Minimum available Flash / RAM required for DFU? Download failing with "insufficient resources"
Hi everyone, I am attempting to integrate buttonless secure DFU into my existing firmware application. I am following this guide: https://content.u-blox.com/sites/default/files/Add-NordicSemiconductorDFU-to-SDKexample_AppNote_UBX-19050198.pdf
I am using SDK 15.2 and intend to deploy this application onto nRF52810, but am using nRF 52 DK for development purposes. When I load only the secure bootloader and softdevice S112 onto my nRF52 DK, from the dfu example ($/examples/dfu/secure_bootloader/pca10040e_ble), I have no problems. I can find the nRF52 DK advertising as dfuTarg, I can connect to it, and then I can do a DFU update using the default unedited "ble_app_uart" example, zipped up with the appropriate private key using nrfutils.
When I use my own custom firmware application that is extended from the defualt ble_app_uart template, zip it up using nrfutils and then try to update using DFU, I get the error "Insufficient resources" and I cannot update the firmware.
The default ble_app_uart project builds with 126.2 / 192KB flash and 17.2 / 24KB RAM. My custom application builds with 163.9 / 192KB flash and 18.2 / 24KB RAM.
What is the minimum required free flash and/or ram to work with DFU? Do I need to optimize my firmware so that there is enough space to perform DFU, or am I doing something else wrong?
Thanks!
 err
File Name: test_app_v10.zip
Parts: 1
Soft Device Size: Zero KB
Bootloader Size: Zero KB
[Callback] Central Manager did update state to: Powered ON
Connecting to DfuTarg...
centralManager.connect(peripheral, options: nil)
[Callback] Central Manager did connect peripheral
Connected to DfuTarg
Discovering services...
peripheral.discoverServices(nil)
Services discovered
Starting Secure DFU...
Services discovered
Secure DFU Service found
Discovering characteristics in DFU Service...
peripheral.discoverCharacteristics(nil, for: FE59)
DFU characteristics discovered
MTU set to 247
Enabling notifications for 8EC90001-F315-4F60-9FB8-838830DAEA50...
peripheral.setNotifyValue(true, for: 8EC90001-F315-4F60-9FB8-838830DAEA50)
Notifications enabled for 8EC90001-F315-4F60-9FB8-838830DAEA50
Secure DFU Control Point notifications enabled
Writing to characteristic 8EC90001-F315-4F60-9FB8-838830DAEA50...
peripheral.writeValue(0x0601, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Data written to 8EC90001-F315-4F60-9FB8-838830DAEA50
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600601000100008e0000008672ebd1
Command object info (Max size = 256, Offset = 142, CRC = D1EB7286) received
peripheral.writeValue(0x01018e000000, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600101
peripheral.writeValue(0x020000, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600201
Packet Receipt Notif disabled (Op Code = 2, Value = 0)
Writing to characteristic 8EC90002-F315-4F60-9FB8-838830DAEA50...
peripheral.writeValue(0x128b010a450801124108db4f10341a02b00120002800300038b8ff03422408031220db43cc45a6468084fe7c6df722c0b203200c5cc67e9614ff26717010abdbb40a480052040801120010001a402578b3009e2a2cc2f913b01300163f31d797670239810eeee2b78adc6ca16d7ac4dae624f77e90ee3c713e772b8f0a43b0083620d886c3a0a49c91b2b2593b65, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
Command object sent (CRC = 1BB50FF8)
peripheral.writeValue(0x03, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003018e000000f80fb51b
Checksum (Offset = 142, CRC = 1BB50FF8) received
peripheral.writeValue(0x04, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600404
Error 4: Insufficient resources
Disconnecting...
centralManager.cancelPeripheralConnection(peripheral)
[Callback] Central Manager did disconnect peripheral
Disconnected
