We have an application where we need the PWM pin state to revert to high impedance between bursts. It doesn't appear this behavior is capable by default. Is there a means to redefine the IO as an input between bursts?
After a SEQEND event you could try to configure the PSEL_OUT[n] register to disconnected and set PIN_CNF[n] to input, with input buffer disconnected. That should make the pin high impedance.
regards
Jared
