Soft reset when watchdogs timer timeout
Could I trigger nRF52832 to do soft reset when watchdogs timer timeout?
  • I have seen the watchdog example. But I don't know what do you mean about "It's not the correct way of using the watchdog". Do you see any problem from my attache files?
  • It shouldn't be necessary to manually reset when the watchdog expires, that would defeat the whole purpose of having a watchdog. The watchdog should schedule a reset once it expires independently of the CPU. If you were dependent on the CPU reaching some state to do a reset when the watchdog has expired then the watchdog wouldn't be that useful.
  • But my question is why watchdog event handler _wdtEventHandler() is not called. Could you explain about this?
    <info> WDT: Function: nrfx_wdt_init, error code: NRF_SUCCESS.
     0> <info> WDT: Function: nrfx_wdt_channel_alloc, error code: NRF_SUCCESS.
     0> <info> WDT: Enabled.
     0> <debug> app: Watchdog timer feed
     0>
     0> <error> app: ERROR 4 [NRF_ERROR_NO_MEM] at ..\..\..\..\..\..\com<error> app: End of error report
  • Can I use NRF_LOG_WARNING() to check if  watchdog event handler _wdtEventHandler() is called? Or I need to use LED to check if  watchdog event handler _wdtEventHandler() is called?
  • I am sure watchdog event handler _wdtEventHandler() is called by checking with LED. But why main() isn't called after calling NVIC_SystemReset().
    int main(void) {
        log_init();
        uart_init();
        _showInfo();
    static void _showInfo(void) {
        NRF_LOG_INFO("Version %d.%d.%d\n", MAJOR_VER, MINOR_VER, PATCH_VER);
    I only " app: Version 1.0.0" one time in following log messages. It should be two times if main() is called after system reboot.
    0> <info> app: Version 1.0.0
     0>
     0> <info> app: ========| flash info |========
     0> <info> app: erase unit:   4096 bytes
     0> <info> app: program unit: 4 bytes
     0> <info> app: end address: 0x7FFFF
     0> <info> app: ==============================
     0> <info> app_timer: RTC: initialized.
     0> <debug> app: NOR_DATA_PERIOD=819
     0>
     0> <debug> app: NOR_RECORD_PERIOD=8192
     0>
     0> <info> app: bsp_button_longkey_handler 0.
     0> <info> app: POWER_ON.
     0> <info> app: External devices initializing start
     0> <info> app: Reg 0 20
     0> <info> app: Reg 9 A
     0> <info> app: Reg A D
     0> <info> app: Reg 1 B
     0> <info> app: Reg 2 D
     0> <info> app: Reg D F
     0> <info> app: Reg E 13
     0> <info> app: Reg 36 10
     0> <info> app: Reg 37 13
     0> <info> app: Reg 5 11
     0> <info> app: Reg 6 13
     0> <info> app: Reg F 15
     0> <info> app: Reg 10 19
     0> <info> app: Reg 3 16
     0> <info> app: Reg 4 19
     0> <info> app: Reg 7 17
     0> <info> app: Reg 8 19
     0> <info> app: Reg 11 1B
     0> <info> app: Reg 12 1F
     0> <info> app: Reg 43 0
     0> <info> app: Reg 44 0
     0> <info> app: Reg B 1D
     0> <info> app: Reg C 1F
     0> <info> app: Reg 13 21
     0> <info> app: Reg 14 25
     0> <info> app: Reg 1D 3F
     0> <info> app: Reg 64 0
     0> <info> app: Reg 65 27
     0> <info> app: Reg 66 0
     0> <info> app: Reg 67 27
     0> <info> app: Reg 68 0
     0> <info> app: Reg 69 27
     0> <info> app: Reg 52 2C
     0> <info> app: Reg 53 2C
     0> <info> app: Reg 6A 32
     0> <info> app: Reg 6B 38
     0> <info> app: Reg 1E 101
     0> <info> app: Reg 20 3
     0> <info> app: Reg 21 2
     0> <info> app: Reg 22 802084
     0> <info> app: Reg 23 124218
     0> <info> app: Reg 4B F
     0> <info> app: Reg 50 18
     0> <info> app: Reg 31 20
     0> <info> app: Reg 39 5
     0> <info> app: Reg 4E 0
     0> <info> app: Reg 4E 8
     0> <info> app: Reg 45 8
     0> <info> app: Reg 46 13
     0> <info> app: Reg 47 14
     0> <info> app: Reg 48 1F
     0> <info> app: Reg 0 21
     0> <warning> app: nrfx_wdt_init() return 0
     0>
     0> <info> app: External devices initializing finish
