Unwanted "Leave" command from coordinator
Hello, I developed for my customer, a ZigBee coordinator in last 2019, using nRF5 SDK for Thread and Zigbee v3.2.0.
Now my customer has this issue:
- End Node connected via router, if router deads, the coordinator rejoin it but after few time send "leave" command to end node
Here attached WireShark log file of ZigBee radio communication
Some details:
- end node has NW address E3DF
- router has NW address D01B
- at line 14631 and following, the router deads
- at line 14680 starting end node routing search
- at line 14747 and followings rejon procedure
- at line 14850 Coordinator sends LEAVE command to end node E3DF
What is happened? Why Coordinator sends "Leave" command?
How can we avoid this unwanted behaviour?
Many thanks for your help!
Abele
  • Hi Abele,
    I got a response from the development team today. They are not able to prioritize resources for debugging logs from a product based on an old stack. The nRF5 SDK for Thread and Zigbee v3.2 has a Zigbee stack supporting specification version R21 – which is not certifiable anymore by CSA. To officially introduce new product into the field (including firmware update), after even minimal change in firmware, it must go throughout product certification. Thus switching to newer platform using R22 is essential.
    Additionally, there is a good chance that this bug is fixed in newer versions of the stack and that the issue will resolve itself when migrating to the latest SDK.
    Marte
  • I'm very disappointed for this answer, when I developed the application the SDK 3.x was the new available, and now after few year Nordic don't support it anymore.
    I hoped a best help to issues, expecially when the alternative solution porposed has high impact on already developed project: migrating to the latest SDK practically forces to redo the project, with all difficulty related.
    In addition, the new SDK don't support IAR EWARM (the 3.2 yes, I have developed my project with IAR EWARM)
    Last, peraphs you can ask to development team if there is a possibility to "disable" the leave command on ZigBee SDK 3.2 ?
    This could be a "patch" that has minor impact the project.
    Please, let me know as soon
    Abele
  • Hi Abele,
    As stated in my previous reply, you will not be able to certify Zigbee products that are using R21 of the Zigbee specification anymore. This is not a limitation on our side, but by CSA. Even if the leave problem is fixed you will not be able to certify a new product developed in v3.2 of the SDK.
    Support for R22 of the specification was added in v4.0.0 and has been supported in our SDKs for more than 2,5 years already. I would really recommend migrating to v4.2 if possible, as this version supports ZCL8 as well and there was a lot of fixes between this version and the previous one, but if that is absolutely not possible then you should at least migrate to v4.1. There are still a lot of changes between v3.2 and v4.1, but it will not be as many as with v4.2, and there is still support for IAR. As mentioned by Kenneth previously we have a migration guide available in our documentation: https://infocenter.nordicsemi.com/topic/sdk_tz_v4.1.0/zigbee_r22_migration.html.
    If you experience any issues with v4.1 I will try to help, but if these are bugs that have been fixed in later versions of the stack I unfortunately cannot help.
    Marte
  • Hi Marte,
    I will inform my customer for your answers.
    Nordic help in migration to 4.1 would be very appreciated, I'll keep you updated in next weeks when I can start this work
    Regards
    Abele
    PS the link you paste seems not working ...
  • Hi Abele,
    Thanks for letting me know. For some reason DevZone changed the link to try to link to something on DevZone instead. I have updated the link, but it is also here: https://infocenter.nordicsemi.com/topic/sdk_tz_v4.1.0/zigbee_r22_migration.html.
    Marte
