BLE Coded PHY: how to determine used data rate
I'm trying to determine the actual used data rate for the coded PHY but cannot find the corresponding API / data structure / enums.
Am I missing something?  Can someone give me a pointer?
Regards
Hardy
  • Hello Hardy,
    As you have noticed, there event struct does not include any fields which tell what the actual data rate is. The Softdevice doesn't support sending with s=2 encoding (500 kbit/s) so it's only when you receive data that it may see this data rate. It is s=8 (125 kbit/s) otherwise.
    Vidar
  • Hello Vidar,
    thanks for response.  I thought S=2 has been introduced in S140 6.0.0?  So I guess I'm wrong.
    One more point: how to determine, if PHY_CODED is really used?  Is there an API for querying the used PHY?
    Thanks & regards
    Hardy
  • Hello Hardy,
    I guess you could say s=2 support was introduced in this release since it did add support for receiving packets with this encoding. There is no Softdevice API to query what PHY is currently in use, but this should be easy to monitor from the app. The connection will always be established with the same PHY used by the advertiser, and the PHY can't be updated without triggering the BLE_GAP_PHY_UPDATE event (PHY Update Procedure).
    Vidar
  • Hello Vidar,
    concerning the used PHY: if one offers a PHY via primary/secondary_phy in the adv params one does not automatically know which PHY is being used, right?
    Problem here are the connection parameters, the device offers the central which could lead to impossible combinations.  E.g. 6 packets/event on a 12ms connection interval if PHY_CODED has been selected.
    How to "code" around?
    Kind regards
    Hardy
  • Hello Hardy,
    The connection is always established with the same PHY depending on how the advertiser is configured. The initiator will use your secondary_phy to initiate the connection if you do extended advertising. The primary phy is used otherwise.
    Do you want to have a longer interval if coded PHY is used? Please note that the number of packets you can send per connection event (i.e. even length) is not a connection paramter like the interval is. The number of packets you can send depends on what the central support, max. event length on the peripheral, and packet loss (event will end early if there is packet loss).
    Vidar
