How do you enable any of the i2c peripherals on the nRF9160 dk boards?
I tried changing the device overlay to the code below:
&i2c0 {
&i2c0 {
Hello Jerome,
You can check all default configured peripherals in ../<your_application_root/<your_build_folder>/zephyr/zephyr.dts. On the nRF9160 DK, &i2c2 is enabled by default.
i2c2: arduino_i2c: i2c@a000 {
#address-cells = < 0x1 >;
#size-cells = < 0x0 >;
reg = < 0xa000 0x1000 >;
clock-frequency = < 0x186a0 >;
interrupts = < 0xa 0x1 >;
status = "okay";
label = "I2C_2";
pinctrl-0 = < &i2c2_default >;
pinctrl-1 = < &i2c2_sleep >;
Due to memory instantiation, you have to disable &uart0 to be able to enable &i2c0 and &spi3 to be able to enable &i2c3 respectively.
Additionally,
CONFIG_I2C=y
needs to be set in your prj.conf.
Unless you are aware of the fact that you have to switch over to RTT if logging is needed, disabling &uart0 is not recommended from my side.
Markus
