I am using the nrf52dk_nrf52832 board and adding a peripheral SPI Flash. I had previously gotten the SPI Flash to work but now it does not.
I've hooked it up to the oscilloscope and determined that my CLK is likely the problem.
I can see the CS and and the MOSI line perfectly but the CLK alternates between 0 V and 1.02V which I believe is too low for the device to recognize.
I am using pin 28 as the CLK which, again, did at one point work; I have switch which pin I am using to no avail.
I have attached my overlay and my initialization functions - I am using the Zephyr drivers and attached an example command.
All help is appreciated,
Tom
void releasePowerDown(void){ // Set up the buffers uint8_t tx_buffer[5]; tx_buffer[0] = 0xab; for(int i = 1; i < 5; i ++){ tx_buffer[i] = 0x00; } uint8_t rx_buffer[5]; const struct spi_buf tx_buf = { .buf = tx_buffer, .len = sizeof(tx_buffer) }; const struct spi_buf_set tx = { .buffers = &tx_buf, .count = 1 }; struct spi_buf rx_buf = { .buf = rx_buffer, .len = sizeof(rx_buffer), }; const struct spi_buf_set rx = { .buffers = &rx_buf, .count = 1 }; int err; err = spi_transceive(spi_dev, &spi_cfg, &tx, &rx); if(err){ printk("SPI transceive fail: %i. Release power down.\n", err); } printk("Release Power Down RX recv: "); for(int i = 0; i < 5; i ++){ printk("%X ", rx_buffer[i]); } printk("\r\n"); }
&spi1 { compatible = "nordic,nrf-spi"; status = "okay"; sck-pin = <28>; mosi-pin = <30>; miso-pin = <31>; cs-gpios = <&gpio0 29 GPIO_ACTIVE_LOW>; w25: w25q32@0 { compatible = "winbond,w25q32", "jedec,spi-nor"; label = "W25Q32"; reg = <0>; jedec-id = [ef 40 14]; size = <0x4000000>; // Can be up to 45000000 spi-max-frequency = <5000000>; wp-gpios = < &gpio0 4 GPIO_ACTIVE_LOW >; hold-gpios = < &gpio0 3 GPIO_ACTIVE_LOW >; // reset-gpios = < &gpio0 5 GPIO_ACTIVE_LOW >; }; }; &radio{ status = "disabled"; }; &i2c0{ status = "disabled"; }; &adc{ status = "disabled"; }; &temp{ status = "disabled"; }; &rng{ status = "disabled"; }; &wdt{ status = "disabled"; }; &spi2{ status = "disabled"; }; &pwm0{ status = "disabled"; };
