Toolchain Manager doesn't detect VS Code if it's not installed in the default location
Running through the Toolchain setup instructions, installing VS Code to a custom location rather than the default location of C:\Users\{Username}\AppData\Local\Programs\Microsoft VS Code leads to a problem where the "Open Vs Code" widget in Toolchain manager brings up an error message saying "VS Code was not detected on your system. install VS Code ...". I looked for a setting in Toolchain Manager to manually tell it where VS Code has been installed, but couldn't find one. Does it exist? Where if so. If not, is there a config file line I can edit to specify it, and any chance that you could an option to manually specify in a future release?
