Build fails for matter samples with nrf5340-DK
Hi, I can successfully build the openthread-cli sample but fail with all matter samples
Please refer the following log
> Executing task: nRF Connect: Build: light_bulb/build (active) <
Building light_bulb
west build --build-dir d:\myWork\Research\matter\prog\light_bulb\build d:\myWork\Research\matter\prog\light_bulb
[0/91] Performing build step for 'chip-gn'
Generating compile_commands took 16ms
Done. Made 77 targets from 84 files in 115ms
ninja: error: objd:\src\access\access.ninja:9: expected newline, got ':'
FAILED: modules/connectedhomeip/src/chip-gn-stamp/chip-gn-build modules/connectedhomeip/-lCHIP
cmd.exe /C "cd /D D:\myWork\Research\matter\prog\light_bulb\build\modules\connectedhomeip && C:\ncs\toolchains\v2.0.0\opt\bin\python.exe C:/ncs/v2.0.0/modules/lib/matter/config/nrfconnect/chip-module/make_gn_args.py @args.tmp > args.gn && C:/ncs/toolchains/v2.0.0/opt/bin/gn.exe --root=C:/ncs/v2.0.0/modules/lib/matter --root-target=C:/ncs/v2.0.0/modules/lib/matter/config/nrfconnect/chip-gn --dotfile=C:/ncs/v2.0.0/modules/lib/matter/config/nrfconnect/chip-gn/.gn --script-executable=C:/ncs/toolchains/v2.0.0/opt/bin/python.exe --export-compile-commands gen --check --fail-on-unused-args . && ninja"
[2/91] cmd.exe /C "cd /D D:\myWork\Research\matter\prog\light_bulb\build\modules\openthread\build && C:\ncs\toolchains\v2.0.0\opt\bin\cmake.exe -DLIST="OPENTHREAD_CONFIG_ASSERT_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0;OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0;OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=1;OPENTHREAD_CONFIG_COAP_API_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=0;OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_ECDSA_ENABLE=1;OPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_DUA_ENABLE=1;OPENTHREAD_CONFIG_MLR_ENABLE=1;OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=1;OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=1;OPENTHREAD_CONFIG_JOINER_ENABLE=1;OPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=1;OPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=1;OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1;OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1;OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=1;OPENTHREAD_SPINEL_CONFIG_RCP_RESTORATION_MAX_COUNT=0;PACKAGE_NAME="OPENTHREAD";OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_2;OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1;KERNEL;__ZEPHYR__=1;_FORTIFY_SOURCE=2;__LINUX_ERRNO_EXTENSIONS__;USE_PARTITION_MANAGER=1;ZCBOR_ASSERT;__PROGRAM_START;NRF5340_XXAA_APPLICATION;NRF_SKIP_FICR_NS_COPY_TO_RAM;NRF_802154_USE_RAW_API=1;NRF_802154_PENDING_SHORT_ADDRESSES=;NRF_802154_PENDING_EXTENDED_ADDRESSES=;NRF_802154_RX_BUFFERS=16;NRF_802154_TX_STARTED_NOTIFY_ENABLED=1;NRF_802154_ACK_TIMEOUT_ENABLED=1;NRF_802154_ENCRYPTION_ENABLED=1;NRF_802154_SECURITY_WRITER_ENABLED=1;NRF_802154_IE_WRITER_ENABLED=1;NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0;NRF_802154_ECB_PRIORITY=-1;NRF_802154_SWI_PRIORITY=1;MBEDTLS_CONFIG_FILE="nrf-config.h";MBEDTLS_USER_CONFIG_FILE="nrf-config-user.h"" -P C:/ncs/v2.0.0/modules/lib/openthread/etc/cmake/print.cmake"
PACKAGE_NAME=OPENTHREAD
KERNEL
__ZEPHYR__=1
_FORTIFY_SOURCE=2
ZCBOR_ASSERT
__PROGRAM_START
MBEDTLS_CONFIG_FILE=nrf-config.h
MBEDTLS_USER_CONFIG_FILE=nrf-config-user.h
FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.0.0\opt\bin\cmake.EXE' --build 'd:\myWork\Research\matter\prog\light_bulb\build'
The terminal process terminated with exit code: 1.
Terminal will be reused by tasks, press any key to close it.
nRF Connect SDK 2.0.0
windows10
nRF5340-DK
