Unwanted "Leave" command from coordinator
Hello, I developed for my customer, a ZigBee coordinator in last 2019, using nRF5 SDK for Thread and Zigbee v3.2.0.
Now my customer has this issue:
- End Node connected via router, if router deads, the coordinator rejoin it but after few time send "leave" command to end node
Here attached WireShark log file of ZigBee radio communication
Some details:
- end node has NW address E3DF
- router has NW address D01B
- at line 14631 and following, the router deads
- at line 14680 starting end node routing search
- at line 14747 and followings rejon procedure
- at line 14850 Coordinator sends LEAVE command to end node E3DF
What is happened? Why Coordinator sends "Leave" command?
How can we avoid this unwanted behaviour?
Many thanks for your help!
Abele
  • Hi Marte,
    I'm evaluating to use Segger Embedded Studio to migrate my project to SDK 4.2.0.
    It's very probably that I will need help for several things, here a starting list:
    - adding BLE gatt/services and DFU bootloader integration
    - Handler when NEW devices will accepted on network (we need to read from device some info and store on BLE GATT)
    - Zboss method to handle end-node steering and net formation (user must manually activate devices network joining process)
    - Computing of needed NVRAM for 100 Zigbee nodes, and how to handle it
    - using and handle of FDS storage for store some data used by custom application (without issues with Zboss NVRAM)
    This is main list, but I think that we could need other help during the development.
    I will inform you that our product is a Zigbee Coordinator, and the previous development (from SDK3.2) was made integrating DFU bootloader and CLI agent configured as coordinator into Multiprotocol Ble-Zigbee template
    Let me know for these helps.
    Many thanks in advance.
    Abele
  • Hi Abele,
    I am sorry for the delay.
    We do have some nRF5 SDK Bluetooth guides on Devzone here:  Bluetooth low energy , such as this guide for services:  Bluetooth low energy Services, a beginner's tutorial . As for DFU there is a guide for getting started with the secure DFU bootloader here:  Getting started with Nordic's Secure DFU bootloader, a step by step guide . You should also be able to find information in our documentation on infocenter. If you have more problems with this part, please create a new ticket.
    You can use the ZB_ZDO_SIGNAL_DEVICE_ANNCE or ZB_ZDO_SIGNAL_DEVICE_UPDATE signals in zboss_signal_handler() to handle when a device is updated/joins the network. See components/zigbee/common/zigbee_helpers.c for how these signals are used there.
    Do you mean that the user must be able to open the network on the coordinator? Because if so, then you can look at the light coordinator example. There the network is reopened if button 1 is pressed:
    case BSP_EVENT_KEY_0:
        UNUSED_RETURN_VALUE(ZB_SCHEDULE_APP_ALARM_CANCEL(steering_finished, ZB_ALARM_ANY_PARAM));
        comm_status = bdb_start_top_level_commissioning(ZB_BDB_NETWORK_STEERING);
    We have some information about NVRAM in our documentation here: https://infocenter.nordicsemi.com/topic/sdk_tz_v4.2.0/group__zboss__nvram.html
    I hope this answers some of the questions. If you have specific questions about any of this, please create a new ticket for the questions, as they are no longer directly related to the original issue in this ticket. Thank you!
    MArte
  • Thanks for answers, Marte.
    For BLE and DFU integration (that I have already done in actual release) I follow same steps I have already done on SDK 3.2.0, and so also for device annonce and update, and to start network formation.
    The question about the needed amount of NVRAM for 100 end node, for the previous Zboss version iI received excel file whit compute of space. You can see on this thread what I means devzone.nordicsemi.com/.../zigbee-maximum-device-number
    Last question, how can I contact you if I need help during the migration to new SDK 4.2.0?
  • Hi Abele,
    I will ask the development team and get back to you.
    Create tickets on DevZone about your specific issues.
    Marte
  • Hi Abele,
    This depends on the application, the network configuration and how often the data needs to be stored in the flash memory. If the configuration of the network is to be changed often, it would be smart to increase the flash memory allocated for the ZBOSS NVRAM.
    The default value should be sufficient unless you actually plant to connect so many devices to the network. But if that is the case, you should double the NVRAM memory capacity.
    Remember that factory reset is required when the device is upgraded from SDK v3 to v4, so do not forget about this.
    Marte
