nrf52840 S140 Central DFU Bluetooth Zephyr 2.0.0 nrf52840 peripheral
We have nrf52840 S140 BLE Central device that currently connects to TI based sensors. I have implemented code that can upgrade those TI sensors' firmware using the TI BLE protocol.
Now we are developing our own BLE peripheral sensors also based on the nrf52840 but now using the newly supported Zephyr 2.0.0. RF connect stuff. I can update the sensors using the Nordic Android program (unauthenticated for now) and now need to implement upgrading BLE DFU using our central device which connects to a cellular gateway.
I do not want to reinvent the wheel, writing existing code, like I had to do with the TI sensors.
Could you point me to code that allows a Central device to update a peripheral device BLE DFU?
If not where can I look to reinvent another wheel?
Thanks David
  • DavidKaplan said:
    Our peripheral sensor has no uart interfaces, unlike the SDKs, and is in a waterproof container.
    Do you have debugger access to the waterproof sensor?
    Your "image list" lists the image as "pending: true".
    This should make MCUboot swap the images.
    Does it still list "pending:true" after multiple resets of the peripheral sensor?
    Are you able to upload a new image from your mobile phone to update the peripheral sensor now?
    Sigurd Hellesvik
  • Yes, I have a bare board which I debug.
    Yes, the phone app updates correctly the image.
    The RTT log does not show bootloader information on reset.
    This is the sensor RTT log from the DFU connection till reset:
    00> 08/02/2023 19:18:35[ami_main.c: 598] NewMin
    00> 08/02/2023 19:19:35[ami_main.c: 598] NewMin
    00> 08/02/2023 19:20:04[ami_main.c: 142] Connected
    00> 08/02/2023 19:20:05[ami_main.c: 197] LE PHY updated: TX PHY LE 2M, RX PHY LE 2M
    00> 08/02/2023 19:20:09[ami_main.c: 174] Connection parameters updated.
    00>  interval: 40, latency: 0, timeout: 42
    00> 08/02/2023 19:20:14[ami_main.c: 174] Connection parameters updated.
    00>  interval: 9, latency: 0, timeout: 42
    00> 08/02/2023 19:20:35[ami_main.c: 598] NewMin
    00> 08/02/2023 19:21:35[ami_main.c: 598] NewMin
    00> *** Booting Zephyr OS build v3.2.99-ncs1 ***
    00> [00:00:00.037,292] <inf> mcumgr_zephyr_grp: zephyr_basic_mgmt_init: Registering Zephyr basic mgmt group
    00> 00/00/0000 00:00:00[ami_main.c: 628] Startup
    00> 00/00/0000 00:00:00[ami_cfg.c: 256] DeviceID:51
    How can I read the bootloader flags in my code? Would this help?
    I copied the default mcuboot.conf file into the child_image folder and added the swap move directive.
    I tried in that file to change log minimal to n and log level to 4 but that did not help.
    I see threads on bootloader RTT in the forum but mainly for non zephyr builds.
    I decided not to use other than the default bootloader keys till the DFU works.
    CONFIG_PM=n
    CONFIG_MAIN_STACK_SIZE=10240
    CONFIG_MBEDTLS_CFG_FILE="mcuboot-mbedtls-cfg.h"
    CONFIG_BOOT_SWAP_SAVE_ENCTLV=n
    CONFIG_BOOT_ENCRYPT_RSA=n
    CONFIG_BOOT_ENCRYPT_EC256=n
    CONFIG_BOOT_ENCRYPT_X25519=n
    CONFIG_BOOT_UPGRADE_ONLY=n
    CONFIG_BOOT_BOOTSTRAP=n
    CONFIG_FLASH=y
    CONFIG_FPROTECT=y
    CONFIG_LOG=y
    CONFIG_LOG_MODE_MINIMAL=y # former CONFIG_MODE_MINIMAL
    ### Ensure Zephyr logging changes don't use more resources
    CONFIG_LOG_DEFAULT_LEVEL=0
    ### Decrease footprint by ~4 KB in comparison to CBPRINTF_COMPLETE=y
    CONFIG_CBPRINTF_NANO=y
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    ### ?!? 18-Dec-2022 Without this swap is used which limits upgrades 10000 / (150 / 4) ~ 267
    CONFIG_BOOT_SWAP_USING_MOVE=y
  • I were able to get some unstable RTT logging from MCUboot using the configurations from  Add RTT Logs to mcuboot
    (You can just set LOG_MODE in child_image/mcuboot.conf I think)
    Sigurd Hellesvik
  • I calculate now a checksum (on the fly) of all of the data sent in send_upload2() and verified that my streamed image is NOT getting corrupted as its checksum is the same as on my PC hard drive before being uploaded to our host by cellular modem and being streamed to the Nordic nRF52840 Central and on to our sensor.
    I tried just SMP uploading and issue the SMP test without the SMP reset. I powered on and off the sensor but that image was not swapped.
    I tried to SMP upload and issued the SMP confirm command instead of the test and got an error 10 as shown below when debugging the central. Maybe this will help?
    [ami_smp.c: 690] DFU:318000/319026
    [ami_smp.c: 690] DFU:318400/319026
    [ami_smp.c: 690] DFU:318800/319026
    [ami_smp.c: 880] SMP UploadOK
    [ami_smp.c:1161] ImageList
    -----------PRIMARY IMAGE-----------
          slot: 0
          version: 0.0.0
          hash: 0x28e54c8886d01dddf92457333eede4405517aba9e7aeca3bbdd43f8475975993
          bootable: true
          pending: false
          confirmed: true
          active: true
          permanent: false
    -----------SECONDARY IMAGE-----------
          slot: 1
          version: 0.0.0
          hash: 0x4165b6dabeb5dfab85e276b4e927b2e32358d38f1ef8d698617c5f449a095
          bootable: true
          pending: false
          confirmed: false
          active: false
          permanent: false
    [ami_smp.c:1170] ImageConfirm
    Decoding error, start_decode images->list  (err: 10)
    This is my upload function. It finishes correctly. I could not see any problem in the function that is much different than the example code.
    #define UPLOAD_CHUNK		400 // (50 worked) This has to be at least 32 bytes, since first it has to send the whole header (which is 32 bytes)
    void send_upload2(void)
      uint8_t       data[UPLOAD_CHUNK+1]; // One more byte, to store '/0'
      zcbor_state_t zse[2];
      size_t        payload_len;
      int           start_addr   = PM_MCUBOOT_SECONDARY_ADDRESS;
      int           last_addr    = PM_MCUBOOT_SECONDARY_ADDRESS+ami_state->dfu.ImageSize.ulong;
      int           curr_addr    = start_addr;
      int           upload_chunk = UPLOAD_CHUNK;
      int           err;
      bool          update_complete = false;
      uint8_t       wait_timeouts = 0;
      ami_state->DFUErr                 = AMI_SMP_DFU_ERR_OK;
      ami_state->dfu.uAddChecksum.word  = 0;
      ami_state->dfu.uXORChecksum       = 0;
      while (!update_complete){
          struct smp_buffer smp_cmd;
          zcbor_new_encode_state(zse, ARRAY_SIZE(zse), smp_cmd.payload,sizeof(smp_cmd.payload), 0);
          k_sem_take(&upload_sem, K_FOREVER);
          err = 0;
          last_addr    = (PM_MCUBOOT_SECONDARY_ADDRESS+ami_state->dfu.ImageSize.ulong);
          if (ami_state->DFUErr){
            update_complete = true;
          // Disconnected?
          if (!atomic_get(&ble_connected)){
            ami_state->DFUErr = AMI_DFU_ERR_DISCONNECTED;
          if ((curr_addr+UPLOAD_CHUNK) > last_addr){
    	upload_chunk = last_addr - curr_addr;
          // Get the data block from ringbuffer
          ami_state->DFUErr = ami_smp_RetDataBlock(data,upload_chunk);
          progress_print(curr_addr-start_addr, last_addr-start_addr);
          data[upload_chunk] = '\0';
          zse->constant_state->stop_on_error = true;
          zcbor_map_start_encode(zse, 20);
          zcbor_tstr_put_lit(zse, "image");
          zcbor_int64_put(zse, 0);
          zcbor_tstr_put_lit(zse, "data");
          zcbor_bstr_put_lit(zse, data);
          zcbor_tstr_put_lit(zse, "len");
    //          zcbor_uint64_put(zse, (uint64_t)ami_state->dfu.ImageSize.ulong);
          zcbor_uint64_put(zse, (uint64_t)0x5B68);
          zcbor_tstr_put_lit(zse, "off");
          zcbor_uint64_put(zse, curr_addr - start_addr);
          zcbor_tstr_put_lit(zse, "sha");
          zcbor_bstr_put_lit(zse, "12345");
          zcbor_tstr_put_lit(zse, "upgrade");
          zcbor_bool_put(zse, false);
          zcbor_map_end_encode(zse, 20);
          // ZCBOR error?
          if (!zcbor_check_error(zse)) {
            d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"Failed to encode SMP test packet, err: %d", zcbor_pop_error(zse));
            ami_state->DFUErr = AMI_SMP_DFU_ERR_UPLOAD_ENCODE;
          curr_addr+=upload_chunk;
          payload_len = (size_t)(zse->payload - smp_cmd.payload);
          smp_cmd.header.op = 2; /* write request */
          smp_cmd.header.flags = 0;
          smp_cmd.header.len_h8 = (uint8_t)((payload_len >> 8) & 0xFF);
          smp_cmd.header.len_l8 = (uint8_t)((payload_len >> 0) & 0xFF);
          smp_cmd.header.group_h8 = 0;
          smp_cmd.header.group_l8 = 1; /* IMAGE */
          smp_cmd.header.seq = 0;
          smp_cmd.header.id  = 1; /* UPLOAD */
          // ZCBOR error?
          err = bt_dfu_smp_command(&dfu_smp,smp_upload_rsp_proc,sizeof(smp_cmd.header)+payload_len,&smp_cmd);
          if (err){
              d_printf(LINE_INFO,kDbg_Error|kDbg_Host,"bt_dfu_smp_command failed with %d", err);
              ami_state->DFUErr = AMI_SMP_DFU_ERR_SEND;
      } // while
      if (!ami_state->DFUErr){
        ami_smp_PrintChecksums();
        d_printf(LINE_INFO,kDbg_General|kDbg_Host,"SMP UploadOK");
      atomic_set(&smp_finished,true);
    } // send_upload2
    I tried several additions to my child_image mcuboot.conf file, but nothing I did showed any RTT bootloader information. It does say 4 messages dropped.
    [00:00:00.036,834] <inf> mcumgr_zephyr_grp: zephyr_basic_mgmt_init: Registering Zephyr basic mgmt group
    build time: Feb  9 2023 15:07:18
    --- 4 messages dropped ---
    [00:00:00.485,168] <inf> sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
                                             6d 90 41 2a 38 e8 ad 17  29 a5 03 38 39 27 d7 85 |m.A*8... )..89'..
                                             1f 85 d8 e1                                      |....
    [00:00:00.487,609] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.487,640] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
    [00:00:00.487,670] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 109.16784 Build 2917677098
    [00:00:00.488,098] <inf> bt_[0m
    [00:00:00.036,804] <inf> mcumgr_zephyr_grp: zephyr_basic_mgmt_init: Registering Zephyr basic mgmt group
    [00:00:00.473,876] <inf> sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
                                             1f 85 d8 e1                                      |....
    [00:00:00.476,318] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.476,348] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
    [00:00:00.476,379] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 109.16784 Build 2917677098
    [00:00:00.476,806] <inf> bt_hci_core: bt_init: No ID address. App must call settings_load()
    00/00/0000 00:00:00[ami_ble.c: 506] ActualTxPwr:8
    00/00/0000 00:00:00[ami_ble.c: 788] Bluetooth initialized
    [00:00:00.477,508] <wrn> bt_hci_core: bt_set_name: Unable to store name
    [00:00:00.478,057] <inf> bt_hci_core: bt_dev_show_info: Identity: D4:FD:9F:BF:4A:27 (random)
    [00:00:00.478,088] <inf> bt_hci_core: bt_dev_show_info: HCI: version 5.3 (0x0c) revision 0x11fa, manufacturer 0x0059
    [00:00:00.478,118] <inf> bt_hci_core: bt_dev_show_info: LMP: version 5.3 (0x0c) subver 0x11fa
    [00:00:00.478,363] <wrn> bt_hci_core: bt_set_name: Unable to store name
    00/00/0000 00:00:00[ami_ble.c: 555] UpdateAdv x:0 y:0 z:0 Tmp:21 F:0x20
    00/00/0000 00:00:00[ami_ble.c: 593] AdvertisingStarted
    00/00/0000 00:00:00[ami_main.c: 680] ResetCause:1
    [00:00:00.493,591] <err> bt_gatt: db_hash_store: Failed to save Database Hash (err -2)
    01/01/2004 00:00:01[ami_adc.c: 470] RdLSM6DSLThread
    01/01/2004 00:00:01[ami_lsm6dsl.c: 120] RdLSM6DSLThread
    01/01/2004 00:00:01[ami_lsm6dsl.c: 153] NewSample
    01/01/2004 00:00:04[ami_lsm6dsl.c: 406] RMS x:0 y:2 z:0 ov:0 Temp:1869 Bat:625
    01/01/2004 00:00:05[ami_ble.c: 555] UpdateAdv x:0 y:2 z:0 Tmp:19 F:0x20
    Any other suggestions?
    Have a good week end
    Thanks David
  • Since the list command works, I also assume that the upload worked.
    Then we can assume that the "confirm" command fails.
    The error is from the response handler.
    From the code, it seems like the "list" handler is used for responses from the "confirm" command.
    This makes sense, though, as The response takes the same format as Get state of images response.
    You see if your "confirm" command worked if the image is tagged as "pending = true".
    If you send a "list" command after doing the "confirm", is the image tagged as "pending" in that case?
    Sigurd Hellesvik
