I follow description of https://github.com/NordicSemiconductor/pc-ble-driver to build pc-ble-driver from source. But it failed to build it.
cmake \
-G Ninja \
-- NRF_BLE_DRIVER_VERSION not specified, setting it to 0.0.0
CMake Warning at /Users/snowuyl/vcpkg/scripts/buildsystems/vcpkg.cmake:116 (message):
Unable to determine target architecture, continuing without vcpkg.
build/CMakeFiles/3.23.1/CMakeSystem.cmake:6 (include)
CMakeLists.txt:25 (project)
-- Architecture not set, using native 64-bit toolchain.
-- Building with build type: .
-- macOS Architecture not set, using x86_64 as default.
-- Compiled tests are installed in directory "bin"
-- Compiled examples are installed in directory "bin"
-- Did not find clang-tidy, target tidy is disabled.
-- If clang-tidy is installed, make sure run-clang-tidy.py and clang-tidy is in PATH
-- Configuring done
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
/Users/snowuyl/pc-ble-driver/ASIO_INCLUDE_DIR
used as include directory in directory /Users/snowuyl/pc-ble-driver
-- Generating done
CMake Generate step failed. Build files cannot be regenerated correctly.
