I've got a working nrf52832 application using central role to connect to another peripheral. I also want to enable SMP DFU mode - so the app needs to advertise and behave as a peripheral too. The only service is SMP.
I can connect to the peripheral; when I try to send a file via SMP, the app faults to fault_s.S SECTION_SUBSEC_FUNC (Line 80).
I've turned off the central role from initialising and scanning so I can try to get the central working properly.
Are there any gotchas with having the BLE Central role enabled and also trying to offer peripheral mode SMP?
os_mgmt_register_group();
img_mgmt_register_group();
smp_bt_register();
bt_conn_cb_register(&conn_callbacks);
err = bt_enable(NULL);
if (err) {
printk("Bluetooth init failed (err %d)", err);
return;
err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
The above all works to initialise ble.
