Zehpyr Shell + Logging on RTT
Dear Nordic,
There is an issue with simultaneous RTT shell and logging on nCS 2.0.0, please check the screenshot.
Althougth CONFIG_LOG_BACKEND_RTT_BUFFER=1 setting is made (I tried '2' also), logger still outputs the data to RTT 'terminal 0' (with 00 mark). What could be wrong here?
  • Have seen following:
     Log and shell through RTT backend don't play nicely
     Using the Zigbee shell through Segger RTT backend
    We have the following on prj.conf:
    # Enable RTT
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # enable LOG on RTT
    CONFIG_LOG=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # CONFIG_LOG_PRINTK=n
    CONFIG_LOG_MODE_OVERFLOW=y
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=100
    CONFIG_LOG_BUFFER_SIZE=16384
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=16384
    # console output on RTT
    CONFIG_RTT_CONSOLE=y
    CONFIG_SHELL=y
    CONFIG_SHELL_BACKENDS=y
    CONFIG_SHELL_BACKEND_RTT=y
    CONFIG_SHELL_PROMPT_RTT="rtt:~$ "
  • Dear Nordic,
    there is some misunderstanding in terms: RTT Viewer operates by Terminals, not RTT channels. Altougth RTT channel for logger (RTT #1) is created and operates well, there is no ready-to-use software to view the logging output and use shell simultaneosly.
    We could use SEGGER RTT Logger, but it only saves logs to file - no option to view logs online.
    Still, there is ability to select particular terminal mark or out to particular terminal using SEGGER_RTT_TerminalOut() funciton. So, do we have a solution to distinquish logs and shell interface between logical terminals easier than writing our own log backend?
