NRF9160 GPS without LTE availability
We are developing with the nrf9160dk as our development board. We are working from the aws-nrf-cloud a-gps sample  (cat tracker sample) for our stack as our main system is AWS based. This works fine for 90% of our use cases.
However:
We have a scenario in 10% of cases where our devices will be used outside of cell signal and should still continue to collect GPS data. The LTE antenna can be fully turned off in these cases. It seems like the "samples/nrf9160/gps" have all been removed from the docs and everything is a-gps, p-gps related and all samples require cell connectivity to function. Will we be able to acquire satellites the old fashion way when we are out of cell range. Is there any up-to-date documentation that describes this task?
Is this AT command based or is there a library we should be using for this?
Thank you.
    What version of the nRF Connect SDK are you currently working on? And what version of the nRF9160DK are you using?
    The GNSS sample (nrf\samples\nrf9160\gnss) should be sufficient to demo the GPS functionality without a cell signal. Have a look at the Modem Library GNSS interface. As described in the GPS Receiver chapter of the nRF9160 Product Specification:
    Operation is time multiplexed with LTE modem, and it is possible to use the GPS and QZSS receiver to obtain position either while the LTE is in RRC Idle mode or power saving mode (PSM), or when the LTE modem is completely deactivated.
    As a general note for all GPS usage
    GPS signals do not usually penetrate ceilings or other structures that well. Therefore, for best GPS performance, the DK should be placed on a flat surface in an open space outside, far from sources of interference and other structures that may block the signals from space.
    The nRF Cloud A-GPS library documentation states the following
    When A-GPS data is downloaded using LTE network, the LTE link is in RRC connected mode. The GNSS module can only operate when the device is in RRC idle mode or Power Saving Mode (PSM). The time to go from RRC connected mode to RRC idle mode is network-dependent. This time is usually not controlled by the device and is typically in the range of 5 to 70 seconds. If the GNSS module has already started before the device enters the RRC idle mode, this RRC inactivity may make TTFF appear longer than the actual time spent searching for the GNSS satellite signals.
    This sample configures modem to functional mode 31. This activates GNSS without changing LTE. The following output is from my nRF9160DK without SIM.
    2022-07-06T08:35:18.494Z DEBUG modem << *** Booting Zephyr OS build v3.0.99-ncs1  ***
    2022-07-06T08:35:18.513Z DEBUG modem << [00:00:00.547,119] [0m<inf> gnss_sample: Starting GNSS sample[0m
    2022-07-06T08:35:19.477Z DEBUG modem << [1;1H[2JTracking:  0 Using:  0 Unhealthy: 0
    2022-07-06T08:35:19.496Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:19.497Z DEBUG modem << Seconds since last fix: 0
    2022-07-06T08:35:19.499Z DEBUG modem << Searching [|]
    2022-07-06T08:35:19.500Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:19.501Z DEBUG modem << $GPGGA,000001.00,,,,,0,,99.99,,M,,M,,*67
    2022-07-06T08:35:19.502Z DEBUG modem << $GPGLL,,,,,000001.00,V,N*4B
    2022-07-06T08:35:19.521Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:19.523Z DEBUG modem << $GPGSV,1,1,0,,,,,,,,,,,,,,,,,1*54
    2022-07-06T08:35:19.525Z DEBUG modem << $GPRMC,000001.00,V,,,,,,,060180,,,N,V*09
    2022-07-06T08:35:20.477Z DEBUG modem << [1;1H[2JTracking:  3 Using:  0 Unhealthy: 0
    2022-07-06T08:35:20.496Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:20.497Z DEBUG modem << Seconds since last fix: 1
    2022-07-06T08:35:20.500Z DEBUG modem << Searching [/]
    2022-07-06T08:35:20.501Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:20.503Z DEBUG modem << $GPGGA,000002.00,,,,,0,,99.99,,M,,M,,*64
    2022-07-06T08:35:20.505Z DEBUG modem << $GPGLL,,,,,000002.00,V,N*48
    2022-07-06T08:35:20.525Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:20.526Z DEBUG modem << $GPGSV,1,1,3,7,,,43,26,,,44,27,,,49,1*6B
    2022-07-06T08:35:20.528Z DEBUG modem << $GPRMC,000002.00,V,,,,,,,060180,,,N,V*0A
    2022-07-06T08:35:21.477Z DEBUG modem << [1;1H[2JTracking:  3 Using:  0 Unhealthy: 0
    2022-07-06T08:35:21.497Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:21.498Z DEBUG modem << Seconds since last fix: 2
    2022-07-06T08:35:21.500Z DEBUG modem << Searching [-]
    2022-07-06T08:35:21.501Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:21.501Z DEBUG modem << $GPGGA,000003.00,,,,,0,,99.99,,M,,M,,*65
    2022-07-06T08:35:21.502Z DEBUG modem << $GPGLL,,,,,000003.00,V,N*49
    2022-07-06T08:35:21.520Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:21.523Z DEBUG modem << $GPGSV,1,1,3,7,,,43,26,,,44,27,,,49,1*6B
    2022-07-06T08:35:21.525Z DEBUG modem << $GPRMC,000003.00,V,,,,,,,060180,,,N,V*0B
    2022-07-06T08:35:22.477Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:22.498Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:22.500Z DEBUG modem << Seconds since last fix: 3
    2022-07-06T08:35:22.503Z DEBUG modem << Searching [\]
    2022-07-06T08:35:22.505Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:22.508Z DEBUG modem << $GPGGA,000004.00,,,,,0,,99.99,,M,,M,,*62
    2022-07-06T08:35:22.510Z DEBUG modem << $GPGLL,,,,,000004.00,V,N*4E
    2022-07-06T08:35:22.511Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:22.531Z DEBUG modem << $GPGSV,1,1,4,7,,,40,16,,,38,26,,,44,27,,,48,1*62
    2022-07-06T08:35:22.533Z DEBUG modem << $GPRMC,000004.00,V,,,,,,,060180,,,N,V*0C
    2022-07-06T08:35:23.477Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:23.498Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:23.500Z DEBUG modem << Seconds since last fix: 4
    2022-07-06T08:35:23.503Z DEBUG modem << Searching [|]
    2022-07-06T08:35:23.506Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:23.507Z DEBUG modem << $GPGGA,000005.00,,,,,0,,99.99,,M,,M,,*63
    2022-07-06T08:35:23.508Z DEBUG modem << $GPGLL,,,,,000005.00,V,N*4F
    2022-07-06T08:35:23.529Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:23.531Z DEBUG modem << $GPGSV,1,1,4,7,,,37,16,,,29,26,,,43,27,,,46,1*6B
    2022-07-06T08:35:23.532Z DEBUG modem << $GPRMC,000005.00,V,,,,,,,060180,,,N,V*0D
    2022-07-06T08:35:24.477Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:24.497Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:24.499Z DEBUG modem << Seconds since last fix: 5
    2022-07-06T08:35:24.500Z DEBUG modem << Searching [/]
    2022-07-06T08:35:24.502Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:24.504Z DEBUG modem << $GPGGA,000006.00,,,,,0,,99.99,,M,,M,,*60
    2022-07-06T08:35:24.506Z DEBUG modem << $GPGLL,,,,,000006.00,V,N*4C
    2022-07-06T08:35:24.525Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:24.527Z DEBUG modem << $GPGSV,1,1,4,7,,,39,16,,,17,26,,,43,27,,,43,1*6D
    2022-07-06T08:35:24.530Z DEBUG modem << $GPRMC,000006.00,V,,,,,,,060180,,,N,V*0E
    2022-07-06T08:35:25.477Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:25.497Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:25.499Z DEBUG modem << Seconds since last fix: 6
    2022-07-06T08:35:25.500Z DEBUG modem << Searching [-]
    2022-07-06T08:35:25.501Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:25.503Z DEBUG modem << $GPGGA,000007.00,,,,,0,,99.99,,M,,M,,*61
    2022-07-06T08:35:25.505Z DEBUG modem << $GPGLL,,,,,000007.00,V,N*4D
    2022-07-06T08:35:25.524Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:25.526Z DEBUG modem << $GPGSV,1,1,4,7,,,38,16,,,04,26,,,40,27,,,44,1*6A
    2022-07-06T08:35:25.528Z DEBUG modem << $GPRMC,000007.00,V,,,,,,,060180,,,N,V*0F
    2022-07-06T08:35:26.477Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:26.496Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:26.498Z DEBUG modem << Seconds since last fix: 7
    2022-07-06T08:35:26.500Z DEBUG modem << Searching [\]
    2022-07-06T08:35:26.502Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:26.504Z DEBUG modem << $GPGGA,000008.00,,,,,0,,99.99,,M,,M,,*6E
    2022-07-06T08:35:26.505Z DEBUG modem << $GPGLL,,,,,000008.00,V,N*42
    2022-07-06T08:35:26.524Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:26.526Z DEBUG modem << $GPGSV,1,1,4,7,,,37,16,,,00,26,,,36,27,,,45,1*61
    2022-07-06T08:35:26.527Z DEBUG modem << $GPRMC,000008.00,V,,,,,,,060180,,,N,V*00
    2022-07-06T08:35:27.478Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:27.498Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:27.500Z DEBUG modem << Seconds since last fix: 8
    2022-07-06T08:35:27.501Z DEBUG modem << Searching [|]
    2022-07-06T08:35:27.503Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:27.504Z DEBUG modem << $GPGGA,000009.00,,,,,0,,99.99,,M,,M,,*6F
    2022-07-06T08:35:27.506Z DEBUG modem << $GPGLL,,,,,000009.00,V,N*43
    2022-07-06T08:35:27.526Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:27.528Z DEBUG modem << $GPGSV,1,1,4,7,,,37,16,,,00,26,,,34,27,,,46,1*60
    2022-07-06T08:35:27.531Z DEBUG modem << $GPRMC,000009.00,V,,,,,,,060180,,,N,V*01
    2022-07-06T08:35:28.479Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:28.498Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:28.500Z DEBUG modem << Seconds since last fix: 9
    2022-07-06T08:35:28.502Z DEBUG modem << Searching [/]
    2022-07-06T08:35:28.503Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:28.505Z DEBUG modem << $GPGGA,000010.00,,,,,0,,99.99,,M,,M,,*67
    2022-07-06T08:35:28.506Z DEBUG modem << $GPGLL,,,,,000010.00,V,N*4B
    2022-07-06T08:35:28.527Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:28.529Z DEBUG modem << $GPGSV,1,1,4,7,,,37,23,,,36,26,,,33,27,,,47,1*65
    2022-07-06T08:35:28.531Z DEBUG modem << $GPRMC,000010.00,V,,,,,,,060180,,,N,V*09
    2022-07-06T08:35:29.478Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:29.498Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:29.501Z DEBUG modem << Seconds since last fix: 10
    2022-07-06T08:35:29.502Z DEBUG modem << Searching [-]
    2022-07-06T08:35:29.504Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:29.505Z DEBUG modem << $GPGGA,000011.00,,,,,0,,99.99,,M,,M,,*66
    2022-07-06T08:35:29.507Z DEBUG modem << $GPGLL,,,,,000011.00,V,N*4A
    2022-07-06T08:35:29.508Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:29.527Z DEBUG modem << $GPGSV,1,1,4,7,,,36,23,,,37,26,,,34,27,,,47,1*62
    2022-07-06T08:35:29.529Z DEBUG modem << $GPRMC,000011.00,V,,,,,,,060180,,,N,V*08
    2022-07-06T08:35:30.478Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:30.499Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:30.501Z DEBUG modem << Seconds since last fix: 11
    2022-07-06T08:35:30.503Z DEBUG modem << Searching [\]
    2022-07-06T08:35:30.505Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:30.507Z DEBUG modem << $GPGGA,000012.00,,,,,0,,99.99,,M,,M,,*65
    2022-07-06T08:35:30.508Z DEBUG modem << $GPGLL,,,,,000012.00,V,N*49
    2022-07-06T08:35:30.528Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:30.530Z DEBUG modem << $GPGSV,1,1,4,7,,,37,23,,,36,26,,,36,27,,,47,1*60
    2022-07-06T08:35:30.531Z DEBUG modem << $GPRMC,000012.00,V,,,,,,,060180,,,N,V*0B
    2022-07-06T08:35:31.479Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:31.499Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:31.501Z DEBUG modem << Seconds since last fix: 12
    2022-07-06T08:35:31.503Z DEBUG modem << Searching [|]
    2022-07-06T08:35:31.505Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:31.506Z DEBUG modem << $GPGGA,000013.00,,,,,0,,99.99,,M,,M,,*64
    2022-07-06T08:35:31.508Z DEBUG modem << $GPGLL,,,,,000013.00,V,N*48
    2022-07-06T08:35:31.527Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:31.530Z DEBUG modem << $GPGSV,1,1,4,7,,,37,23,,,36,26,,,38,27,,,47,1*6E
    2022-07-06T08:35:31.533Z DEBUG modem << $GPRMC,000013.00,V,,,,,,,060180,,,N,V*0A
    2022-07-06T08:35:32.493Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:32.513Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:32.515Z DEBUG modem << Seconds since last fix: 13
    2022-07-06T08:35:32.516Z DEBUG modem << Searching [/]
    2022-07-06T08:35:32.518Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:32.519Z DEBUG modem << $GPGGA,000014.00,,,,,0,,99.99,,M,,M,,*63
    2022-07-06T08:35:32.521Z DEBUG modem << $GPGLL,,,,,000014.00,V,N*4F
    2022-07-06T08:35:32.542Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:32.544Z DEBUG modem << $GPGSV,1,1,4,7,,,38,23,,,37,26,,,39,27,,,47,1*61
    2022-07-06T08:35:32.547Z DEBUG modem << $GPRMC,000014.00,V,,,,,,,060180,,,N,V*0D
    2022-07-06T08:35:33.493Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:33.517Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:33.520Z DEBUG modem << Seconds since last fix: 14
    2022-07-06T08:35:33.522Z DEBUG modem << Searching [-]
    2022-07-06T08:35:33.524Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:33.525Z DEBUG modem << $GPGGA,000015.00,,,,,0,,99.99,,M,,M,,*62
    2022-07-06T08:35:33.526Z DEBUG modem << $GPGLL,,,,,000015.00,V,N*4E
    2022-07-06T08:35:33.547Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:33.548Z DEBUG modem << $GPGSV,1,1,4,7,,,38,23,,,36,26,,,40,27,,,47,1*6E
    2022-07-06T08:35:33.551Z DEBUG modem << $GPRMC,000015.00,V,,,,,,,060180,,,N,V*0C
    2022-07-06T08:35:34.493Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:34.514Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:34.515Z DEBUG modem << Seconds since last fix: 15
    2022-07-06T08:35:34.517Z DEBUG modem << Searching [\]
    2022-07-06T08:35:34.519Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:34.521Z DEBUG modem << $GPGGA,000016.00,,,,,0,,99.99,,M,,M,,*61
    2022-07-06T08:35:34.522Z DEBUG modem << $GPGLL,,,,,000016.00,V,N*4D
    2022-07-06T08:35:34.541Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:34.543Z DEBUG modem << $GPGSV,1,1,4,7,,,39,23,,,36,26,,,40,27,,,47,1*6F
    2022-07-06T08:35:34.546Z DEBUG modem << $GPRMC,000016.00,V,,,,,,,060180,,,N,V*0F
    2022-07-06T08:35:35.493Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:35.513Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:35.515Z DEBUG modem << Seconds since last fix: 16
    2022-07-06T08:35:35.516Z DEBUG modem << Searching [|]
    2022-07-06T08:35:35.517Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:35.519Z DEBUG modem << $GPGGA,000017.00,,,,,0,,99.99,,M,,M,,*60
    2022-07-06T08:35:35.520Z DEBUG modem << $GPGLL,,,,,000017.00,V,N*4C
    2022-07-06T08:35:35.541Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:35.542Z DEBUG modem << $GPGSV,1,1,4,7,,,39,23,,,35,26,,,39,27,,,47,1*62
    2022-07-06T08:35:35.544Z DEBUG modem << $GPRMC,000017.00,V,,,,,,,060180,,,N,V*0E
    2022-07-06T08:35:36.493Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:36.513Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:36.515Z DEBUG modem << Seconds since last fix: 17
    2022-07-06T08:35:36.517Z DEBUG modem << Searching [/]
    2022-07-06T08:35:36.519Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:36.521Z DEBUG modem << $GPGGA,000018.00,,,,,0,,99.99,,M,,M,,*6F
    2022-07-06T08:35:36.522Z DEBUG modem << $GPGLL,,,,,000018.00,V,N*43
    2022-07-06T08:35:36.542Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:36.544Z DEBUG modem << $GPGSV,1,1,4,7,,,38,23,,,34,26,,,40,27,,,47,1*6C
    2022-07-06T08:35:36.545Z DEBUG modem << $GPRMC,000018.00,V,,,,,,,060180,,,N,V*01
    2022-07-06T08:35:37.494Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:37.515Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:37.517Z DEBUG modem << Seconds since last fix: 18
    2022-07-06T08:35:37.519Z DEBUG modem << Searching [-]
    2022-07-06T08:35:37.522Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:37.523Z DEBUG modem << $GPGGA,000019.00,,,,,0,,99.99,,M,,M,,*6E
    2022-07-06T08:35:37.524Z DEBUG modem << $GPGLL,,,,,000019.00,V,N*42
    2022-07-06T08:35:37.526Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:37.551Z DEBUG modem << $GPGSV,1,1,4,7,,,38,23,,,33,26,,,40,27,,,44,1*68
    2022-07-06T08:35:37.554Z DEBUG modem << $GPRMC,000019.00,V,,,,,,,060180,,,N,V*00
    2022-07-06T08:35:38.493Z DEBUG modem << [1;1H[2JTracking:  4 Using:  0 Unhealthy: 0
    2022-07-06T08:35:38.515Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:38.518Z DEBUG modem << Seconds since last fix: 19
    2022-07-06T08:35:38.520Z DEBUG modem << Searching [\]
    2022-07-06T08:35:38.522Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:38.524Z DEBUG modem << $GPGGA,000020.00,,,,,0,,99.99,,M,,M,,*64
    2022-07-06T08:35:38.524Z DEBUG modem << $GPGLL,,,,,000020.00,V,N*48
    2022-07-06T08:35:38.525Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:38.546Z DEBUG modem << $GPGSV,1,1,4,7,,,34,23,,,30,26,,,36,27,,,42,1*60
    2022-07-06T08:35:38.548Z DEBUG modem << $GPRMC,000020.00,V,,,,,,,060180,,,N,V*0A
    2022-07-06T08:35:39.495Z DEBUG modem << [1;1H[2JTracking:  6 Using:  0 Unhealthy: 0
    2022-07-06T08:35:39.516Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:39.519Z DEBUG modem << Seconds since last fix: 20
    2022-07-06T08:35:39.521Z DEBUG modem << Searching [|]
    2022-07-06T08:35:39.524Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:39.525Z DEBUG modem << $GPGGA,000021.00,,,,,0,,99.99,,M,,M,,*65
    2022-07-06T08:35:39.526Z DEBUG modem << $GPGLL,,,,,000021.00,V,N*49
    2022-07-06T08:35:39.547Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:39.549Z DEBUG modem << $GPGSV,2,1,6,3,,,27,4,,,27,7,,,31,23,,,31,1*60
    2022-07-06T08:35:39.551Z DEBUG modem << $GPGSV,2,2,6,26,,,35,27,,,41,1*50
    2022-07-06T08:35:39.572Z DEBUG modem << $GPRMC,000021.00,V,,,,,,,060180,,,N,V*0B
    2022-07-06T08:35:40.495Z DEBUG modem << [1;1H[2JTracking:  7 Using:  0 Unhealthy: 0
    2022-07-06T08:35:40.515Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:40.518Z DEBUG modem << Seconds since last fix: 21
    2022-07-06T08:35:40.519Z DEBUG modem << Searching [/]
    2022-07-06T08:35:40.521Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:40.523Z DEBUG modem << $GPGGA,000022.00,,,,,0,,99.99,,M,,M,,*66
    2022-07-06T08:35:40.524Z DEBUG modem << $GPGLL,,,,,000022.00,V,N*4A
    2022-07-06T08:35:40.544Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:40.546Z DEBUG modem << $GPGSV,2,1,7,3,,,25,4,,,25,7,,,30,16,,,40,1*60
    2022-07-06T08:35:40.549Z DEBUG modem << $GPGSV,2,2,7,23,,,32,26,,,37,27,,,41,1*53
    2022-07-06T08:35:40.551Z DEBUG modem << $GPRMC,000022.00,V,,,,,,,060180,,,N,V*08
    2022-07-06T08:35:41.496Z DEBUG modem << [1;1H[2JTracking:  8 Using:  0 Unhealthy: 0
    2022-07-06T08:35:41.518Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:41.519Z DEBUG modem << Seconds since last fix: 22
    2022-07-06T08:35:41.521Z DEBUG modem << Searching [-]
    2022-07-06T08:35:41.522Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:41.524Z DEBUG modem << $GPGGA,000023.00,,,,,0,,99.99,,M,,M,,*67
    2022-07-06T08:35:41.525Z DEBUG modem << $GPGLL,,,,,000023.00,V,N*4B
    2022-07-06T08:35:41.545Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:41.548Z DEBUG modem << $GPGSV,2,1,8,3,,,25,4,,,25,7,,,29,8,,,27,1*59
    2022-07-06T08:35:41.551Z DEBUG modem << $GPGSV,2,2,8,16,,,37,23,,,31,26,,,39,27,,,41,1*52
    2022-07-06T08:35:41.552Z DEBUG modem << $GPRMC,000023.00,V,,,,,,,060180,,,N,V*09
    2022-07-06T08:35:42.496Z DEBUG modem << [1;1H[2JTracking:  8 Using:  0 Unhealthy: 0
    2022-07-06T08:35:42.516Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:42.518Z DEBUG modem << Seconds since last fix: 23
    2022-07-06T08:35:42.520Z DEBUG modem << Searching [\]
    2022-07-06T08:35:42.522Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:42.524Z DEBUG modem << $GPGGA,000024.00,,,,,0,,99.99,,M,,M,,*60
    2022-07-06T08:35:42.526Z DEBUG modem << $GPGLL,,,,,000024.00,V,N*4C
    2022-07-06T08:35:42.552Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:42.553Z DEBUG modem << $GPGSV,2,1,8,3,,,25,4,,,24,7,,,29,8,,,25,1*5A
    2022-07-06T08:35:42.556Z DEBUG modem << $GPGSV,2,2,8,16,,,38,23,,,31,26,,,40,27,,,42,1*50
    2022-07-06T08:35:42.578Z DEBUG modem << $GPRMC,000024.00,V,,,,,,,060180,,,N,V*0E
    2022-07-06T08:35:43.494Z DEBUG modem << [1;1H[2JTracking:  6 Using:  0 Unhealthy: 0
    2022-07-06T08:35:43.516Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:43.517Z DEBUG modem << Seconds since last fix: 24
    2022-07-06T08:35:43.519Z DEBUG modem << Searching [|]
    2022-07-06T08:35:43.522Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:43.523Z DEBUG modem << $GPGGA,000025.00,,,,,0,,99.99,,M,,M,,*61
    2022-07-06T08:35:43.525Z DEBUG modem << $GPGLL,,,,,000025.00,V,N*4D
    2022-07-06T08:35:43.546Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:43.548Z DEBUG modem << $GPGSV,2,1,6,7,,,28,8,,,25,16,,,39,23,,,31,1*5D
    2022-07-06T08:35:43.550Z DEBUG modem << $GPGSV,2,2,6,26,,,39,27,,,43,1*5E
    2022-07-06T08:35:43.573Z DEBUG modem << $GPRMC,000025.00,V,,,,,,,060180,,,N,V*0F
    2022-07-06T08:35:44.505Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:44.526Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:44.529Z DEBUG modem << Seconds since last fix: 25
    2022-07-06T08:35:44.531Z DEBUG modem << Searching [/]
    2022-07-06T08:35:44.533Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:44.534Z DEBUG modem << $GPGGA,083530.46,,,,,0,01,99.99,,M,,M,,*68
    2022-07-06T08:35:44.535Z DEBUG modem << $GPGLL,,,,,083530.46,V,N*45
    2022-07-06T08:35:44.556Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:44.558Z DEBUG modem << $GPGSV,2,1,6,7,,,24,8,,,24,16,,,39,23,,,32,1*53
    2022-07-06T08:35:44.561Z DEBUG modem << $GPGSV,2,2,6,26,,,39,27,,,45,1*58
    2022-07-06T08:35:44.582Z DEBUG modem << $GPRMC,083530.46,V,,,,,,,060722,,,N,V*09
    2022-07-06T08:35:45.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:45.520Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:45.522Z DEBUG modem << Seconds since last fix: 26
    2022-07-06T08:35:45.524Z DEBUG modem << Searching [-]
    2022-07-06T08:35:45.525Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:45.526Z DEBUG modem << $GPGGA,083531.46,,,,,0,01,99.99,,M,,M,,*69
    2022-07-06T08:35:45.527Z DEBUG modem << $GPGLL,,,,,083531.46,V,N*44
    2022-07-06T08:35:45.528Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:45.548Z DEBUG modem << $GPGSV,2,1,6,7,,,25,16,,,39,19,,,26,23,,,31,1*63
    2022-07-06T08:35:45.550Z DEBUG modem << $GPGSV,2,2,6,26,,,40,27,,,45,1*56
    2022-07-06T08:35:45.552Z DEBUG modem << $GPRMC,083531.46,V,,,,,,,060722,,,N,V*08
    2022-07-06T08:35:46.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:46.521Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:46.544Z DEBUG modem << Seconds since last fix: 27
    2022-07-06T08:35:46.546Z DEBUG modem << Searching [\]
    2022-07-06T08:35:46.548Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:46.550Z DEBUG modem << $GPGGA,083532.46,,,,,0,01,99.99,,M,,M,,*6A
    2022-07-06T08:35:46.551Z DEBUG modem << $GPGLL,,,,,083532.46,V,N*47
    2022-07-06T08:35:46.552Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:46.553Z DEBUG modem << $GPGSV,2,1,6,7,,,26,16,,,39,19,,,26,23,,,31,1*60
    2022-07-06T08:35:46.554Z DEBUG modem << $GPGSV,2,2,6,26,,,40,27,,,45,1*56
    2022-07-06T08:35:46.555Z DEBUG modem << $GPRMC,083532.46,V,,,,,,,060722,,,N,V*0B
    2022-07-06T08:35:47.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:47.520Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:47.521Z DEBUG modem << Seconds since last fix: 28
    2022-07-06T08:35:47.524Z DEBUG modem << Searching [|]
    2022-07-06T08:35:47.525Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:47.527Z DEBUG modem << $GPGGA,083533.46,,,,,0,01,99.99,,M,,M,,*6B
    2022-07-06T08:35:47.528Z DEBUG modem << $GPGLL,,,,,083533.46,V,N*46
    2022-07-06T08:35:47.529Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:47.550Z DEBUG modem << $GPGSV,2,1,6,7,,,27,16,,,39,19,,,25,23,,,31,1*62
    2022-07-06T08:35:47.551Z DEBUG modem << $GPGSV,2,2,6,26,,,40,27,,,46,1*55
    2022-07-06T08:35:47.554Z DEBUG modem << $GPRMC,083533.46,V,,,,,,,060722,,,N,V*0A
    2022-07-06T08:35:48.497Z DEBUG modem << [1;1H[2JTracking:  7 Using:  1 Unhealthy: 0
    2022-07-06T08:35:48.519Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:48.521Z DEBUG modem << Seconds since last fix: 29
    2022-07-06T08:35:48.523Z DEBUG modem << Searching [/]
    2022-07-06T08:35:48.525Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:48.527Z DEBUG modem << $GPGGA,083534.46,,,,,0,01,99.99,,M,,M,,*6C
    2022-07-06T08:35:48.528Z DEBUG modem << $GPGLL,,,,,083534.46,V,N*41
    2022-07-06T08:35:48.550Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:48.552Z DEBUG modem << $GPGSV,2,1,7,7,,,27,16,,,38,19,,,24,23,,,31,1*63
    2022-07-06T08:35:48.554Z DEBUG modem << $GPGSV,2,2,7,26,,,40,27,,,46,32,,,27,1*50
    2022-07-06T08:35:48.576Z DEBUG modem << $GPRMC,083534.46,V,,,,,,,060722,,,N,V*0D
    2022-07-06T08:35:49.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:49.521Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:49.523Z DEBUG modem << Seconds since last fix: 30
    2022-07-06T08:35:49.525Z DEBUG modem << Searching [-]
    2022-07-06T08:35:49.527Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:49.528Z DEBUG modem << $GPGGA,083535.46,,,,,0,01,99.99,,M,,M,,*6D
    2022-07-06T08:35:49.528Z DEBUG modem << $GPGLL,,,,,083535.46,V,N*40
    2022-07-06T08:35:49.529Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:49.555Z DEBUG modem << $GPGSV,2,1,6,7,,,27,16,,,38,23,,,31,26,,,40,1*6C
    2022-07-06T08:35:49.558Z DEBUG modem << $GPGSV,2,2,6,27,,,46,32,,,25,1*53
    2022-07-06T08:35:49.561Z DEBUG modem << $GPRMC,083535.46,V,,,,,,,060722,,,N,V*0C
    2022-07-06T08:35:50.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:50.520Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:50.521Z DEBUG modem << Seconds since last fix: 31
    2022-07-06T08:35:50.525Z DEBUG modem << Searching [\]
    2022-07-06T08:35:50.527Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:50.528Z DEBUG modem << $GPGGA,083536.46,,,,,0,01,99.99,,M,,M,,*6E
    2022-07-06T08:35:50.528Z DEBUG modem << $GPGLL,,,,,083536.46,V,N*43
    2022-07-06T08:35:50.529Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:50.550Z DEBUG modem << $GPGSV,2,1,6,7,,,27,16,,,38,23,,,31,26,,,40,1*6C
    2022-07-06T08:35:50.551Z DEBUG modem << $GPGSV,2,2,6,27,,,46,32,,,25,1*53
    2022-07-06T08:35:50.554Z DEBUG modem << $GPRMC,083536.46,V,,,,,,,060722,,,N,V*0F
    2022-07-06T08:35:51.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:51.519Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:51.522Z DEBUG modem << Seconds since last fix: 32
    2022-07-06T08:35:51.524Z DEBUG modem << Searching [|]
    2022-07-06T08:35:51.526Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:51.527Z DEBUG modem << $GPGGA,083537.46,,,,,0,01,99.99,,M,,M,,*6F
    2022-07-06T08:35:51.529Z DEBUG modem << $GPGLL,,,,,083537.46,V,N*42
    2022-07-06T08:35:51.530Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:51.552Z DEBUG modem << $GPGSV,2,1,6,7,,,26,16,,,39,23,,,31,26,,,40,1*6C
    2022-07-06T08:35:51.554Z DEBUG modem << $GPGSV,2,2,6,27,,,45,32,,,24,1*51
    2022-07-06T08:35:51.578Z DEBUG modem << $GPRMC,083537.46,V,,,,,,,060722,,,N,V*0E
    2022-07-06T08:35:52.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:52.519Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:52.522Z DEBUG modem << Seconds since last fix: 33
    2022-07-06T08:35:52.525Z DEBUG modem << Searching [/]
    2022-07-06T08:35:52.527Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:52.528Z DEBUG modem << $GPGGA,083538.46,,,,,0,01,99.99,,M,,M,,*60
    2022-07-06T08:35:52.529Z DEBUG modem << $GPGLL,,,,,083538.46,V,N*4D
    2022-07-06T08:35:52.530Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:52.551Z DEBUG modem << $GPGSV,2,1,6,1,,,26,7,,,24,16,,,39,23,,,31,1*5B
    2022-07-06T08:35:52.553Z DEBUG modem << $GPGSV,2,2,6,26,,,40,27,,,46,1*55
    2022-07-06T08:35:52.578Z DEBUG modem << $GPRMC,083538.46,V,,,,,,,060722,,,N,V*01
    2022-07-06T08:35:53.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:53.519Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:53.521Z DEBUG modem << Seconds since last fix: 34
    2022-07-06T08:35:53.525Z DEBUG modem << Searching [-]
    2022-07-06T08:35:53.528Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:53.529Z DEBUG modem << $GPGGA,083539.46,,,,,0,01,99.99,,M,,M,,*61
    2022-07-06T08:35:53.531Z DEBUG modem << $GPGLL,,,,,083539.46,V,N*4C
    2022-07-06T08:35:53.532Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:53.554Z DEBUG modem << $GPGSV,2,1,6,1,,,26,7,,,26,16,,,40,23,,,31,1*57
    2022-07-06T08:35:53.556Z DEBUG modem << $GPGSV,2,2,6,26,,,40,27,,,46,1*55
    2022-07-06T08:35:53.558Z DEBUG modem << $GPRMC,083539.46,V,,,,,,,060722,,,N,V*00
    2022-07-06T08:35:54.496Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:54.520Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:54.522Z DEBUG modem << Seconds since last fix: 35
    2022-07-06T08:35:54.524Z DEBUG modem << Searching [\]
    2022-07-06T08:35:54.526Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:54.527Z DEBUG modem << $GPGGA,083540.46,,,,,0,01,99.99,,M,,M,,*6F
    2022-07-06T08:35:54.528Z DEBUG modem << $GPGLL,,,,,083540.46,V,N*42
    2022-07-06T08:35:54.529Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:54.551Z DEBUG modem << $GPGSV,2,1,6,7,,,26,11,,,25,16,,,40,23,,,31,1*65
    2022-07-06T08:35:54.553Z DEBUG modem << $GPGSV,2,2,6,26,,,40,27,,,46,1*55
    2022-07-06T08:35:54.576Z DEBUG modem << $GPRMC,083540.46,V,,,,,,,060722,,,N,V*0E
    2022-07-06T08:35:55.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:55.520Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:55.522Z DEBUG modem << Seconds since last fix: 36
    2022-07-06T08:35:55.524Z DEBUG modem << Searching [|]
    2022-07-06T08:35:55.525Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:55.527Z DEBUG modem << $GPGGA,083541.46,,,,,0,01,99.99,,M,,M,,*6E
    2022-07-06T08:35:55.528Z DEBUG modem << $GPGLL,,,,,083541.46,V,N*43
    2022-07-06T08:35:55.528Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:55.549Z DEBUG modem << $GPGSV,2,1,6,7,,,26,11,,,24,16,,,40,23,,,31,1*64
    2022-07-06T08:35:55.551Z DEBUG modem << $GPGSV,2,2,6,26,,,40,27,,,46,1*55
    2022-07-06T08:35:55.554Z DEBUG modem << $GPRMC,083541.46,V,,,,,,,060722,,,N,V*0F
    2022-07-06T08:35:56.496Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:56.520Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:56.522Z DEBUG modem << Seconds since last fix: 37
    2022-07-06T08:35:56.525Z DEBUG modem << Searching [/]
    2022-07-06T08:35:56.527Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:56.528Z DEBUG modem << $GPGGA,083542.46,,,,,0,01,99.99,,M,,M,,*6D
    2022-07-06T08:35:56.528Z DEBUG modem << $GPGLL,,,,,083542.46,V,N*40
    2022-07-06T08:35:56.529Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:56.550Z DEBUG modem << $GPGSV,2,1,6,7,,,26,11,,,25,16,,,41,23,,,31,1*64
    2022-07-06T08:35:56.552Z DEBUG modem << $GPGSV,2,2,6,26,,,39,27,,,46,1*5B
    2022-07-06T08:35:56.554Z DEBUG modem << $GPRMC,083542.46,V,,,,,,,060722,,,N,V*0C
    2022-07-06T08:35:57.498Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:35:57.521Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:57.524Z DEBUG modem << Seconds since last fix: 38
    2022-07-06T08:35:57.526Z DEBUG modem << Searching [-]
    2022-07-06T08:35:57.527Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:57.528Z DEBUG modem << $GPGGA,083543.46,,,,,0,01,99.99,,M,,M,,*6C
    2022-07-06T08:35:57.529Z DEBUG modem << $GPGLL,,,,,083543.46,V,N*41
    2022-07-06T08:35:57.530Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:57.552Z DEBUG modem << $GPGSV,2,1,6,7,,,25,11,,,24,16,,,41,23,,,31,1*66
    2022-07-06T08:35:57.554Z DEBUG modem << $GPGSV,2,2,6,26,,,40,27,,,46,1*55
    2022-07-06T08:35:57.557Z DEBUG modem << $GPRMC,083543.46,V,,,,,,,060722,,,N,V*0D
    2022-07-06T08:35:58.497Z DEBUG modem << [1;1H[2JTracking:  5 Using:  1 Unhealthy: 0
    2022-07-06T08:35:58.521Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:58.524Z DEBUG modem << Seconds since last fix: 39
    2022-07-06T08:35:58.526Z DEBUG modem << Searching [\]
    2022-07-06T08:35:58.528Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:58.529Z DEBUG modem << $GPGGA,083544.46,,,,,0,01,99.99,,M,,M,,*6B
    2022-07-06T08:35:58.529Z DEBUG modem << $GPGLL,,,,,083544.46,V,N*46
    2022-07-06T08:35:58.530Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:58.551Z DEBUG modem << $GPGSV,2,1,5,7,,,24,16,,,41,23,,,31,26,,,40,1*62
    2022-07-06T08:35:58.553Z DEBUG modem << $GPGSV,2,2,5,27,,,46,1*56
    2022-07-06T08:35:58.556Z DEBUG modem << $GPRMC,083544.46,V,,,,,,,060722,,,N,V*0A
    2022-07-06T08:35:59.497Z DEBUG modem << [1;1H[2JTracking:  7 Using:  1 Unhealthy: 0
    2022-07-06T08:35:59.520Z DEBUG modem << -----------------------------------
    2022-07-06T08:35:59.523Z DEBUG modem << Seconds since last fix: 40
    2022-07-06T08:35:59.525Z DEBUG modem << Searching [|]
    2022-07-06T08:35:59.527Z DEBUG modem << NMEA strings:
    2022-07-06T08:35:59.528Z DEBUG modem << $GPGGA,083545.46,,,,,0,01,99.99,,M,,M,,*6A
    2022-07-06T08:35:59.529Z DEBUG modem << $GPGLL,,,,,083545.46,V,N*47
    2022-07-06T08:35:59.530Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:35:59.552Z DEBUG modem << $GPGSV,2,1,7,7,,,24,8,,,26,16,,,41,23,,,31,1*5C
    2022-07-06T08:35:59.554Z DEBUG modem << $GPGSV,2,2,7,26,,,39,27,,,46,30,,,25,1*5E
    2022-07-06T08:35:59.578Z DEBUG modem << $GPRMC,083545.46,V,,,,,,,060722,,,N,V*0B
    2022-07-06T08:36:00.499Z DEBUG modem << [1;1H[2JTracking:  8 Using:  1 Unhealthy: 0
    2022-07-06T08:36:00.522Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:00.524Z DEBUG modem << Seconds since last fix: 41
    2022-07-06T08:36:00.528Z DEBUG modem << Searching [/]
    2022-07-06T08:36:00.529Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:00.530Z DEBUG modem << $GPGGA,083546.46,,,,,0,01,99.99,,M,,M,,*69
    2022-07-06T08:36:00.531Z DEBUG modem << $GPGLL,,,,,083546.46,V,N*44
    2022-07-06T08:36:00.531Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:00.553Z DEBUG modem << $GPGSV,2,1,8,4,,,29,7,,,24,16,,,41,23,,,31,1*50
    2022-07-06T08:36:00.555Z DEBUG modem << $GPGSV,2,2,8,26,,,39,27,,,46,29,,,26,30,,,25,1*5E
    2022-07-06T08:36:00.580Z DEBUG modem << $GPRMC,083546.46,V,,,,,,,060722,,,N,V*08
    2022-07-06T08:36:01.500Z DEBUG modem << [1;1H[2JTracking:  8 Using:  1 Unhealthy: 0
    2022-07-06T08:36:01.525Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:01.527Z DEBUG modem << Seconds since last fix: 42
    2022-07-06T08:36:01.530Z DEBUG modem << Searching [-]
    2022-07-06T08:36:01.532Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:01.533Z DEBUG modem << $GPGGA,083547.46,,,,,0,01,99.99,,M,,M,,*68
    2022-07-06T08:36:01.534Z DEBUG modem << $GPGLL,,,,,083547.46,V,N*45
    2022-07-06T08:36:01.536Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:01.558Z DEBUG modem << $GPGSV,2,1,8,4,,,25,7,,,25,16,,,41,23,,,31,1*5D
    2022-07-06T08:36:01.560Z DEBUG modem << $GPGSV,2,2,8,26,,,39,27,,,45,29,,,26,30,,,25,1*5D
    2022-07-06T08:36:01.562Z DEBUG modem << $GPRMC,083547.46,V,,,,,,,060722,,,N,V*09
    2022-07-06T08:36:02.498Z DEBUG modem << [1;1H[2JTracking:  7 Using:  1 Unhealthy: 0
    2022-07-06T08:36:02.521Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:02.524Z DEBUG modem << Seconds since last fix: 43
    2022-07-06T08:36:02.527Z DEBUG modem << Searching [\]
    2022-07-06T08:36:02.529Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:02.530Z DEBUG modem << $GPGGA,083548.46,,,,,0,01,99.99,,M,,M,,*67
    2022-07-06T08:36:02.530Z DEBUG modem << $GPGLL,,,,,083548.46,V,N*4A
    2022-07-06T08:36:02.531Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:02.554Z DEBUG modem << $GPGSV,2,1,7,7,,,26,16,,,40,23,,,31,26,,,39,1*6D
    2022-07-06T08:36:02.557Z DEBUG modem << $GPGSV,2,2,7,27,,,45,29,,,26,30,,,25,1*5C
    2022-07-06T08:36:02.583Z DEBUG modem << $GPRMC,083548.46,V,,,,,,,060722,,,N,V*06
    2022-07-06T08:36:03.498Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:36:03.526Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:03.528Z DEBUG modem << Seconds since last fix: 44
    2022-07-06T08:36:03.530Z DEBUG modem << Searching [|]
    2022-07-06T08:36:03.532Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:03.533Z DEBUG modem << $GPGGA,083549.46,,,,,0,01,99.99,,M,,M,,*66
    2022-07-06T08:36:03.534Z DEBUG modem << $GPGLL,,,,,083549.46,V,N*4B
    2022-07-06T08:36:03.534Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:03.534Z DEBUG modem << $GPGSV,2,1,6,7,,,23,16,,,40,23,,,31,26,,,39,1*69
    2022-07-06T08:36:03.536Z DEBUG modem << $GPGSV,2,2,6,27,,,45,29,,,25,1*5A
    2022-07-06T08:36:03.537Z DEBUG modem << $GPRMC,083549.46,V,,,,,,,060722,,,N,V*07
    2022-07-06T08:36:04.496Z DEBUG modem << [1;1H[2JTracking:  5 Using:  1 Unhealthy: 0
    2022-07-06T08:36:04.529Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:04.532Z DEBUG modem << Seconds since last fix: 45
    2022-07-06T08:36:04.535Z DEBUG modem << Searching [/]
    2022-07-06T08:36:04.536Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:04.538Z DEBUG modem << $GPGGA,083550.46,,,,,0,01,99.99,,M,,M,,*6E
    2022-07-06T08:36:04.541Z DEBUG modem << $GPGLL,,,,,083550.46,V,N*43
    2022-07-06T08:36:04.542Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:04.544Z DEBUG modem << $GPGSV,2,1,5,7,,,22,16,,,40,23,,,31,26,,,39,1*6B
    2022-07-06T08:36:04.546Z DEBUG modem << $GPGSV,2,2,5,27,,,45,1*55
    2022-07-06T08:36:04.575Z DEBUG modem << $GPRMC,083550.46,V,,,,,,,060722,,,N,V*0F
    2022-07-06T08:36:05.496Z DEBUG modem << [1;1H[2JTracking:  5 Using:  1 Unhealthy: 0
    2022-07-06T08:36:05.519Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:05.522Z DEBUG modem << Seconds since last fix: 46
    2022-07-06T08:36:05.524Z DEBUG modem << Searching [-]
    2022-07-06T08:36:05.526Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:05.527Z DEBUG modem << $GPGGA,083551.46,,,,,0,01,99.99,,M,,M,,*6F
    2022-07-06T08:36:05.527Z DEBUG modem << $GPGLL,,,,,083551.46,V,N*42
    2022-07-06T08:36:05.528Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:05.550Z DEBUG modem << $GPGSV,2,1,5,7,,,21,16,,,40,23,,,31,26,,,39,1*68
    2022-07-06T08:36:05.552Z DEBUG modem << $GPGSV,2,2,5,27,,,45,1*55
    2022-07-06T08:36:05.554Z DEBUG modem << $GPRMC,083551.46,V,,,,,,,060722,,,N,V*0E
    2022-07-06T08:36:06.498Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:36:06.522Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:06.524Z DEBUG modem << Seconds since last fix: 47
    2022-07-06T08:36:06.526Z DEBUG modem << Searching [\]
    2022-07-06T08:36:06.528Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:06.529Z DEBUG modem << $GPGGA,083552.46,,,,,0,01,99.99,,M,,M,,*6C
    2022-07-06T08:36:06.530Z DEBUG modem << $GPGLL,,,,,083552.46,V,N*41
    2022-07-06T08:36:06.530Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:06.531Z DEBUG modem << $GPGSV,2,1,6,7,,,21,12,,,27,16,,,41,23,,,31,1*62
    2022-07-06T08:36:06.532Z DEBUG modem << $GPGSV,2,2,6,26,,,39,27,,,45,1*58
    2022-07-06T08:36:06.534Z DEBUG modem << $GPRMC,083552.46,V,,,,,,,060722,,,N,V*0D
    2022-07-06T08:36:07.497Z DEBUG modem << [1;1H[2JTracking:  7 Using:  1 Unhealthy: 0
    2022-07-06T08:36:07.523Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:07.525Z DEBUG modem << Seconds since last fix: 48
    2022-07-06T08:36:07.527Z DEBUG modem << Searching [|]
    2022-07-06T08:36:07.529Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:07.530Z DEBUG modem << $GPGGA,083553.46,,,,,0,01,99.99,,M,,M,,*6D
    2022-07-06T08:36:07.531Z DEBUG modem << $GPGLL,,,,,083553.46,V,N*40
    2022-07-06T08:36:07.532Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:07.533Z DEBUG modem << $GPGSV,2,1,7,7,,,24,8,,,26,12,,,25,16,,,39,1*54
    2022-07-06T08:36:07.534Z DEBUG modem << $GPGSV,2,2,7,23,,,30,26,,,39,27,,,45,1*5B
    2022-07-06T08:36:07.535Z DEBUG modem << $GPRMC,083553.46,V,,,,,,,060722,,,N,V*0C
    2022-07-06T08:36:08.497Z DEBUG modem << [1;1H[2JTracking:  8 Using:  0 Unhealthy: 0
    2022-07-06T08:36:08.522Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:08.526Z DEBUG modem << Seconds since last fix: 49
    2022-07-06T08:36:08.528Z DEBUG modem << Searching [/]
    2022-07-06T08:36:08.530Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:08.530Z DEBUG modem << $GPGGA,083554.46,,,,,0,,99.99,,M,,M,,*6B
    2022-07-06T08:36:08.531Z DEBUG modem << $GPGLL,,,,,083554.46,V,N*47
    2022-07-06T08:36:08.531Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:08.533Z DEBUG modem << $GPGSV,2,1,8,7,,,26,8,,,25,12,,,25,16,,,36,1*55
    2022-07-06T08:36:08.534Z DEBUG modem << $GPGSV,2,2,8,21,,,41,23,,,29,26,,,10,27,,,10,1*51
    2022-07-06T08:36:08.535Z DEBUG modem << $GPRMC,083554.46,V,,,,,,,060722,,,N,V*0B
    2022-07-06T08:36:09.496Z DEBUG modem << [1;1H[2JTracking:  8 Using:  0 Unhealthy: 0
    2022-07-06T08:36:09.521Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:09.523Z DEBUG modem << Seconds since last fix: 50
    2022-07-06T08:36:09.525Z DEBUG modem << Searching [-]
    2022-07-06T08:36:09.527Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:09.529Z DEBUG modem << $GPGGA,083555.46,,,,,0,,99.99,,M,,M,,*6A
    2022-07-06T08:36:09.530Z DEBUG modem << $GPGLL,,,,,083555.46,V,N*46
    2022-07-06T08:36:09.530Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:09.532Z DEBUG modem << $GPGSV,2,1,8,7,,,26,8,,,24,12,,,25,16,,,32,1*50
    2022-07-06T08:36:09.534Z DEBUG modem << $GPGSV,2,2,8,21,,,26,23,,,28,26,,,18,27,,,18,1*51
    2022-07-06T08:36:09.535Z DEBUG modem << $GPRMC,083555.46,V,,,,,,,060722,,,N,V*0A
    2022-07-06T08:36:10.498Z DEBUG modem << [1;1H[2JTracking:  8 Using:  0 Unhealthy: 1
    2022-07-06T08:36:10.524Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:10.526Z DEBUG modem << Seconds since last fix: 51
    2022-07-06T08:36:10.528Z DEBUG modem << Searching [\]
    2022-07-06T08:36:10.530Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:10.531Z DEBUG modem << $GPGGA,083556.46,,,,,0,,99.99,,M,,M,,*69
    2022-07-06T08:36:10.532Z DEBUG modem << $GPGLL,,,,,083556.46,V,N*45
    2022-07-06T08:36:10.533Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:10.534Z DEBUG modem << $GPGSV,2,1,8,7,,,26,8,,,25,16,,,33,21,,,25,1*50
    2022-07-06T08:36:10.536Z DEBUG modem << $GPGSV,2,2,8,23,,,25,26,,,21,27,,,22,28,,,27,1*57
    2022-07-06T08:36:10.539Z DEBUG modem << $GPRMC,083556.46,V,,,,,,,060722,,,N,V*09
    2022-07-06T08:36:11.497Z DEBUG modem << [1;1H[2JTracking:  7 Using:  0 Unhealthy: 1
    2022-07-06T08:36:11.523Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:11.525Z DEBUG modem << Seconds since last fix: 52
    2022-07-06T08:36:11.528Z DEBUG modem << Searching [|]
    2022-07-06T08:36:11.529Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:11.530Z DEBUG modem << $GPGGA,083557.46,,,,,0,,99.99,,M,,M,,*68
    2022-07-06T08:36:11.531Z DEBUG modem << $GPGLL,,,,,083557.46,V,N*44
    2022-07-06T08:36:11.532Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:11.534Z DEBUG modem << $GPGSV,2,1,7,7,,,27,16,,,34,21,,,24,23,,,27,1*63
    2022-07-06T08:36:11.535Z DEBUG modem << $GPGSV,2,2,7,26,,,27,27,,,28,28,,,25,1*50
    2022-07-06T08:36:11.536Z DEBUG modem << $GPRMC,083557.46,V,,,,,,,060722,,,N,V*08
    2022-07-06T08:36:12.498Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 1
    2022-07-06T08:36:12.521Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:12.547Z DEBUG modem << Seconds since last fix: 53
    2022-07-06T08:36:12.550Z DEBUG modem << Searching [/]
    2022-07-06T08:36:12.552Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:12.554Z DEBUG modem << $GPGGA,083558.46,,,,,0,01,99.99,,M,,M,,*66
    2022-07-06T08:36:12.555Z DEBUG modem << $GPGLL,,,,,083558.46,V,N*4B
    2022-07-06T08:36:12.556Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:12.558Z DEBUG modem << $GPGSV,2,1,6,7,,,31,16,,,35,23,,,28,26,,,31,1*68
    2022-07-06T08:36:12.581Z DEBUG modem << $GPGSV,2,2,6,27,,,30,28,,,24,1*58
    2022-07-06T08:36:12.585Z DEBUG modem << $GPRMC,083558.46,V,,,,,,,060722,,,N,V*07
    2022-07-06T08:36:13.498Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 1
    2022-07-06T08:36:13.522Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:13.525Z DEBUG modem << Seconds since last fix: 54
    2022-07-06T08:36:13.527Z DEBUG modem << Searching [-]
    2022-07-06T08:36:13.530Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:13.531Z DEBUG modem << $GPGGA,083559.46,,,,,0,01,99.99,,M,,M,,*67
    2022-07-06T08:36:13.531Z DEBUG modem << $GPGLL,,,,,083559.46,V,N*4A
    2022-07-06T08:36:13.532Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:13.533Z DEBUG modem << $GPGSV,2,1,6,7,,,35,16,,,39,23,,,29,26,,,38,1*68
    2022-07-06T08:36:13.534Z DEBUG modem << $GPGSV,2,2,6,27,,,37,28,,,25,1*5E
    2022-07-06T08:36:13.535Z DEBUG modem << $GPRMC,083559.46,V,,,,,,,060722,,,N,V*06
    2022-07-06T08:36:14.498Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:36:14.523Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:14.526Z DEBUG modem << Seconds since last fix: 55
    2022-07-06T08:36:14.528Z DEBUG modem << Searching [\]
    2022-07-06T08:36:14.530Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:14.531Z DEBUG modem << $GPGGA,083600.46,,,,,0,01,99.99,,M,,M,,*68
    2022-07-06T08:36:14.533Z DEBUG modem << $GPGLL,,,,,083600.46,V,N*45
    2022-07-06T08:36:14.534Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:14.536Z DEBUG modem << $GPGSV,2,1,6,7,,,37,16,,,42,23,,,29,26,,,42,1*6B
    2022-07-06T08:36:14.537Z DEBUG modem << $GPGSV,2,2,6,27,,,41,30,,,27,1*54
    2022-07-06T08:36:14.539Z DEBUG modem << $GPRMC,083600.46,V,,,,,,,060722,,,N,V*09
    2022-07-06T08:36:15.498Z DEBUG modem << [1;1H[2JTracking:  7 Using:  1 Unhealthy: 0
    2022-07-06T08:36:15.523Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:15.525Z DEBUG modem << Seconds since last fix: 56
    2022-07-06T08:36:15.527Z DEBUG modem << Searching [|]
    2022-07-06T08:36:15.528Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:15.529Z DEBUG modem << $GPGGA,083601.46,,,,,0,01,99.99,,M,,M,,*69
    2022-07-06T08:36:15.530Z DEBUG modem << $GPGLL,,,,,083601.46,V,N*44
    2022-07-06T08:36:15.531Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:15.532Z DEBUG modem << $GPGSV,2,1,7,7,,,38,10,,,26,16,,,43,23,,,30,1*6B
    2022-07-06T08:36:15.533Z DEBUG modem << $GPGSV,2,2,7,26,,,43,27,,,44,30,,,26,1*52
    2022-07-06T08:36:15.535Z DEBUG modem << $GPRMC,083601.46,V,,,,,,,060722,,,N,V*08
    2022-07-06T08:36:16.499Z DEBUG modem << [1;1H[2JTracking:  8 Using:  1 Unhealthy: 0
    2022-07-06T08:36:16.526Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:16.528Z DEBUG modem << Seconds since last fix: 57
    2022-07-06T08:36:16.530Z DEBUG modem << Searching [/]
    2022-07-06T08:36:16.532Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:16.533Z DEBUG modem << $GPGGA,083602.46,,,,,0,01,99.99,,M,,M,,*6A
    2022-07-06T08:36:16.534Z DEBUG modem << $GPGLL,,,,,083602.46,V,N*47
    2022-07-06T08:36:16.534Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:16.535Z DEBUG modem << $GPGSV,2,1,8,7,,,38,10,,,25,16,,,42,23,,,29,1*6E
    2022-07-06T08:36:16.536Z DEBUG modem << $GPGSV,2,2,8,26,,,41,27,,,42,30,,,24,32,,,26,1*5E
    2022-07-06T08:36:16.537Z DEBUG modem << $GPRMC,083602.46,V,,,,,,,060722,,,N,V*0B
    2022-07-06T08:36:17.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:36:17.521Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:17.525Z DEBUG modem << Seconds since last fix: 58
    2022-07-06T08:36:17.527Z DEBUG modem << Searching [-]
    2022-07-06T08:36:17.528Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:17.529Z DEBUG modem << $GPGGA,083603.46,,,,,0,01,99.99,,M,,M,,*6B
    2022-07-06T08:36:17.529Z DEBUG modem << $GPGLL,,,,,083603.46,V,N*46
    2022-07-06T08:36:17.530Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:17.553Z DEBUG modem << $GPGSV,2,1,6,7,,,35,16,,,40,23,,,26,26,,,37,1*66
    2022-07-06T08:36:17.556Z DEBUG modem << $GPGSV,2,2,6,27,,,39,30,,,24,1*58
    2022-07-06T08:36:17.583Z DEBUG modem << $GPRMC,083603.46,V,,,,,,,060722,,,N,V*0A
    2022-07-06T08:36:18.496Z DEBUG modem << [1;1H[2JTracking:  5 Using:  1 Unhealthy: 0
    2022-07-06T08:36:18.522Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:18.525Z DEBUG modem << Seconds since last fix: 59
    2022-07-06T08:36:18.527Z DEBUG modem << Searching [\]
    2022-07-06T08:36:18.529Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:18.531Z DEBUG modem << $GPGGA,083604.46,,,,,0,01,99.99,,M,,M,,*6C
    2022-07-06T08:36:18.532Z DEBUG modem << $GPGLL,,,,,083604.46,V,N*41
    2022-07-06T08:36:18.534Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:18.562Z DEBUG modem << $GPGSV,2,1,5,7,,,35,16,,,38,23,,,26,26,,,37,1*6A
    2022-07-06T08:36:18.565Z DEBUG modem << $GPGSV,2,2,5,27,,,39,1*5E
    2022-07-06T08:36:18.568Z DEBUG modem << $GPRMC,083604.46,V,,,,,,,060722,,,N,V*0D
    2022-07-06T08:36:19.497Z DEBUG modem << [1;1H[2JTracking:  5 Using:  1 Unhealthy: 0
    2022-07-06T08:36:19.526Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:19.529Z DEBUG modem << Seconds since last fix: 60
    2022-07-06T08:36:19.532Z DEBUG modem << Searching [|]
    2022-07-06T08:36:19.533Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:19.534Z DEBUG modem << $GPGGA,083605.46,,,,,0,01,99.99,,M,,M,,*6D
    2022-07-06T08:36:19.535Z DEBUG modem << $GPGLL,,,,,083605.46,V,N*40
    2022-07-06T08:36:19.536Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:19.537Z DEBUG modem << $GPGSV,2,1,5,7,,,39,16,,,40,23,,,26,26,,,39,1*67
    2022-07-06T08:36:19.538Z DEBUG modem << $GPGSV,2,2,5,27,,,42,1*52
    2022-07-06T08:36:19.566Z DEBUG modem << $GPRMC,083605.46,V,,,,,,,060722,,,N,V*0C
    2022-07-06T08:36:20.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:36:20.526Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:20.528Z DEBUG modem << Seconds since last fix: 61
    2022-07-06T08:36:20.530Z DEBUG modem << Searching [/]
    2022-07-06T08:36:20.532Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:20.533Z DEBUG modem << $GPGGA,083606.46,,,,,0,01,99.99,,M,,M,,*6E
    2022-07-06T08:36:20.534Z DEBUG modem << $GPGLL,,,,,083606.46,V,N*43
    2022-07-06T08:36:20.536Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:20.537Z DEBUG modem << $GPGSV,2,1,6,7,,,40,12,,,26,16,,,43,23,,,27,1*61
    2022-07-06T08:36:20.579Z DEBUG modem << $GPGSV,2,2,6,26,,,42,27,,,43,1*52
    2022-07-06T08:36:20.582Z DEBUG modem << $GPRMC,083606.46,V,,,,,,,060722,,,N,V*0F
    2022-07-06T08:36:21.499Z DEBUG modem << [1;1H[2JTracking:  9 Using:  1 Unhealthy: 1
    2022-07-06T08:36:21.535Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:21.539Z DEBUG modem << Seconds since last fix: 62
    2022-07-06T08:36:21.542Z DEBUG modem << Searching [-]
    2022-07-06T08:36:21.544Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:21.545Z DEBUG modem << $GPGGA,083607.46,,,,,0,01,99.99,,M,,M,,*6F
    2022-07-06T08:36:21.546Z DEBUG modem << $GPGLL,,,,,083607.46,V,N*42
    2022-07-06T08:36:21.547Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:21.548Z DEBUG modem << $GPGSV,3,1,9,7,,,40,11,,,25,12,,,25,14,,,27,1*6F
    2022-07-06T08:36:21.549Z DEBUG modem << $GPGSV,3,2,9,16,,,45,23,,,27,26,,,44,27,,,44,1*5F
    2022-07-06T08:36:21.550Z DEBUG modem << $GPGSV,3,3,9,28,,,28,1*5D
    2022-07-06T08:36:21.575Z DEBUG modem << $GPRMC,083607.46,V,,,,,,,060722,,,N,V*0E
    2022-07-06T08:36:22.499Z DEBUG modem << [1;1H[2JTracking:  9 Using:  1 Unhealthy: 0
    2022-07-06T08:36:22.529Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:22.532Z DEBUG modem << Seconds since last fix: 63
    2022-07-06T08:36:22.535Z DEBUG modem << Searching [\]
    2022-07-06T08:36:22.537Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:22.538Z DEBUG modem << $GPGGA,083608.46,,,,,0,01,99.99,,M,,M,,*60
    2022-07-06T08:36:22.539Z DEBUG modem << $GPGLL,,,,,083608.46,V,N*4D
    2022-07-06T08:36:22.540Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:22.542Z DEBUG modem << $GPGSV,3,1,9,4,,,27,7,,,40,10,,,27,12,,,24,1*5C
    2022-07-06T08:36:22.568Z DEBUG modem << $GPGSV,3,2,9,14,,,25,16,,,46,23,,,26,26,,,45,1*5B
    2022-07-06T08:36:22.571Z DEBUG modem << $GPGSV,3,3,9,27,,,44,1*58
    2022-07-06T08:36:22.574Z DEBUG modem << $GPRMC,083608.46,V,,,,,,,060722,,,N,V*01
    2022-07-06T08:36:23.500Z DEBUG modem << [1;1H[2JTracking:  9 Using:  1 Unhealthy: 0
    2022-07-06T08:36:23.530Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:23.533Z DEBUG modem << Seconds since last fix: 64
    2022-07-06T08:36:23.536Z DEBUG modem << Searching [|]
    2022-07-06T08:36:23.538Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:23.540Z DEBUG modem << $GPGGA,083609.46,,,,,0,01,99.99,,M,,M,,*61
    2022-07-06T08:36:23.543Z DEBUG modem << $GPGLL,,,,,083609.46,V,N*4C
    2022-07-06T08:36:23.545Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:23.547Z DEBUG modem << $GPGSV,3,1,9,4,,,25,7,,,39,10,,,25,12,,,25,1*53
    2022-07-06T08:36:23.572Z DEBUG modem << $GPGSV,3,2,9,14,,,25,16,,,47,23,,,26,26,,,45,1*5A
    2022-07-06T08:36:23.575Z DEBUG modem << $GPGSV,3,3,9,27,,,44,1*58
    2022-07-06T08:36:23.579Z DEBUG modem << $GPRMC,083609.46,V,,,,,,,060722,,,N,V*00
    2022-07-06T08:36:24.498Z DEBUG modem << [1;1H[2JTracking:  7 Using:  1 Unhealthy: 0
    2022-07-06T08:36:24.528Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:24.530Z DEBUG modem << Seconds since last fix: 65
    2022-07-06T08:36:24.533Z DEBUG modem << Searching [/]
    2022-07-06T08:36:24.535Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:24.536Z DEBUG modem << $GPGGA,083610.46,,,,,0,01,99.99,,M,,M,,*69
    2022-07-06T08:36:24.537Z DEBUG modem << $GPGLL,,,,,083610.46,V,N*44
    2022-07-06T08:36:24.538Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:24.540Z DEBUG modem << $GPGSV,2,1,7,4,,,25,7,,,39,10,,,25,16,,,47,1*5C
    2022-07-06T08:36:24.567Z DEBUG modem << $GPGSV,2,2,7,23,,,26,26,,,45,27,,,44,1*56
    2022-07-06T08:36:24.569Z DEBUG modem << $GPRMC,083610.46,V,,,,,,,060722,,,N,V*08
    2022-07-06T08:36:25.498Z DEBUG modem << [1;1H[2JTracking:  7 Using:  1 Unhealthy: 0
    2022-07-06T08:36:25.534Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:25.536Z DEBUG modem << Seconds since last fix: 66
    2022-07-06T08:36:25.538Z DEBUG modem << Searching [-]
    2022-07-06T08:36:25.540Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:25.543Z DEBUG modem << $GPGGA,083611.46,,,,,0,01,99.99,,M,,M,,*68
    2022-07-06T08:36:25.544Z DEBUG modem << $GPGLL,,,,,083611.46,V,N*45
    2022-07-06T08:36:25.545Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:25.546Z DEBUG modem << $GPGSV,2,1,7,4,,,25,7,,,39,10,,,25,16,,,47,1*5C
    2022-07-06T08:36:25.547Z DEBUG modem << $GPGSV,2,2,7,23,,,26,26,,,45,27,,,44,1*56
    2022-07-06T08:36:25.548Z DEBUG modem << $GPRMC,083611.46,V,,,,,,,060722,,,N,V*09
    2022-07-06T08:36:26.497Z DEBUG modem << [1;1H[2JTracking:  5 Using:  1 Unhealthy: 0
    2022-07-06T08:36:26.525Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:26.528Z DEBUG modem << Seconds since last fix: 67
    2022-07-06T08:36:26.530Z DEBUG modem << Searching [\]
    2022-07-06T08:36:26.532Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:26.533Z DEBUG modem << $GPGGA,083612.46,,,,,0,01,99.99,,M,,M,,*6B
    2022-07-06T08:36:26.533Z DEBUG modem << $GPGLL,,,,,083612.46,V,N*46
    2022-07-06T08:36:26.534Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:26.534Z DEBUG modem << $GPGSV,2,1,5,7,,,40,16,,,47,23,,,26,26,,,46,1*66
    2022-07-06T08:36:26.535Z DEBUG modem << $GPGSV,2,2,5,27,,,44,1*54
    2022-07-06T08:36:26.536Z DEBUG modem << $GPRMC,083612.46,V,,,,,,,060722,,,N,V*0A
    2022-07-06T08:36:27.498Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:36:27.525Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:27.528Z DEBUG modem << Seconds since last fix: 68
    2022-07-06T08:36:27.530Z DEBUG modem << Searching [|]
    2022-07-06T08:36:27.532Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:27.533Z DEBUG modem << $GPGGA,083613.46,,,,,0,01,99.99,,M,,M,,*6A
    2022-07-06T08:36:27.533Z DEBUG modem << $GPGLL,,,,,083613.46,V,N*47
    2022-07-06T08:36:27.534Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:27.534Z DEBUG modem << $GPGSV,2,1,6,5,,,26,7,,,40,16,,,47,23,,,25,1*51
    2022-07-06T08:36:27.536Z DEBUG modem << $GPGSV,2,2,6,26,,,46,27,,,43,1*56
    2022-07-06T08:36:27.537Z DEBUG modem << $GPRMC,083613.46,V,,,,,,,060722,,,N,V*0B
    2022-07-06T08:36:28.500Z DEBUG modem << [1;1H[2JTracking:  9 Using:  1 Unhealthy: 0
    2022-07-06T08:36:28.528Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:28.531Z DEBUG modem << Seconds since last fix: 69
    2022-07-06T08:36:28.533Z DEBUG modem << Searching [/]
    2022-07-06T08:36:28.534Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:28.535Z DEBUG modem << $GPGGA,083614.46,,,,,0,01,99.99,,M,,M,,*6D
    2022-07-06T08:36:28.537Z DEBUG modem << $GPGLL,,,,,083614.46,V,N*40
    2022-07-06T08:36:28.538Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:28.539Z DEBUG modem << $GPGSV,3,1,9,5,,,25,7,,,40,10,,,26,16,,,47,1*5F
    2022-07-06T08:36:28.541Z DEBUG modem << $GPGSV,3,2,9,17,,,27,20,,,25,23,,,25,26,,,46,1*5A
    2022-07-06T08:36:28.545Z DEBUG modem << $GPGSV,3,3,9,27,,,43,1*5F
    2022-07-06T08:36:28.548Z DEBUG modem << $GPRMC,083614.46,V,,,,,,,060722,,,N,V*0C
    2022-07-06T08:36:29.500Z DEBUG modem << [1;1H[2JTracking:  9 Using:  1 Unhealthy: 0
    2022-07-06T08:36:29.526Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:29.530Z DEBUG modem << Seconds since last fix: 70
    2022-07-06T08:36:29.533Z DEBUG modem << Searching [-]
    2022-07-06T08:36:29.534Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:29.535Z DEBUG modem << $GPGGA,083615.46,,,,,0,01,99.99,,M,,M,,*6C
    2022-07-06T08:36:29.536Z DEBUG modem << $GPGLL,,,,,083615.46,V,N*41
    2022-07-06T08:36:29.537Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:29.539Z DEBUG modem << $GPGSV,3,1,9,5,,,24,7,,,40,10,,,25,16,,,47,1*5D
    2022-07-06T08:36:29.541Z DEBUG modem << $GPGSV,3,2,9,17,,,25,20,,,25,23,,,25,26,,,46,1*58
    2022-07-06T08:36:29.544Z DEBUG modem << $GPGSV,3,3,9,27,,,43,1*5F
    2022-07-06T08:36:29.545Z DEBUG modem << $GPRMC,083615.46,V,,,,,,,060722,,,N,V*0D
    2022-07-06T08:36:30.499Z DEBUG modem << [1;1H[2JTracking:  9 Using:  1 Unhealthy: 0
    2022-07-06T08:36:30.527Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:30.530Z DEBUG modem << Seconds since last fix: 71
    2022-07-06T08:36:30.532Z DEBUG modem << Searching [\]
    2022-07-06T08:36:30.534Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:30.535Z DEBUG modem << $GPGGA,083616.46,,,,,0,01,99.99,,M,,M,,*6F
    2022-07-06T08:36:30.537Z DEBUG modem << $GPGLL,,,,,083616.46,V,N*42
    2022-07-06T08:36:30.538Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:30.538Z DEBUG modem << $GPGSV,3,1,9,5,,,24,7,,,40,10,,,25,16,,,47,1*5D
    2022-07-06T08:36:30.539Z DEBUG modem << $GPGSV,3,2,9,17,,,25,20,,,25,23,,,25,26,,,46,1*58
    2022-07-06T08:36:30.540Z DEBUG modem << $GPGSV,3,3,9,27,,,44,1*58
    2022-07-06T08:36:30.542Z DEBUG modem << $GPRMC,083616.46,V,,,,,,,060722,,,N,V*0E
    2022-07-06T08:36:31.497Z DEBUG modem << [1;1H[2JTracking:  6 Using:  1 Unhealthy: 0
    2022-07-06T08:36:31.523Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:31.525Z DEBUG modem << Seconds since last fix: 72
    2022-07-06T08:36:31.528Z DEBUG modem << Searching [|]
    2022-07-06T08:36:31.529Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:31.531Z DEBUG modem << $GPGGA,083617.46,,,,,0,01,99.99,,M,,M,,*6E
    2022-07-06T08:36:31.532Z DEBUG modem << $GPGLL,,,,,083617.46,V,N*43
    2022-07-06T08:36:31.534Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:31.535Z DEBUG modem << $GPGSV,2,1,6,7,,,40,10,,,25,16,,,47,23,,,25,1*66
    2022-07-06T08:36:31.537Z DEBUG modem << $GPGSV,2,2,6,26,,,46,27,,,44,1*51
    2022-07-06T08:36:31.538Z DEBUG modem << $GPRMC,083617.46,V,,,,,,,060722,,,N,V*0F
    2022-07-06T08:36:32.482Z DEBUG modem << [1;1H[2JTracking:  5 Using:  1 Unhealthy: 0
    2022-07-06T08:36:32.510Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:32.512Z DEBUG modem << Seconds since last fix: 73
    2022-07-06T08:36:32.514Z DEBUG modem << Searching [/]
    2022-07-06T08:36:32.516Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:32.517Z DEBUG modem << $GPGGA,083618.46,,,,,0,01,99.99,,M,,M,,*61
    2022-07-06T08:36:32.518Z DEBUG modem << $GPGLL,,,,,083618.46,V,N*4C
    2022-07-06T08:36:32.519Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:32.519Z DEBUG modem << $GPGSV,2,1,5,7,,,40,16,,,48,23,,,25,26,,,46,1*6A
    2022-07-06T08:36:32.520Z DEBUG modem << $GPGSV,2,2,5,27,,,43,1*53
    2022-07-06T08:36:32.522Z DEBUG modem << $GPRMC,083618.46,V,,,,,,,060722,,,N,V*00
    2022-07-06T08:36:33.482Z DEBUG modem << [1;1H[2JTracking:  7 Using:  1 Unhealthy: 0
    2022-07-06T08:36:33.519Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:33.521Z DEBUG modem << Seconds since last fix: 74
    2022-07-06T08:36:33.524Z DEBUG modem << Searching [-]
    2022-07-06T08:36:33.527Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:33.528Z DEBUG modem << $GPGGA,083619.46,,,,,0,01,99.99,,M,,M,,*60
    2022-07-06T08:36:33.529Z DEBUG modem << $GPGLL,,,,,083619.46,V,N*4D
    2022-07-06T08:36:33.530Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:33.531Z DEBUG modem << $GPGSV,2,1,7,7,,,40,8,,,27,10,,,27,16,,,47,1*5E
    2022-07-06T08:36:33.532Z DEBUG modem << $GPGSV,2,2,7,23,,,25,26,,,46,27,,,43,1*51
    2022-07-06T08:36:33.533Z DEBUG modem << $GPRMC,083619.46,V,,,,,,,060722,,,N,V*01
    2022-07-06T08:36:34.485Z DEBUG modem << [1;1H[2JTracking:  9 Using:  1 Unhealthy: 0
    2022-07-06T08:36:34.512Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:34.515Z DEBUG modem << Seconds since last fix: 75
    2022-07-06T08:36:34.517Z DEBUG modem << Searching [\]
    2022-07-06T08:36:34.519Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:34.520Z DEBUG modem << $GPGGA,083620.46,,,,,0,01,99.99,,M,,M,,*6A
    2022-07-06T08:36:34.521Z DEBUG modem << $GPGLL,,,,,083620.46,V,N*47
    2022-07-06T08:36:34.521Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:34.522Z DEBUG modem << $GPGSV,3,1,9,7,,,40,8,,,25,9,,,27,10,,,25,1*69
    2022-07-06T08:36:34.548Z DEBUG modem << $GPGSV,3,2,9,11,,,25,16,,,47,23,,,26,26,,,46,1*5C
    2022-07-06T08:36:34.550Z DEBUG modem << $GPGSV,3,3,9,27,,,43,1*5F
    2022-07-06T08:36:34.553Z DEBUG modem << $GPRMC,083620.46,V,,,,,,,060722,,,N,V*0B
    2022-07-06T08:36:35.485Z DEBUG modem << [1;1H[2JTracking:  9 Using:  1 Unhealthy: 0
    2022-07-06T08:36:35.512Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:35.515Z DEBUG modem << Seconds since last fix: 76
    2022-07-06T08:36:35.518Z DEBUG modem << Searching [|]
    2022-07-06T08:36:35.520Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:35.521Z DEBUG modem << $GPGGA,083621.46,,,,,0,01,99.99,,M,,M,,*6B
    2022-07-06T08:36:35.522Z DEBUG modem << $GPGLL,,,,,083621.46,V,N*46
    2022-07-06T08:36:35.523Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:35.524Z DEBUG modem << $GPGSV,3,1,9,7,,,40,8,,,25,9,,,25,10,,,25,1*6B
    2022-07-06T08:36:35.526Z DEBUG modem << $GPGSV,3,2,9,11,,,25,16,,,47,23,,,26,26,,,47,1*5D
    2022-07-06T08:36:35.527Z DEBUG modem << $GPGSV,3,3,9,27,,,43,1*5F
    2022-07-06T08:36:35.529Z DEBUG modem << $GPRMC,083621.46,V,,,,,,,060722,,,N,V*0A
    2022-07-06T08:36:36.484Z DEBUG modem << [1;1H[2JTracking:  8 Using:  1 Unhealthy: 0
    2022-07-06T08:36:36.513Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:36.515Z DEBUG modem << Seconds since last fix: 77
    2022-07-06T08:36:36.517Z DEBUG modem << Searching [/]
    2022-07-06T08:36:36.519Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:36.520Z DEBUG modem << $GPGGA,083622.46,,,,,0,01,99.99,,M,,M,,*68
    2022-07-06T08:36:36.521Z DEBUG modem << $GPGLL,,,,,083622.46,V,N*45
    2022-07-06T08:36:36.522Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:36.523Z DEBUG modem << $GPGSV,2,1,8,7,,,40,9,,,25,10,,,25,14,,,27,1*54
    2022-07-06T08:36:36.524Z DEBUG modem << $GPGSV,2,2,8,16,,,47,23,,,26,26,,,47,27,,,43,1*58
    2022-07-06T08:36:36.527Z DEBUG modem << $GPRMC,083622.46,V,,,,,,,060722,,,N,V*09
    2022-07-06T08:36:37.484Z DEBUG modem << [1;1H[2JTracking:  7 Using:  1 Unhealthy: 0
    2022-07-06T08:36:37.512Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:37.541Z DEBUG modem << Seconds since last fix: 78
    2022-07-06T08:36:37.544Z DEBUG modem << Searching [-]
    2022-07-06T08:36:37.546Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:37.548Z DEBUG modem << $GPGGA,083623.46,,,,,0,01,99.99,,M,,M,,*69
    2022-07-06T08:36:37.549Z DEBUG modem << $GPGLL,,,,,083623.46,V,N*44
    2022-07-06T08:36:37.550Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:37.551Z DEBUG modem << $GPGSV,2,1,7,7,,,40,9,,,24,14,,,25,16,,,47,1*5A
    2022-07-06T08:36:37.552Z DEBUG modem << $GPGSV,2,2,7,23,,,25,26,,,47,27,,,43,1*50
    2022-07-06T08:36:37.578Z DEBUG modem << $GPRMC,083623.46,V,,,,,,,060722,,,N,V*08
    2022-07-06T08:36:38.484Z DEBUG modem << [1;1H[2JTracking:  6 Using:  3 Unhealthy: 0
    2022-07-06T08:36:38.514Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:38.516Z DEBUG modem << Seconds since last fix: 79
    2022-07-06T08:36:38.518Z DEBUG modem << Searching [\]
    2022-07-06T08:36:38.520Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:38.521Z DEBUG modem << $GPGGA,083624.46,,,,,0,03,99.99,,M,,M,,*6C
    2022-07-06T08:36:38.522Z DEBUG modem << $GPGLL,,,,,083624.46,V,N*43
    2022-07-06T08:36:38.523Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:38.524Z DEBUG modem << $GPGSV,2,1,6,7,,,40,14,,,24,16,,,47,23,,,25,1*63
    2022-07-06T08:36:38.525Z DEBUG modem << $GPGSV,2,2,6,26,,,46,27,,,43,1*56
    2022-07-06T08:36:38.528Z DEBUG modem << $GPRMC,083624.46,V,,,,,,,060722,,,N,V*0F
    2022-07-06T08:36:39.485Z DEBUG modem << [1;1H[2JTracking:  7 Using:  3 Unhealthy: 0
    2022-07-06T08:36:39.514Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:39.516Z DEBUG modem << Seconds since last fix: 80
    2022-07-06T08:36:39.519Z DEBUG modem << Searching [|]
    2022-07-06T08:36:39.520Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:39.521Z DEBUG modem << $GPGGA,083625.46,,,,,0,03,99.99,,M,,M,,*6D
    2022-07-06T08:36:39.522Z DEBUG modem << $GPGLL,,,,,083625.46,V,N*42
    2022-07-06T08:36:39.523Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:39.524Z DEBUG modem << $GPGSV,2,1,7,6,,,25,7,,,40,14,,,24,16,,,47,1*55
    2022-07-06T08:36:39.525Z DEBUG modem << $GPGSV,2,2,7,23,,,26,26,,,46,27,,,43,1*52
    2022-07-06T08:36:39.527Z DEBUG modem << $GPRMC,083625.46,V,,,,,,,060722,,,N,V*0E
    2022-07-06T08:36:40.488Z DEBUG modem << [1;1H[2JTracking: 10 Using:  3 Unhealthy: 0
    2022-07-06T08:36:40.516Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:40.518Z DEBUG modem << Seconds since last fix: 81
    2022-07-06T08:36:40.522Z DEBUG modem << Searching [/]
    2022-07-06T08:36:40.524Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:40.525Z DEBUG modem << $GPGGA,083626.46,,,,,0,03,99.99,,M,,M,,*6E
    2022-07-06T08:36:40.525Z DEBUG modem << $GPGLL,,,,,083626.46,V,N*41
    2022-07-06T08:36:40.526Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:40.527Z DEBUG modem << $GPGSV,3,1,10,3,,,25,4,,,27,5,,,27,6,,,25,1*63
    2022-07-06T08:36:40.528Z DEBUG modem << $GPGSV,3,2,10,7,,,40,16,,,47,23,,,26,26,,,46,1*50
    2022-07-06T08:36:40.530Z DEBUG modem << $GPGSV,3,3,10,27,,,43,31,,,25,1*62
    2022-07-06T08:36:40.532Z DEBUG modem << $GPRMC,083626.46,V,,,,,,,060722,,,N,V*0D
    2022-07-06T08:36:41.488Z DEBUG modem << [1;1H[2JTracking: 10 Using:  3 Unhealthy: 0
    2022-07-06T08:36:41.517Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:41.519Z DEBUG modem << Seconds since last fix: 82
    2022-07-06T08:36:41.522Z DEBUG modem << Searching [-]
    2022-07-06T08:36:41.523Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:41.524Z DEBUG modem << $GPGGA,083627.46,,,,,0,03,99.99,,M,,M,,*6F
    2022-07-06T08:36:41.525Z DEBUG modem << $GPGLL,,,,,083627.46,V,N*40
    2022-07-06T08:36:41.526Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:41.528Z DEBUG modem << $GPGSV,3,1,10,3,,,25,4,,,25,5,,,25,6,,,25,1*63
    2022-07-06T08:36:41.529Z DEBUG modem << $GPGSV,3,2,10,7,,,40,16,,,47,23,,,25,26,,,47,1*52
    2022-07-06T08:36:41.532Z DEBUG modem << $GPGSV,3,3,10,27,,,44,31,,,25,1*65
    2022-07-06T08:36:41.534Z DEBUG modem << $GPRMC,083627.46,V,,,,,,,060722,,,N,V*0C
    2022-07-06T08:36:42.488Z DEBUG modem << [1;1H[2JTracking: 10 Using:  3 Unhealthy: 0
    2022-07-06T08:36:42.517Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:42.520Z DEBUG modem << Seconds since last fix: 83
    2022-07-06T08:36:42.523Z DEBUG modem << Searching [\]
    2022-07-06T08:36:42.524Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:42.525Z DEBUG modem << $GPGGA,083628.46,,,,,0,03,99.99,,M,,M,,*60
    2022-07-06T08:36:42.526Z DEBUG modem << $GPGLL,,,,,083628.46,V,N*4F
    2022-07-06T08:36:42.527Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:42.529Z DEBUG modem << $GPGSV,3,1,10,3,,,25,4,,,25,5,,,25,6,,,25,1*63
    2022-07-06T08:36:42.556Z DEBUG modem << $GPGSV,3,2,10,7,,,40,16,,,47,23,,,25,26,,,47,1*52
    2022-07-06T08:36:42.560Z DEBUG modem << $GPGSV,3,3,10,27,,,44,31,,,25,1*65
    2022-07-06T08:36:42.562Z DEBUG modem << $GPRMC,083628.46,V,,,,,,,060722,,,N,V*03
    2022-07-06T08:36:43.487Z DEBUG modem << [1;1H[2JTracking:  9 Using:  3 Unhealthy: 0
    2022-07-06T08:36:43.516Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:43.519Z DEBUG modem << Seconds since last fix: 84
    2022-07-06T08:36:43.521Z DEBUG modem << Searching [|]
    2022-07-06T08:36:43.523Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:43.524Z DEBUG modem << $GPGGA,083629.46,,,,,0,03,99.99,,M,,M,,*61
    2022-07-06T08:36:43.525Z DEBUG modem << $GPGLL,,,,,083629.46,V,N*4E
    2022-07-06T08:36:43.526Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:36:43.527Z DEBUG modem << $GPGSV,3,1,9,3,,,25,4,,,24,5,,,25,7,,,40,1*58
    2022-07-06T08:36:43.561Z DEBUG modem << $GPGSV,3,2,9,16,,,47,23,,,24,26,,,47,27,,,44,1*5D
    2022-07-06T08:36:43.564Z DEBUG modem << $GPGSV,3,3,9,31,,,24,1*59
    2022-07-06T08:36:43.567Z DEBUG modem << $GPRMC,083629.46,V,,,,,,,060722,,,N,V*02
    2022-07-06T08:36:44.547Z DEBUG modem << [1;1H[2JTracking:  5 Using:  5 Unhealthy: 0
    2022-07-06T08:36:44.576Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:44.578Z DEBUG modem << Latitude:       62.384966
    2022-07-06T08:36:44.581Z DEBUG modem << Longitude:      6.579618
    2022-07-06T08:36:44.583Z DEBUG modem << Altitude:       98.5 m
    2022-07-06T08:36:44.584Z DEBUG modem << Accuracy:       8.8 m
    2022-07-06T08:36:44.585Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:44.586Z DEBUG modem << Speed accuracy: 1.0 m/s
    2022-07-06T08:36:44.587Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:44.588Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:44.589Z DEBUG modem << Time (UTC):     08:36:30.464
    2022-07-06T08:36:44.591Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:44.618Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:44.621Z DEBUG modem << VDOP:           2.7
    2022-07-06T08:36:44.623Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:44.625Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:44.626Z DEBUG modem << $GPGGA,083630.46,6223.09793,N,00634.77710,E,1,05,2.21,98.49,M,,M,,*40
    2022-07-06T08:36:44.653Z DEBUG modem << $GPGLL,6223.09793,N,00634.77710,E,083630.46,A,A*63
    2022-07-06T08:36:44.655Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.52,2.21,2.74,1*1B
    2022-07-06T08:36:44.658Z DEBUG modem << $GPGSV,3,1,12,5,23,038,,7,13,338,40,8,00,272,,10,00,162,,1*58
    2022-07-06T08:36:44.660Z DEBUG modem << $GPGSV,3,2,12,13,00,053,,16,65,251,47,18,64,103,,20,01,016,,1*6E
    2022-07-06T08:36:44.661Z DEBUG modem << $GPGSV,3,3,12,23,19,142,24,26,53,191,47,27,36,265,43,29,20,093,,1*62
    2022-07-06T08:36:44.687Z DEBUG modem << $GPRMC,083630.46,A,6223.09793,N,00634.77710,E,0.19,0.00,060722,,,A,V*27
    2022-07-06T08:36:45.555Z DEBUG modem << [1;1H[2JTracking:  7 Using:  5 Unhealthy: 0
    2022-07-06T08:36:45.584Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:45.587Z DEBUG modem << Latitude:       62.384962
    2022-07-06T08:36:45.590Z DEBUG modem << Longitude:      6.579639
    2022-07-06T08:36:45.592Z DEBUG modem << Altitude:       100.4 m
    2022-07-06T08:36:45.593Z DEBUG modem << Accuracy:       6.3 m
    2022-07-06T08:36:45.594Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:45.594Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:45.595Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:45.595Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:45.597Z DEBUG modem << Time (UTC):     08:36:31.464
    2022-07-06T08:36:45.599Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:45.625Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:45.628Z DEBUG modem << VDOP:           2.7
    2022-07-06T08:36:45.630Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:45.632Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:45.633Z DEBUG modem << $GPGGA,083631.46,6223.09771,N,00634.77833,E,1,05,2.21,100.45,M,,M,,*7F
    2022-07-06T08:36:45.661Z DEBUG modem << $GPGLL,6223.09771,N,00634.77833,E,083631.46,A,A*60
    2022-07-06T08:36:45.664Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.52,2.21,2.74,1*1B
    2022-07-06T08:36:45.666Z DEBUG modem << $GPGSV,3,1,12,5,23,038,30,7,13,338,40,8,00,272,,10,00,162,,1*5B
    2022-07-06T08:36:45.668Z DEBUG modem << $GPGSV,3,2,12,13,00,053,,16,65,251,46,18,64,103,31,20,01,016,,1*6D
    2022-07-06T08:36:45.669Z DEBUG modem << $GPGSV,3,3,12,23,19,142,24,26,53,191,46,27,36,265,43,29,20,093,,1*63
    2022-07-06T08:36:45.695Z DEBUG modem << $GPRMC,083631.46,A,6223.09771,N,00634.77833,E,0.19,0.00,060722,,,A,V*24
    2022-07-06T08:36:46.555Z DEBUG modem << [1;1H[2JTracking:  7 Using:  5 Unhealthy: 0
    2022-07-06T08:36:46.586Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:46.588Z DEBUG modem << Latitude:       62.384961
    2022-07-06T08:36:46.591Z DEBUG modem << Longitude:      6.579636
    2022-07-06T08:36:46.592Z DEBUG modem << Altitude:       100.6 m
    2022-07-06T08:36:46.593Z DEBUG modem << Accuracy:       5.2 m
    2022-07-06T08:36:46.594Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:46.595Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:46.596Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:46.599Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:46.600Z DEBUG modem << Time (UTC):     08:36:32.464
    2022-07-06T08:36:46.601Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:46.628Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:46.630Z DEBUG modem << VDOP:           2.7
    2022-07-06T08:36:46.632Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:46.634Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:46.636Z DEBUG modem << $GPGGA,083632.46,6223.09769,N,00634.77817,E,1,05,2.21,100.59,M,,M,,*7E
    2022-07-06T08:36:46.662Z DEBUG modem << $GPGLL,6223.09769,N,00634.77817,E,083632.46,A,A*6C
    2022-07-06T08:36:46.665Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.52,2.21,2.74,1*1B
    2022-07-06T08:36:46.667Z DEBUG modem << $GPGSV,3,1,12,5,23,038,30,7,13,338,41,8,00,272,,10,00,162,,1*5A
    2022-07-06T08:36:46.669Z DEBUG modem << $GPGSV,3,2,12,13,00,053,,16,65,251,46,18,64,103,29,20,01,016,,1*64
    2022-07-06T08:36:46.671Z DEBUG modem << $GPGSV,3,3,12,23,19,142,24,26,53,191,47,27,36,265,43,29,20,093,,1*62
    2022-07-06T08:36:46.673Z DEBUG modem << $GPRMC,083632.46,A,6223.09769,N,00634.77817,E,0.23,0.00,060722,,,A,V*21
    2022-07-06T08:36:47.561Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:36:47.589Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:47.591Z DEBUG modem << Latitude:       62.384965
    2022-07-06T08:36:47.593Z DEBUG modem << Longitude:      6.579651
    2022-07-06T08:36:47.594Z DEBUG modem << Altitude:       101.1 m
    2022-07-06T08:36:47.595Z DEBUG modem << Accuracy:       4.5 m
    2022-07-06T08:36:47.595Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:47.596Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:47.596Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:47.598Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:47.601Z DEBUG modem << Time (UTC):     08:36:33.464
    2022-07-06T08:36:47.631Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:47.633Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:47.636Z DEBUG modem << VDOP:           2.7
    2022-07-06T08:36:47.638Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:47.639Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:47.667Z DEBUG modem << $GPGGA,083633.46,6223.09792,N,00634.77906,E,1,05,2.21,101.06,M,,M,,*71
    2022-07-06T08:36:47.670Z DEBUG modem << $GPGLL,6223.09792,N,00634.77906,E,083633.46,A,A*68
    2022-07-06T08:36:47.672Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.53,2.21,2.74,1*1A
    2022-07-06T08:36:47.674Z DEBUG modem << $GPGSV,4,1,13,5,23,038,31,7,13,338,41,8,00,272,,10,00,162,,1*5D
    2022-07-06T08:36:47.675Z DEBUG modem << $GPGSV,4,2,13,13,00,053,,16,65,251,46,18,64,103,31,20,01,016,,1*6B
    2022-07-06T08:36:47.676Z DEBUG modem << $GPGSV,4,3,13,23,19,142,24,26,53,191,47,27,36,265,43,28,,,28,1*57
    2022-07-06T08:36:47.677Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:36:47.704Z DEBUG modem << $GPRMC,083633.46,A,6223.09792,N,00634.77906,E,0.12,0.00,060722,,,A,V*27
    2022-07-06T08:36:48.563Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:36:48.592Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:48.595Z DEBUG modem << Latitude:       62.384966
    2022-07-06T08:36:48.597Z DEBUG modem << Longitude:      6.579657
    2022-07-06T08:36:48.599Z DEBUG modem << Altitude:       100.9 m
    2022-07-06T08:36:48.600Z DEBUG modem << Accuracy:       4.1 m
    2022-07-06T08:36:48.601Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:48.603Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:48.604Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:48.607Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:48.608Z DEBUG modem << Time (UTC):     08:36:34.464
    2022-07-06T08:36:48.636Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:48.639Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:48.641Z DEBUG modem << VDOP:           2.7
    2022-07-06T08:36:48.643Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:48.644Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:48.645Z DEBUG modem << $GPGGA,083634.46,6223.09799,N,00634.77942,E,1,05,2.21,100.91,M,,M,,*72
    2022-07-06T08:36:48.673Z DEBUG modem << $GPGLL,6223.09799,N,00634.77942,E,083634.46,A,A*64
    2022-07-06T08:36:48.676Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.53,2.21,2.74,1*1A
    2022-07-06T08:36:48.678Z DEBUG modem << $GPGSV,4,1,13,5,23,038,31,7,13,338,41,8,00,272,,10,00,162,,1*5D
    2022-07-06T08:36:48.680Z DEBUG modem << $GPGSV,4,2,13,13,00,053,,16,65,251,46,18,64,103,32,20,01,016,,1*68
    2022-07-06T08:36:48.681Z DEBUG modem << $GPGSV,4,3,13,23,19,142,24,26,53,191,47,27,36,265,43,28,,,25,1*5A
    2022-07-06T08:36:48.682Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:36:48.684Z DEBUG modem << $GPRMC,083634.46,A,6223.09799,N,00634.77942,E,0.19,0.00,060722,,,A,V*20
    2022-07-06T08:36:49.560Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:36:49.589Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:49.591Z DEBUG modem << Latitude:       62.384963
    2022-07-06T08:36:49.593Z DEBUG modem << Longitude:      6.579654
    2022-07-06T08:36:49.596Z DEBUG modem << Altitude:       100.5 m
    2022-07-06T08:36:49.598Z DEBUG modem << Accuracy:       3.8 m
    2022-07-06T08:36:49.599Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:49.602Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:49.604Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:49.606Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:49.606Z DEBUG modem << Time (UTC):     08:36:35.464
    2022-07-06T08:36:49.607Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:49.634Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:49.637Z DEBUG modem << VDOP:           2.7
    2022-07-06T08:36:49.639Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:49.641Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:49.642Z DEBUG modem << $GPGGA,083635.46,6223.09776,N,00634.77926,E,1,05,2.22,100.51,M,,M,,*7F
    2022-07-06T08:36:49.669Z DEBUG modem << $GPGLL,6223.09776,N,00634.77926,E,083635.46,A,A*66
    2022-07-06T08:36:49.672Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.53,2.22,2.75,1*18
    2022-07-06T08:36:49.675Z DEBUG modem << $GPGSV,4,1,13,5,23,038,32,7,13,338,41,8,00,272,,10,00,162,,1*5E
    2022-07-06T08:36:49.677Z DEBUG modem << $GPGSV,4,2,13,13,00,053,,16,65,251,46,18,64,103,33,20,01,016,,1*69
    2022-07-06T08:36:49.678Z DEBUG modem << $GPGSV,4,3,13,23,19,142,24,26,53,191,47,27,36,265,42,28,,,25,1*5B
    2022-07-06T08:36:49.679Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:36:49.681Z DEBUG modem << $GPRMC,083635.46,A,6223.09776,N,00634.77926,E,0.13,0.00,060722,,,A,V*28
    2022-07-06T08:36:50.559Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:36:50.590Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:50.593Z DEBUG modem << Latitude:       62.384960
    2022-07-06T08:36:50.595Z DEBUG modem << Longitude:      6.579652
    2022-07-06T08:36:50.597Z DEBUG modem << Altitude:       99.5 m
    2022-07-06T08:36:50.598Z DEBUG modem << Accuracy:       3.6 m
    2022-07-06T08:36:50.599Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:50.600Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:50.601Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:50.604Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:50.605Z DEBUG modem << Time (UTC):     08:36:36.464
    2022-07-06T08:36:50.606Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:50.635Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:50.638Z DEBUG modem << VDOP:           2.7
    2022-07-06T08:36:50.641Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:50.642Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:50.643Z DEBUG modem << $GPGGA,083636.46,6223.09763,N,00634.77912,E,1,05,2.22,99.49,M,,M,,*47
    2022-07-06T08:36:50.645Z DEBUG modem << $GPGLL,6223.09763,N,00634.77912,E,083636.46,A,A*66
    2022-07-06T08:36:50.647Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.53,2.22,2.75,1*18
    2022-07-06T08:36:50.648Z DEBUG modem << $GPGSV,4,1,13,5,23,038,32,7,13,338,41,8,00,272,,10,00,162,,1*5E
    2022-07-06T08:36:50.649Z DEBUG modem << $GPGSV,4,2,13,13,00,053,,16,65,251,46,18,64,103,33,20,01,016,,1*69
    2022-07-06T08:36:50.650Z DEBUG modem << $GPGSV,4,3,13,23,19,142,24,26,53,191,47,27,36,265,42,28,,,24,1*5A
    2022-07-06T08:36:50.651Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:36:50.653Z DEBUG modem << $GPRMC,083636.46,A,6223.09763,N,00634.77912,E,0.28,0.00,060722,,,A,V*20
    2022-07-06T08:36:51.557Z DEBUG modem << [1;1H[2JTracking:  7 Using:  5 Unhealthy: 0
    2022-07-06T08:36:51.587Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:51.590Z DEBUG modem << Latitude:       62.384962
    2022-07-06T08:36:51.592Z DEBUG modem << Longitude:      6.579660
    2022-07-06T08:36:51.594Z DEBUG modem << Altitude:       99.7 m
    2022-07-06T08:36:51.595Z DEBUG modem << Accuracy:       3.4 m
    2022-07-06T08:36:51.596Z DEBUG modem << Speed:          0.2 m/s
    2022-07-06T08:36:51.597Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:51.598Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:51.600Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:51.602Z DEBUG modem << Time (UTC):     08:36:37.464
    2022-07-06T08:36:51.603Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:51.629Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:51.632Z DEBUG modem << VDOP:           2.7
    2022-07-06T08:36:51.635Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:51.637Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:51.638Z DEBUG modem << $GPGGA,083637.46,6223.09773,N,00634.77962,E,1,05,2.22,99.67,M,,M,,*4C
    2022-07-06T08:36:51.668Z DEBUG modem << $GPGLL,6223.09773,N,00634.77962,E,083637.46,A,A*61
    2022-07-06T08:36:51.670Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.53,2.22,2.75,1*18
    2022-07-06T08:36:51.673Z DEBUG modem << $GPGSV,3,1,12,5,23,038,32,7,13,338,41,8,00,272,,10,00,162,,1*58
    2022-07-06T08:36:51.675Z DEBUG modem << $GPGSV,3,2,12,13,00,053,,16,65,250,46,18,64,103,34,20,01,016,,1*69
    2022-07-06T08:36:51.677Z DEBUG modem << $GPGSV,3,3,12,23,19,142,24,26,53,191,47,27,36,265,43,29,20,093,,1*62
    2022-07-06T08:36:51.678Z DEBUG modem << $GPRMC,083637.46,A,6223.09773,N,00634.77962,E,0.31,0.00,060722,,,A,V*2F
    2022-07-06T08:36:52.558Z DEBUG modem << [1;1H[2JTracking:  7 Using:  5 Unhealthy: 0
    2022-07-06T08:36:52.589Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:52.591Z DEBUG modem << Latitude:       62.384960
    2022-07-06T08:36:52.594Z DEBUG modem << Longitude:      6.579658
    2022-07-06T08:36:52.596Z DEBUG modem << Altitude:       99.7 m
    2022-07-06T08:36:52.597Z DEBUG modem << Accuracy:       3.3 m
    2022-07-06T08:36:52.599Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:52.600Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:52.602Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:52.604Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:52.604Z DEBUG modem << Time (UTC):     08:36:38.464
    2022-07-06T08:36:52.605Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:52.633Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:52.636Z DEBUG modem << VDOP:           2.7
    2022-07-06T08:36:52.638Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:52.640Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:52.641Z DEBUG modem << $GPGGA,083638.46,6223.09761,N,00634.77947,E,1,05,2.22,99.74,M,,M,,*45
    2022-07-06T08:36:52.643Z DEBUG modem << $GPGLL,6223.09761,N,00634.77947,E,083638.46,A,A*6A
    2022-07-06T08:36:52.644Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.53,2.22,2.75,1*18
    2022-07-06T08:36:52.645Z DEBUG modem << $GPGSV,3,1,12,5,23,038,32,7,13,338,40,8,00,272,,10,00,162,,1*59
    2022-07-06T08:36:52.647Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,46,18,64,103,33,20,01,016,,1*6F
    2022-07-06T08:36:52.647Z DEBUG modem << $GPGSV,3,3,12,23,19,142,24,26,53,191,47,27,36,265,43,29,20,093,,1*62
    2022-07-06T08:36:52.648Z DEBUG modem << $GPRMC,083638.46,A,6223.09761,N,00634.77947,E,0.15,0.00,060722,,,A,V*22
    2022-07-06T08:36:53.555Z DEBUG modem << [1;1H[2JTracking:  7 Using:  5 Unhealthy: 0
    2022-07-06T08:36:53.585Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:53.588Z DEBUG modem << Latitude:       62.384962
    2022-07-06T08:36:53.591Z DEBUG modem << Longitude:      6.579671
    2022-07-06T08:36:53.592Z DEBUG modem << Altitude:       99.8 m
    2022-07-06T08:36:53.593Z DEBUG modem << Accuracy:       3.2 m
    2022-07-06T08:36:53.594Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:53.595Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:53.596Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:53.599Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:53.601Z DEBUG modem << Time (UTC):     08:36:39.464
    2022-07-06T08:36:53.602Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:53.630Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:53.633Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:36:53.636Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:53.637Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:53.638Z DEBUG modem << $GPGGA,083639.46,6223.09771,N,00634.78028,E,1,05,2.22,99.78,M,,M,,*46
    2022-07-06T08:36:53.640Z DEBUG modem << $GPGLL,6223.09771,N,00634.78028,E,083639.46,A,A*65
    2022-07-06T08:36:53.641Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.53,2.22,2.75,1*18
    2022-07-06T08:36:53.642Z DEBUG modem << $GPGSV,3,1,12,5,23,038,33,7,13,338,40,8,00,272,,10,00,162,,1*58
    2022-07-06T08:36:53.643Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,46,18,64,103,33,20,01,016,,1*6F
    2022-07-06T08:36:53.644Z DEBUG modem << $GPGSV,3,3,12,23,19,142,25,26,53,191,47,27,36,265,42,29,20,093,,1*62
    2022-07-06T08:36:53.645Z DEBUG modem << $GPRMC,083639.46,A,6223.09771,N,00634.78028,E,0.13,0.00,060722,,,A,V*2B
    2022-07-06T08:36:54.555Z DEBUG modem << [1;1H[2JTracking:  7 Using:  5 Unhealthy: 0
    2022-07-06T08:36:54.585Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:54.588Z DEBUG modem << Latitude:       62.384961
    2022-07-06T08:36:54.590Z DEBUG modem << Longitude:      6.579679
    2022-07-06T08:36:54.592Z DEBUG modem << Altitude:       99.5 m
    2022-07-06T08:36:54.593Z DEBUG modem << Accuracy:       3.2 m
    2022-07-06T08:36:54.595Z DEBUG modem << Speed:          0.0 m/s
    2022-07-06T08:36:54.596Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:54.597Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:54.601Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:54.602Z DEBUG modem << Time (UTC):     08:36:40.464
    2022-07-06T08:36:54.603Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:54.632Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:54.635Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:36:54.637Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:54.639Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:54.640Z DEBUG modem << $GPGGA,083640.46,6223.09768,N,00634.78076,E,1,05,2.22,99.48,M,,M,,*48
    2022-07-06T08:36:54.642Z DEBUG modem << $GPGLL,6223.09768,N,00634.78076,E,083640.46,A,A*68
    2022-07-06T08:36:54.643Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.53,2.22,2.75,1*18
    2022-07-06T08:36:54.644Z DEBUG modem << $GPGSV,3,1,12,5,23,038,33,7,13,338,41,8,00,272,,10,00,162,,1*59
    2022-07-06T08:36:54.645Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,46,18,64,103,33,20,01,016,,1*6F
    2022-07-06T08:36:54.646Z DEBUG modem << $GPGSV,3,3,12,23,19,142,25,26,53,191,47,27,37,265,43,29,20,093,,1*62
    2022-07-06T08:36:54.647Z DEBUG modem << $GPRMC,083640.46,A,6223.09768,N,00634.78076,E,0.07,0.00,060722,,,A,V*23
    2022-07-06T08:36:55.560Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:36:55.590Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:55.593Z DEBUG modem << Latitude:       62.384962
    2022-07-06T08:36:55.595Z DEBUG modem << Longitude:      6.579686
    2022-07-06T08:36:55.597Z DEBUG modem << Altitude:       99.2 m
    2022-07-06T08:36:55.598Z DEBUG modem << Accuracy:       3.1 m
    2022-07-06T08:36:55.599Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:55.600Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:55.601Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:55.602Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:55.604Z DEBUG modem << Time (UTC):     08:36:41.464
    2022-07-06T08:36:55.606Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:55.639Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:55.644Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:36:55.646Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:55.648Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:55.649Z DEBUG modem << $GPGGA,083641.46,6223.09772,N,00634.78115,E,1,05,2.22,99.24,M,,M,,*4C
    2022-07-06T08:36:55.679Z DEBUG modem << $GPGLL,6223.09772,N,00634.78115,E,083641.46,A,A*66
    2022-07-06T08:36:55.682Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.54,2.22,2.75,1*1F
    2022-07-06T08:36:55.686Z DEBUG modem << $GPGSV,4,1,13,5,23,038,33,7,13,338,41,8,00,272,,10,00,162,,1*5F
    2022-07-06T08:36:55.688Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,46,18,64,103,33,20,01,016,,1*69
    2022-07-06T08:36:55.689Z DEBUG modem << $GPGSV,4,3,13,23,19,142,24,26,53,191,48,27,37,265,43,28,,,26,1*57
    2022-07-06T08:36:55.690Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:36:55.692Z DEBUG modem << $GPRMC,083641.46,A,6223.09772,N,00634.78115,E,0.15,0.00,060722,,,A,V*2E
    2022-07-06T08:36:56.555Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:36:56.587Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:56.590Z DEBUG modem << Latitude:       62.384959
    2022-07-06T08:36:56.592Z DEBUG modem << Longitude:      6.579682
    2022-07-06T08:36:56.594Z DEBUG modem << Altitude:       98.4 m
    2022-07-06T08:36:56.595Z DEBUG modem << Accuracy:       3.1 m
    2022-07-06T08:36:56.596Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:56.597Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:56.600Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:56.601Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:56.603Z DEBUG modem << Time (UTC):     08:36:42.464
    2022-07-06T08:36:56.604Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:56.633Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:56.636Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:36:56.639Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:56.641Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:56.642Z DEBUG modem << $GPGGA,083642.46,6223.09752,N,00634.78092,E,1,05,2.22,98.36,M,,M,,*41
    2022-07-06T08:36:56.643Z DEBUG modem << $GPGLL,6223.09752,N,00634.78092,E,083642.46,A,A*69
    2022-07-06T08:36:56.645Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.54,2.22,2.75,1*1F
    2022-07-06T08:36:56.646Z DEBUG modem << $GPGSV,4,1,13,5,23,038,33,7,13,338,41,8,00,272,,10,00,162,,1*5F
    2022-07-06T08:36:56.647Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,46,18,64,103,33,20,01,016,,1*69
    2022-07-06T08:36:56.648Z DEBUG modem << $GPGSV,4,3,13,23,19,142,24,26,53,191,48,27,37,265,43,28,,,26,1*57
    2022-07-06T08:36:56.651Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:36:56.652Z DEBUG modem << $GPRMC,083642.46,A,6223.09752,N,00634.78092,E,0.15,0.00,060722,,,A,V*21
    2022-07-06T08:36:57.558Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:36:57.590Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:57.593Z DEBUG modem << Latitude:       62.384956
    2022-07-06T08:36:57.596Z DEBUG modem << Longitude:      6.579688
    2022-07-06T08:36:57.598Z DEBUG modem << Altitude:       97.7 m
    2022-07-06T08:36:57.599Z DEBUG modem << Accuracy:       3.0 m
    2022-07-06T08:36:57.601Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:57.604Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:57.605Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:57.606Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:57.608Z DEBUG modem << Time (UTC):     08:36:43.464
    2022-07-06T08:36:57.609Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:57.610Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:57.641Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:36:57.644Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:57.647Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:57.649Z DEBUG modem << $GPGGA,083643.46,6223.09736,N,00634.78125,E,1,05,2.22,97.69,M,,M,,*4A
    2022-07-06T08:36:57.650Z DEBUG modem << $GPGLL,6223.09736,N,00634.78125,E,083643.46,A,A*67
    2022-07-06T08:36:57.680Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.54,2.22,2.76,1*1C
    2022-07-06T08:36:57.684Z DEBUG modem << $GPGSV,4,1,13,5,23,038,33,7,13,338,42,8,00,272,,10,00,162,,1*5C
    2022-07-06T08:36:57.687Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,46,18,64,103,32,20,01,016,,1*68
    2022-07-06T08:36:57.688Z DEBUG modem << $GPGSV,4,3,13,23,19,142,24,26,53,191,48,27,37,265,43,28,,,26,1*57
    2022-07-06T08:36:57.689Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:36:57.691Z DEBUG modem << $GPRMC,083643.46,A,6223.09736,N,00634.78125,E,0.18,0.00,060722,,,A,V*22
    2022-07-06T08:36:58.560Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:36:58.593Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:58.596Z DEBUG modem << Latitude:       62.384953
    2022-07-06T08:36:58.599Z DEBUG modem << Longitude:      6.579687
    2022-07-06T08:36:58.601Z DEBUG modem << Altitude:       96.8 m
    2022-07-06T08:36:58.603Z DEBUG modem << Accuracy:       3.0 m
    2022-07-06T08:36:58.605Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:36:58.607Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:58.608Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:58.608Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:58.609Z DEBUG modem << Time (UTC):     08:36:44.464
    2022-07-06T08:36:58.610Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:58.611Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:58.640Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:36:58.643Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:58.645Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:58.647Z DEBUG modem << $GPGGA,083644.46,6223.09721,N,00634.78122,E,1,05,2.22,96.75,M,,M,,*40
    2022-07-06T08:36:58.649Z DEBUG modem << $GPGLL,6223.09721,N,00634.78122,E,083644.46,A,A*61
    2022-07-06T08:36:58.651Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.54,2.22,2.76,1*1C
    2022-07-06T08:36:58.653Z DEBUG modem << $GPGSV,4,1,13,5,23,038,33,7,13,338,42,8,00,272,,10,00,162,,1*5C
    2022-07-06T08:36:58.655Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,46,18,64,103,32,20,01,016,,1*68
    2022-07-06T08:36:58.657Z DEBUG modem << $GPGSV,4,3,13,23,19,142,24,26,53,191,48,27,37,265,43,28,,,25,1*54
    2022-07-06T08:36:58.658Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:36:58.659Z DEBUG modem << $GPRMC,083644.46,A,6223.09721,N,00634.78122,E,0.14,0.00,060722,,,A,V*28
    2022-07-06T08:36:59.561Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:36:59.592Z DEBUG modem << -----------------------------------
    2022-07-06T08:36:59.595Z DEBUG modem << Latitude:       62.384949
    2022-07-06T08:36:59.598Z DEBUG modem << Longitude:      6.579683
    2022-07-06T08:36:59.599Z DEBUG modem << Altitude:       96.0 m
    2022-07-06T08:36:59.601Z DEBUG modem << Accuracy:       3.0 m
    2022-07-06T08:36:59.602Z DEBUG modem << Speed:          0.2 m/s
    2022-07-06T08:36:59.605Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:36:59.607Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:36:59.608Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:36:59.609Z DEBUG modem << Time (UTC):     08:36:45.464
    2022-07-06T08:36:59.610Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:36:59.640Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:36:59.643Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:36:59.645Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:36:59.647Z DEBUG modem << NMEA strings:
    2022-07-06T08:36:59.649Z DEBUG modem << $GPGGA,083645.46,6223.09693,N,00634.78097,E,1,05,2.22,96.01,M,,M,,*45
    2022-07-06T08:36:59.650Z DEBUG modem << $GPGLL,6223.09693,N,00634.78097,E,083645.46,A,A*67
    2022-07-06T08:36:59.651Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.54,2.22,2.76,1*1C
    2022-07-06T08:36:59.653Z DEBUG modem << $GPGSV,4,1,13,5,23,038,33,7,13,338,42,8,00,272,,10,00,162,,1*5C
    2022-07-06T08:36:59.655Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,46,18,64,103,32,20,01,016,,1*68
    2022-07-06T08:36:59.657Z DEBUG modem << $GPGSV,4,3,13,23,19,142,24,26,53,190,48,27,37,265,43,28,,,25,1*55
    2022-07-06T08:36:59.658Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:36:59.659Z DEBUG modem << $GPRMC,083645.46,A,6223.09693,N,00634.78097,E,0.31,0.00,060722,,,A,V*29
    2022-07-06T08:37:00.559Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:37:00.591Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:00.593Z DEBUG modem << Latitude:       62.384947
    2022-07-06T08:37:00.596Z DEBUG modem << Longitude:      6.579681
    2022-07-06T08:37:00.598Z DEBUG modem << Altitude:       95.7 m
    2022-07-06T08:37:00.599Z DEBUG modem << Accuracy:       3.0 m
    2022-07-06T08:37:00.600Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:37:00.602Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:37:00.604Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:00.605Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:00.606Z DEBUG modem << Time (UTC):     08:36:46.464
    2022-07-06T08:37:00.607Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:37:00.608Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:37:00.638Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:37:00.640Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:37:00.642Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:00.644Z DEBUG modem << $GPGGA,083646.46,6223.09680,N,00634.78086,E,1,05,2.22,95.71,M,,M,,*40
    2022-07-06T08:37:00.645Z DEBUG modem << $GPGLL,6223.09680,N,00634.78086,E,083646.46,A,A*66
    2022-07-06T08:37:00.648Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.54,2.22,2.76,1*1C
    2022-07-06T08:37:00.649Z DEBUG modem << $GPGSV,4,1,13,5,23,038,34,7,13,338,42,8,00,272,,10,00,162,,1*5B
    2022-07-06T08:37:00.651Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,46,18,64,103,31,20,01,016,,1*6B
    2022-07-06T08:37:00.653Z DEBUG modem << $GPGSV,4,3,13,23,19,142,25,26,53,190,48,27,37,265,43,28,,,25,1*54
    2022-07-06T08:37:00.655Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:00.656Z DEBUG modem << $GPRMC,083646.46,A,6223.09680,N,00634.78086,E,0.24,0.00,060722,,,A,V*2C
    2022-07-06T08:37:01.559Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:37:01.591Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:01.593Z DEBUG modem << Latitude:       62.384948
    2022-07-06T08:37:01.596Z DEBUG modem << Longitude:      6.579689
    2022-07-06T08:37:01.598Z DEBUG modem << Altitude:       96.1 m
    2022-07-06T08:37:01.599Z DEBUG modem << Accuracy:       3.0 m
    2022-07-06T08:37:01.600Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:37:01.603Z DEBUG modem << Speed accuracy: 0.8 m/s
    2022-07-06T08:37:01.605Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:01.606Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:01.607Z DEBUG modem << Time (UTC):     08:36:47.464
    2022-07-06T08:37:01.607Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:37:01.608Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:37:01.637Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:37:01.640Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:37:01.644Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:01.645Z DEBUG modem << $GPGGA,083647.46,6223.09687,N,00634.78135,E,1,05,2.22,96.07,M,,M,,*4D
    2022-07-06T08:37:01.646Z DEBUG modem << $GPGLL,6223.09687,N,00634.78135,E,083647.46,A,A*69
    2022-07-06T08:37:01.648Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.54,2.22,2.76,1*1C
    2022-07-06T08:37:01.650Z DEBUG modem << $GPGSV,4,1,13,5,23,038,34,7,13,338,42,8,00,272,,10,00,162,,1*5B
    2022-07-06T08:37:01.652Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,47,18,64,103,31,20,01,016,,1*6A
    2022-07-06T08:37:01.654Z DEBUG modem << $GPGSV,4,3,13,23,19,142,25,26,53,190,48,27,37,265,43,28,,,28,1*59
    2022-07-06T08:37:01.655Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:01.656Z DEBUG modem << $GPRMC,083647.46,A,6223.09687,N,00634.78135,E,0.16,0.00,060722,,,A,V*22
    2022-07-06T08:37:02.561Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:37:02.595Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:02.598Z DEBUG modem << Latitude:       62.384943
    2022-07-06T08:37:02.601Z DEBUG modem << Longitude:      6.579672
    2022-07-06T08:37:02.603Z DEBUG modem << Altitude:       95.3 m
    2022-07-06T08:37:02.606Z DEBUG modem << Accuracy:       3.0 m
    2022-07-06T08:37:02.607Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:02.608Z DEBUG modem << Speed accuracy: 0.9 m/s
    2022-07-06T08:37:02.609Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:02.610Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:02.611Z DEBUG modem << Time (UTC):     08:36:48.464
    2022-07-06T08:37:02.612Z DEBUG modem << PDOP:           3.5
    2022-07-06T08:37:02.613Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:37:02.615Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:37:02.645Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:37:02.648Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:02.651Z DEBUG modem << $GPGGA,083648.46,6223.09656,N,00634.78032,E,1,05,2.22,95.32,M,,M,,*4D
    2022-07-06T08:37:02.653Z DEBUG modem << $GPGLL,6223.09656,N,00634.78032,E,083648.46,A,A*6C
    2022-07-06T08:37:02.656Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.55,2.22,2.76,1*1D
    2022-07-06T08:37:02.688Z DEBUG modem << $GPGSV,4,1,13,5,23,038,32,7,13,338,41,8,00,272,,10,00,162,,1*5E
    2022-07-06T08:37:02.690Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,47,18,64,103,29,20,01,016,,1*63
    2022-07-06T08:37:02.694Z DEBUG modem << $GPGSV,4,3,13,23,19,142,26,26,53,190,46,27,37,265,42,28,,,25,1*58
    2022-07-06T08:37:02.695Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:02.696Z DEBUG modem << $GPRMC,083648.46,A,6223.09656,N,00634.78032,E,1.94,0.00,060722,,,A,V*2C
    2022-07-06T08:37:03.544Z DEBUG modem << [1;1H[2JTracking:  8 Using:  2 Unhealthy: 1
    2022-07-06T08:37:03.576Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:03.579Z DEBUG modem << Latitude:       62.384939
    2022-07-06T08:37:03.582Z DEBUG modem << Longitude:      6.579654
    2022-07-06T08:37:03.584Z DEBUG modem << Altitude:       94.6 m
    2022-07-06T08:37:03.585Z DEBUG modem << Accuracy:       3.5 m
    2022-07-06T08:37:03.587Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:03.589Z DEBUG modem << Speed accuracy: 1.6 m/s
    2022-07-06T08:37:03.591Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:03.592Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:03.594Z DEBUG modem << Time (UTC):     08:36:49.464
    2022-07-06T08:37:03.595Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:03.596Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:03.627Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:03.629Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:03.632Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:03.634Z DEBUG modem << $GPGGA,083649.46,6223.09635,N,00634.77926,E,1,02,100.00,94.62,M,,M,,*4A
    2022-07-06T08:37:03.635Z DEBUG modem << $GPGLL,6223.09635,N,00634.77926,E,083649.46,A,A*6B
    2022-07-06T08:37:03.669Z DEBUG modem << $GPGSA,A,3,07,23,,,,,,,,,,,100.00,100.00,100.00,1*18
    2022-07-06T08:37:03.672Z DEBUG modem << $GPGSV,4,1,13,5,23,038,31,7,13,338,41,8,00,272,,10,00,162,,1*5D
    2022-07-06T08:37:03.674Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,10,18,64,103,24,20,01,016,,1*6C
    2022-07-06T08:37:03.676Z DEBUG modem << $GPGSV,4,3,13,23,19,142,26,26,53,190,10,27,37,265,10,28,,,24,1*5D
    2022-07-06T08:37:03.677Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:03.678Z DEBUG modem << $GPRMC,083649.46,A,6223.09635,N,00634.77926,E,1.93,0.00,060722,,,A,V*2C
    2022-07-06T08:37:04.547Z DEBUG modem << [1;1H[2JTracking:  8 Using:  1 Unhealthy: 1
    2022-07-06T08:37:04.579Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:04.582Z DEBUG modem << Latitude:       62.384936
    2022-07-06T08:37:04.585Z DEBUG modem << Longitude:      6.579637
    2022-07-06T08:37:04.586Z DEBUG modem << Altitude:       93.9 m
    2022-07-06T08:37:04.587Z DEBUG modem << Accuracy:       4.5 m
    2022-07-06T08:37:04.588Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:04.591Z DEBUG modem << Speed accuracy: 2.0 m/s
    2022-07-06T08:37:04.592Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:04.594Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:04.594Z DEBUG modem << Time (UTC):     08:36:50.464
    2022-07-06T08:37:04.595Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:04.596Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:04.633Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:04.636Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:04.640Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:04.643Z DEBUG modem << $GPGGA,083650.46,6223.09614,N,00634.77821,E,1,01,100.00,93.92,M,,M,,*4C
    2022-07-06T08:37:04.685Z DEBUG modem << $GPGLL,6223.09614,N,00634.77821,E,083650.46,A,A*66
    2022-07-06T08:37:04.688Z DEBUG modem << $GPGSA,A,3,23,,,,,,,,,,,,100.00,100.00,100.00,1*1F
    2022-07-06T08:37:04.693Z DEBUG modem << $GPGSV,4,1,13,5,23,038,26,7,13,338,10,8,00,272,,10,00,162,,1*5F
    2022-07-06T08:37:04.695Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,16,18,64,103,22,20,01,016,,1*6C
    2022-07-06T08:37:04.698Z DEBUG modem << $GPGSV,4,3,13,23,19,141,24,26,53,190,20,27,37,265,18,28,,,24,1*57
    2022-07-06T08:37:04.700Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:04.702Z DEBUG modem << $GPRMC,083650.46,A,6223.09614,N,00634.77821,E,1.93,0.00,060722,,,A,V*21
    2022-07-06T08:37:05.545Z DEBUG modem << [1;1H[2JTracking:  8 Using:  1 Unhealthy: 1
    2022-07-06T08:37:05.581Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:05.583Z DEBUG modem << Latitude:       62.384932
    2022-07-06T08:37:05.586Z DEBUG modem << Longitude:      6.579619
    2022-07-06T08:37:05.588Z DEBUG modem << Altitude:       93.2 m
    2022-07-06T08:37:05.590Z DEBUG modem << Accuracy:       6.0 m
    2022-07-06T08:37:05.592Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:05.593Z DEBUG modem << Speed accuracy: 2.4 m/s
    2022-07-06T08:37:05.594Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:05.594Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:05.595Z DEBUG modem << Time (UTC):     08:36:51.464
    2022-07-06T08:37:05.596Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:05.596Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:05.597Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:05.629Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:05.633Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:05.635Z DEBUG modem << $GPGGA,083651.46,6223.09592,N,00634.77717,E,1,01,100.00,93.22,M,,M,,*41
    2022-07-06T08:37:05.637Z DEBUG modem << $GPGLL,6223.09592,N,00634.77717,E,083651.46,A,A*60
    2022-07-06T08:37:05.670Z DEBUG modem << $GPGSA,A,3,23,,,,,,,,,,,,100.00,100.00,100.00,1*1F
    2022-07-06T08:37:05.673Z DEBUG modem << $GPGSV,4,1,13,5,23,038,23,7,13,338,17,8,00,272,,10,00,162,,1*5D
    2022-07-06T08:37:05.675Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,20,18,64,103,21,20,01,016,,1*6A
    2022-07-06T08:37:05.677Z DEBUG modem << $GPGSV,4,3,13,23,19,141,25,26,53,190,24,27,37,265,24,28,,,25,1*5C
    2022-07-06T08:37:05.678Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:05.679Z DEBUG modem << $GPRMC,083651.46,A,6223.09592,N,00634.77717,E,1.92,0.00,060722,,,A,V*26
    2022-07-06T08:37:06.543Z DEBUG modem << [1;1H[2JTracking:  8 Using:  1 Unhealthy: 1
    2022-07-06T08:37:06.580Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:06.584Z DEBUG modem << Latitude:       62.384928
    2022-07-06T08:37:06.587Z DEBUG modem << Longitude:      6.579602
    2022-07-06T08:37:06.589Z DEBUG modem << Altitude:       92.5 m
    2022-07-06T08:37:06.591Z DEBUG modem << Accuracy:       8.0 m
    2022-07-06T08:37:06.592Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:06.594Z DEBUG modem << Speed accuracy: 2.8 m/s
    2022-07-06T08:37:06.596Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:06.598Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:06.600Z DEBUG modem << Time (UTC):     08:36:52.464
    2022-07-06T08:37:06.603Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:06.606Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:06.608Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:06.612Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:06.649Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:06.653Z DEBUG modem << $GPGGA,083652.46,6223.09569,N,00634.77614,E,1,01,100.00,92.53,M,,M,,*43
    2022-07-06T08:37:06.656Z DEBUG modem << $GPGLL,6223.09569,N,00634.77614,E,083652.46,A,A*65
    2022-07-06T08:37:06.658Z DEBUG modem << $GPGSA,A,3,23,,,,,,,,,,,,100.00,100.00,100.00,1*1F
    2022-07-06T08:37:06.659Z DEBUG modem << $GPGSV,4,1,13,5,23,038,20,7,13,338,19,8,00,272,,10,00,162,,1*50
    2022-07-06T08:37:06.661Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,20,18,64,103,19,20,01,016,,1*61
    2022-07-06T08:37:06.700Z DEBUG modem << $GPGSV,4,3,13,23,19,141,24,26,53,190,22,27,37,265,25,28,,,25,1*5A
    2022-07-06T08:37:06.704Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:06.706Z DEBUG modem << $GPRMC,083652.46,A,6223.09569,N,00634.77614,E,1.91,0.00,060722,,,A,V*20
    2022-07-06T08:37:07.551Z DEBUG modem << [1;1H[2JTracking:  8 Using:  2 Unhealthy: 1
    2022-07-06T08:37:07.588Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:07.591Z DEBUG modem << Latitude:       62.384924
    2022-07-06T08:37:07.594Z DEBUG modem << Longitude:      6.579585
    2022-07-06T08:37:07.596Z DEBUG modem << Altitude:       91.9 m
    2022-07-06T08:37:07.598Z DEBUG modem << Accuracy:       10.4 m
    2022-07-06T08:37:07.600Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:07.601Z DEBUG modem << Speed accuracy: 3.0 m/s
    2022-07-06T08:37:07.603Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:07.605Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:07.606Z DEBUG modem << Time (UTC):     08:36:53.464
    2022-07-06T08:37:07.608Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:07.610Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:07.614Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:07.616Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:07.652Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:07.655Z DEBUG modem << $GPGGA,083653.46,6223.09546,N,00634.77508,E,1,02,100.00,91.87,M,,M,,*48
    2022-07-06T08:37:07.657Z DEBUG modem << $GPGLL,6223.09546,N,00634.77508,E,083653.46,A,A*67
    2022-07-06T08:37:07.659Z DEBUG modem << $GPGSA,A,3,23,27,,,,,,,,,,,100.00,100.00,100.00,1*1A
    2022-07-06T08:37:07.661Z DEBUG modem << $GPGSV,4,1,13,5,23,038,22,7,13,338,20,8,00,272,,10,00,162,,1*58
    2022-07-06T08:37:07.693Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,21,18,64,103,19,20,01,016,,1*60
    2022-07-06T08:37:07.696Z DEBUG modem << $GPGSV,4,3,13,23,19,141,22,26,53,190,21,27,37,265,25,28,,,24,1*5E
    2022-07-06T08:37:07.698Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:07.700Z DEBUG modem << $GPRMC,083653.46,A,6223.09546,N,00634.77508,E,1.94,0.00,060722,,,A,V*27
    2022-07-06T08:37:08.550Z DEBUG modem << [1;1H[2JTracking:  8 Using:  2 Unhealthy: 1
    2022-07-06T08:37:08.589Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:08.592Z DEBUG modem << Latitude:       62.384921
    2022-07-06T08:37:08.595Z DEBUG modem << Longitude:      6.579567
    2022-07-06T08:37:08.597Z DEBUG modem << Altitude:       91.2 m
    2022-07-06T08:37:08.599Z DEBUG modem << Accuracy:       13.0 m
    2022-07-06T08:37:08.600Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:08.601Z DEBUG modem << Speed accuracy: 3.3 m/s
    2022-07-06T08:37:08.603Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:08.604Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:08.605Z DEBUG modem << Time (UTC):     08:36:54.464
    2022-07-06T08:37:08.606Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:08.607Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:08.608Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:08.611Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:08.612Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:08.646Z DEBUG modem << $GPGGA,083654.46,6223.09523,N,00634.77403,E,1,02,100.00,91.19,M,,M,,*41
    2022-07-06T08:37:08.649Z DEBUG modem << $GPGLL,6223.09523,N,00634.77403,E,083654.46,A,A*69
    2022-07-06T08:37:08.652Z DEBUG modem << $GPGSA,A,3,23,27,,,,,,,,,,,100.00,100.00,100.00,1*1A
    2022-07-06T08:37:08.653Z DEBUG modem << $GPGSV,4,1,13,5,23,038,23,7,13,338,20,8,00,272,,10,00,162,,1*59
    2022-07-06T08:37:08.655Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,22,18,64,103,21,20,01,016,,1*68
    2022-07-06T08:37:08.657Z DEBUG modem << $GPGSV,4,3,13,23,19,141,19,26,53,190,21,27,37,265,25,28,,,25,1*57
    2022-07-06T08:37:08.659Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:08.661Z DEBUG modem << $GPRMC,083654.46,A,6223.09523,N,00634.77403,E,1.94,0.00,060722,,,A,V*29
    2022-07-06T08:37:09.556Z DEBUG modem << [1;1H[2JTracking:  9 Using:  2 Unhealthy: 1
    2022-07-06T08:37:09.559Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:09.600Z DEBUG modem << Latitude:       62.384917
    2022-07-06T08:37:09.604Z DEBUG modem << Longitude:      6.579549
    2022-07-06T08:37:09.607Z DEBUG modem << Altitude:       90.5 m
    2022-07-06T08:37:09.609Z DEBUG modem << Accuracy:       15.9 m
    2022-07-06T08:37:09.610Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:09.612Z DEBUG modem << Speed accuracy: 3.5 m/s
    2022-07-06T08:37:09.615Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:09.618Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:09.620Z DEBUG modem << Time (UTC):     08:36:55.464
    2022-07-06T08:37:09.622Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:09.624Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:09.626Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:09.628Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:09.630Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:09.632Z DEBUG modem << $GPGGA,083655.46,6223.09500,N,00634.77293,E,1,02,100.00,90.54,M,,M,,*46
    2022-07-06T08:37:09.668Z DEBUG modem << $GPGLL,6223.09500,N,00634.77293,E,083655.46,A,A*66
    2022-07-06T08:37:09.671Z DEBUG modem << $GPGSA,A,3,23,27,,,,,,,,,,,100.00,100.00,100.00,1*1A
    2022-07-06T08:37:09.674Z DEBUG modem << $GPGSV,4,1,13,5,23,038,19,7,13,338,18,8,00,272,,10,00,162,,1*5B
    2022-07-06T08:37:09.676Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,19,18,64,103,19,20,01,016,,1*6B
    2022-07-06T08:37:09.679Z DEBUG modem << $GPGSV,4,3,13,23,19,141,17,26,53,190,18,27,37,265,23,28,,,25,1*55
    2022-07-06T08:37:09.681Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:09.685Z DEBUG modem << $GPRMC,083655.46,A,6223.09500,N,00634.77293,E,1.96,0.00,060722,,,A,V*24
    2022-07-06T08:37:10.556Z DEBUG modem << [1;1H[2JTracking:  9 Using:  2 Unhealthy: 1
    2022-07-06T08:37:10.620Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:10.625Z DEBUG modem << Latitude:       62.384913
    2022-07-06T08:37:10.628Z DEBUG modem << Longitude:      6.579531
    2022-07-06T08:37:10.631Z DEBUG modem << Altitude:       89.9 m
    2022-07-06T08:37:10.636Z DEBUG modem << Accuracy:       18.9 m
    2022-07-06T08:37:10.639Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:10.643Z DEBUG modem << Speed accuracy: 3.8 m/s
    2022-07-06T08:37:10.646Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:10.649Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:10.653Z DEBUG modem << Time (UTC):     08:36:56.464
    2022-07-06T08:37:10.657Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:10.661Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:10.665Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:10.668Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:10.671Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:10.675Z DEBUG modem << $GPGGA,083656.46,6223.09478,N,00634.77184,E,1,02,100.00,89.88,M,,M,,*47
    2022-07-06T08:37:10.677Z DEBUG modem << $GPGLL,6223.09478,N,00634.77184,E,083656.46,A,A*6E
    2022-07-06T08:37:10.679Z DEBUG modem << $GPGSA,A,3,23,27,,,,,,,,,,,100.00,100.00,100.00,1*1A
    2022-07-06T08:37:10.681Z DEBUG modem << $GPGSV,4,1,13,5,23,038,21,7,13,338,20,8,00,272,,10,00,162,,1*5B
    2022-07-06T08:37:10.722Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,19,18,64,103,19,20,00,016,,1*6A
    2022-07-06T08:37:10.726Z DEBUG modem << $GPGSV,4,3,13,23,19,141,16,26,53,190,19,27,37,265,23,28,,,25,1*55
    2022-07-06T08:37:10.739Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:10.742Z DEBUG modem << $GPRMC,083656.46,A,6223.09478,N,00634.77184,E,1.97,0.00,060722,,,A,V*2D
    2022-07-06T08:37:11.561Z DEBUG modem << [1;1H[2JTracking: 11 Using:  1 Unhealthy: 1
    2022-07-06T08:37:11.608Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:11.611Z DEBUG modem << Latitude:       62.384909
    2022-07-06T08:37:11.613Z DEBUG modem << Longitude:      6.579513
    2022-07-06T08:37:11.615Z DEBUG modem << Altitude:       89.2 m
    2022-07-06T08:37:11.617Z DEBUG modem << Accuracy:       22.2 m
    2022-07-06T08:37:11.619Z DEBUG modem << Speed:          1.0 m/s
    2022-07-06T08:37:11.620Z DEBUG modem << Speed accuracy: 4.0 m/s
    2022-07-06T08:37:11.625Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:11.627Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:11.629Z DEBUG modem << Time (UTC):     08:36:57.464
    2022-07-06T08:37:11.631Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:11.634Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:11.636Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:11.638Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:11.640Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:11.642Z DEBUG modem << $GPGGA,083657.46,6223.09455,N,00634.77077,E,1,01,100.00,89.21,M,,M,,*44
    2022-07-06T08:37:11.680Z DEBUG modem << $GPGLL,6223.09455,N,00634.77077,E,083657.46,A,A*6D
    2022-07-06T08:37:11.683Z DEBUG modem << $GPGSA,A,3,23,,,,,,,,,,,,100.00,100.00,100.00,1*1F
    2022-07-06T08:37:11.686Z DEBUG modem << $GPGSV,4,1,13,5,23,038,23,7,13,338,20,8,00,272,,10,00,162,,1*59
    2022-07-06T08:37:11.688Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,21,18,64,103,17,20,00,016,,1*6F
    2022-07-06T08:37:11.691Z DEBUG modem << $GPGSV,4,3,13,23,19,141,16,26,53,190,21,27,37,265,41,28,,,24,1*5B
    2022-07-06T08:37:11.692Z DEBUG modem << $GPGSV,4,4,13,29,20,093,25,1*52
    2022-07-06T08:37:11.728Z DEBUG modem << $GPRMC,083657.46,A,6223.09455,N,00634.77077,E,1.97,0.00,060722,,,A,V*2E
    2022-07-06T08:37:12.574Z DEBUG modem << [1;1H[2JTracking: 12 Using:  1 Unhealthy: 1
    2022-07-06T08:37:12.617Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:12.620Z DEBUG modem << Seconds since last fix: 1
    2022-07-06T08:37:12.623Z DEBUG modem << Searching [/]
    2022-07-06T08:37:12.625Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:12.664Z DEBUG modem << $GPGGA,083658.46,,,,,0,01,99.99,,M,,M,,*65
    2022-07-06T08:37:12.667Z DEBUG modem << $GPGLL,,,,,083658.46,V,N*48
    2022-07-06T08:37:12.671Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:37:12.675Z DEBUG modem << $GPGSV,4,1,13,5,23,038,23,7,13,338,22,8,00,272,,10,00,162,,1*5B
    2022-07-06T08:37:12.678Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,24,18,64,103,16,20,00,016,,1*6B
    2022-07-06T08:37:12.681Z DEBUG modem << $GPGSV,4,3,13,23,19,141,19,26,53,190,21,27,37,265,41,28,,,25,1*55
    2022-07-06T08:37:12.685Z DEBUG modem << $GPGSV,4,4,13,29,20,093,25,1*52
    2022-07-06T08:37:12.689Z DEBUG modem << $GPRMC,083658.46,V,,,,,,,060722,,,N,V*04
    2022-07-06T08:37:13.555Z DEBUG modem << [1;1H[2JTracking: 11 Using:  1 Unhealthy: 0
    2022-07-06T08:37:13.592Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:13.595Z DEBUG modem << Seconds since last fix: 1
    2022-07-06T08:37:13.598Z DEBUG modem << Searching [-]
    2022-07-06T08:37:13.600Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:13.602Z DEBUG modem << $GPGGA,083659.46,,,,,0,01,99.99,,M,,M,,*64
    2022-07-06T08:37:13.603Z DEBUG modem << $GPGLL,,,,,083659.46,V,N*49
    2022-07-06T08:37:13.604Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:37:13.606Z DEBUG modem << $GPGSV,3,1,12,5,23,038,24,7,13,338,22,8,00,272,,10,00,162,,1*5A
    2022-07-06T08:37:13.607Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,25,18,64,103,19,20,00,016,,1*63
    2022-07-06T08:37:13.641Z DEBUG modem << $GPGSV,3,3,12,23,19,141,19,26,53,190,23,27,37,265,38,29,20,093,24,1*67
    2022-07-06T08:37:13.645Z DEBUG modem << $GPRMC,083659.46,V,,,,,,,060722,,,N,V*05
    2022-07-06T08:37:14.557Z DEBUG modem << [1;1H[2JTracking: 11 Using:  3 Unhealthy: 0
    2022-07-06T08:37:14.594Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:14.598Z DEBUG modem << Seconds since last fix: 2
    2022-07-06T08:37:14.600Z DEBUG modem << Searching [\]
    2022-07-06T08:37:14.602Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:14.604Z DEBUG modem << $GPGGA,083700.46,,,,,0,03,99.99,,M,,M,,*6B
    2022-07-06T08:37:14.606Z DEBUG modem << $GPGLL,,,,,083700.46,V,N*44
    2022-07-06T08:37:14.607Z DEBUG modem << $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
    2022-07-06T08:37:14.608Z DEBUG modem << $GPGSV,3,1,12,5,23,038,24,7,13,338,24,8,00,272,,10,00,162,,1*5C
    2022-07-06T08:37:14.610Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,26,18,64,103,22,20,00,016,,1*68
    2022-07-06T08:37:14.646Z DEBUG modem << $GPGSV,3,3,12,23,19,141,21,26,53,190,24,27,37,265,35,29,20,093,24,1*66
    2022-07-06T08:37:14.649Z DEBUG modem << $GPRMC,083700.46,V,,,,,,,060722,,,N,V*08
    2022-07-06T08:37:15.559Z DEBUG modem << [1;1H[2JTracking:  9 Using:  5 Unhealthy: 0
    2022-07-06T08:37:15.595Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:15.640Z DEBUG modem << Latitude:       62.384973
    2022-07-06T08:37:15.643Z DEBUG modem << Longitude:      6.579697
    2022-07-06T08:37:15.647Z DEBUG modem << Altitude:       103.4 m
    2022-07-06T08:37:15.649Z DEBUG modem << Accuracy:       34.0 m
    2022-07-06T08:37:15.652Z DEBUG modem << Speed:          0.9 m/s
    2022-07-06T08:37:15.654Z DEBUG modem << Speed accuracy: 1.7 m/s
    2022-07-06T08:37:15.656Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:15.657Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:15.659Z DEBUG modem << Time (UTC):     08:37:01.464
    2022-07-06T08:37:15.660Z DEBUG modem << PDOP:           3.6
    2022-07-06T08:37:15.661Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:37:15.662Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:37:15.663Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:37:15.664Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:15.698Z DEBUG modem << $GPGGA,083701.46,6223.09840,N,00634.78180,E,1,05,2.23,103.44,M,,M,,*7E
    2022-07-06T08:37:15.701Z DEBUG modem << $GPGLL,6223.09840,N,00634.78180,E,083701.46,A,A*61
    2022-07-06T08:37:15.704Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.56,2.23,2.78,1*11
    2022-07-06T08:37:15.706Z DEBUG modem << $GPGSV,3,1,12,5,23,038,24,7,13,338,25,8,00,272,,10,00,162,,1*5D
    2022-07-06T08:37:15.707Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,25,18,64,103,22,20,00,016,,1*6B
    2022-07-06T08:37:15.708Z DEBUG modem << $GPGSV,3,3,12,23,19,141,21,26,53,190,26,27,37,265,34,29,20,093,,1*63
    2022-07-06T08:37:15.710Z DEBUG modem << $GPRMC,083701.46,A,6223.09840,N,00634.78180,E,1.83,0.00,060722,,,A,V*27
    2022-07-06T08:37:16.573Z DEBUG modem << [1;1H[2JTracking: 10 Using:  5 Unhealthy: 1
    2022-07-06T08:37:16.612Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:16.615Z DEBUG modem << Latitude:       62.384964
    2022-07-06T08:37:16.618Z DEBUG modem << Longitude:      6.579750
    2022-07-06T08:37:16.620Z DEBUG modem << Altitude:       98.4 m
    2022-07-06T08:37:16.621Z DEBUG modem << Accuracy:       23.7 m
    2022-07-06T08:37:16.622Z DEBUG modem << Speed:          0.2 m/s
    2022-07-06T08:37:16.623Z DEBUG modem << Speed accuracy: 1.3 m/s
    2022-07-06T08:37:16.624Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:16.625Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:16.627Z DEBUG modem << Time (UTC):     08:37:02.464
    2022-07-06T08:37:16.628Z DEBUG modem << PDOP:           3.6
    2022-07-06T08:37:16.629Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:37:16.630Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:37:16.631Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:37:16.633Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:16.670Z DEBUG modem << $GPGGA,083702.46,6223.09785,N,00634.78501,E,1,05,2.23,98.43,M,,M,,*42
    2022-07-06T08:37:16.673Z DEBUG modem << $GPGLL,6223.09785,N,00634.78501,E,083702.46,A,A*69
    2022-07-06T08:37:16.676Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.57,2.23,2.78,1*10
    2022-07-06T08:37:16.678Z DEBUG modem << $GPGSV,4,1,13,5,23,038,24,7,13,338,26,8,00,272,,10,00,162,,1*58
    2022-07-06T08:37:16.679Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,26,18,64,103,25,20,00,016,,1*69
    2022-07-06T08:37:16.681Z DEBUG modem << $GPGSV,4,3,13,23,19,141,19,26,53,190,26,27,37,265,34,28,,,33,1*57
    2022-07-06T08:37:16.685Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:16.687Z DEBUG modem << $GPRMC,083702.46,A,6223.09785,N,00634.78501,E,0.32,0.00,060722,,,A,V*24
    2022-07-06T08:37:17.564Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:37:17.602Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:17.604Z DEBUG modem << Latitude:       62.384991
    2022-07-06T08:37:17.607Z DEBUG modem << Longitude:      6.579714
    2022-07-06T08:37:17.610Z DEBUG modem << Altitude:       104.5 m
    2022-07-06T08:37:17.613Z DEBUG modem << Accuracy:       19.8 m
    2022-07-06T08:37:17.615Z DEBUG modem << Speed:          0.1 m/s
    2022-07-06T08:37:17.617Z DEBUG modem << Speed accuracy: 1.3 m/s
    2022-07-06T08:37:17.619Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:17.620Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:17.623Z DEBUG modem << Time (UTC):     08:37:03.464
    2022-07-06T08:37:17.626Z DEBUG modem << PDOP:           3.6
    2022-07-06T08:37:17.628Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:37:17.630Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:37:17.631Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:37:17.633Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:17.669Z DEBUG modem << $GPGGA,083703.46,6223.09946,N,00634.78284,E,1,05,2.23,104.46,M,,M,,*79
    2022-07-06T08:37:17.674Z DEBUG modem << $GPGLL,6223.09946,N,00634.78284,E,083703.46,A,A*63
    2022-07-06T08:37:17.676Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.57,2.23,2.78,1*10
    2022-07-06T08:37:17.678Z DEBUG modem << $GPGSV,4,1,13,5,23,038,25,7,13,338,24,8,00,272,,10,00,162,,1*5B
    2022-07-06T08:37:17.679Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,25,18,64,103,27,20,00,016,,1*68
    2022-07-06T08:37:17.719Z DEBUG modem << $GPGSV,4,3,13,23,19,141,20,26,53,190,26,27,37,265,33,28,,,25,1*5D
    2022-07-06T08:37:17.723Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:17.728Z DEBUG modem << $GPRMC,083703.46,A,6223.09946,N,00634.78284,E,0.11,0.00,060722,,,A,V*2F
    2022-07-06T08:37:18.565Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:37:18.602Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:18.605Z DEBUG modem << Latitude:       62.385009
    2022-07-06T08:37:18.609Z DEBUG modem << Longitude:      6.579739
    2022-07-06T08:37:18.611Z DEBUG modem << Altitude:       105.6 m
    2022-07-06T08:37:18.613Z DEBUG modem << Accuracy:       17.5 m
    2022-07-06T08:37:18.615Z DEBUG modem << Speed:          0.0 m/s
    2022-07-06T08:37:18.616Z DEBUG modem << Speed accuracy: 1.3 m/s
    2022-07-06T08:37:18.618Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:18.619Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:18.620Z DEBUG modem << Time (UTC):     08:37:04.464
    2022-07-06T08:37:18.622Z DEBUG modem << PDOP:           3.6
    2022-07-06T08:37:18.624Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:37:18.628Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:37:18.629Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:37:18.664Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:18.668Z DEBUG modem << $GPGGA,083704.46,6223.10053,N,00634.78433,E,1,05,2.24,105.58,M,,M,,*78
    2022-07-06T08:37:18.671Z DEBUG modem << $GPGLL,6223.10053,N,00634.78433,E,083704.46,A,A*6B
    2022-07-06T08:37:18.672Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.57,2.24,2.78,1*17
    2022-07-06T08:37:18.674Z DEBUG modem << $GPGSV,4,1,13,5,23,038,24,7,13,338,24,8,00,272,,10,00,162,,1*5A
    2022-07-06T08:37:18.713Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,26,18,64,103,29,20,00,016,,1*65
    2022-07-06T08:37:18.716Z DEBUG modem << $GPGSV,4,3,13,23,19,141,19,26,53,190,25,27,37,265,31,28,,,24,1*57
    2022-07-06T08:37:18.719Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:18.721Z DEBUG modem << $GPRMC,083704.46,A,6223.10053,N,00634.78433,E,0.06,0.00,060722,,,A,V*21
    2022-07-06T08:37:19.564Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 1
    2022-07-06T08:37:19.600Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:19.604Z DEBUG modem << Latitude:       62.385003
    2022-07-06T08:37:19.607Z DEBUG modem << Longitude:      6.579710
    2022-07-06T08:37:19.609Z DEBUG modem << Altitude:       100.2 m
    2022-07-06T08:37:19.611Z DEBUG modem << Accuracy:       16.0 m
    2022-07-06T08:37:19.612Z DEBUG modem << Speed:          0.2 m/s
    2022-07-06T08:37:19.614Z DEBUG modem << Speed accuracy: 1.3 m/s
    2022-07-06T08:37:19.615Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:19.616Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:19.619Z DEBUG modem << Time (UTC):     08:37:05.464
    2022-07-06T08:37:19.621Z DEBUG modem << PDOP:           3.6
    2022-07-06T08:37:19.622Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:37:19.624Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:37:19.625Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:37:19.659Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:19.663Z DEBUG modem << $GPGGA,083705.46,6223.10019,N,00634.78262,E,1,05,2.24,100.23,M,,M,,*7C
    2022-07-06T08:37:19.666Z DEBUG modem << $GPGLL,6223.10019,N,00634.78262,E,083705.46,A,A*66
    2022-07-06T08:37:19.668Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.57,2.24,2.78,1*17
    2022-07-06T08:37:19.669Z DEBUG modem << $GPGSV,4,1,13,5,23,038,24,7,13,338,24,8,00,272,,10,00,162,,1*5A
    2022-07-06T08:37:19.704Z DEBUG modem << $GPGSV,4,2,13,13,00,052,,16,65,250,27,18,64,103,27,20,00,016,,1*6A
    2022-07-06T08:37:19.707Z DEBUG modem << $GPGSV,4,3,13,23,19,141,16,26,53,190,25,27,37,265,30,28,,,25,1*58
    2022-07-06T08:37:19.710Z DEBUG modem << $GPGSV,4,4,13,29,20,093,,1*55
    2022-07-06T08:37:19.712Z DEBUG modem << $GPRMC,083705.46,A,6223.10019,N,00634.78262,E,0.30,0.00,060722,,,A,V*29
    2022-07-06T08:37:20.568Z DEBUG modem << [1;1H[2JTracking:  8 Using:  5 Unhealthy: 0
    2022-07-06T08:37:20.607Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:20.617Z DEBUG modem << Latitude:       62.384985
    2022-07-06T08:37:20.657Z DEBUG modem << Longitude:      6.579660
    2022-07-06T08:37:20.662Z DEBUG modem << Altitude:       96.5 m
    2022-07-06T08:37:20.664Z DEBUG modem << Accuracy:       15.4 m
    2022-07-06T08:37:20.666Z DEBUG modem << Speed:          0.2 m/s
    2022-07-06T08:37:20.668Z DEBUG modem << Speed accuracy: 1.4 m/s
    2022-07-06T08:37:20.670Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:20.672Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:20.673Z DEBUG modem << Time (UTC):     08:37:06.464
    2022-07-06T08:37:20.675Z DEBUG modem << PDOP:           3.6
    2022-07-06T08:37:20.677Z DEBUG modem << HDOP:           2.2
    2022-07-06T08:37:20.679Z DEBUG modem << VDOP:           2.8
    2022-07-06T08:37:20.681Z DEBUG modem << TDOP:           1.3
    2022-07-06T08:37:20.682Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:20.683Z DEBUG modem << $GPGGA,083706.46,6223.09912,N,00634.77959,E,1,05,2.24,96.54,M,,M,,*47
    2022-07-06T08:37:20.685Z DEBUG modem << $GPGLL,6223.09912,N,00634.77959,E,083706.46,A,A*63
    2022-07-06T08:37:20.723Z DEBUG modem << $GPGSA,A,3,07,16,23,26,27,,,,,,,,3.57,2.24,2.78,1*17
    2022-07-06T08:37:20.728Z DEBUG modem << $GPGSV,3,1,12,5,23,038,21,7,13,338,24,8,00,272,,10,00,162,,1*59
    2022-07-06T08:37:20.730Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,26,18,64,103,27,20,00,016,,1*6D
    2022-07-06T08:37:20.732Z DEBUG modem << $GPGSV,3,3,12,23,19,141,14,26,53,190,22,27,37,265,29,29,20,093,,1*6D
    2022-07-06T08:37:20.733Z DEBUG modem << $GPRMC,083706.46,A,6223.09912,N,00634.77959,E,0.36,0.00,060722,,,A,V*2A
    2022-07-06T08:37:21.561Z DEBUG modem << [1;1H[2JTracking:  8 Using:  4 Unhealthy: 0
    2022-07-06T08:37:21.600Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:21.604Z DEBUG modem << Latitude:       62.384980
    2022-07-06T08:37:21.606Z DEBUG modem << Longitude:      6.579625
    2022-07-06T08:37:21.608Z DEBUG modem << Altitude:       93.0 m
    2022-07-06T08:37:21.610Z DEBUG modem << Accuracy:       15.1 m
    2022-07-06T08:37:21.612Z DEBUG modem << Speed:          0.5 m/s
    2022-07-06T08:37:21.613Z DEBUG modem << Speed accuracy: 1.5 m/s
    2022-07-06T08:37:21.615Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:21.618Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:21.620Z DEBUG modem << Time (UTC):     08:37:07.464
    2022-07-06T08:37:21.622Z DEBUG modem << PDOP:           5.1
    2022-07-06T08:37:21.624Z DEBUG modem << HDOP:           2.9
    2022-07-06T08:37:21.626Z DEBUG modem << VDOP:           4.2
    2022-07-06T08:37:21.627Z DEBUG modem << TDOP:           2.9
    2022-07-06T08:37:21.667Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:21.671Z DEBUG modem << $GPGGA,083707.46,6223.09882,N,00634.77750,E,1,04,2.88,93.04,M,,M,,*4E
    2022-07-06T08:37:21.674Z DEBUG modem << $GPGLL,6223.09882,N,00634.77750,E,083707.46,A,A*6D
    2022-07-06T08:37:21.676Z DEBUG modem << $GPGSA,A,3,07,16,26,27,,,,,,,,,5.11,2.88,4.22,1*1D
    2022-07-06T08:37:21.677Z DEBUG modem << $GPGSV,3,1,12,5,23,038,18,7,13,338,22,8,00,272,,10,00,162,,1*55
    2022-07-06T08:37:21.680Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,25,18,64,103,25,20,00,016,,1*6C
    2022-07-06T08:37:21.682Z DEBUG modem << $GPGSV,3,3,12,23,19,141,09,26,53,190,21,27,37,265,30,29,20,093,,1*6A
    2022-07-06T08:37:21.685Z DEBUG modem << $GPRMC,083707.46,A,6223.09882,N,00634.77750,E,0.99,0.00,060722,,,A,V*21
    2022-07-06T08:37:22.560Z DEBUG modem << [1;1H[2JTracking:  8 Using:  4 Unhealthy: 0
    2022-07-06T08:37:22.601Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:22.605Z DEBUG modem << Latitude:       62.384979
    2022-07-06T08:37:22.607Z DEBUG modem << Longitude:      6.579618
    2022-07-06T08:37:22.609Z DEBUG modem << Altitude:       89.6 m
    2022-07-06T08:37:22.610Z DEBUG modem << Accuracy:       14.7 m
    2022-07-06T08:37:22.612Z DEBUG modem << Speed:          0.6 m/s
    2022-07-06T08:37:22.614Z DEBUG modem << Speed accuracy: 1.5 m/s
    2022-07-06T08:37:22.617Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:22.619Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:22.620Z DEBUG modem << Time (UTC):     08:37:08.464
    2022-07-06T08:37:22.621Z DEBUG modem << PDOP:           5.1
    2022-07-06T08:37:22.623Z DEBUG modem << HDOP:           2.9
    2022-07-06T08:37:22.624Z DEBUG modem << VDOP:           4.2
    2022-07-06T08:37:22.625Z DEBUG modem << TDOP:           2.9
    2022-07-06T08:37:22.627Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:22.668Z DEBUG modem << $GPGGA,083708.46,6223.09871,N,00634.77711,E,1,04,2.88,89.58,M,,M,,*4A
    2022-07-06T08:37:22.671Z DEBUG modem << $GPGLL,6223.09871,N,00634.77711,E,083708.46,A,A*6B
    2022-07-06T08:37:22.674Z DEBUG modem << $GPGSA,A,3,07,16,26,27,,,,,,,,,5.11,2.88,4.22,1*1D
    2022-07-06T08:37:22.677Z DEBUG modem << $GPGSV,3,1,12,5,23,038,15,7,13,338,24,8,00,272,,10,00,162,,1*5E
    2022-07-06T08:37:22.679Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,27,18,64,103,25,20,00,016,,1*6E
    2022-07-06T08:37:22.720Z DEBUG modem << $GPGSV,3,3,12,23,19,141,12,26,53,190,19,27,37,265,31,29,20,093,,1*6A
    2022-07-06T08:37:22.724Z DEBUG modem << $GPRMC,083708.46,A,6223.09871,N,00634.77711,E,1.08,0.00,060722,,,A,V*2E
    2022-07-06T08:37:23.549Z DEBUG modem << [1;1H[2JTracking:  7 Using:  3 Unhealthy: 0
    2022-07-06T08:37:23.552Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:23.555Z DEBUG modem << Latitude:       62.384983
    2022-07-06T08:37:23.558Z DEBUG modem << Longitude:      6.579613
    2022-07-06T08:37:23.561Z DEBUG modem << Altitude:       89.6 m
    2022-07-06T08:37:23.604Z DEBUG modem << Accuracy:       15.0 m
    2022-07-06T08:37:23.607Z DEBUG modem << Speed:          0.6 m/s
    2022-07-06T08:37:23.610Z DEBUG modem << Speed accuracy: 2.0 m/s
    2022-07-06T08:37:23.612Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:23.615Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:23.617Z DEBUG modem << Time (UTC):     08:37:09.464
    2022-07-06T08:37:23.619Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:23.622Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:23.623Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:23.625Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:23.626Z DEBUG modem << NMEA strings:
    2022-07-06T08:37:23.629Z DEBUG modem << $GPGGA,083709.46,6223.09896,N,00634.77675,E,1,03,100.00,89.64,M,,M,,*4A
    2022-07-06T08:37:23.631Z DEBUG modem << $GPGLL,6223.09896,N,00634.77675,E,083709.46,A,A*60
    2022-07-06T08:37:23.633Z DEBUG modem << $GPGSA,A,3,07,16,27,,,,,,,,,,100.00,100.00,100.00,1*1B
    2022-07-06T08:37:23.671Z DEBUG modem << $GPGSV,3,1,12,5,23,038,12,7,13,338,25,8,00,272,,10,00,162,,1*58
    2022-07-06T08:37:23.674Z DEBUG modem << $GPGSV,3,2,12,13,00,052,,16,65,250,26,18,64,103,25,20,00,016,,1*6F
    2022-07-06T08:37:23.678Z DEBUG modem << $GPGSV,3,3,12,23,19,141,,26,53,190,08,27,37,265,32,29,20,093,,1*6A
    2022-07-06T08:37:23.680Z DEBUG modem << $GPRMC,083709.46,A,6223.09896,N,00634.77675,E,1.08,0.00,060722,,,A,V*25
    2022-07-06T08:37:24.544Z DEBUG modem << [1;1H[2JTracking:  6 Using:  3 Unhealthy: 0
    2022-07-06T08:37:24.590Z DEBUG modem << -----------------------------------
    2022-07-06T08:37:24.593Z DEBUG modem << Latitude:       62.384987
    2022-07-06T08:37:24.597Z DEBUG modem << Longitude:      6.579607
    2022-07-06T08:37:24.599Z DEBUG modem << Altitude:       89.7 m
    2022-07-06T08:37:24.601Z DEBUG modem << Accuracy:       15.7 m
    2022-07-06T08:37:24.604Z DEBUG modem << Speed:          0.6 m/s
    2022-07-06T08:37:24.608Z DEBUG modem << Speed accuracy: 2.4 m/s
    2022-07-06T08:37:24.610Z DEBUG modem << Heading:        0.0 deg
    2022-07-06T08:37:24.612Z DEBUG modem << Date:           2022-07-06
    2022-07-06T08:37:24.614Z DEBUG modem << Time (UTC):     08:37:10.464
    2022-07-06T08:37:24.616Z DEBUG modem << PDOP:           100.0
    2022-07-06T08:37:24.618Z DEBUG modem << HDOP:           100.0
    2022-07-06T08:37:24.620Z DEBUG modem << VDOP:           100.0
    2022-07-06T08:37:24.622Z DEBUG modem << TDOP:           100.0
    2022-07-06T08:37:24.624Z DEBUG modem << NMEA strings:
    It takes some time before it gets a fix due to the placement of the receiver.
    Hope this answers your question.
    Øyvind
  • Thank you Øyvind!
    The Modem Library GNSS interface link is exactly what I was trying to find in the docs.
    "Operation is time multiplexed with LTE modem, and it is possible to use the GPS and QZSS receiver to obtain position either while the LTE is in RRC Idle mode or power saving mode (PSM), or when the LTE modem is completely deactivated."
    I will start testing based off the gnss sample. Thank you.
    Happy to hear, and happy to help!
