Error about MCUBOOT_BUILD_STRATEGY_FROM_SOURCE when trying to provide a signing key
I want to do firmware updates over BLE. To do that I added these settings to my prj.conf which I mostly got from the smp_svr example:
This "works" but it uses the default signing key. So I added CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="signing_key.pem" according to this answer but I got this message during build:
If I follow that advice and set CONFIG_BOOT_SIGNATURE_KEY_FILE I get these messages:
But it doesn't seem like MCUBOOT_BUILD_STRATEGY_FROM_SOURCE is a valid prj.conf setting for an NCS project?
I'm on NCS 1.9.1.
    The message instructed you to consider setting CONFIG_MCUBOOT_SIGNATURE_KEY_FILE. Did you set CONFIG_BOOT_SIGNATURE_KEY_FILE instead? If so, to which value?
    Dejan
  • Are you referring to the last sentence of the message? If I understand the message correctly, it encourages me to remove (= set to the default, an empty string) CONFIG_MCUBOOT_SIGNATURE_KEY_FILE again just to get rid of the message. But then I would still not have a custom signing key.
    Could you specify the way how you built your project?
    Dejan
  • Here's my complete prj.conf:
    If you just create a new project in VSCode and hit Build, you should get a message about the default key being used.
    If you then add CONFIG_MCUBOOT_SIGNATURE_KEY_FILE you should see the message about it being ignored.
    Similar to what is shown in the configuration file for nrf_desktop sample, you should put CONFIG_BOOT_SIGNATURE_KEY_FILE in the configuration file for the child image. Inside your project directory, create child_image directory with mcuboot.conf file where you put your mcuboot configuration. If you still have an issue, try adding CONFIG_BOOT_SIGNATURE_KEY_FILE in both prj.conf and in child_image/mcuboot.conf
    You can read more about default configuration for multi-image build, signing binaries and adding custom signature key file.
    Dejan
1 2 3
