Migrating to NCS v2.0.0 "error: NRFX_TWI (defined at C:\NCS\v2.0.0\zephyr\modules\hal_nordic\nrfx\Kconfig:277"
I've been working on porting a project to NCS using VS Code as my IDE. Now that NSC v2.0.0 is out, I wanted to move to that. I found the migration guide: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/migration/migration_guide_1.x_to_2.x.html. I re-targeted the toolchain, and I found the scripts to change the include paths and pin control setup. That made that change over pretty painless; however, it did not fix an issue I was having with a TWI definition: "error: NRFX_TWI (defined at C:\NCS\v2.0.0\zephyr\modules\hal_nordic\nrfx\Kconfig:277"
It went on the state that "\build\modules\hal_nordic\nrfx\Kconfig:277 is assigned in a configuration file, but is not directly user-
configurable (has no prompt). It gets its value indirectly from other symbols. See
docs.zephyrproject.org/.../kconfig.html and/or look up NRFX_TWI in the
menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
and Kconfig - Tips and Best Practices sections of the manual might be helpful too."
I read some about those Kconfig files and compared the ones in v1.9.1 versus my new one in v2.0.0.
In v2.0.0 it looks like
config NRFX_TWI
	bool
In v1.9.1 it looks like
config NRFX_TWI
	bool "Enable TWI driver"
	depends on HAS_HW_NRF_TWI0 || HAS_HW_NRF_TWI1
The term "bool" without any value after it looks odd to me, but I'm still just learning how to understand these Kconfig files.I noticed that NRFX_TWIM is that same way along with several other entries. I tried copying the ones from v1.9.1 to v2.0.0 and it now objected to the NRFX_TWIM entry. So then I deleted it and it claimed I was over the memory boundary. I don't think that's a good fix. I couldn't find anyone else with the same problem.
Also, the link provided in the error "http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_NRFX_TWI" does not lead to valid search term. But when you take a "$" character off the end it show the values in the Kconfig file except for the ones with the empty "boot" terms.
Back to the issue, at this point I'm not sure where to look next. I doubt the Kconfig has an issue, but I'm still learning the basics of how that works.
    If you were using CONFIG_NRFX_TWI, try using CONFIG_NRFX_TWI1 for example instead, replacing the number with the instance of i2c you are using. This is specifically if you are not using the Zephyr API. When using the Zephyr API just use CONFIG_I2C.
  • It looks like this project had both CONFIG_I2C and CONFIG_NRFX_TWI equaling 'y' and I suppose that led to a conflict that was not present in sdk versions older than 2.0.0. I commented out all the NRFX stuff:
    # I2C
    CONFIG_I2C=y
    CONFIG_I2C_NRFX=y
    # CONFIG_NRFX_TWI=y
    # CONFIG_NRFX_TWI0=y
    # CONFIG_NRFX_TWIM=y
    # CONFIG_NRFX_TWIM0=y
    CONFIG_I2C_LOG_LEVEL_DBG=y
    I still haven't gotten it to compile since the macro "DT_PROP" appears to use "DT_CAT" to concatenate some stuff to get the identifier for the i2c channel pin. That must have changed between the Zephyr usage and the NRFX usage. I'm digging to find out how to use something else in it's place, but it looks like you've got me on the right track.
  • I think I understand what I am looking for now, but I don't see it. The code I was upgrade from v1.9.1 to v2.0.0 is still having a problem with the I2C (TWI) settings and the PWM settings. Those were both update in a script to migrate them to the newer pinctrl overlay. That seems to be the source of my latest issues. Before, this line of code would set a PWM going:
    		pwm_pin_set_usec(pwm_dev, DT_PROP(PWM_CTRL, ch1_pin), PWM_PER_US, OFF, flags);
    DT_PROP() is giving me trouble here and where it was used for the I2C. It talks about accessing properties from the device tree in the the docs here, but with the new pinctrl setup is does not seem to address the change and the device tree does not seem to work the same. The macro seems to not work for this case. 'ch1_pin' doesn't exist. 'clock_frequency' does seem to for the I2C, but the pin and channel numbers do not seem accessible through the 'DT_PROP()' macro. Unfortunately, the documentation does not seem to address the change in how I2C, PWM and SPI properties are accessed as far as I can tell.
    Thank you for your patience with this. The summer holidays have begun here in Norway, and thus DevZone is operating at reduced capacity. Apologies for any inconveniences this might cause.
    You will need to make changes to the Device Tree according to the migration guide for the pinctrl migration documentation in order for this to work after the upgrade to NCS v2.0.0.
    Could you possibly share your entire prj.conf and device tree? I could take a look to see if I spot where it is going wrong.
    Please let me know if you would like me to change the ticket to private before you do any sharing - this will make it viewable by only yourself and the support engineers here at Nordic.
    Karl
  • I might be missing something in the migration guide, but I have tried to follow it. I ran the script for spliting out the pincontrol in to a new .dtsi file. As of right now I have issues with the TWI and PWM modules, but when I bring the SPI online, I will expect to see issues there. My TWI issue shows up when I am displaying the pin numbers used by that peripheral, but I should be able to make it work. Before the switch to the pin control module, the DT_PROP() macro was used to get the attribute, in this case the pin numbers, from the board file.
    As far as I understand it, the board file should be the source of truth for the pin setup. After running the provided update script according to the migration guide (pinctrl_nrf_migrate.py) a new *-pinctrl.dsti was created with the proper migration complete. In the switch to pin control, the DT_PROP()macro fails to recover the pin numbers. I can recover the set frequency because that still remained in the parent board .dts file. DT_PROP() does not appear to work for a pinctrl property. I haven't found instructions on how to accomplish it.
    This becomes important when I have to run a recovery on the TWI bus for a particular encoder that we are using, It requires us to bit-bang the bus with a sequence to recover the device from a locked up mode. To run that I have to get the pin numbers.
    The PWM module call "pwm_set()" requires a channel number which is also defined in the pinctrl module. We were using "DT_PROP(PWM_CTRL, ch0_pin)" to access that channel in v1.9.1, but that does not work because that property is deeper in the pincrl file rather than in the board device tree top level.
    pwm_pin_set_usec(pwm_dev, DT_PROP(PWM_CTRL, ch0_pin), PWM_PER_US, SPEED2PULSE(speed), flags);
    I'll go a head and include the requested code below:
    prj.conf:
    # Incresed stack due to settings API usage
    # Logging
    CONFIG_CONSOLE=y
    CONFIG_LOG=y
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_DEFAULT_LEVEL=4
    CONFIG_DEBUG_OPTIMIZATIONS=y
    CONFIG_DEBUG_THREAD_INFO=y
    CONFIG_PRINTK=y
    CONFIG_LOG_PRINTK=y
    # Segger RTT
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BUFFER_SIZE=15360
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=15360
    # Random Number Generator
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_ENTROPY_NRF5_RNG=y
    CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=16
    CONFIG_ENTROPY_NRF5_THR_THRESHOLD=6
    # Flash NVS
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_NVS=y
    CONFIG_NVS_LOG_LEVEL_DBG=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # Bluetooth
    CONFIG_BT=y
    CONFIG_BT_SETTINGS=y
    CONFIG_BT_DEBUG_LOG=y
    CONFIG_BT_SMP=n
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_PNP=n
    CONFIG_BT_ATT_PREPARE_COUNT=5
    CONFIG_BT_DEVICE_NAME="myLIFTER"
    CONFIG_BT_DEVICE_APPEARANCE=1856
    CONFIG_BT_DEVICE_NAME_DYNAMIC=n
    CONFIG_BT_DIS_MODEL="project V0.1"
    CONFIG_BT_DIS_SERIAL_NUMBER=y
    CONFIG_BT_DIS_SERIAL_NUMBER_STR="10001"
    CONFIG_BT_DIS_MANUF="company Inc"
    # I2C
    CONFIG_I2C=y
    CONFIG_I2C_NRFX=y
    # CONFIG_NRFX_TWI=y
    # ADC
    CONFIG_ADC=y
    CONFIG_ADC_NRFX_SAADC=y
    CONFIG_ADC_LOG_LEVEL_DBG=y
    # PWM
    CONFIG_PWM=y
    CONFIG_PWM_LOG_LEVEL_INF=y
    # SETTINGS
    CONFIG_STACK_SENTINEL=y
    CONFIG_SETTINGS=y
    CONFIG_NEWLIB_LIBC=y
    # BOOTLOADER
    # Stuff I am experimenting with:
    # nRF immutable secure bootloader
    # CONFIG_SECURE_BOOT=y
    # b0_CONF_FILE=prj_minimal.conf
    # CONFIG_SB_SIGNING_KEY_FILE="priv.pem"
    # For use without the private key that may be managed separately
    # CONFIG_SB_SIGNING_CUSTOM=y
    # CONFIG_SB_SIGNING_PUBLIC_KEY="/path/to/pub.pem"
    # CONFIG_SB_SIGNING_COMMAND="my_command"
    # MCUBOOT for OTA
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_IMG_MANAGER=y
    CONFIG_IMG_ENABLE_IMAGE_CHECK=y
    # BOOT_SIGNATURE_KEY_FILE ="${workspacefolder}/sec/sh_myl_key.pem"
    # CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="${workspacefolder}/sec/sh_myl_key.pem"
    # CONFIG_MCUMGR=y
    # CONFIG_MCUMGR_CMD_OS_MGMT=y
    # CONFIG_MCUMGR_CMD_IMG_MGMT=y
    # CONFIG_MCUMGR_SMP_BT=y
    board.dts:
    /dts-v1/;
    #include <nordic/nrf52832_qfaa.dtsi>
    #include "board-pinctrl.dtsi"
    	model = "project";
    	compatible = "company,board";
    	chosen {
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart0;
    		zephyr,bt-c2h-uart = &uart0;
    		zephyr,sram = &sram0;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    	leds {								/* added mot_en here for now need to find out how to define plain gpio output pin*/
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = <&gpio0 2 GPIO_ACTIVE_HIGH>;
    			label = "LED_R";
    		led1: led_1 {
    			gpios = <&gpio0 31 GPIO_ACTIVE_HIGH>;
    			label = "LED_G";
    		moten: mot_en {
    			gpios = <&gpio0 20 GPIO_ACTIVE_HIGH>;
    			label = "MOT_EN";
    	buttons {
    		compatible = "gpio-keys";
    		button0: button_0 {
    			gpios = <&gpio0 6 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Lim_SW1";
    		button1: button_1 {
    			gpios = <&gpio0 7 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Bind_SW";
    		button2: button_2 {
    			gpios = <&gpio0 18 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Lim_SW0";
    	vsys0: vsys {
    		compatible = "voltage-divider";
    		status = "okay";
    		label = "VIN_AN";
    		io-channels = <&adc 1>, <&adc 2>, <&adc 3>;
    		io-channel-names = "TEMP_AN", "I_MOT_AN", "VIN_AN";
    		output-ohms = <2000>;
    		full-ohms = <(6490 + 2000)>;
    	/* These aliases are provided for compatibility with samples */
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		bootloader-led0 = &led0;
    		/*notes */
    		ledr = &led0;
    		ledg = &led1;
    		limsw1 = &button0;
    		bindsw = &button1;
    		limsw0 = &button2;
    		anin = &adc;
    		pwm	= &pwm0;
    		moten = &moten;
    &gpiote {
    	compatible = "nordic,nrf-gpiote";
    	status = "okay";
    &gpio0 {
    	status = "okay";
    &adc {
    	compatible = "nordic,nrf-saadc";
    	status = "okay";
    &i2c0 {
    	compatible = "nordic,nrf-twi";
    	status = "okay";
    	clock-frequency = < 400000 >;
    	pinctrl-0 = <&i2c0_default>;
    	pinctrl-1 = <&i2c0_sleep>;
    &pwm0 {
    	compatible = "nordic,nrf-pwm";
    	status = "okay";
    	pinctrl-0 = <&pwm0_default>;
    	pinctrl-1 = <&pwm0_sleep>;
    &spi1 {
    	compatible = "nordic,nrf-spi";
    	status = "okay";
    	cs-gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
    	pinctrl-0 = <&spi1_default>;
    	pinctrl-1 = <&spi1_sleep>;
    &flash0 {
    	partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		boot_partition: partition@0 {
    			label = "mcuboot";
    			reg = <0x00000000 0xc000>;
    		slot0_partition: partition@c000 {
    			label = "image-0";
    			reg = <0x0000C000 0x32000>;
    		slot1_partition: partition@3e000 {
    			label = "image-1";
    			reg = <0x0003E000 0x32000>;
    		scratch_partition: partition@70000 {
    			label = "image-scratch";
    			reg = <0x00070000 0xa000>;
    		storage_partition: partition@7a000 {
    			label = "storage";
    			reg = <0x0007a000 0x00006000>;
    pinctrl.dtsi:
    &pinctrl {
    	i2c0_default: i2c0_default {
    		group1 {
    			psels = <NRF_PSEL(TWIM_SDA, 0, 8)>,
    				<NRF_PSEL(TWIM_SCL, 0, 9)>;
    	i2c0_sleep: i2c0_sleep {
    		group1 {
    			low-power-enable;
    	pwm0_default: pwm0_default {
    		group1 {
    			psels = <NRF_PSEL(PWM_OUT0, 0, 17)>,
    				<NRF_PSEL(PWM_OUT1, 0, 16)>,
    				<NRF_PSEL(PWM_OUT2, 0, 19)>;
    	pwm0_sleep: pwm0_sleep {
    		group1 {
    			low-power-enable;
    	spi1_default: spi1_default {
    		group1 {
    			psels = <NRF_PSEL(SPIM_SCK, 0, 12)>,
    				<NRF_PSEL(SPIM_MOSI, 0, 10)>,
    				<NRF_PSEL(SPIM_MISO, 0, 11)>;
    	spi1_sleep: spi1_sleep {
    		group1 {
    			low-power-enable;
    You may note that in prj.conf I have commented out the "CONFIG_NRFX" TWI stuff and left in "CONFIG_I2C" stuff as that was causing a compile time issue that was discussed earlier in this ticket.
    Thank you for looking into this for me, your help is much appreciated.
