In BLE Master, get GATT Services and characteristics about a peripheral. (nrf5_SDK)
Hello, I want to get information list about BLE GATT services and characteristics of a device.
I want to connect to a peripheral with a specific name, then  get all metadata about the device and store it in a structure.
I couldn't find a specific example about generic discovery.  The SDK provide API for different kind of official service.
I have taken a look here to see what can exist.
- Bluetooth low energy Characteristics, a beginner's tutorial
- Discovering Different UUID base of service and characteristics from BLE Central
- S130 Custom UUID Service discovery
- nrf connect sdk - generic discovery and reading/writing Gatt services and characteristics
- What is the best way to get these data with nrf5_SDK ?
- How I can read/wirte/be notified after that ? (set specific handle ? )
Configuration:
- Bluetooth : SoftDevice S132.
- SDK : nRF5_SDK_17.1.0_ddde560
lilian
  • Using  "ble_db_discovery" API is the good way to do this ?
    typedef struct
        ble_db_discovery_evt_type_t evt_type;    /**< Type of event. */
        uint16_t                    conn_handle; /**< Handle of the connection for which this event has occurred. */
        union
            ble_gatt_db_srv_t   discovered_db;  /**< Structure containing the information about the GATT Database at the server. This will be filled when the event type is @ref BLE_DB_DISCOVERY_COMPLETE. The UUID field of this will be filled when the event type is @ref BLE_DB_DISCOVERY_SRV_NOT_FOUND. */
            void const        * p_db_instance;  /**< Pointer to DB discovery instance @ref ble_db_discovery_t, indicating availability to the new discovery process. This will be filled when the event type is @ref BLE_DB_DISCOVERY_AVAILABLE. */
            uint32_t            err_code;       /**< nRF Error code indicating the type of error which occurred in the DB Discovery module. This will be filled when the event type is @ref BLE_DB_DISCOVERY_ERROR. */
        } params;
    } ble_db_discovery_evt_t;
    static void _db_disc_handler(ble_db_discovery_evt_t* p_evt)
         .... // Get informations here.
  • Yes. Look at how e.g. the ble_app_uart_c does service discovery and uses the db_disc_handler() to call ble_nus_c_on_db_disc_evt(). I know that ble_nus_c_on_db_disc_evt() is service specific, but you can look at the implementation how it checks the service UUID in the handler. Instead of comparing it to a known UUID, you can do whatever you like with that information.
    Edvin
  • Thank you for your answer. I looked at how the example works.
    I managed to get the characteristics of a service using the API.
    ble_uuid_t puuid = { .type= BLE_UUID_TYPE_BLE, .uuid = 0x1170};
    ble_db_discovery_evt_register(&puuid);
    ble_db_discovery_start(&_xDbDiscovery, p_ble_evt->evt.gap_evt.conn_handle);
    However, I need to know the UUID of the service before launching a discovery start.
    - Is there a way to find out which UUIDs are available on the device before starting the discovery scan?
    - If I understand correctly, I need to register each UUID  that I want to discover in the device before ble_db_discovery_start ?
    No. That is the point of the service discovery. To discover what UUIDs that are available on the device.
    The reason I pointed to the ble_app_uart_c example is that this starts the discovery process without knowing the UUID up front. You can see how the discovery is started in the BLE_GAP_EVT_CONNECTED event in ble_evt_handler() in main.c.
    This will trigger callbacks (for each service) in db_disc_handler(), which in this case is handled by ble_nus_c_on_db_disc_evt(), but you can handle it in any function. the ble_nus_c_on_db_disc_evt() is just an example comparing the UUID of a preknown UUID. The UUID in the callback is present in:
    p_evt->params.discovered_db.srv_uuid.uuid
    the number of characteristics in that service will be present in p_evt->params.discovered_db.char_count
    and the characteristics UUIDs will be present in:
    p_evt->params.discovered_db.charateristics[i].characteristic.uuid
    And all of these are used for reference in ble_nus_c_on_db_disc_evt() in the ble_app_uart_c example.
    BR,
    Edvin
  • However, when I read the source code, I see that the NUS service registers a UUID.
    uint32_t ble_nus_c_init(ble_nus_c_t * p_ble_nus_c, ble_nus_c_init_t * p_ble_nus_c_init)
        uint32_t      err_code;
        ble_uuid_t    uart_uuid;
        ble_uuid128_t nus_base_uuid = NUS_BASE_UUID;
        VERIFY_PARAM_NOT_NULL(p_ble_nus_c);
        VERIFY_PARAM_NOT_NULL(p_ble_nus_c_init);
        VERIFY_PARAM_NOT_NULL(p_ble_nus_c_init->p_gatt_queue);
        err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_ble_nus_c->uuid_type);
        VERIFY_SUCCESS(err_code);
        uart_uuid.type = p_ble_nus_c->uuid_type;
        uart_uuid.uuid = BLE_UUID_NUS_SERVICE;
        p_ble_nus_c->conn_handle           = BLE_CONN_HANDLE_INVALID;
        p_ble_nus_c->evt_handler           = p_ble_nus_c_init->evt_handler;
        p_ble_nus_c->error_handler         = p_ble_nus_c_init->error_handler;
        p_ble_nus_c->handles.nus_tx_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_nus_c->handles.nus_rx_handle = BLE_GATT_HANDLE_INVALID;
        p_ble_nus_c->p_gatt_queue          = p_ble_nus_c_init->p_gatt_queue;
        return ble_db_discovery_evt_register(&uart_uuid);
    This seems logic because I am unable to start a discovery without register a service first (error 8). The variable "m_num_of_handlers_reg" is equal to 0.
    uint32_t ble_db_discovery_start(ble_db_discovery_t * const p_db_discovery, uint16_t conn_handle)
        VERIFY_PARAM_NOT_NULL(p_db_discovery);
        VERIFY_MODULE_INITIALIZED();
        if (m_num_of_handlers_reg == 0)
            // No user modules were registered. There are no services to discover.
        if (p_db_discovery->discovery_in_progress)
            return NRF_ERROR_BUSY;
        return discovery_start(p_db_discovery, conn_handle);
    When I start the scan:
    - With good UUID registered,  I then have 2 events :  BLE_DB_DISCOVERY_SRV_NOT_FOUND and BLE_DB_DISCOVERY_AVAILABLE
    - Without good UUID registered,  I then have 2 events :  BLE_DB_DISCOVERY_COMPLETE and BLE_DB_DISCOVERY_AVAILABLE
    Sorry for the misunderstanding. I want to know the services UUIDs on the peripheral device before those of the characteristics.
    It is possible ?
    Lilian
