'NRFX_TIMER3_INST_IDX' undeclared here (not in a function); did you mean 'NRFX_TIMER_INSTANCE'
I am using nrf52840 DK board, from that I am using Segger embedded studio, so I am building SAADC with ble_app_uart combined code. If I build my code, getting some error, I will share the code in below attachment. The error as "   'NRFX_TIMER3_INST_IDX' undeclared here (not in a function); did you mean 'NRFX_TIMER_INSTANCE'"
The code is
* Copyright (c) 2015 - 2021, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#ifndef NRFX_TIMER_H__
#define NRFX_TIMER_H__
#include <nrfx.h>
#include <hal/nrf_timer.h>
#ifdef __cplusplus
extern "C" {
* @defgroup nrfx_timer Timer driver
* @ingroup nrf_timer
* @brief TIMER peripheral driver.
* @brief Timer driver instance data structure.
typedef struct
NRF_TIMER_Type * p_reg; ///< Pointer to the structure with TIMER peripheral instance registers.
uint8_t instance_id; ///< Index of the driver instance. For internal use only.
uint8_t cc_channel_count; ///< Number of capture/compare channels.
} nrfx_timer_t;
/** @brief Macro for creating a timer driver instance. */
#define NRFX_TIMER_INSTANCE(id) \
.p_reg = NRFX_CONCAT_2(NRF_TIMER, id), \
.instance_id = NRFX_CONCAT_3(NRFX_TIMER, id, _INST_IDX), \
.cc_channel_count = NRF_TIMER_CC_CHANNEL_COUNT(id), \
#ifndef __NRFX_DOXYGEN__
enum {
#if NRFX_CHECK(NRFX_TIMER0_ENABLED)
NRFX_TIMER0_INST_IDX,
#if NRFX_CHECK(NRFX_TIMER1_ENABLED)
NRFX_TIMER1_INST_IDX,
#if NRFX_CHECK(NRFX_TIMER2_ENABLED)
NRFX_TIMER2_INST_IDX,
#if NRFX_CHECK(NRFX_TIMER3_ENABLED)
NRFX_TIMER3_INST_IDX,
#if NRFX_CHECK(NRFX_TIMER4_ENABLED)
NRFX_TIMER4_INST_IDX,
NRFX_TIMER_ENABLED_COUNT
/** @brief The configuration structure of the timer driver instance. */
typedef struct
nrf_timer_frequency_t frequency; ///< Frequency.
nrf_timer_mode_t mode; ///< Mode of operation.
nrf_timer_bit_width_t bit_width; ///< Bit width.
uint8_t interrupt_priority; ///< Interrupt priority.
void * p_context; ///< Context passed to interrupt handler.
} nrfx_timer_config_t;
/** @brief Timer driver instance default configuration. */
#define NRFX_TIMER_DEFAULT_CONFIG \
.frequency = (nrf_timer_frequency_t)NRFX_TIMER_DEFAULT_CONFIG_FREQUENCY,\
.mode = (nrf_timer_mode_t)NRFX_TIMER_DEFAULT_CONFIG_MODE, \
.bit_width = (nrf_timer_bit_width_t)NRFX_TIMER_DEFAULT_CONFIG_BIT_WIDTH,\
.interrupt_priority = NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY, \
.p_context = NULL \
* @brief Timer driver event handler type.
* @param[in] event_type Timer event.
* @param[in] p_context General purpose parameter set during initialization of
* the timer. This parameter can be used to pass
* additional information to the handler function, for
* example, the timer ID.
typedef void (* nrfx_timer_event_handler_t)(nrf_timer_event_t event_type,
void * p_context);
* @brief Function for initializing the timer.
* @param[in] p_instance Pointer to the driver instance structure.
* @param[in] p_config Pointer to the structure with the initial configuration.
* @param[in] timer_event_handler Event handler provided by the user.
* Must not be NULL.
* @retval NRFX_SUCCESS Initialization was successful.
* @retval NRFX_ERROR_INVALID_STATE The instance is already initialized.
nrfx_err_t nrfx_timer_init(nrfx_timer_t const * const p_instance,
nrfx_timer_config_t const * p_config,
nrfx_timer_event_handler_t timer_event_handler);
* @brief Function for uninitializing the timer.
void nrfx_timer_uninit(nrfx_timer_t const * const p_instance);
* @brief Function for turning on the timer.
void nrfx_timer_enable(nrfx_timer_t const * const p_instance);
* @brief Function for turning off the timer.
* The timer will allow to enter the lowest possible SYSTEM_ON state
* only after this function is called.
void nrfx_timer_disable(nrfx_timer_t const * const p_instance);
* @brief Function for checking the timer state.
* @retval true Timer is enabled.
* @retval false Timer is not enabled.
bool nrfx_timer_is_enabled(nrfx_timer_t const * const p_instance);
* @brief Function for pausing the timer.
void nrfx_timer_pause(nrfx_timer_t const * const p_instance);
* @brief Function for resuming the timer.
void nrfx_timer_resume(nrfx_timer_t const * const p_instance);
* @brief Function for clearing the timer.
void nrfx_timer_clear(nrfx_timer_t const * const p_instance);
* @brief Function for incrementing the timer.
void nrfx_timer_increment(nrfx_timer_t const * const p_instance);
* @brief Function for returning the address of the specified timer task.
* @param[in] timer_task Timer task.
* @return Task address.
__STATIC_INLINE uint32_t nrfx_timer_task_address_get(nrfx_timer_t const * const p_instance,
nrf_timer_task_t timer_task);
* @brief Function for returning the address of the specified timer capture task.
* @param[in] channel Capture channel number.
__STATIC_INLINE uint32_t nrfx_timer_capture_task_address_get(nrfx_timer_t const * const p_instance,
uint32_t channel);
* @brief Function for returning the address of the specified timer event.
* @param[in] timer_event Timer event.
* @return Event address.
__STATIC_INLINE uint32_t nrfx_timer_event_address_get(nrfx_timer_t const * const p_instance,
nrf_timer_event_t timer_event);
* @brief Function for returning the address of the specified timer compare event.
* @param[in] channel Compare channel number.
__STATIC_INLINE uint32_t nrfx_timer_compare_event_address_get(nrfx_timer_t const * const p_instance,
uint32_t channel);
* @brief Function for capturing the timer value.
* @param[in] cc_channel Capture channel number.
* @return Captured value.
uint32_t nrfx_timer_capture(nrfx_timer_t const * const p_instance,
nrf_timer_cc_channel_t cc_channel);
* @brief Function for returning the capture value from the specified channel.
* Use this function to read channel values when PPI is used for capturing.
__STATIC_INLINE uint32_t nrfx_timer_capture_get(nrfx_timer_t const * const p_instance,
* @brief Function for setting the timer channel in compare mode.
* @param[in] cc_channel Compare channel number.
* @param[in] cc_value Compare value.
* @param[in] enable_int Enable or disable the interrupt for the compare channel.
void nrfx_timer_compare(nrfx_timer_t const * const p_instance,
nrf_timer_cc_channel_t cc_channel,
uint32_t cc_value,
bool enable_int);
* @brief Function for setting the timer channel in the extended compare mode.
* @param[in] timer_short_mask Shortcut between the compare event on the channel
* and the timer task (STOP or CLEAR).
void nrfx_timer_extended_compare(nrfx_timer_t const * const p_instance,
uint32_t cc_value,
nrf_timer_short_mask_t timer_short_mask,
bool enable_int);
* @brief Function for converting time in microseconds to timer ticks.
* @param[in] time_us Time in microseconds.
* @return Number of ticks.
__STATIC_INLINE uint32_t nrfx_timer_us_to_ticks(nrfx_timer_t const * const p_instance,
uint32_t time_us);
* @brief Function for converting time in milliseconds to timer ticks.
* @param[in] time_ms Time in milliseconds.
__STATIC_INLINE uint32_t nrfx_timer_ms_to_ticks(nrfx_timer_t const * const p_instance,
uint32_t time_ms);
* @brief Function for enabling timer compare interrupt.
* @param[in] channel Compare channel.
void nrfx_timer_compare_int_enable(nrfx_timer_t const * const p_instance,
uint32_t channel);
* @brief Function for disabling timer compare interrupt.
void nrfx_timer_compare_int_disable(nrfx_timer_t const * const p_instance,
uint32_t channel);
#ifndef SUPPRESS_INLINE_IMPLEMENTATION
return (uint32_t)nrf_timer_task_address_get(p_instance->p_reg, timer_task);
uint32_t channel)
NRFX_ASSERT(channel < p_instance->cc_channel_count);
nrf_timer_capture_task_get(channel));
return (uint32_t)nrf_timer_event_address_get(p_instance->p_reg, timer_event);
uint32_t channel)
nrf_timer_compare_event_get(channel));
return nrf_timer_cc_read(p_instance->p_reg, cc_channel);
uint32_t timer_us)
return nrf_timer_us_to_ticks(timer_us, nrf_timer_frequency_get(p_instance->p_reg));
uint32_t timer_ms)
return nrf_timer_ms_to_ticks(timer_ms, nrf_timer_frequency_get(p_instance->p_reg));
#endif // SUPPRESS_INLINE_IMPLEMENTATION
void nrfx_timer_0_irq_handler(void);
void nrfx_timer_1_irq_handler(void);
void nrfx_timer_2_irq_handler(void);
void nrfx_timer_3_irq_handler(void);
void nrfx_timer_4_irq_handler(void);
#ifdef __cplusplus
#endif // NRFX_TIMER_H__
Anyone please help on this, how to solve the error. Thanks
    Could you confirm that you have NRFX_TIMER_ENABLED 1 and NRFX_TIMER3_ENABLED 1 in your sdk_config.h file?
    Please also make sure that you do not have the legacy "TIMER_ENABLED" defined in your sdk_config.h since this will cause apply_old_config.h to overwrite your NRFX_* defines.
    This is true for all peripherals - i.e you should not have SAADC_ENABLED defined in your sdk_config.h if you intend to use the NRFX_SAADC_* defines for you configurations, etc.
    Karl
