I need to build a project in a Docker container. It built fine under Windows 10 with a connect SDK v1.9.1.
Now I am using a Docker image built with the Dockerfile for nrfconnect-toolchain: https://github.com/NordicPlayground/nrfconnect-chip-docker/tree/master/nrfconnect-toolchain
1. I am not sure which version of the connect SDK is installed with this image but I assume it would be the latest one (v2.0.0). Would that be incompatible with my project which was built with a SDK v1.9.1?
2. My main issue is an error during the build with west that I don't understand:
root@a81dfea4756f:/workspace/nRF52840_zephyr-bsp# west build
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: /workspace/nRF52840_zephyr-bsp
-- Cache files will be written to: /workspace/nRF52840_zephyr-bsp/zephyr/.cache
-- Zephyr version: 3.1.99 (/workspace/nRF52840_zephyr-bsp/zephyr)
-- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
-- Board: nrf52840dk_nrf52840
-- Found dtc: /usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/opt/gcc-arm-none-eabi-9-2019-q4-major)
-- Found BOARD.dts: /workspace/nRF52840_zephyr-bsp/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
-- Generated zephyr.dts: /workspace/nRF52840_zephyr-bsp/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /workspace/nRF52840_zephyr-bsp/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /workspace/nRF52840_zephyr-bsp/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /workspace/nRF52840_zephyr-bsp/build/zephyr/dts.cmake
/workspace/nRF52840_zephyr-bsp/prj.conf:28: warning: attempt to assign the value 'y' to the undefined symbol BT_LL_SOFTDEVICE
/workspace/nRF52840_zephyr-bsp/prj.conf:31: warning: attempt to assign the value 'y' to the undefined symbol BT_GATT_DM
/workspace/nRF52840_zephyr-bsp/prj.conf:33: warning: attempt to assign the value 'y' to the undefined symbol BT_RECV_IS_RX_THREAD
Parsing /workspace/nRF52840_zephyr-bsp/Kconfig
Loaded configuration '/workspace/nRF52840_zephyr-bsp/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
Merged configuration '/workspace/nRF52840_zephyr-bsp/prj.conf'
error: Aborting due to Kconfig warnings
CMake Error at zephyr/cmake/modules/kconfig.cmake:290 (message):
command failed with return code: 1
zephyr/cmake/modules/zephyr_default.cmake:121 (include)
zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:96 (include_boilerplate)
CMakeLists.txt:11 (find_package)
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/workspace/nRF52840_zephyr-bsp/build -S/workspace/nRF52840_zephyr-bsp -GNinja
I saw this ticket which seems to talk about what appears to be a related issue: Cannot Replicate Build in Docker Environment
However the workaround addressed in this ticket did not work in my case.
Benjamin
