Hello ,
i m using sdk 15.0.0 and spi example for flash winbond 25q64 read write .
i m successfully read manufacture id,,device id.
but problem is writing and reading data from flash memory.
let me know the any hint.
Hello ,
Hi
I need more information on what exactly you're having trouble with, how are you writing and reading data from the Winbond device exactly? Are you seeing any error/return codes that could give us an idea as to what is going on in your application? Also there are multiple SPI examples in the nRF5 SDK. Which one is your application based on exactly?
Simon
Hello Embol tech ,i m truing to read write from windbond w25q64 pls help for write and read into flash where erase is succesfully pls pls consider me
Please create a new ticket where you describe your issue in detail, as this is an old case at this point and it might not even be you're using the same SDK for development.
Simon
