Zigbee brightness cluster attribute and cluster
Using v1.9.1 nrfConnect and the Coordinator example on a nrf52840 -DK.
From Nordic docs:
I think I may be miss interpreting Zigbee Cluster spec...
Below is example of an RGB light bulb I'm trying to change brightness on but can't get it to change.
(I tried many different ways too long to list)
#1  Based on below cluster info etc. can you give example of ZCL commend format to set brightness to 50%?
We can use "move to level" to 50%. I believe range is 0x000 - 0xfe if I read it right?
I can turn same bulb on/off by sending on/off command.
zcl cmd 0xcf3e 01 0x0006 0x01 --- ON, as example.
But I can't read the attribute showing on/off status? Am i missing some setting in Kconfig?
I tried including profile id 0x0104 also since my default is HA.
#2  Can you me show ZCL command example of how to read this?
From Nordic doc:
zcl attr read h:dst_addr d:ep h:cluster [-c] h:profile h:attr_id
PS: I looked at other tickets but looks like my issue is much simpler.
Thank you, Jorgen
  • Hi Jorgen,
    I've also replied this to the other case you've posted that I'm working on, but I'm writing it here as well! This is just a note that I've picked up your case and will begin investigating it. However due to summer holidays here in Norway we are currently running with a reduced support staff, so the reply time might be longer than normal. I hope I can get back to you during early next week with more answers.
    Andreas
  • Hi Andreas,
    No problem. Thanks for letting me know.
    Jörgen
  • Hi Jorgen,
    Is the light bulb application based on a sample application or is the firmware written from scratch? And is the RGB bulb a specific device, or just a bulb that is ZigBee-compatible?
    If you have not seen the zigbee samples already I believe the light bulb sample is a dimmable ZigBee device which might contain the functionality you are looking for. And I will take a look and see if I have a sample available tomorrow morning
    I believe I also have a sample for this, but I will need to find it first
    Andreas
  • Hi Andreas, It's just a generic Zigbee HA1.2 RGB light bulb with dimming and color control.
    The Nordic zigbee light bulb controller example is a eval board "light switch" so it doesn't show actual codes that are sent.
    At least I could not find it...?
    I think I'm not sending the correct attr_id
    In fact I'm not sure where I can find the att_id , for "level" (dimming) as example.
    I assume it's not the same as "level" cluster which is 0x0800 as per below.
    An example of the just the command would be great.
    Thanks!
    Jorgen
    I see you have the ZigBee Cluster Specification available, so I will also be using some snippets from the ZCL Spec V7 in my example below. I am also making an assumption that you know your devices ID and how to find their addresses and the correct end point values, so if I am assuming wrong on this, please correct me!
    By this, do you mean the the light switch sample?
    The level control attribute id is correct (0x0800) as per ZigBee Cluster Library Specification 7 states, but the command to change the value of the light is another command
    Here is a few examples of how to "mock" a light switch with commands:
    Off command with example:
    • zcl cmd [-d] <h:dst_addr> <d:ep> <h:cluster> [-p h:profile] <cmd_ID> [-l h:payload]
    • zcl cmd -d 0x8041 10 0x0006 0x00
    Step command (dimmer function):
      • for clarity: "-l" in [-l h:payload] = lower case L
    • zcl cmd 0x8041 10 0x0008 0x02 -l 00A01400
    This example is sent to the device at address 0x8041,  at the endpoint 10 (light bulb), and utilizes the ZigBee Home Automation Profile (0x0104) by default. When it is recived by the bulb, it should gradually increase the value of CurrentLevel attribute by 160 over 2 seconds
    So to do this, you need to replace the cmd_ID in the example above from step (0x02) to "move to level 0x00. I am not 100% certain about the range, but my current best guess is that it is a long hexadecimal number. I will see if I can find someone who can verify this for me, but try with the same range you were trying the previous command with
    From Nordic doc:
    In my sample, sending the command "zcl attr_read 0x8041 10 0x0006 0x0104 0x0000" returns ID: 0 Type: 10 Value: True, so I  think you just misinput the order of the parameters based on your screen shot.
    Let me know if this clarifies things for you or answers your questions!
    Andreas
