false.
    	return true;
    static void le_param_updated(struct bt_conn *conn, uint16_t interval, uint16_t latency, uint16_t timeout)
    		printk("Connection parameters updated!	\n\
    		New Connection Interval: %u				\n\
    		New Slave Latency: %u					\n\
    		New Connection Supervisory Timeout: %u	\n"
    		, addr, info.le.interval, info.le.latency, info.le.timeout);
    static struct bt_conn_cb conn_callbacks =
    	.connected				= connected,
    	.disconnected   		= disconnected,
    	.le_param_req			= le_param_req,
    	.le_param_updated		= le_param_updated
    static void bt_ready(int err)
    	if (err)
    		printk("BLE init failed with error code %d\n", err);
    		return;
    	//Configure connection callbacks
    	bt_conn_cb_register(&conn_callbacks);
    	//Initalize services
    	err = my_service_init();
    	if (err)
    		printk("Failed to init LBS (err:%d)\n", err);
    		return;
    	//Start advertising
    	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
    			      sd, ARRAY_SIZE(sd));
    	if (err)
    		printk("Advertising failed to start (err %d)\n", err);
    		return;
    	printk("Advertising successfully started\n");
    	k_sem_give(&ble_init_ok);
    static void error(void)
    	while (true) {
    		printk("Error!\n");
    		/* Spin for ever */
    		k_sleep(K_MSEC(1000)); //1000ms
    void main(void)
    	int err = 0;
    	uint32_t number = 0;
    	printk("Starting Nordic BLE peripheral tutorial\n");
    	err = bt_enable(bt_ready);
    	if (err)
    		printk("BLE initialization failed\n");
    		error(); //Catch error
    	/* 	Bluetooth stack should be ready in less than 100 msec. 								\
    		We use this semaphore to wait for bt_enable to call bt_ready before we proceed 		\
    		to the main loop. By using the semaphore to block execution we allow the RTOS to 	\
    		execute other tasks while we wait. */
    	err = k_sem_take(&ble_init_ok, K_MSEC(500));
    	if (!err)
    		printk("Bluetooth initialized\n");
    	} else
    		printk("BLE initialization did not complete in time\n");
    	for (;;)
    		// Main loop
    		my_service_send(my_connection, (uint8_t *)&number, sizeof(number));
    		number++;
    		k_sleep(K_MSEC(1000)); // 1000ms
  • #include "remote.h"
    #define BT_UUID_MY_SERVICE      BT_UUID_DECLARE_128(MY_SERVICE_UUID)
    #define BT_UUID_MY_SERVICE_RX   BT_UUID_DECLARE_128(RX_CHARACTERISTIC_UUID)
    #define BT_UUID_MY_SERVICE_TX   BT_UUID_DECLARE_128(TX_CHARACTERISTIC_UUID)
    #define MAX_TRANSMIT_SIZE 240//TODO figure this out
    uint8_t data_rx[MAX_TRANSMIT_SIZE];
    uint8_t data_tx[MAX_TRANSMIT_SIZE];
        int err = 0;
        memset(&data_rx, 0, MAX_TRANSMIT_SIZE);
        memset(&data_tx, 0, MAX_TRANSMIT_SIZE);
        return err;
    /* This function is called whenever the RX Characteristic has been written to by a Client */
    static ssize_t on_receive(struct bt_conn *conn,
    			  const struct bt_gatt_attr *attr,
    			  const void *buf,
    			  uint16_t len,
    			  uint16_t offset,
    			  uint8_t flags)
        const uint8_t * buffer = buf;
    	printk("Received data, handle %d, conn %p, data: 0x", attr->handle, conn);
        for(uint8_t i = 0; i < len; i++){
            printk("%02X", buffer[i]);
        printk("\n");
    	return len;
    /* This function is called whenever a Notification has been sent by the TX Characteristic */
    static void on_sent(struct bt_conn *conn, void *user_data)
    	ARG_UNUSED(user_data);
        const bt_addr_le_t * addr = bt_conn_get_dst(conn);
    	printk("Data sent to Address 0x %02X %02X %02X %02X %02X %02X \n", addr->a.val[0]
        , addr->a.val[1]
        , addr->a.val[2]
        , addr->a.val[3]
        , addr->a.val[4]
        , addr->a.val[5]);
    /* This function is called whenever the CCCD register has been changed by the client*/
    void on_cccd_changed(const struct bt_gatt_attr *attr, uint16_t value)
        ARG_UNUSED(attr);
        switch(value)
            case BT_GATT_CCC_NOTIFY:
                // Start sending stuff!
            case BT_GATT_CCC_INDICATE:
                // Start sending stuff via indications
            case 0:
                // Stop sending stuff
                printk("Error, CCCD has been set to an invalid value");
    /* LED Button Service Declaration and Registration */
    BT_GATT_SERVICE_DEFINE(my_service,
    BT_GATT_PRIMARY_SERVICE(BT_UUID_MY_SERVICE),
    BT_GATT_CHARACTERISTIC(BT_UUID_MY_SERVICE_RX,
    			       BT_GATT_CHRC_WRITE | BT_GATT_CHRC_WRITE_WITHOUT_RESP,
    			       BT_GATT_PERM_READ | BT_GATT_PERM_WRITE,
                       NULL, on_receive, NULL),
    BT_GATT_CHARACTERISTIC(BT_UUID_MY_SERVICE_TX,
    			       BT_GATT_CHRC_NOTIFY,
    			       BT_GATT_PERM_READ,
                       NULL, NULL, NULL),
    BT_GATT_CCC(on_cccd_changed,
            BT_GATT_PERM_READ | BT_GATT_PERM_WRITE),
    /* This function sends a notification to a Client with the provided data,
    given that the Client Characteristic Control Descripter has been set to Notify (0x1).
    It also calls the on_sent() callback if successful*/
        The attribute for the TX characteristic is used with bt_gatt_is_subscribed
        to check whether notification has been enabled by the peer or not.
        Attribute table: 0 = Service, 1 = Primary service, 2 = RX, 3 = TX, 4 = CCC.
        const struct bt_gatt_attr *attr = &my_service.attrs[3];
        struct bt_gatt_notify_params params =
            .uuid   = BT_UUID_MY_SERVICE_TX,
            .attr   = attr,
            .data   = data,
            .len    = len,
            .func   = on_sent
        // Check whether notifications are enabled or not
        if(bt_gatt_is_subscribed(conn, attr, BT_GATT_CCC_NOTIFY))
            // Send the notification
    	    if(bt_gatt_notify_cb(conn, &params))
                printk("Error, unable to send notification\n");
            printk("Warning, notification not enabled on the selected attribute\n");
  • attached main and header below here is my prj.conf
