Grove LCD - Grove LCD: Device not ready.
I am running the standard Grove LCD code, as below but am getting an error, "Grove LCD: Device not ready.'
the code is
 * Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr.h>
#include <device.h>
//#include <display/cfb.h>
#include <stdio.h>
#include <drivers/display.h>
#include <nrf-pinctrl.h>
#include <drivers/i2c.h>
#include <sys/printk.h>
#include <zephyr/drivers/sensor.h>
#include <zephyr/sys/util.h>
#include <drivers/misc/grove_lcd/grove_lcd.h>
#include <string.h>
 * @file Display a counter through I2C and Grove LCD.
/* sleep time in msec */
#define SLEEPTIME  100
uint8_t clamp_rgb(int val)
	if (val > 255) {
		return 255;
	} else if (val < 0) {
		return 0;
	} else {
		return val;
void main(void)
	const struct device *glcd = DEVICE_DT_GET(DT_NODELABEL(glcd));
	char str[20];
	int rgb[] = { 0x0, 0x0, 0x0 };
	uint8_t rgb_chg[3];
	const uint8_t rgb_step = 16U;
	uint8_t set_config;
	int i, j, m;
	int cnt;
	if (!device_is_ready(glcd)) {
		printk("Grove LCD: Device not ready.\n");
		return;
	/* Now configure the LCD the way we want it */
	set_config = GLCD_FS_ROWS_2
		     | GLCD_FS_DOT_SIZE_LITTLE
		     | GLCD_FS_8BIT_MODE;
	glcd_function_set(glcd, set_config);
	set_config = GLCD_DS_DISPLAY_ON | GLCD_DS_CURSOR_ON | GLCD_DS_BLINK_ON;
	glcd_display_state_set(glcd, set_config);
	/* Setup variables /*/
	for (i = 0; i < sizeof(str); i++) {
		str[i] = '\0';
	/* Starting counting */
	cnt = 0;
	while (1) {
		glcd_cursor_pos_set(glcd, 0, 0);
		/* RGB values are from 0 - 511.
		 * First half means incrementally brighter.
		 * Second half is opposite (i.e. goes darker).
		/* Update the RGB values for backlight */
		m = (rgb[2] > 255) ? (512 - rgb[2]) : (rgb[2]);
		rgb_chg[2] = clamp_rgb(m);
		m = (rgb[1] > 255) ? (512 - rgb[1]) : (rgb[1]);
		rgb_chg[1] = clamp_rgb(m);
		m = (rgb[0] > 255) ? (512 - rgb[0]) : (rgb[0]);
		rgb_chg[0] = clamp_rgb(m);
		glcd_color_set(glcd, rgb_chg[0], rgb_chg[1], rgb_chg[2]);
		/* Display the counter
		 * well... sprintf() might be easier,
		 * but this is more fun.
		m = cnt;
		i = 1000000000;
		j = 0;
		while (i > 0) {
			str[j] = '0' + (m / i);
			m = m % i;
			i = i / 10;
			j++;
		cnt++;
		glcd_print(glcd, str, j);
		/* Rotate RGB values */
		rgb[2] += rgb_step;
		if (rgb[2] > 511) {
			rgb[2] = 0;
			rgb[1] += rgb_step;
		if (rgb[1] > 511) {
			rgb[1] = 0;
			rgb[0] += rgb_step;
		if (rgb[0] > 511) {
			rgb[0] = 0;
		/* wait a while */
		k_msleep(SLEEPTIME);
my overlay file is
        chosen {
		zephyr,display = &glcd;
&pinctrl {
	uart0_default_alt: uart0_default_alt {
		group0 {
			psels = <NRF_PSEL(UART_TX, 0, 24)>, <NRF_PSEL(UART_RX, 0, 22)>;
	uart0_sleep_alt: uart0_sleep_alt {
		group1 {
			low-power-enable;
	i2c0_default_alt: i2c0_default_alt {
       		group2 {
          		psels = <NRF_PSEL(TWIM_SDA, 0, 17)>,
                  		<NRF_PSEL(TWIM_SCL, 0, 20)>;
&uart0 {
	pinctrl-0 = <&uart0_default_alt>;
	pinctrl-1 = <&uart0_sleep_alt>;
	compatible = "nordic,nrf-uart";
	current-speed = <115200>;
	status = "okay";
&i2c0 {
	status = "okay";
	pinctrl-0 = <&i2c0_default>;
	pinctrl-1 = <&i2c0_sleep>;
    	clock-frequency = <I2C_BITRATE_STANDARD>;
//	clock-frequency = <I2C_BITRATE_FAST>;
	zephyr,concat-buf-size = <520>;
	glcd: glcd@3e {
		compatible = "seeed,grove-lcd-rgb";
		label = "GLCD";
		reg = <0x3e>;
&i2c0 {
/delete-property/sda-gpios;
/delete-property/scl-gpios;
and my proj file
# General config
CONFIG_BOARD_HAS_NRF5_BOOTLOADER=n
CONFIG_ASSERT=y
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_GPIO=y
CONFIG_SERIAL=y
CONFIG_NEWLIB_LIBC=y
CONFIG_CONSOLE_SUBSYS=y
CONFIG_CONSOLE_GETCHAR=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_CONSOLE=y
CONFIG_CPLUSPLUS=y
CONFIG_LOG=y
CONFIG_SHELL=y
CONFIG_REBOOT=y
CONFIG_UART_CONSOLE=y
CONFIG_GPIO=y
CONFIG_PRINTK=y
CONFIG_PINCTRL=y
CONFIG_PM_DEVICE=y
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
CONFIG_SENSOR=y
CONFIG_BOOT_BANNER=n
#Display
CONFIG_DISPLAY=y
CONFIG_CHARACTER_FRAMEBUFFER=y
CONFIG_SHELL=y
CONFIG_CHARACTER_FRAMEBUFFER_SHELL=y
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_GROVE_LCD_RGB=y
I think I'm missing something obvious but can't see it :-(
Rod
Parents Reply
  • Sorry, just found my mistake. I was comparing your code to mine I realised I made an error in the overlay file.
    I had defined the group as
    i2c1_default_alt: i2c1_default_alt
    but then when I called it, i used
    pinctrl-0 = <&i2c1_default>;
    and missed off the _alt. Dooh!, my mistake, sorry.
    The code is now running,  It is not running as previously, the characters are jumping around and it is not running as it did in older versions, although the source code does look the same. So, Im guessing there is something else hidden in there.
    I will close this now, thanks for your help and sorry again for the mistake
    Rod
