nrf9160 azure_iot_hub sample with Azure IoT Central
Hi All,
I try to connect nrf9160 to our azure space ( Azure IoT Central) using sample : sdk-nrf/samples/nrf9160/azure_iot_hub at main · nrfconnect/sdk-nrf · GitHub
After this update and generating certificats, the code still give error in connection:
[00:00:13.334,350] [1B][0m<dbg> azure_iot_hub: connection_state_set: New connection state: STATE_INIT[1B][0m
[00:00:13.341,979] [1B][0m<dbg> azure_iot_hub: mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = -111[1B][0m
[00:00:13.341,979] [1B][0m<dbg> azure_iot_hub: connection_state_set: New connection state: STATE_INIT[1B][0m
[00:00:13.344,726] [1B][1;31m<err> azure_iot_hub: Cloud MQTT input error: -111[1B][0m
It's possible to use this sample to test connexion to  Azure IoT Central or is valid only for Azure IoT Hub?
If no, can you suggest for use a working sample with Azure IoT Central or any updates to do in sample for IoT Central?
Thank you!
Parents Reply
  • Christoffer Brask said:
    I would also like to know if there are any news on samples with IoT Central
    We do still not have any libraries for Azure IoT Central.
    or how much should be changed to make the IoT Hub sample work with Central
    This is not a feature we have implemented or tested. However, if I understend correctly IoT Central requires the same communication protocols as IoT Hub, so it should be a matter of updating the interface code.
    We do have support for DPS, which IoT Central needs.
    I cant say how much work it is, as I have not tried it myself, but I think it should be possible.
    Sigurd Hellesvik
