nRF52840 SPI pin-out configuration is not according to schematics
First of all, I'm not a hw-engineer Slight smile
I've 2 evaluation devices of nRF52840 (BL654-DVK) and I'm trying to test the SPI communication between them (one as master, other as slave).
I've based on the spi & spis examples from here: https://github.com/sigurdnev/ncs-playground
1) The examples do not compile "off the shelf", to compile properly, I've to comment out prj.conf the directives "CONFIG_SPI_1" & "CONFIG_DEPRECATED_ZEPHYR_INT_TYPES", otherwise they fail with the following error:
> Executing task: nRF Connect: Generate config nrf52840dk_nrf52840 for c:\work\repo\nordic\ncs-playground\samples\spi_test <
Building spi_test
west build --build-dir c:\work\repo\nordic\ncs-playground\samples\spi_test\build_1 c:\work\repo\nordic\ncs-playground\samples\spi_test --pristine --board nrf52840dk_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/work/repo/SurgicalWirelessProtocol/EVB/spi;c:/work/repo/SurgicalWirelessProtocol/EVB/spi_loopback;c:/work/repo/SurgicalWirelessProtocol/EVB/spi_comm/spi_master"
Including boilerplate (Zephyr base): C:/Users/vagner.landskron/ncs/v1.9.1/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/work/repo/nordic/ncs-playground/samples/spi_test
-- Zephyr version: 2.7.99 (C:/Users/vagner.landskron/ncs/v1.9.1/zephyr), build: v2.7.99-ncs1-1
-- Found Python3: C:/Users/vagner.landskron/ncs/v1.9.1/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: nrf52840dk_nrf52840
-- Cache files will be written to: C:/Users/vagner.landskron/ncs/v1.9.1/zephyr/.cache
-- Found dtc: C:/Users/vagner.landskron/ncs/v1.9.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/Users/vagner.landskron/ncs/v1.9.1/toolchain/opt)
-- Found BOARD.dts: C:/Users/vagner.landskron/ncs/v1.9.1/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
-- Found devicetree overlay: C:/work/repo/nordic/ncs-playground/samples/spi_test/nrf52840dk_nrf52840.overlay
-- Generated zephyr.dts: C:/work/repo/nordic/ncs-playground/samples/spi_test/build_1/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/work/repo/nordic/ncs-playground/samples/spi_test/build_1/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/work/repo/nordic/ncs-playground/samples/spi_test/build_1/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/work/repo/nordic/ncs-playground/samples/spi_test/build_1/zephyr/dts.cmake
C:\work\repo\nordic\ncs-playground\samples\spi_test\prj.conf:12: warning: attempt to assign the value 'y' to the undefined symbol SPI_1
C:\work\repo\nordic\ncs-playground\samples\spi_test\prj.conf:14: warning: attempt to assign the value 'y' to the undefined symbol DEPRECATED_ZEPHYR_INT_TYPES
error: Aborting due to Kconfig warnings
Parsing C:/Users/vagner.landskron/ncs/v1.9.1/zephyr/Kconfig
Loaded configuration 'C:/Users/vagner.landskron/ncs/v1.9.1/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
Merged configuration 'C:/work/repo/nordic/ncs-playground/samples/spi_test/prj.conf'
CMake Error at C:\Users\vagner.landskron\ncs\v1.9.1\zephyr\cmake\kconfig.cmake:272 (message):
  command failed with return code: 1
  C:\Users\vagner.landskron\ncs\v1.9.1\zephyr\cmake\app\boilerplate.cmake:544 (include)
  C:\Users\vagner.landskron\ncs\v1.9.1\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:24 (include)
  C:\Users\vagner.landskron\ncs\v1.9.1\zephyr\share\zephyr-package\cmake\ZephyrConfig.cmake:35 (include_boilerplate)
  c:\work\repo\nordic\ncs-playground\samples\spi_test\build_1\CMakeLists.txt:27 (find_package)
FATAL ERROR: command exited with status 1: 'c:\Users\vagner.landskron\ncs\v1.9.1\toolchain\opt\bin\cmake.EXE' '-DWEST_PYTHON=c:\Users\vagner.landskron\ncs\v1.9.1\toolchain\opt\bin\python.exe' '-Bc:\work\repo\nordic\ncs-playground\samples\spi_test\build_1' '-Sc:\work\repo\nordic\ncs-playground\samples\spi_test' -GNinja -DBOARD=nrf52840dk_nrf52840 -DNCS_TOOLCHAIN_VERSION:STRING=NONE '-DBOARD_ROOT:STRING=c:/work/repo/SurgicalWirelessProtocol/EVB/spi;c:/work/repo/SurgicalWirelessProtocol/EVB/spi_loopback;c:/work/repo/SurgicalWirelessProtocol/EVB/spi_comm/spi_master'
The terminal process terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
2) My Setup:
NCS: v1.9.1
Visual Code project;
I'm taking the SPI Master as a base and setting my own pinnage as follows (app.overlay):
&zephyr_udc0 {
	cdc_acm_uart0 {
		compatible = "zephyr,cdc-acm-uart";
		label = "CDC_ACM_0";
&spi1 {
	status = "okay";
	sck-pin = <14>;
	mosi-pin = <13>;
	miso-pin = <12>;
	cs-gpios = <&gpio0 28 0>;
And here is my prj.conf:
CONFIG_BOOT_BANNER=y
CONFIG_SPI=y
CONFIG_SPI_ASYNC=y
CONFIG_SPI_LOG_LEVEL_INF=y
CONFIG_LOG=y
CONFIG_UART_CONSOLE=y
CONFIG_SERIAL=y
CONFIG_UART_LINE_CTRL=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="Zephyr CDC ACM sample"
CONFIG_SPI_1_NRF_ORC=0x00
CONFIG_SPI_LOOPBACK_DRV_NAME="SPI_1"
CONFIG_SPI_LOOPBACK_CS_GPIO=y
CONFIG_SPI_LOOPBACK_CS_CTRL_GPIO_DRV_NAME="GPIO_0"
CONFIG_SPI_LOOPBACK_CS_CTRL_GPIO_PIN=28
This is the generated zephyr.dts
		spi1: spi@40004000 {
			#address-cells = < 0x1 >;
			#size-cells = < 0x0 >;
			reg = < 0x40004000 0x1000 >;
			interrupts = < 0x4 0x1 >;
			status = "okay";
			label = "SPI_1";
			sck-pin = < 0xe >;
			mosi-pin = < 0xd >;
			miso-pin = < 0xc >;
			cs-gpios = < &gpio0 0x1c 0x0 >;
			mx25r6435f@0 {
				compatible = "jedec,spi-nor";
				reg = < 0x0 >;
				spi-max-frequency = < 0x4c4b400 >;
				label = "MX25R64";
				jedec-id = [ C2 28 17 ];
				size = < 0x4000000 >;
				wp-gpios = < &gpio0 0x16 0x0 >;
				hold-gpios = < &gpio0 0x17 0x0 >;
Problem:
According to the schematics, I should get the CLK on J47-pin4, but I'm actually getting it on J47-pin9 (checked using Oscilloscope).
Same for MOSI, I'm getting data on J47-pin7 instead of J47-pin5.
I'm trying to understand where I've messed...
    I am not familiar with the BL654-DVK board, as it is not made by Nordic. I tried to look up this in a datasheet, but with no luck. What pins are J47-pin4 and J47-pin9 connected to?
    According to this datasheet, it looks like they are connected to SIO_19 and SIO_13 respectively, but I don't know what pins those are. Are they P0.19 and P0.13, respectively? Perhaps you can check this with Laird, who made the module/DVK board.
    With the overlay file that you posted above, setting sck-pin = <14>, that should refer to P0.14, which is described in the pin assignment here.
    But you need to check with Laird how these pins are routed out to the board if it is not clear from some datasheet that you have.
    Edvin
