Jlink RTT Viewer not working with NRF52832
I am using NRF52832 DK, SDK 17.1.0, S132 Softdevice, Segger 5.42a and rtt viewer v7.62.
I am using blinky code from example.After building and debug the code I disconnect the board and reconnect it through external
rtt but it does not show any output though LOG shows: RTT Viewer connected. I tried with different board it works but it does not work with NRf52832 DK.
Below are my rtt viewer settings
Thanks & Regards
Meet Shah
    Are you using the same firmware on both boards? Have you modified anything from the blinky example?
    regards
    Jared
  • Hi Jared
    Thank for your response
    I am using the same firmware on both the boards. No I have not modified blinky example. The other boards which i have tried are NRF538340 and NRF52833
  • The ble_app_blinky example will use the UART as backend for the logger module not RTT:
  • Hi Jared
    instead of blinky example i am referring to twi_sensor example as i wanted to work with rtt. I have totally modify the code to simple one and in sdkconfig i have have enabled  NRF_LOG_BACKEND_RTT_ENABLED 1,NRF_LOG_ENABLED 1 and NRF_LOG_BACKEND_UART_ENABLED 0 to use rtt instead of uart.
    The modified code is
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf.h"
    #include "nordic_common.h"
    #include "boards.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_log_backend_rtt.h"
    * @brief Function for application main entry.
    // Initialize the Logger module and check if any error occured during initialization
    // Initialize the default backends for nrf logger
    // print the log msg over uart port
    printf("This is log data from nordic device..\r\n");
    NRF_LOG_INFO("This is log data from nordic device..\r\n");
    // a variable to hold counter value
    uint32_t count = 0;
    while (true)
    // Dsiplay the logger info with variable
    printf("Counter Value: %d \r\n", count);
    NRF_LOG_INFO("Counter Value: %d \r\n", count);
    nrf_delay_ms(500); // delay for 500 ms
    count++; // increment the counter by 1
    Before diconnecting I get logs in RTT viewer but after diconnecting DK and again connecting not logs are shown
    Output before disconnecting
    After disconnecting and again connecting
    I think you might have to restart the J-Link RTT Viewer program.
    regards
    Jared
1 2
