nrf_desktop application can't off the b0 bootloader
Dear Nordic Engineers
Our customers use the nrf_desktop  application to develop their product.
 They use the NCS 2.0.0\nrf\applications\nrf_desktop and build project on the nrf52840dk_nrf52840.
It looks normal. The program can run.
They would like off the b0 bootloader. So I went to their company to help them.
I read this link:https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.0.0/nrf/applications/nrf_desktop/README.html
The bo bootloader can set the following configs to open/off the b0 bootloader.
CONFIG_SECURE_BOOT
CONFIG_BUILD_S1_VARIANT
CONFIG_FW_INFO
CONFIG_FW_INFO_FIRMWARE_VERSION
CONFIG_SB_SIGNING_KEY_FILE
So I off this config on nrf\applications\nrf_desktop\configuration\nrf52840dk_nrf52840\prj.conf.
I rebuilt the project and it reports some errors. I found that it needs off "CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE".
Then the project can be built.I downloaded the program to PCA10056(V1.0.0). The program can't run.
I review nrf_desktop\configuration\nrf52840dk_nrf52840\prj.conf of NCS V1.9.1 and NCS V2.0.0. Their difference is the following configs.
CONFIG_SECURE_BOOT
CONFIG_FW_INFO
Do I need off other config? Please give me some good suggestions.
Best regards.
    I have tried your provided sample nrf_desktop.zip. I have noticed the presence of -DBOARD_ROOT:STRING="e:/NCS/my_samples/serial_lte_modem" and app.overlay. In addition, your prj.conf has had CONFIG_SECURE_BOOT=n, but does not have CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE=n. Is there any reason for this?
    When I flashed your project, LEDs were not turned on.
    I have also tried your merged1.hex and merged2.hex. Merged1.hex does turn LED1 ON and LED2 ON/OFF, but merged2.hex does not turn ON any LEDs.
    Dejan
  • Dear Dejans
    1. You can delete my build files and rebuild a new build project for nrf52840dk.
    2. "CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE" is a default config of nrf_desktop.
    Its default config is "CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE=y".
    So you should look for it to prj.conf's line 60.
    3. Yes, merged2.hex does not turn ON any LEDs and you can't use phone or PC's bluetooth scan advertising of DK.
    I tried to three PCs to build and test nrf_desktop for this problem. This problem reappears every time.
    So I think this problem is a bug of NCS 2.0.0.
    4. You can use your PC and PCA10056(v1.0.0) to copy this way.
    You only close "CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE" and "CONFIG_SECURE_BOOT" in your prj.conf of nrf_desktop.
    Then build the project and download program to PCA10056(v1.0.0).
    This problem will recurrence.
    Best regards.
    I have tested the nrf_desktop sample again. I observed as well the LEDs behavior and I could reproduce the sttus of the LEDs. With relevant two options (CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE and CONFIG_SECURE_BOOT) enabled, LEDs are turned ON, but with two options disabled LEDs are not turned ON. This is expected as shown in the LED stream module configuration. CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE=n disables LEDs.
    Dejan
  • Dear Dejans
    If set  "CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE=n" and "CONFIG_SECURE_BOOT=y",the project will not be build.
    And close "CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE",the program will not have advertising.
    So how to close b0 bootloader?
    Best regards.
    The advertising should not be affected.
    Can you verify that you will not have advertising when you turn off b0 bootloader?
    Dejan
