nfr_crypto_aead AES GCM nonce size question
I'm trying to implement radio transfer protocol with symmetric encryption and auth - AES GCM. The main requirements are low overhead in packet added to encrypted payload and relatively high security.
I'm not security expert and trying to compare available in NRF SDK mbedtls backend implementation with data described in RFCs.
What i found in nfr_crypto_aead.h
/**@brief Integrated encryption / decryption function.
 * @param[in]  p_context        Context object. Must be initialized before the call.
 * @param[in]  operation        Parameter indicating whether an encrypt (NRF_CRYPTO_ENCRYPT) or
 *                              a decrypt (NRF_CRYPTO_DECRYPT) operation shall be performed.
 * @param[in]  p_nonce          Pointer to nonce. For nonce_size == 0 p_nonce can be NULL.
 * @param[in]  nonce_size       Nonce byte size. Valid values for supported modes:
 *                                - CCM         [7 ... 13]
 *                                - CCM*        [13]
 *                                - EAX         nonce size can be any length
 *                                - GCM         nonce size can be any length
 *                                - CHACHA-POLY [12]
 * @param[in]  p_adata          Pointer to additional authenticated data (adata).
 * @param[in]  adata_size       Length of additional authenticated data in bytes.
 *                              For CHACHA-POLY mode must be > 0.
 * @param[in]  p_data_in        Pointer to the input data buffer for encryption or decryption.
 * @param[in]  data_in_size     Length of the data in p_data_in buffer in bytes. Size of the
 *                              p_data_out buffer must not be smaller than this value.
 *                              When selecting CC310 backend data_in_size value shall be limited
 *                              to 65535 bytes. Data out buffer must be at least the same length.
 * @param[out] p_data_out       Pointer to the output buffer where encrypted or decrypted data
 *                              will be stored. Must be at least 'data_in_size' bytes wide.
 *                                - GCM: On encryption, the p_data_out buffer can be the same as
 *                                       the p_data_in buffer.
 *                                       On decryption, the p_data_out buffer cannot be the same
 *                                       as p_data_in buffer. If buffers overlap, the p_data_out
 *                                       buffer must trail at least 8 bytes behind the p_data_in
 *                                       buffer.
 * @param[out] p_mac            Pointer to the MAC result buffer. Fo mac_size == 0 p_mac can be NULL.
 * @param[in]  mac_size         MAC byte size. Valid values for supported modes:
 *                                -CCM          [4, 6, 8, 10, 12, 14, 16]
 *                                -CCM*         [0, 4, 8, 16]
 *                                -EAX          [1 ... 16]
 *                                -GCM          [4 ... 16]
 *                                -CHACHA-POLY  [16]
 * @retval  NRF_SUCCESS  Message was successfully encrypted.
ret_code_t nrf_crypto_aead_crypt( ...
So I tried to tune AES example with next params:
mac_size: 4B
nonce_size: 0B
The operation fails with next output
Error = 0x8517
Invalid combination of input parameters
The reason is 0 nonce.
I suggest nonce can be length >0
What the security effect making nonce less than 12B (as RFC recommends)?
