nrf9160 mqtt simple example configured to talk to test.mosquitto.org using mutual TLS on port 8884?
Is there a configuration / sample available of mqtt simple to talk to the mosquitto server using an authenticated client on port 8884?  I saw a message on here that was about 2 years old that looked like it was trying to solve the same issue, but the modified sample code does not seem to build with the latest SDK?
Mosquitto has instructions for building the private key and signing the certificate using openssl and a webpage to paste the csr into.
Thank you in advance.
  • Decided to look at the aws_iot code as a reference to what needed to be done.  Took the certificate provisioning code and put in the private key I generated and the CA file referenced on test.mosquitto.org (mosquitto.org.crt (PEM format)).  Not sure what to use for the server certificate.  And not sure what to do with the signed certificate I got back from mosquito via https://test.mosquitto.org/ssl/  Also set the port to 8884.
    When I try to connect I get a -111 error (connection refused).
    The certificates are in proper PEM format.
    Any suggestions on how to get this working?
    Thanks.
    Have a look at the TLS/DTLS configuration chapter in the modem library documentation. You can also provision certificates in the Certificate Manager found in the LTE Link Monitor. Both issue AT command CMNG to provision certs.
    The AWS IoT uses Root CA, Client certificate and private key as described in the AWS IoT library documentation. When provisioning certificates to your board it is important to use correct sec_tag and then refer to this in the MQTT sample with CONFIG_MQTT_TLS_SEC_TAG
    Let me know how that works for you
    Kind regards
    Øyvind
  • We were able to configure the CA, device public cert (signed by mosquito), and device private key (generated locally by openssl) using the Certificate Manager in the LTE Link Monitor and get it to connect to mosquitto's port 8884.
    We tried using what we thought was the correct interface (modem_key_mgmt_write) to programmatically set the above information but that did not work.  No error was returned.  Is that expected to be in PEM format or does it need to be the un-base64'd binary of the key/cert?
    I read the comments about using the link manager to pre-program the security information, but did want to understand how to do it programmatically.
    We also tried connecting to port 8887 which has an intentionally expired certificate and using the verify_peer set to 2 (required) it doesn't fail, which I would expect.  How can I turn on logging in the modem or TLS so I can see why the expired certificate is not being flagged.
    Thank you.
  • Another oddity.  We modified the MQTT sample to configure it for TLS as described 9 hours ago.
    We took the code that connected to port 8884 and the proj.cnf file and merged it into our working code (with GPS, I2C, SPI Flash, etc.) and we can not connect to test.mosquitto.org on port 8884.  We seem to get random errors.   Errors -12, -111, -116, and -104 after some period of trying to connect to the server.
    Any suggestions on how to debug this?  How to get more information from the system as to what's going on?
    Back to frustrated...
  • Sorry to hear about this frustration.
    Yes, we will need to see a modem trace captured with the Trace Collector v2. Make sure to follow instructions and reset device after starting the trace collector. What modem FW and nRF Connect SDK version are you working on?
    When do you get the errors? From nrfxlib\nrf_modem\include\nrf_errno.h
    #define NRF_ENOMEM 12           /**< Not enough space */
    #define NRF_ECONNRESET 104      /**< Connection reset */
    #define NRF_ECONNREFUSED 111    /**< Connection refused */
    #define NRF_ETIMEDOUT 116       /**< Connection timed out */
    Are you able to share more information on you configuration? I found this support ticket regarding ENOMEM and ECONNRESET when connecting to MQTT.
