debugging a non-secure app (with tfm)
I was wondering what I need to do, or if it is even possible, to debug a non-secure app which uses TFM.
Running 'west debug' on e.g. the blinky sample works regardless if I built it with secure or non-secure board type on an nrf9160dk. However, on an app that uses modem/crypto/tfm functionality, like the psa_crypto sample from the zephyr repository, that will result in a debugging session that is unable to get to the main function of the app.
This feels like I'm missing something really obvious, but I can't tell what it is. Anyone here willing to push me in the right direction?
Cheers!
    Can you show how do you run "west debug" command?
    Can you show the differences when running "west debug" with blinky and psa_crypto?
    Dejan
  • I have attached gdb session logs for the following scenarios:
    • blinky built with zephyr 3.1.0 w/o ns --> works
    • blinky built with zephyr 3.1.0 with ns --> hangs on the first "continue"
    • blinky built with zephyr 2.7.99 with ns --> works
    • psa_crypto sample built with zephyr 3.1.0 (ns mandatory) --> jumps to unknown memory
    The main difference (apart from the memory locations) I spotted was that the psa_crypto sample and the 3.1.0-ns-blinky use tfm, while the 2.7.99-ns-blinky uses spm, and the blinky built without the '_ns' uses neither.
    So the plot thickens. All this points to my earlier suspicion that it might not be possible at all to debug a tfm application beyond the bootloader.
    $ west flash
    -- west flash: rebuilding
    ninja: no work to do.
    -- west flash: using runner nrfjprog
    Using board 960027662
    -- runners.nrfjprog: Flashing file: /path/to/zephyrproject/zephyr/samples/basic/blinky/build/zephyr/zephyr.hex
    Parsing image file.
    Verifying programming.
    Verified OK.
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 960027662 flashed successfully.
    $ west debug
    -- west debug: rebuilding
    -- west debug: using runner jlink
    -- runners.jlink: JLink version: 7.58b
    -- runners.jlink: J-Link GDB server running on port 2331; no thread info available
    SEGGER J-Link GDB Server V7.58b Command Line Version
    JLinkARM.dll V7.58b (DLL compiled Nov 16 2021 15:04:27)
    -----GDB Server start settings-----
    GDBInit file:                  none
    GDB Server Listening port:     2331
    SWO raw output listening port: 2332
    Terminal I/O port:             2333
    Accept remote connection:      yes
    Generate logfile:              off
    Verify download:               off
    Init regs on start:            off
    Silent mode:                   on
    Single run mode:               on
    Target connection timeout:     0 ms
    ------J-Link related settings------
    J-Link Host interface:         USB
    J-Link script:                 none
    J-Link settings file:          none
    ------Target related settings------
    Target device:                 nRF9160_xxAA
    Target interface:              SWD
    Target interface speed:        4000kHz
    Target endian:                 little
    GNU gdb (Zephyr SDK 0.14.2) 9.2
    Copyright (C) 2020 Free Software Foundation, Inc.
    License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
    This is free software: you are free to change and redistribute it.
    There is NO WARRANTY, to the extent permitted by law.
    Type "show copying" and "show warranty" for details.
    This GDB was configured as "--host=x86_64-build_pc-linux-gnu --target=arm-zephyr-eabi".
    Type "show configuration" for configuration details.
    For bug reporting instructions, please see:
    <https://github.com/zephyrproject-rtos/sdk-ng/issues>.
    Find the GDB manual and other documentation resources online at:
        <http://www.gnu.org/software/gdb/documentation/>.
    For help, type "help".
    Type "apropos word" to search for commands related to "word"...
    Reading symbols from /path/to/zephyrproject/zephyr/samples/basic/blinky/build/zephyr/zephyr.elf...
    Remote debugging using :2331
    arch_cpu_idle () at /path/to/zephyrproject/zephyr/arch/arm/core/aarch32/cpu_idle.S:105
    105             cpsie   i
    Resetting target
    Loading section rom_start, size 0x144 lma 0x0
    Loading section text, size 0x44e8 lma 0x144
    Loading section .ARM.exidx, size 0x8 lma 0x462c
    Loading section initlevel, size 0x30 lma 0x4634
    Loading section devices, size 0x48 lma 0x4664
    Loading section sw_isr_table, size 0x208 lma 0x46ac
    Loading section device_handles, size 0x12 lma 0x48b4
    Loading section rodata, size 0x180 lma 0x48d0
    Loading section datas, size 0x94 lma 0x4a50
    Loading section device_states, size 0xc lma 0x4ae4
    Start address 0x000014e4, load size 19174
    Transfer rate: 3120 KB/sec, 1743 bytes/write.
    (gdb) b main
    Breakpoint 1 at 0x41c: file /path/to/zephyrproject/zephyr/samples/basic/blinky/build/zephyr/include/generated/syscalls/device.h, line 55.
    (gdb) c
    Continuing.
    Breakpoint 1, main () at /path/to/zephyrproject/zephyr/samples/basic/blinky/build/zephyr/include/generated/syscalls/device.h:55
    55              compiler_barrier();
    (gdb) s
    26              if (!device_is_ready(led.port)) {
    (gdb)
    device_is_ready (dev=<optimized out>) at /path/to/zephyrproject/zephyr/samples/basic/blinky/src/main.c:26
    (gdb)
    z_impl_device_is_ready (dev=<optimized out>) at /path/to/zephyrproject/zephyr/include/zephyr/device.h:831
    831             return z_device_is_ready(dev);
    (gdb)
    z_device_is_ready (dev=dev@entry=0x467c <__device_dts_ord_9>) at /path/to/zephyrproject/zephyr/kernel/device.c:157
    157             if (dev == NULL) {
    (gdb) c
    Continuing.
    $ west flash
    [0/13] Performing build step for 'spm_subimage'
    -- runners.nrfjprog: Flashing file: /path/to/ncs/zephyr/samples/basic/blinky/build/zephyr/merged.hex
    Parsing image file.
    Verified OK.
    Applying pin reset.
    $ west debug
    GDBInit file:                  none
    Silent mode:                   on
    Single run mode:               on
    J-Link script:                 none
    Reading symbols from /path/to/ncs/zephyr/samples/basic/blinky/build/zephyr/zephyr.elf...
    arch_cpu_idle () at /path/to/ncs/zephyr/arch/arm/core/aarch32/cpu_idle.S:107
    107             cpsie   i
    Resetting target
    Loading section rom_start, size 0x23c lma 0x10000
    Loading section text, size 0x66dc lma 0x1023c
    Loading section .ARM.exidx, size 0x8 lma 0x16918
    Loading section initlevel, size 0x50 lma 0x16920
    Loading section devices, size 0x60 lma 0x16970
    Loading section sw_isr_table, size 0x208 lma 0x169d0
    Loading section device_handles, size 0x18 lma 0x16bd8
    Loading section rodata, size 0x2b0 lma 0x16bf0
    Loading section datas, size 0x88 lma 0x16eb8
    Loading section device_states, size 0x10 lma 0x16f40
    Loading section k_heap_area, size 0x14 lma 0x16f50
    Start address 0x000115b0, load size 28492
    Transfer rate: 13912 KB/sec, 2374 bytes/write.
    (gdb) b main
    Breakpoint 1 at 0x10514: file /path/to/ncs/zephyr/samples/basic/blinky/build/zephyr/include/generated/syscalls/device.h, line 43.
    (gdb) c
    Continuing.
    Breakpoint 1, main () at /path/to/ncs/zephyr/samples/basic/blinky/build/zephyr/include/generated/syscalls/device.h:43
    43              compiler_barrier();
    (gdb) n
    36              dev = device_get_binding(LED0);
    (gdb)
    37              if (dev == NULL) {
    (gdb)
    41              ret = gpio_pin_configure(dev, PIN, GPIO_OUTPUT_ACTIVE | FLAGS);
    (gdb) c
    Continuing.
    $ west flash
    [0/12] Performing build step for 'tfm'
    -- runners.nrfjprog: Flashing file: /path/to/zephyrproject/zephyr/samples/basic/blinky/build/tfm_merged.hex
    Parsing image file.
    Verified OK.
    Applying pin reset.
    $ west debug
    GDBInit file:                  none
    Silent mode:                   on
    Single run mode:               on
    J-Link script:                 none
    105             cpsie   i
    Resetting target
    Loading section rom_start, size 0x544 lma 0x50000
    Loading section text, size 0x43f8 lma 0x50544
    Loading section .ARM.exidx, size 0x8 lma 0x5493c
    Loading section initlevel, size 0x38 lma 0x54944
    Loading section devices, size 0x48 lma 0x5497c
    Loading section sw_isr_table, size 0x208 lma 0x549c4
    Loading section device_handles, size 0x12 lma 0x54bcc
    Loading section rodata, size 0x180 lma 0x54be0
    Loading section datas, size 0x94 lma 0x54d60
    Loading section device_states, size 0xc lma 0x54df4
    Start address 0x000518cc, load size 19966
    Transfer rate: 9749 KB/sec, 1815 bytes/write.
    (gdb) b main
    Breakpoint 1 at 0x5081c: file /path/to/zephyrproject/zephyr/samples/basic/blinky/build/zephyr/include/generated/syscalls/device.h, line 55.
    (gdb) c
    Continuing.
    $ west flash
    -- runners.nrfjprog: Flashing file: /path/to/zephyrproject/applications/psa_crypto_sample/build/tfm_merged.hex
    Parsing image file.
    Verified OK.
    Applying pin reset.
    $ west debug
    GDBInit file:                  none
    Silent mode:                   on
    Single run mode:               on
    J-Link script:                 none
    Reading symbols from /path/to/zephyrproject/applications/psa_crypto_sample/build/zephyr/zephyr.elf...
    105             cpsie   i
    Resetting target
    Loading section text, size 0x9d50 lma 0x50548
    Loading section .ARM.exidx, size 0x8 lma 0x5a298
    Loading section initlevel, size 0x50 lma 0x5a2a0
    Loading section devices, size 0x48 lma 0x5a2f0
    Loading section sw_isr_table, size 0x208 lma 0x5a338
    Loading section device_handles, size 0x12 lma 0x5a540
    Loading section log_const_sections, size 0x48 lma 0x5a554
    Loading section log_backends_sections, size 0x10 lma 0x5a59c
    Loading section rodata, size 0x2208 lma 0x5a5b0
    Loading section datas, size 0x1b5 lma 0x5c7b8
    Loading section device_states, size 0xc lma 0x5c970
    Loading section log_dynamic_sections, size 0x24 lma 0x5c97c
    Loading section k_heap_area, size 0x14 lma 0x5c9a0
    Loading section k_mutex_area, size 0x14 lma 0x5c9b4
    Loading section k_sem_area, size 0x10 lma 0x5c9c8
    Start address 0x00053f00, load size 51659
    Transfer rate: 10089 KB/sec, 2869 bytes/write.
    (gdb) b main
    Breakpoint 1 at 0x508f8: file /path/to/zephyrproject/applications/psa_crypto_sample/src/main.c, line 27.
    (gdb) c
    Continuing.
    Program received signal SIGTRAP, Trace/breakpoint trap.
    0xeffffffe in ?? ()
    (gdb) s
    Cannot find bounds of current function
    (gdb)
    The toolchain provided by Zephyr is set of tools to help in building and debugging. You should use Zephyr toolchain version 0.14.1 instead of 0.14.2.
    Dejan
  • I've switched to Zephyr toolchain version 0.14.1, but It makes no difference.
    Crypto sample requires target reset.
    What exactly did you mean by that? Do I have to reset the target manually? If so, when and how? I thought, the target reset would be executed automatically by whatever 'west flash' or 'west debug' did behind the scenes.
    The reset is done inside "west debug", after the breakpoint is set. First, you have "break main" and "continue", followed by "mon reset" and "continue", it should break into main.
    Dejan
  • Dude! That was it! Actually, that was all there was to it.
    Thank you so much!
  • Hey there, I don't quite follow what the resolution was here. Could you spell it out a bit more clearly for us dullards at the back?
    I've got an app which has TFM enabled. If I debug it, it hangs at the reset_handler(). I've opened the debug console and typed in "-exec mon reset" and then continued the debug , but it just go off into nowhere land, and never reaches my main function.
    This is my first project with this ecosystem, so all a bit new. Would it be valid to revert to non _ns board files disable the TFM and complete the development cycle. And then create a little script to convert the source over to use TFM? Or is this a naive notion?
