The following error message appears when the original code "asset_tracker_v2" under NCS 2.0 is compiled with vs code IDE,
Can anyone give me some comments? Thanks!
Hello!
Did you install NCS through the Toolchain Manager in nRF Connect for Desktop?
What device are you trying to compile for?
best regards,
Einar
Hi Einar,
-> Yes.
-> nrf9160dk_nrf9160_ns
BR,
Devin
Hi
Are you still having issues with this?
There seemed to be problems after an nRF Connect for VS Code update last week, but this appears to have been sorted out on my end by now.
-Einar
Hi Einar,
I updated to ncs v2.0.1 and found that the problem still exists. The log information I compiled is as follows:
D:\ncs\gitbranch\nrf (HEAD detached at ffd959d)
λ west zephyr-export
Zephyr (D:/ncs/gitbranch/zephyr/share/zephyr-package/cmake)
has been added to the user package registry in:
HKEY_CURRENT_USER\Software\Kitware\CMake\Packages\Zephyr
ZephyrUnittest (D:/ncs/gitbranch/zephyr/share/zephyrunittest-package/cmake)
HKEY_CURRENT_USER\Software\Kitware\CMake\Packages\ZephyrUnittest
λ cd applications\asset_tracker_v2\
D:\ncs\gitbranch\nrf\applications\asset_tracker_v2 (HEAD detached at ffd959d)
λ west build -b nrf9160dk_nrf9160_ns -p
-- west build: making build dir D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build pristine
-- Application: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2
-- Found Python3: C:/Python39/python.exe (found suitable exact version "3.9.6") found components: Interpreter
-- Cache files will be written to: D:/ncs/gitbranch/zephyr/.cache
-- Zephyr version: 3.0.99 (D:/ncs/gitbranch/zephyr)
-- Found west (found suitable version "0.13.1", minimum required is "0.7.1")
-- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
-- Found dtc: C:/ProgramData/chocolatey/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/gnuarmemb)
-- Found BOARD.dts: D:/ncs/gitbranch/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
-- Found devicetree overlay: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/boards/nrf9160dk_nrf9160_ns.overlay
-- Generated zephyr.dts: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/zephyr/dts.cmake
warning: Experimental symbol NET_SOCKETS_OFFLOAD is enabled.
Parsing D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/Kconfig
Loaded configuration 'D:/ncs/gitbranch/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
Merged configuration 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/prj.conf'
Merged configuration 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/boards/nrf9160dk_nrf9160_ns.conf'
Configuration saved to 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/zephyr/.config'
Kconfig header saved to 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/gnuarmemb/bin/arm-none-eabi-gcc.exe
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image b0 - begin ===
loading initial cache file D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/b0/child_image_preload.cmake
Loading Zephyr default modules (Zephyr base).-- Application: D:/ncs/gitbranch/nrf/samples/bootloader
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found BOARD.dts: D:/ncs/gitbranch/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Generated zephyr.dts: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/b0/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/b0/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/b0/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/b0/zephyr/dts.cmake
Parsing D:/ncs/gitbranch/zephyr/Kconfig
Loaded configuration 'D:/ncs/gitbranch/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration 'D:/ncs/gitbranch/nrf/samples/bootloader/prj.conf'
Merged configuration 'D:/ncs/gitbranch/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/b0/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/b0/zephyr/.config'
Kconfig header saved to 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/b0/zephyr/include/generated/autoconf.h'
CMake Warning at D:/ncs/gitbranch/nrf/subsys/bootloader/CMakeLists.txt:21 (message):
--- WARNING: When using the immutable bootloader on ---
--- this SoC, the UICR must be erased when flashing. ---
--- E.g. by calling 'west flash --erase' ---
-- Configuring done
-- Generating done
-- Build files have been written to: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/b0
=== child image b0 - end ===
-- Found Python3: C:/Python39/python.exe (found version "3.9.6") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/child_image_preload.cmake
-- Application: D:/ncs/gitbranch/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: D:/ncs/gitbranch/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/dts.cmake
Parsing D:/ncs/gitbranch/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration 'D:/ncs/gitbranch/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'D:/ncs/gitbranch/nrf/subsys/bootloader/image/multi_image_mcuboot.conf'
Merged configuration 'D:/ncs/gitbranch/nrf/subsys/bootloader/image/fw_info.conf'
Merged configuration 'D:/ncs/gitbranch/nrf/subsys/bootloader/image/build_s1.conf'
Merged configuration 'D:/ncs/gitbranch/nrf/modules/mcuboot/tfm.conf'
Merged configuration 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/.config'
Kconfig header saved to 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: D:/ncs/gitbranch/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot
=== child image mcuboot - end ===
=== child image s1_image - begin ===
Loading Zephyr default modules (Zephyr base).-- Application: D:/ncs/gitbranch/bootloader/mcuboot/boot/zephyr
-- Generated zephyr.dts: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/s1_image/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/s1_image/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/s1_image/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/s1_image/zephyr/dts.cmake
Merged configuration 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/s1_image/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/s1_image/zephyr/.config'
Kconfig header saved to 'D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/s1_image/zephyr/include/generated/autoconf.h'
-- Configuring done
-- Generating done
-- Build files have been written to: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/s1_image
=== child image s1_image - end ===
CMake Warning at D:/ncs/gitbranch/nrf/modules/mcuboot/CMakeLists.txt:281 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
CMake Warning at D:/ncs/gitbranch/zephyr/CMakeLists.txt:1803 (message):
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
[0/428] Generating signing key
[1/428] Generating include/generated/version.h
-- Zephyr version: 3.0.99 (D:/ncs/gitbranch/zephyr), build: v3.0.99-ncs1
[6/428] Generating extra provision key files
[47/428] Performing build step for 'b0_subimage'
[1/160] Generating include/generated/version.h
[150/160] Linking C executable zephyr\zephyr_pre0.elf
[154/160] Linking C executable zephyr\zephyr_pre1.elf
[160/160] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 23212 B 32 KB 70.84%
SRAM: 37264 B 178968 B 20.82%
IDT_LIST: 0 GB 2 KB 0.00%
[68/428] Generating ../../tfm/CMakeCache.txt
Start to generate partition files:
Generating Header: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/tfm/generated/secure_fw/partitions/crypto/psa_manifest/tfm_crypto.h
Generating Intermedia: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/tfm/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.c
Generating Loadinfo: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/tfm/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.c
Generating Header: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/tfm/generated/secure_fw/partitions/platform/psa_manifest/tfm_platform.h
Generating Intermedia: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/tfm/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.c
Generating Loadinfo: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/tfm/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.c
Per-partition files done:
Start to generate file from the generated list:
Generating D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build\tfm\generated\secure_fw/spm/cmsis_func/tfm_spm_db_func.inc
Generating D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build\tfm\generated\secure_fw/spm/cmsis_func/tfm_veneers.c
Generating D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build\tfm\generated\interface/include/tfm_veneers.h
Generating D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build\tfm\generated\secure_fw/spm/cmsis_func/tfm_secure_irq_handlers.inc
Generating D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build\tfm\generated\interface/include/psa_manifest/sid.h
Generating D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build\tfm\generated\interface/include/psa_manifest/pid.h
Generating D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build\tfm\generated\interface/include/config_impl.h
Generation of files done
-- ---------- Display crypto configuration - start --------------
-- CRYPTO_RNG_MODULE_DISABLED is set to FALSE
-- CRYPTO_KEY_MODULE_DISABLED is set to TRUE
-- CRYPTO_AEAD_MODULE_DISABLED is set to TRUE
-- CRYPTO_MAC_MODULE_DISABLED is set to TRUE
-- CRYPTO_CIPHER_MODULE_DISABLED is set to TRUE
-- CRYPTO_HASH_MODULE_DISABLED is set to TRUE
-- CRYPTO_KEY_DERIVATION_MODULE_DISABLED is set to TRUE
-- CRYPTO_ASYM_SIGN_MODULE_DISABLED is set to TRUE
-- CRYPTO_ASYM_ENCRYPT_MODULE_DISABLED is set to TRUE
-- CRYPTO_ENGINE_BUF_SIZE is set to 1
-- CRYPTO_CONC_OPER_NUM is set to 8
-- CRYPTO_IOVEC_BUFFER_SIZE is set to 5120
-- ---------- Display crypto configuration - stop ---------------
-- Configuring done
-- Generating done
-- Build files have been written to: D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/tfm
[78/428] Creating public key from private key used for signing
[81/428] Performing build step for 'mcuboot_subimage'
[1/186] Generating include/generated/version.h
[176/186] Linking C executable zephyr\zephyr_pre0.elf
[180/186] Linking C executable zephyr\zephyr_pre1.elf
[186/186] Linking C executable zephyr\zephyr.elf
FAILED: zephyr/zephyr.elf zephyr/zephyr.map zephyr/zephyr.hex zephyr/zephyr.bin zephyr/zephyr.meta zephyr/zephyr.lst zephyr/zephyr.stat D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr.map D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr.hex D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr.bin D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr.meta D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr.lst D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr.stat
cmd.exe /C "cd . && C:\gnuarmemb\bin\arm-none-eabi-gcc.exe zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj -o zephyr\zephyr.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -Wl,-T zephyr/linker.cmd -Wl,-Map=D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr_final.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/boards/boards/arm/nrf9160dk_nrf9160/libboards__arm__nrf9160dk_nrf9160.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/fw_info/lib..__nrf__subsys__fw_info.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main+fp/hard" -LD:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr -lgcc -Wl,--print-memory-usage zephyr/arch/common/libisr_tables.a -no-pie -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms
-nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn D:/ncs/gitbranch/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_platform_0.9.14.a D:/ncs/gitbranch/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cmd.exe /C "cd /D D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build\mcuboot\zephyr && C:\Python39\Lib\site-packages\cmake\data\bin\cmake.exe -E copy zephyr_final.map zephyr.map && C:\gnuarmemb\bin\arm-none-eabi-objcopy.exe --gap-fill 0xff --output-target=ihex --remove-section=.comment --remove-section=COMMON --remove-section=.eh_frame zephyr.elf zephyr.hex && C:\gnuarmemb\bin\arm-none-eabi-objcopy.exe --gap-fill 0xff --output-target=binary --remove-section=.comment --remove-section=COMMON --remove-section=.eh_frame zephyr.elf zephyr.bin && C:\Python39\python.exe D:/ncs/gitbranch/zephyr/scripts/zephyr_module.py --zephyr-base D:/ncs/gitbranch/zephyr --meta-out zephyr.meta && C:\gnuarmemb\bin\arm-none-eabi-objdump.exe -d -S zephyr.elf > zephyr.lst && C:\gnuarmemb\bin\arm-none-eabi-readelf.exe -e zephyr.elf > zephyr.stat""
FLASH: 34256 B 48 KB 69.69%
SRAM: 18504 B 178968 B 10.34%
File "D:\ncs\gitbranch\zephyr\scripts\zephyr_module.py", line 548, in <module>
main()
File "D:\ncs\gitbranch\zephyr\scripts\zephyr_module.py", line 540, in main
meta = process_meta(args.zephyr_base, west_proj, modules,
File "D:\ncs\gitbranch\zephyr\scripts\zephyr_module.py", line 319, in process_meta
if project.sha(MANIFEST_REV_BRANCH) != revision:
File "C:\Python39\lib\site-packages\west\manifest.py", line 866, in sha
cp = self.git(f'rev-parse {rev}^{{commit}}', capture_stdout=True,
File "C:\Python39\lib\site-packages\west\manifest.py", line 850, in git
raise subprocess.CalledProcessError(popen.returncode, cmd_list,
subprocess.CalledProcessError: Command '['rev-parse', 'manifest-rev^{commit}']' returned non-zero exit status 128.
[82/428] Generating zephyr/b0_container.hex
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr.hex D:/ncs/gitbranch/nrf/applications/asset_tracker_v2/build/mcuboot/zephyr/zephyr.elf
cmd.exe /C "cd /D D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build\mcuboot && C:\Python39\Lib\site-packages\cmake\data\bin\cmake.exe --build . --"
FATAL ERROR: command exited with status 1: 'C:\Python39\Scripts\cmake.EXE' --build 'D:\ncs\gitbranch\nrf\applications\asset_tracker_v2\build'
λ
can you find out what the problem is?
When I checkout to ncs v1.9.2 it compiles fine.
BR,
Devin
Hi
It looks like you are getting a different error after updating?
Have you tried deleting your VS Code project and making a new one? I believe this was necessary on my end.
Einar
Hi Einar,
The problem was solved after I updated to NCS 2.0.2。
Thanks.
Devin
Hi Einar,
Thanks.
Devin
