Could I trigger nRF52832 to do soft reset when watchdogs timer timeout?
#include "band_nctu.h"
#include "error.h"
#include "nrf_log.h"
#include "nrfx_wdt.h"
#include "wdt.h"
static bool _gWdtInitialized = false;
static nrfx_wdt_channel_id _gWdtChannelID;
void _wdtReboot(void) {
NVIC_SystemReset();
* WDT events handler.
static void _wdtEventHandler(void) {
NRF_LOG_WARNING("Watchdog timer event handler\n");
_wdtReboot();
int wdtInit(void) {
ret_code_t errCode;
nrfx_wdt_config_t wdtConfig = NRFX_WDT_DEAFULT_CONFIG;
errCode = nrfx_wdt_init(&wdtConfig, _wdtEventHandler);
if (errCode != NRF_SUCCESS) {
NRF_LOG_WARNING("nrfx_wdt_init() failed\n");
return ERROR_WDT_INITIALIZE_FAIL;
errCode = nrfx_wdt_channel_alloc(&_gWdtChannelID);
nrfx_wdt_enable();
_gWdtInitialized = true;
NRF_LOG_WARNING("nrfx_wdt_init() return 0\n");
return 0;
int wdtFeed(void) {
if (!_gWdtInitialized) {
return ERROR_WDT_UNINITIALIZED;
NRF_LOG_DEBUG("Watchdog timer feed\n");
nrfx_wdt_channel_feed(_gWdtChannelID);
return 0;
snowuyl said:0> <error> app: ERROR 4 [NRF_ERROR_NO_MEM] at ..\..\..\..\..\..\com<error> app: End of error report
Something is asserting in your program, a function is returning error code 4. The full error report should specify what function that is returning that code.
snowuyl said:But why main() isn't called after calling NVIC_SystemReset().
The CPU will do a reset when this function is called, the program will not return directly to the main loop but would rather start from the beginning again.
regards
Jared
Does Nordic provide API for soft reset and return directly to the main loop?
No every type of reset whether it's brownout reset, pin reset, soft reset, power-on-reset, watchdog reset, wake up from system off reset will reset the program.
regards
Jared
