I cannot get my nRF Connect SDK to install correctly such that VS Code nRF Connect extension works. On the Quick Setup, it complains that the nRF Connect Toolchain is invalid because "west is required but not found".
If I open a terminal and type 'west' - it runs.
Steps I took:
- Installed nRF Command-Line Tools v10.16.0
- Installed nRF Connect for Desktop v3.11.
- Installed Toolchain Manger v1.1.1 from nRF Connect for Desktop
- Installed nRF Connect SDK v2.0.0 from Toolchain Manager
- Clicked Open in VS Code
- Installed VS Code extensions
- Go to Welcome nRF Connect screen, Quick Setup:
- nRF Connect SDK: 2.0.0
- nRF Connect Toolchain: 2.0.0
- Red box: "Invalid toolchain installation" "west is required but not found. Make sure the 'west' executable is in your PATH"
(When I did all this on another computer, everything worked fine. Using that other computer for development is not an option for me though.)
Looking at the Toolchain Manager log, it looks like an issue with west's manifest file. Perhaps this is a Python issue on my machine, however, if that's the case I don't know how to fix it. I have uninstalled/re-installed Python along with all the Nordic software, SDKs. After all that, the same error occurs.
2022-07-06T16:44:57.155Z INFO Start to install toolchain v2.0.0
2022-07-06T16:44:57.156Z INFO Installing ncs-toolchain-windows-x86_64-v2.0.0-20220602T091202-9389261.tar.gz at C:\dev\sdk\nordic\toolchains\v2.0.0
2022-07-06T16:44:57.156Z DEBUG Install with toolchain version 20220602T091202
2022-07-06T16:44:57.157Z DEBUG Install with sha512 42d1ea1d332368798e13f475b2c72be92798bb638999e63bc7373852f9d5a3d8163fd2f8c0c00fdd6a703ab8a3eee287aef1c7dac883fdccfc886d58faf954a5
2022-07-06T16:50:29.804Z INFO Cloning nRF Connect SDK v2.0.0
2022-07-06T16:50:30.425Z DEBUG Traceback (most recent call last):
File "runpy.py", line 193, in _run_module_as_main
2022-07-06T16:50:30.426Z DEBUG File "runpy.py", line 86, in _run_code
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Scripts\west.exe\__main__.py", line 7, in <module>
2022-07-06T16:50:30.426Z DEBUG File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\app\main.py", line 786, in main
2022-07-06T16:50:30.426Z DEBUG app.run(argv or sys.argv[1:])
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\app\main.py", line 101, in run
2022-07-06T16:50:30.426Z DEBUG self.load_manifest()
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\app\main.py", line 119, in load_manifest
2022-07-06T16:50:30.427Z DEBUG self.manifest = Manifest.from_topdir(topdir=self.topdir,
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\manifest.py", line 1105, in from_topdir
2022-07-06T16:50:30.427Z DEBUG return Manifest(topdir=topdir, config=config,
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\manifest.py", line 1373, in __init__
2022-07-06T16:50:30.427Z DEBUG self._ctx = self._top_level_init(source_data,
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\manifest.py", line 1715, in _top_level_init
2022-07-06T16:50:30.428Z DEBUG manifest_path_option = get_option('manifest.path')
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\manifest.py", line 1712, in get_option
2022-07-06T16:50:30.428Z DEBUG return config.get(option, default=default,
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\configuration.py", line 169, in get
2022-07-06T16:50:30.428Z DEBUG return self._get(lambda cf: cf.get(option), default, configfile)
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\configuration.py", line 208, in _get
2022-07-06T16:50:30.429Z DEBUG for cf in self._whence(configfile):
File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\configuration.py", line 229, in _whence
2022-07-06T16:50:30.429Z DEBUG raise RuntimeError('local configuration file not found')
RuntimeError: local configuration file not found
2022-07-06T16:50:30.914Z DEBUG Traceback (most recent call last):
2022-07-06T16:50:30.914Z DEBUG File "runpy.py", line 86, in _run_code
2022-07-06T16:50:30.914Z DEBUG File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Scripts\west.exe\__main__.py", line 7, in <module>
2022-07-06T16:50:30.915Z DEBUG File "C:\dev\sdk\nordic\toolchains\v2.0.0\opt\bin\Lib\site-packages\west\app\main.py", line 786, in main
2022-07-06T16:50:30.915Z DEBUG app.run(argv or sys.argv[1:])
2022-07-06T16:50:30.915Z DEBUG self.load_manifest()
2022-07-06T16:50:30.916Z DEBUG return Manifest(topdir=topdir, config=config,
2022-07-06T16:50:30.916Z DEBUG self._ctx = self._top_level_init(source_data,
2022-07-06T16:50:30.917Z DEBUG manifest_path_option = get_option('manifest.path')
2022-07-06T16:50:30.918Z DEBUG return config.get(option, default=default,
2022-07-06T16:50:30.956Z INFO Finished cloning version v2.0.0 of the nRF Connect SDK after approximately 0 minute(s)
