Data rate using nRF52832 and NUS
I am looking into the example of SAADC and sending data through BLE. My tests are based on this example: github.com/.../ble_app_uart__saadc_timer_driven__scan_mode
I am trying to get a higher data rate, so I changed several configurations.
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)
#define SAADC_SAMPLES_IN_BUFFER         40
#define SAADC_SAMPLE_RATE               10
#define NRF_SDH_BLE_GAP_EVENT_LENGTH 40
The log on my nRF Connect mobile app on Android shows an updated connection interval of 45 ms. But, when I check the detailed dssata receiving log, it shows data received every 90 ms.
My questions:
1. Does it mean I only receive one data every 90ms?
2. I want to achieve higher data rate, what can I do? My goal is ~100 kbps.
Thanks in advance!
    To further increase the throughput you can try to place the raw values inside the notification packet and skip the string conversion. Here is the result I got when I tried it here  (assuming my calculations are correct):
    Sampling @1ms
    Updated main.c:
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * Peripheral: SAADC
     * Compatibility: nRF52832 rev 2/nRF52840 rev 1, SDK 15.2.0
     * Softdevice used: S132 v6.1.0/S140 v6.1.0
     * This SAADC example samples on 4 different input pins, and enables scan mode to do that. It is
     * otherwise an offsprint from the standard ble_app_uart example available in nRF5 SDK 15.2.0 Works
     * together with softdevice S132 v6.1.0 on nRF52832 and S140 v6.1.0 on nRF52840 Transmits SAADC
     * output to hardware UART and over BLE via Nordic UART Servive (NUS). Info on NUS ->
     * http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/ble_sdk_app_nus_eval.html?cp=4_0_0_4_1_2_17
     * Info on hardware UART settings ->
     * http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v13.0.0/uart_example.html?cp=4_0_0_4_4_41
    #include "app_timer.h"
    #include "app_uart.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_hci.h"
    #include "ble_nus.h"
    #include "bsp_btn_ble.h"
    #include "nordic_common.h"
    #include "nrf.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_timer.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include <stdint.h>
    #include <string.h>
    #if defined(UART_PRESENT)
    #include "nrf_uart.h"
    #if defined(UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(15, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SAADC_SAMPLE_RATE               1                                         /**< SAADC sample rate in ms. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                         /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                           /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);               /**< Advertising module instance. */
    APP_TIMER_DEF(m_throughput_timer_id);
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
    static uint16_t m_ble_nus_max_data_len =
        BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to
                                         the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
        {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};
    volatile uint8_t state = 1;
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(3);
    static nrf_saadc_value_t m_buffer_pool[2][SAADC_SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t m_ppi_channel;
    static uint32_t m_adc_evt_counter;
    static uint32_t m_samples_sent;
    static void throughput_timeout_handler(void * p_context)
        if (m_samples_sent !=0)
            NRF_LOG_INFO("%d samples/s", m_samples_sent);
        m_samples_sent = 0;
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
        err_code = app_timer_create(&m_throughput_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    throughput_timeout_handler);
    static void timers_start(void)
        ret_code_t err_code;
        err_code = app_timer_start(m_throughput_timer_id, APP_TIMER_TICKS(1000), NULL);
     *          the device. It also sets the permissions and appearance.
        uint32_t err_code;
        ble_gap_conn_params_t gap_conn_params;
        err_code =
            sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
        gap_conn_params.slave_latency = SLAVE_LATENCY;
        gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
    static void nrf_qwr_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); }
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY)
        uint32_t err_code;
        ble_nus_init_t nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
    static void conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); }
        uint32_t err_code;
        cp_init.p_conn_params = NULL;
        cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
        cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
        cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
        cp_init.disconnect_on_fail = false;
        cp_init.evt_handler = on_conn_params_evt;
        cp_init.error_handler = conn_params_error_handler;
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys = {
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            case BLE_GAP_EVT_PHY_UPDATE:
                NRF_LOG_INFO("PHY updated. Current bitrate %dM.",
                             p_ble_evt->evt.gap_evt.params.phy_update.tx_phy);
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(
                    m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            case BLE_GATTC_EVT_TIMEOUT:
                    p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BLE_GATTS_EVT_TIMEOUT:
                    p_ble_evt->evt.gatts_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BLE_GATTS_EVT_HVN_TX_COMPLETE:
                //NRF_LOG_INFO("Notification(s) sent");
            case BLE_GAP_EVT_CONN_PARAM_UPDATE:
                /* Interval is given in units of 1.25 ms. Multiply by 1.25 to get interval in ms */
                uint32_t new_conn_interval =
                    p_ble_evt->evt.gap_evt.params.conn_param_update.conn_params.max_conn_interval *
                    1.25;
                NRF_LOG_INFO("Connection paramaters updated. New interval is %d ms", new_conn_interval);
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) &&
            (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
            p_gatt->att_mtu_desired_central, p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code =
                    sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                                (err_code != NRF_ERROR_RESOURCES) && (err_code != NRF_ERROR_NOT_FOUND))
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
        uint32_t err_code;
        app_uart_comm_params_t const comm_params = {
            .rx_pin_no = RX_PIN_NUMBER,
            .tx_pin_no = TX_PIN_NUMBER,
            .rts_pin_no = RTS_PIN_NUMBER,
            .cts_pin_no = CTS_PIN_NUMBER,
            .use_parity = false,
            .baud_rate = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate = NRF_UARTE_BAUDRATE_115200
        APP_UART_FIFO_INIT(&comm_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_event_handle,
            APP_IRQ_PRIORITY_LOWEST, err_code);
        uint32_t err_code;
        ble_advertising_init_t init;
        init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.srdata.uuids_complete.p_uuids = m_adv_uuids;
        init.config.ble_adv_fast_enabled = true;
        init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
     * @param[out] p_erase_bonds  Will be true if the clear bonding button was pressed to wake the
     * application up.
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    void timer_handler(nrf_timer_event_t event_type, void * p_context) {}
        nrf_drv_timer_config_t timer_config = NRF_DRV_TIMER_DEFAULT_CONFIG;
        timer_config.frequency = NRF_TIMER_FREQ_31250Hz;
        err_code = nrf_drv_timer_init(&m_timer, &timer_config, timer_handler);
        /* setup m_timer for compare event */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, SAADC_SAMPLE_RATE);
        nrf_drv_timer_extended_compare(
            &m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
        uint32_t timer_compare_event_addr =
            nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
        uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
        err_code = nrf_drv_ppi_channel_assign(
            m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
        static uint8_t n_samples;
        static uint8_t index;
        static uint8_t nus_data[NRF_SDH_BLE_GATT_MAX_MTU_SIZE - 3];
        uint8_t sample_len = sizeof(nrf_saadc_value_t);
        uint8_t max_samples = (m_ble_nus_max_data_len / sample_len);
            uint16_t adc_value;
            uint8_t value[SAADC_SAMPLES_IN_BUFFER * 2];
            uint16_t bytes_to_send;
            // set buffers
            err_code =
                nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER);
            // print samples on hardware UART and parse data for BLE transmission
            printf("ADC event number: %d\r\n", (int)m_adc_evt_counter);
            for (int i = 0; i < SAADC_SAMPLES_IN_BUFFER; i++)
                printf("%d\r\n", p_event->data.done.p_buffer[i]);
                adc_value = p_event->data.done.p_buffer[i];
                value[i * 2] = adc_value;
                value[(i * 2) + 1] = adc_value >> 8;
            // Send data over BLE via NUS service.
            if ((n_samples + SAADC_SAMPLES_IN_BUFFER) < max_samples)
                index = n_samples * sample_len;
                ASSERT(!((index + sample_len) > m_ble_nus_max_data_len))
                memcpy(&nus_data[index], p_event->data.done.p_buffer, SAADC_SAMPLES_IN_BUFFER * 2);
                n_samples += SAADC_SAMPLES_IN_BUFFER;
                bytes_to_send = index;
                err_code = ble_nus_data_send(&m_nus, nus_data, &bytes_to_send, m_conn_handle);
                if (err_code == NRF_SUCCESS)
                    m_samples_sent += n_samples;
                else if (err_code == NRF_ERROR_RESOURCES)
                    /* Too many notifications queued. */
                    NRF_LOG_WARNING("%d SAADC samples dropped", n_samples);
                else if ((err_code != NRF_ERROR_INVALID_STATE) &&
                        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING) &&
                index = 0;
                n_samples = 0;
    void saadc_init(void)
        nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
        saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
        nrf_saadc_channel_config_t channel_0_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
        channel_0_config.gain = NRF_SAADC_GAIN1_4;
        channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_1_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
        channel_1_config.gain = NRF_SAADC_GAIN1_4;
        channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_2_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
        channel_2_config.gain = NRF_SAADC_GAIN1_4;
        channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
        nrf_saadc_channel_config_t channel_3_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
        channel_3_config.gain = NRF_SAADC_GAIN1_4;
        channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
        err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
        err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
        err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
        err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAADC_SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAADC_SAMPLES_IN_BUFFER);
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        saadc_sampling_event_init();
        saadc_init();
        // Start execution.
        advertising_start();
        timers_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • No problem Slight smile  Just note that my buffer handling inside the saadc_callback() requires a bit more work. Now it will drop 4 samples every time the nus_data array is full.  A simple solution may be to use two buffers so you can start preparing the next buffer when the previous one is being transferred over BLE.
    Some other obvious mistakes I noticed when I looked at the code again:
    1. Previous check did not include the 'equal' operator so the packet would be sent before it was full (probably won't make much difference but still an optimizations you can make). 2. Removed what should be a redundant assert check. I added it to make sure I wasn't overrunning the nus_data buffer. 3. index which was used earlier is always SAADC_SAMPLES_IN_BUFFER * 2 bytes less than the number of bytes we actually want to send.
