Flash Consumed % in Build results of Asset_tracker
I build the asset_tracker with custom code added to it and working well. The build time messages are shown in the attached text file. There e %of Flash used in show thrice in it. Which one represents which flash area of which SOC / SIP ? 99%, 66% and 63 % is shown.
Building firmware
west build --build-dir c:\firmware\firmware\firmware\build c:\firmware\firmware\firmware --pristine --board nrf9160dk_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/firmware/firmware/firmware" -DDTC_OVERLAY_FILE:STRING="c:/firmware/firmware/firmware/boards/nrf9160dk_nrf9160_ns.overlay" -DCONF_FILE:STRING="c:/firmware/firmware/firmware/prj.conf;c:/firmware/firmware/firmware/boards/nrf9160dk_nrf9160_ns.conf" -DOVERLAY_CONFIG:STRING="c:/firmware/firmware/firmware/asset-tracker-cloud-firmware-azure.conf;c:/firmware/firmware/firmware/firmware.conf;c:/firmware/firmware/firmware/overlay-azure.conf;c:/firmware/firmware/firmware/overlay-debug.conf"
Including boilerplate (Zephyr base): C:/firmware/firmware/zephyr/cmake/app/boilerplate.cmake
CMake Warning at C:\firmware\firmware\zephyr\cmake\app\boilerplate.cmake:16 (message):
  Loading of Zephyr boilerplate.cmake directly is deprecated, please use
  'find_package(Zephyr)'
  C:\Users\Gulza\ncs\v1.7.1\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:24 (include)
  C:\Users\Gulza\ncs\v1.7.1\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:35 (include_boilerplate)
  c:\firmware\firmware\firmware\build\CMakeLists.txt:9 (find_package)
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: C:/firmware/firmware/firmware
-- Found Python3: C:/Users/Gulza/ncs/v1.9.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/firmware/firmware/zephyr/.cache
-- Zephyr version: 3.0.99 (C:/firmware/firmware/zephyr)
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
-- Found dtc: C:/Users/Gulza/ncs/v1.9.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/Users/Gulza/ncs/v1.9.1/toolchain/opt)
-- Found BOARD.dts: C:/firmware/firmware/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
-- Found devicetree overlay: c:/firmware/firmware/firmware/boards/nrf9160dk_nrf9160_ns.overlay
-- Generated zephyr.dts: C:/firmware/firmware/firmware/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/firmware/firmware/firmware/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/firmware/firmware/firmware/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/firmware/firmware/firmware/build/zephyr/dts.cmake
Parsing C:/firmware/firmware/firmware/Kconfig
Loaded configuration 'C:/firmware/firmware/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
Merged configuration 'c:/firmware/firmware/firmware/prj.conf'
Merged configuration 'c:/firmware/firmware/firmware/boards/nrf9160dk_nrf9160_ns.conf'
warning: Experimental symbol AZURE_FOTA is enabled.
warning: Experimental symbol AZURE_IOT_HUB_CHOICE is enabled.
warning: Experimental symbol NET_SOCKETS_OFFLOAD is enabled.
Merged configuration 'c:/firmware/firmware/firmware/asset-tracker-cloud-firmware-azure.conf'
Merged configuration 'c:/firmware/firmware/firmware/firmware.conf'
Merged configuration 'c:/firmware/firmware/firmware/overlay-azure.conf'
Merged configuration 'c:/firmware/firmware/firmware/overlay-debug.conf'
Configuration saved to 'C:/firmware/firmware/firmware/build/zephyr/.config'
Kconfig header saved to 'C:/firmware/firmware/firmware/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/Users/Gulza/ncs/v1.9.1/toolchain/opt/bin/arm-none-eabi-gcc.exe
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm -  begin ===
loading initial cache file C:/firmware/firmware/firmware/build/spm/child_image_preload.cmake
-- Application: C:/firmware/firmware/nrf/samples/spm
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found BOARD.dts: C:/firmware/firmware/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: C:/firmware/firmware/nrf/samples/spm/nrf9160dk_nrf9160.overlay
-- Generated zephyr.dts: C:/firmware/firmware/firmware/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/firmware/firmware/firmware/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/firmware/firmware/firmware/build/spm/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/firmware/firmware/firmware/build/spm/zephyr/dts.cmake
Parsing C:/firmware/firmware/zephyr/Kconfig
Loaded configuration 'C:/firmware/firmware/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'C:/firmware/firmware/nrf/samples/spm/prj.conf'
Merged configuration 'C:/firmware/firmware/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
Merged configuration 'C:/firmware/firmware/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/firmware/firmware/firmware/child_image/spm.conf'
Merged configuration 'C:/firmware/firmware/firmware/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/firmware/firmware/firmware/build/spm/zephyr/.config'
Kconfig header saved to 'C:/firmware/firmware/firmware/build/spm/zephyr/include/generated/autoconf.h'
CMake Warning at C:\firmware\firmware\zephyr\CMakeLists.txt:775 (message):
  No SOURCES given to Zephyr library: drivers__console
  Excluding target from build.
CMake Warning at C:\firmware\firmware\zephyr\CMakeLists.txt:1744 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: C:/firmware/firmware/firmware/build/spm
=== child image spm -  end ===
=== child image mcuboot -  begin ===
loading initial cache file C:/firmware/firmware/firmware/build/mcuboot/child_image_preload.cmake
-- Application: C:/firmware/firmware/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: C:/firmware/firmware/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: C:/firmware/firmware/firmware/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/firmware/firmware/firmware/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/firmware/firmware/firmware/build/mcuboot/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/firmware/firmware/firmware/build/mcuboot/zephyr/dts.cmake
Parsing C:/firmware/firmware/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration 'C:/firmware/firmware/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/firmware/firmware/firmware/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/firmware/firmware/firmware/build/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/firmware/firmware/firmware/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: C:/firmware/firmware/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/firmware/firmware/firmware/build/mcuboot
=== child image mcuboot -  end ===
CMake Warning at C:\firmware\firmware\nrf\modules\mcuboot\CMakeLists.txt:263 (message):
        --- WARNING: Using default MCUBoot key, it should not ---
        --- be used for production.                           ---
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
[1/332] Creating directories for 'spm_subimage'
[2/332] Generating include/generated/version.h
-- Zephyr version: 3.0.99 (C:/firmware/firmware/zephyr), build: v2.7.99-ncs1-2223-g240c7b9a691f
[3/332] Creating directories for 'mcuboot_subimage'
[4/332] No download step for 'spm_subimage'
[5/332] No download step for 'mcuboot_subimage'
[6/332] No update step for 'spm_subimage'
[7/332] No update step for 'mcuboot_subimage'
[8/332] No patch step for 'spm_subimage'
[9/332] No patch step for 'mcuboot_subimage'
[10/332] No configure step for 'spm_subimage'
[10/332] Performing build step for 'spm_subimage'
[1/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/ssl_ticket.c.obj
[2/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/ssl_tls13_keys.c.obj
[3/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/ssl_cookie.c.obj
[4/263] Generating include/generated/version.h
[5/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/asn1write.c.obj
[6/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/asn1parse.c.obj
[7/263] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[8/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/ssl_msg.c.obj
[9/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/ssl_srv.c.obj
[10/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/base64.c.obj
[11/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/pem.c.obj
[12/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/ssl_cli.c.obj
[13/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/nist_kw.c.obj
[14/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/pkwrite.c.obj
[15/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/padlock.c.obj
[16/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/pkcs5.c.obj
[17/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/ssl_tls.c.obj
[18/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/oid.c.obj
[19/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/pkcs12.c.obj
[20/263] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[21/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/platform_util.c.obj
[22/263] Generating include/generated/driver-validation.h
[23/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/pkparse.c.obj
[24/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/version.c.obj
[25/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/aesni.c.obj
[26/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/aria.c.obj
[27/263] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[28/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/des.c.obj
[29/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/camellia.c.obj
[30/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/platform.c.obj
[31/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/cipher_wrap.c.obj
[32/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/ecdh.c.obj
[33/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/ecdsa.c.obj
[34/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/bignum.c.obj
[35/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/ripemd160.c.obj
[36/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/ecp_curves.c.obj
[37/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/cipher.c.obj
[38/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/md.c.obj
[39/263] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[40/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/md5.c.obj
[41/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/hmac_drbg.c.obj
[42/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/sha1.c.obj
[43/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/rsa_alt_helpers.c.obj
[44/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/pk.c.obj
[45/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/pk_wrap.c.obj
[46/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/sha256.c.obj
[47/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto_cipher.c.obj
[48/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto_ecp.c.obj
[49/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto_aead.c.obj
[50/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/ecp.c.obj
[51/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto_mac.c.obj
[52/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto.c.obj
[53/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/sha512.c.obj
[54/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto_rsa.c.obj
[55/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto_hash.c.obj
[56/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto_slot_management.c.obj
[57/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/random_ext.c.obj
[58/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto_storage.c.obj
[59/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/psa_crypto_driver_wrappers.c.obj
[60/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/psa_crypto_client.c.obj
[61/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/pk.c.obj
[62/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/firmware/firmware/mbedtls/library/rsa.c.obj
[63/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/cipher_wrap.c.obj
[64/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/md.c.obj
[65/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/dhm.c.obj
[66/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/ecdh.c.obj
[67/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/pk_wrap.c.obj
[68/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/cmac.c.obj
[69/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/ccm.c.obj
[70/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/ecjpake.c.obj
[71/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/cipher.c.obj
[72/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/chachapoly.c.obj
[73/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/ecdsa.c.obj
[74/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/gcm.c.obj
[75/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/ecp_curves.c.obj
[76/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/chacha20.c.obj
[77/263] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto_base.a
[78/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes_oberon.c.obj
[79/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/hkdf.c.obj
[80/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/rsa_alt_helpers.c.obj
[81/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/ecjpake_oberon.c.obj
[82/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/legacy/aes.c.obj
[83/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/poly1305.c.obj
[84/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/firmware/firmware/mbedtls/library/x509_create.c.obj
[85/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/firmware/firmware/mbedtls/library/x509write_csr.c.obj
[86/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/debug.c.obj
[87/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/ecp.c.obj
[88/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/ssl_cache.c.obj
[89/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/firmware/firmware/mbedtls/library/rsa.c.obj
[90/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/firmware/firmware/mbedtls/library/x509.c.obj
[91/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/firmware/firmware/mbedtls/library/x509_crl.c.obj
[92/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/net_sockets.c.obj
[93/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/firmware/firmware/mbedtls/library/x509_csr.c.obj
[94/263] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
[95/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/firmware/firmware/mbedtls/library/ssl_ciphersuites.c.obj
[96/263] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/firmware/firmware/mbedtls/library/x509_crt.c.obj
[97/263] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedx509.a
[98/263] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedtls.a
[99/263] Generating include/generated/offsets.h
[100/263] Building C object zephyr/CMakeFiles/zephyr.dir/C_/firmware/firmware/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[101/263] Building C object zephyr/CMakeFiles/zephyr.dir/C_/firmware/firmware/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[102/263] Building C object zephyr/CMakeFiles/zephyr.dir/C_/firmware/firmware/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[103/263] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[104/263] Generating linker_zephyr_pre0.cmd
[105/263] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[106/263] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[107/263] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[108/263] Generating linker_zephyr_pre1.cmd
[109/263] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[110/263] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[111/263] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[112/263] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[113/263] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[114/263] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[115/263] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[116/263] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[117/263] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[118/263] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[119/263] Linking C static library zephyr\arch\common\libisr_tables.a
[120/263] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[121/263] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[122/263] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[123/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[124/263] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[125/263] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[126/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[127/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[128/263] Linking C static library zephyr\arch\common\libarch__common.a
[129/263] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[130/263] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[131/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[132/263] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[133/263] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
[134/263] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[135/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[136/263] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[137/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[138/263] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[139/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[140/263] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[141/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[142/263] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[143/263] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
[144/263] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[145/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[146/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[147/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[148/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[149/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[150/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[151/263] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[152/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[153/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[154/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[155/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[156/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[157/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[158/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[159/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[160/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[161/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[162/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[163/263] Building C object CMakeFiles/app.dir/src/main.c.obj
[164/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[165/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[166/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[167/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[168/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[169/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[170/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[171/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[172/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[173/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[174/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[175/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[176/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[177/263] Linking C static library app\libapp.a
[178/263] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[179/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[180/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[181/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[182/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[183/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[184/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[185/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[186/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[187/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[188/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[189/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[190/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[191/263] Linking C static library zephyr\kernel\libkernel.a
[192/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[193/263] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[194/263] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[195/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[196/263] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[197/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[198/263] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[199/263] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
[200/263] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
[201/263] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
[202/263] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[203/263] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[204/263] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/constraint.c.obj
[205/263] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[206/263] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
[207/263] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/residency.c.obj
[208/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[209/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[210/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[211/263] Building C object zephyr/CMakeFiles/zephyr.dir/C_/firmware/firmware/nrf/subsys/spm/spm.c.obj
[212/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[213/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[214/263] Building C object zephyr/CMakeFiles/zephyr.dir/C_/firmware/firmware/nrf/subsys/spm/secure_services.c.obj
[215/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[216/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[217/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[218/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[219/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[220/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[221/263] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[222/263] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[223/263] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[224/263] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[225/263] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[226/263] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[227/263] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/firmware/firmware/nrf/drivers/entropy/entropy_cc3xx.c.obj
[228/263] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/cortex_m_systick.c.obj
[229/263] Linking C static library zephyr\libzephyr.a
[230/263] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[231/263] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[232/263] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[233/263] Linking C static library zephyr\lib\posix\liblib__posix.a
[234/263] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[235/263] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[236/263] Linking C static library zephyr\subsys\random\libsubsys__random.a
[237/263] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[238/263] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[239/263] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[240/263] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[241/263] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[242/263] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[243/263] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
[244/263] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[245/263] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[246/263] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[247/263] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[248/263] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
[249/263] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[250/263] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[251/263] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.c.obj
[252/263] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[253/263] Linking C executable zephyr\zephyr_pre0.elf
[254/263] Generating dev_handles.c
[255/263] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[256/263] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[257/263] Linking C executable zephyr\zephyr_pre1.elf
[258/263] Generating linker.cmd
[259/263] Generating isr_tables.c, isrList.bin
[260/263] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[261/263] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[262/263] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[263/263] Linking C executable zephyr\zephyr.elf
           FLASH:       65024 B        64 KB     99.22%
            SRAM:       11976 B        32 KB     36.55%
        IDT_LIST:          0 GB         2 KB      0.00%
[15/332] Generating include/generated/driver-validation.h
[16/332] Performing build step for 'mcuboot_subimage'
[1/182] Generating include/generated/version.h
[2/182] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/182] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/182] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[5/182] Generating include/generated/driver-validation.h
[6/182] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/182] Generating include/generated/offsets.h
[8/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[9/182] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[10/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[11/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[12/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
[13/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[14/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[15/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
[16/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[17/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[18/182] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[19/182] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[20/182] Building C object zephyr/CMakeFiles/zephyr.dir/C_/firmware/firmware/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
[21/182] Building C object zephyr/CMakeFiles/zephyr.dir/C_/firmware/firmware/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[22/182] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[23/182] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[24/182] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[25/182] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[26/182] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[27/182] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[28/182] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[29/182] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[30/182] Building C object zephyr/CMakeFiles/zephyr.dir/C_/firmware/firmware/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[31/182] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[32/182] Generating linker_zephyr_pre0.cmd
[33/182] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[34/182] Generating linker_zephyr_pre1.cmd
[35/182] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[36/182] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[37/182] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[38/182] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[39/182] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[40/182] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[41/182] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[42/182] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[43/182] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[44/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[45/182] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[46/182] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[47/182] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[48/182] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[49/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[50/182] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[51/182] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[52/182] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[53/182] Linking C static library zephyr\arch\common\libisr_tables.a
[54/182] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[55/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[56/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[57/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[58/182] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[59/182] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[60/182] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[61/182] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[62/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[63/182] Generating zephyr/autogen-pubkey.c
[64/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[65/182] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[66/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[67/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[68/182] Linking C static library zephyr\arch\common\libarch__common.a
[69/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[70/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[71/182] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[72/182] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[73/182] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[74/182] Building C object CMakeFiles/app.dir/keys.c.obj
[75/182] Building C object CMakeFiles/app.dir/os.c.obj
[76/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[77/182] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[78/182] Building C object CMakeFiles/app.dir/main.c.obj
[79/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[80/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[81/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[82/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[83/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[84/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[85/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[86/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[87/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[88/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[89/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
[90/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
[91/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[92/182] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[93/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
[94/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[95/182] Building C object CMakeFiles/app.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[96/182] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[97/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[98/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[99/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[100/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[101/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[102/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[103/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[104/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[105/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[106/182] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[107/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[108/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[109/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[110/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[111/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[112/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[113/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[114/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[115/182] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[116/182] Linking C static library app\libapp.a
[117/182] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[118/182] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[119/182] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
[120/182] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[121/182] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[122/182] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[123/182] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[124/182] Linking C static library zephyr\libzephyr.a
[125/182] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[126/182] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[127/182] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[128/182] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
[129/182] Linking C static library zephyr\lib\posix\liblib__posix.a
[130/182] Linking C static library zephyr\drivers\console\libdrivers__console.a
[131/182] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[132/182] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[133/182] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[134/182] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/firmware/firmware/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[135/182] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[136/182] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
[137/182] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[138/182] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[139/182] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[140/182] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[141/182] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
[142/182] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[143/182] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[144/182] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[145/182] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
[146/182] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[147/182] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[148/182] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[149/182] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[150/182] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[151/182] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[152/182] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[153/182] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[154/182] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[155/182] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/firmware/firmware/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
[156/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[157/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[158/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[159/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[160/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[161/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[162/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[163/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[164/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[165/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[166/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[167/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[168/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[169/182] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[170/182] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[171/182] Linking C static library zephyr\kernel\libkernel.a
[172/182] Linking C executable zephyr\zephyr_pre0.elf
[173/182] Generating dev_handles.c
[174/182] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[175/182] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[176/182] Linking C executable zephyr\zephyr_pre1.elf
[177/182] Generating linker.cmd
[178/182] Generating isr_tables.c, isrList.bin
[179/182] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[180/182] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[181/182] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[182/182] Linking C executable zephyr\zephyr.elf
           FLASH:       32572 B        48 KB     66.27%
            SRAM:         16 KB     211736 B      7.74%
[123/332] Building C object CMakeFiles/app.dir/src/modules/bms/serial_irq.c.obj
../src/modules/bms/serial_irq.c: In function 'get_device_ptr':
c:\firmware\firmware\firmware\src\modules\bms\serial_irq.c:22:12: warning: return discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
   22 |     return bms_uart;
[129/332] Building C object CMakeFiles/app.dir/src/modules/gnss_module.c.obj
c:\firmware\firmware\firmware\src\modules\gnss_module.c:403:13: warning: 'print_pvt' defined but not used [-Wunused-function]
  403 | static void print_pvt(void)
[311/332] Linking C executable zephyr\zephyr_pre0.elf
[315/332] Linking C executable zephyr\zephyr_pre1.elf
[320/332] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[322/332] No install step for 'mcuboot_subimage'
[323/332] Completed 'mcuboot_subimage'
[324/332] Linking C executable zephyr\zephyr.elf
           FLASH:      249264 B     392704 B     63.47%
            SRAM:      135544 B     211736 B     64.02%
[325/332] Generating zephyr/mcuboot_primary.hex
[326/332] Generating zephyr/mcuboot_primary_app.hex
[327/332] Generating ../../zephyr/app_update.bin
[328/332] Generating ../../zephyr/dfu_application.zip
[329/332] Generating ../../zephyr/app_signed.hex
[330/332] Generating ../../zephyr/app_test_update.hex
[331/332] Generating ../../zephyr/app_moved_test_update.hex
[332/332] Generating zephyr/merged.hex
  • Hi Gulzar,
    I suggest you read through Bootloaders and Device Firmware Updates — nRF Connect SDK 2.0.0 documentation (nordicsemi.com) to learn the usage of different images.
    The asset_tracker_v2\build\partitions.yml or running west build -t partition_manager_report to get partition manager report like below will help you identify the different images with their size.
    :\NCS\v2.0.0\nrf\applications\asset_tracker_v2>west build -t partition_manager_report
    -- west build: running target partition_manager_report
    [1/1] cmd.exe /C "cd /D C:\NCS\v2.0.0\nrf\applications\asset_tracker_v2\b...put C:/NCS/v2.0.0/nrf/applications/asset_tracker_v2/build/partitions.yml"  flash_primary (0x100000 - 1024kB):
    +---0x0: b0_container (0x8000 - 32kB)--------------+
    | 0x0: b0 (0x8000 - 32kB)                          |
    +---0x8000: s0 (0xc200 - 48kB)---------------------+
    | 0x8000: s0_pad (0x200 - 512B)                    |
    +---0x8200: s0_image (0xc000 - 48kB)---------------+
    | 0x8200: mcuboot (0xc000 - 48kB)                  |
    | 0x14200: EMPTY_0 (0x3e00 - 15kB)                 |
    +---0x18000: s1 (0xc200 - 48kB)--------------------+
    | 0x18000: s1_pad (0x200 - 512B)                   |
    | 0x18200: s1_image (0xc000 - 48kB)                |
    | 0x24200: EMPTY_1 (0x3e00 - 15kB)                 |
    +---0x28000: mcuboot_primary (0x68000 - 416kB)-----+
    +---0x28000: tfm_secure (0x8200 - 32kB)------------+
    | 0x28000: mcuboot_pad (0x200 - 512B)              |
    +---0x28200: app_image (0x67e00 - 415kB)-----------+
    +---0x28200: mcuboot_primary_app (0x67e00 - 415kB)-+
    | 0x28200: tfm (0x8000 - 32kB)                     |
    +---0x30200: tfm_nonsecure (0x5fe00 - 383kB)-------+
    | 0x30200: app (0x5fe00 - 383kB)                   |
    | 0x90000: mcuboot_secondary (0x68000 - 416kB)     |
    +---0xf8000: nonsecure_storage (0x2000 - 8kB)------+
    | 0xf8000: settings_storage (0x2000 - 8kB)         |
    | 0xfa000: EMPTY_2 (0x6000 - 24kB)                 |
      otp (0x2f4 - 756B):
    | 0xff8108: provision (0x280 - 640B) |
    | 0xff8388: otp (0x74 - 116B)        |
      sram_primary (0x40000 - 256kB):
    +---0x20000000: sram_secure (0x10000 - 64kB)-------+
    | 0x20000000: tfm_sram (0x10000 - 64kB)            |
    +---0x20010000: sram_nonsecure (0x30000 - 192kB)---+
    +---0x20010000: nrf_modem_lib_sram (0x44e8 - 17kB)-+
    | 0x20010000: nrf_modem_lib_ctrl (0x4e8 - 1kB)     |
    | 0x200104e8: nrf_modem_lib_tx (0x2000 - 8kB)      |
    | 0x200124e8: nrf_modem_lib_rx (0x2000 - 8kB)      |
    | 0x200144e8: sram_primary (0x2bb18 - 174kB)       |
    Charlie
