nRF Connect SDK DFU
After reviewing the add DFU support to your application guide
 Add DFU support to your application
i have several questions:
1)What modifications are required for the nRF5340 with an app core and net core?  This example shows using Device Manager to upload a .bin file but that is only one of the app core or net core, not both.  Can Device Manager accept a the generated .zip with the manifest to update both at once?  Could a similar guide be generated for updating both the app and net cores at the same time?  When trying to upload the zip of both, Device Manager shows the hash of both bin files, but when started with confirm only, the state shows VALIDATING… for a while then “Sending the request timed out.”  When using the advanced page, I can manually select the app core and download the bin for it – not the zip.
2)In Device Manger, the read, test, confirm, and erase options do not work.  How can they be activated?
3)The guide said that Device Manager will reset the device after the transfer but watching the debug output on the device, this is not the case.  I need to manually press the advanced button to get the reset command to show then issue it.  Is this correct?
4)I have read about encryption and updating keys but in other places it appears it is not supported to encrypt an image:
 Please add/enable support for encrypted images with MCUBOOT
Is it correct to say signing is supported but encryption is not?  Is there a step by step guide to generate new encryption keys (or signing keys) and update the MCUboot and app for both the app core and net core?
5)If singing is working correctly, is it still possible for a user to upload an image that is not correctly signed, but that the MCUboot will just not swap to it?
Thank you
  • Thank you for your help Simon.
    Is there a step by step guide on how to generate and use keys for both the bootloader and application so only a signed app may work not using the development default MCUBoot key?  I have seen many different posts on the issue but no guide on the complete process.
    Thank you
  • Check out this ticket:  Signing and versioning an image for MCUboot
    It explains two ways to use your own custom key instead of the default one, manually and through the build system using CONFIG_BOOT_SIGNATURE_KEY_FILE.
    Simon
  • For anyone else who wishes to use signatures to only load authorized software with a custom signature after DFU support has been added to their project:
    These steps were performed in windows.
    Inside the SDK, go to:
    v2.0.0\bootloader\mcuboot\scripts\
    And then generate a new private key and a public key from the private key.  I have not tested with any other type then rsa-2048.
    python imgtool.py keygen -k my_private_key.pem -t rsa-2048
    python imgtool.py getpub -k my_private_key.pem > pub_key.c
    Generating the c file is not required but useful for confirmation later.  The placement of the key file seams unimportant but I placed mine in the project directory such as follows:
                    My_Project\Key\my_private_key.pem
    Then create a directory called child_image if it does not already exist as follows:
                    My_Project\child_image\
    Create a file called mcuboot.conf inside the directory as follows:
                    My_Project\child_image\mcuboot.conf
    Add a single line to the file pointing to the absolute path of the key file.  You must use forward slashes.  The line may look such as follows:
    CONFIG_BOOT_SIGNATURE_KEY_FILE="C:/Projects/My_Project/Key/my_private_key.pem"
    Take care not to add any extra spaces or the build will fail.  Go ahead and rebuild your project.  It should succeed and build the bootloader using the private key and build your application with a public key automatically extracted from the private key.  Because of this you are not required to generate a key pair but just a private key.  However, you may verify the project is using your new private key by verifying the public key generated by the build system is the same as the pub_key.c you previously generated.  The build generated public key file is located at:
                    My_Project\build\mcuboot\zephyr\autogen-pubkey.c
    As far as I know, at the time of writing, encrypting your software images is not yet supported but you can prevent software not signed by you from being loaded.
    I have read other methods to add the private key including changing the CMakeList.txt file and a method to manually sign but i wanted to use the build system to handle it.
    I hope this helps anyone else struggling with this.
  • Hello Simon
    The DFU guide has a BLE OTA section but also a serial section:
    Could this documentation be updated or expanded on and instruction given to use mcumgr in windows?  Also could the instructions be updated to build with VS Code?
    Thank you
