Matter commissioning fails between two nrf52840 boards
What I've done
1) Set up ot-br on an Rpi4 by following this guide.
2) Set up a 52840Dongle (plugged into the RPi4) as RCP by following this guide.
3) Installed the light_bulb example on a 52840DK using the nrf connect vscode extenrion.
What I've tried next
1) Hold "IF BOOT RESET" on the DK to reset to a clean state
2) Commission the device on to the network by running
~/connectedhomeip/out/host$ sudo ./chip-tool pairing code 1 MT:6FCJ142C00KA0648G00
` 3 times. Note that the runs give different results.
Logs from the chip-tool commands:
ubuntu@ubuntu:~/connectedhomeip/out/host$ sudo ./chip-tool pairing code 1 MT:6FCJ142C00KA0648G00
[1657752376.872877][1970:1970] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1657752376.873088][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_kvs-DWgaQ8)
[1657752376.873223][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_kvs)
[1657752376.873565][1970:1970] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1657752376.873684][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-wrZbmc)
[1657752376.873799][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
[1657752376.873864][1970:1970] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1657752376.873949][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_config.ini-d4Jxq9)
[1657752376.874029][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
[1657752376.874086][1970:1970] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1657752376.874153][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-XW8F57)
[1657752376.874231][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752376.874413][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-8kIW2b)
[1657752376.874770][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
[1657752376.874804][1970:1970] CHIP:DL: NVS set: chip-factory/unique-id = "C652FD5861393522"
[1657752376.874900][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-Ni6EH9)
[1657752376.877865][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
[1657752376.877913][1970:1970] CHIP:DL: NVS set: chip-factory/vendor-id = 65521 (0xFFF1)
[1657752376.878043][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_factory.ini-u3OlZa)
[1657752376.878598][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_factory.ini)
[1657752376.878639][1970:1970] CHIP:DL: NVS set: chip-factory/product-id = 32769 (0x8001)
[1657752376.878747][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-A0fIda)
[1657752376.879317][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752376.879381][1970:1970] CHIP:DL: NVS set: chip-counters/reboot-count = 1 (0x1)
[1657752376.879538][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-YOSyV9)
[1657752376.880083][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752376.880127][1970:1970] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1657752376.880282][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-x1b0Rb)
[1657752376.883532][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752376.883598][1970:1970] CHIP:DL: NVS set: chip-counters/boot-reason = 0 (0x0)
[1657752376.883774][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_config.ini-ZZfYg9)
[1657752376.884263][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
[1657752376.884317][1970:1970] CHIP:DL: NVS set: chip-config/regulatory-location = 0 (0x0)
[1657752376.884460][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_config.ini-2lvcJb)
[1657752376.884999][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_config.ini)
[1657752376.885055][1970:1970] CHIP:DL: NVS set: chip-config/location-capability = 2 (0x2)
[1657752376.886042][1970:1970] CHIP:DL: Got Ethernet interface: eth0
[1657752376.887042][1970:1970] CHIP:DL: Found the primary Ethernet interface:eth0
[1657752376.887542][1970:1970] CHIP:DL: Got WiFi interface: wlan0
[1657752376.890024][1970:1970] CHIP:DL: Found the primary WiFi interface:wlan0
[1657752376.890097][1970:1970] CHIP:IN: UDP::Init bind&listen port=0
[1657752376.890444][1970:1970] CHIP:IN: UDP::Init bound to port=43463
[1657752376.890479][1970:1970] CHIP:IN: UDP::Init bind&listen port=0
[1657752376.890579][1970:1970] CHIP:IN: UDP::Init bound to port=50465
[1657752376.890608][1970:1970] CHIP:IN: BLEBase::Init - setting/overriding transport
[1657752376.890656][1970:1970] CHIP:IN: TransportMgr initialized
[1657752376.890726][1970:1970] CHIP:FP: Initializing FabricTable from persistent storage
[1657752376.890841][1970:1970] CHIP:TS: Last Known Good Time: [unknown]
[1657752376.890886][1970:1970] CHIP:TS: Setting Last Known Good Time to firmware build time 2022-07-13T18:42:46
[1657752376.893380][1970:1970] CHIP:ZCL: Using ZAP configuration...
[1657752376.894841][1970:1970] CHIP:DL: MDNS failed to join multicast group on eth0 for address type IPv4: ../../src/inet/UDPEndPointImplSockets.cpp:772: Inet Error 0x00000110: Address not found
[1657752376.897134][1970:1970] CHIP:DL: MDNS failed to join multicast group on wpan0 for address type IPv4: ../../src/inet/UDPEndPointImplSockets.cpp:772: Inet Error 0x00000110: Address not found
[1657752376.898032][1970:1970] CHIP:CTL: System State Initialized...
[1657752376.899133][1970:1970] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752376.899190][1970:1970] CHIP:CTL: Setting attestation nonce to random value
[1657752376.899255][1970:1970] CHIP:CTL: Setting CSR nonce to random value
[1657752376.899372][1970:1970] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752376.899401][1970:1970] CHIP:CTL: Setting attestation nonce to random value
[1657752376.899447][1970:1970] CHIP:CTL: Setting CSR nonce to random value
[1657752376.899880][1970:1970] CHIP:CTL: Couldn't get ExampleOpCredsCAKey from storage: ../../examples/chip-tool/config/PersistentStorage.cpp:85: CHIP Error 0x000000A0: Value not found in the persisted storage
[1657752376.902620][1970:1970] CHIP:CTL: Couldn't get ExampleOpCredsICAKey from storage: ../../examples/chip-tool/config/PersistentStorage.cpp:85: CHIP Error 0x000000A0: Value not found in the persisted storage
[1657752376.903838][1970:1970] CHIP:CTL: Generating RCAC
[1657752376.907228][1970:1970] CHIP:CTL: Generating ICAC
[1657752376.910410][1970:1970] CHIP:CTL: Generating NOC
[1657752376.913826][1970:1970] CHIP:FP: Validating NOC chain
[1657752376.915908][1970:1970] CHIP:FP: NOC chain validation successful
[1657752376.918116][1970:1970] CHIP:FP: Added new fabric at index: 0x1
[1657752376.918152][1970:1970] CHIP:FP: Assigned compressed fabric ID: 0x0D0D872986F5DBB4, node ID: 0x000000000001B669
[1657752376.918185][1970:1970] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752376.918213][1970:1970] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752376.918237][1970:1970] CHIP:TS: Retaining current Last Known Good Time
[1657752376.919893][1970:1970] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1657752376.922141][1970:1970] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752376.924454][1970:1970] CHIP:CTL: Joined the fabric at index 1. Compressed fabric ID is: 0x0000000000000000
[1657752376.924570][1970:1970] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752376.924613][1970:1970] CHIP:CTL: Setting attestation nonce to random value
[1657752376.924686][1970:1970] CHIP:CTL: Setting CSR nonce to random value
[1657752376.926024][1970:1970] CHIP:CTL: Generating NOC
[1657752376.926955][1970:1970] CHIP:FP: Validating NOC chain
[1657752376.929072][1970:1970] CHIP:FP: NOC chain validation successful
[1657752376.929264][1970:1970] CHIP:FP: Added new fabric at index: 0x2
[1657752376.929295][1970:1970] CHIP:FP: Assigned compressed fabric ID: 0x371042A6B8C55FE8, node ID: 0x000000000001B669
[1657752376.929326][1970:1970] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752376.929350][1970:1970] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752376.929372][1970:1970] CHIP:TS: Retaining current Last Known Good Time
[1657752376.930982][1970:1970] CHIP:FP: Metadata for Fabric 0x2 persisted to storage.
[1657752376.933252][1970:1970] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752376.938283][1970:1970] CHIP:CTL: Joined the fabric at index 2. Compressed fabric ID is: 0x0000000000000000
[1657752376.938396][1970:1970] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752376.938430][1970:1970] CHIP:CTL: Setting attestation nonce to random value
[1657752376.938488][1970:1970] CHIP:CTL: Setting CSR nonce to random value
[1657752376.939555][1970:1970] CHIP:CTL: Generating NOC
[1657752376.940418][1970:1970] CHIP:FP: Validating NOC chain
[1657752376.942116][1970:1970] CHIP:FP: NOC chain validation successful
[1657752376.942269][1970:1970] CHIP:FP: Added new fabric at index: 0x3
[1657752376.942291][1970:1970] CHIP:FP: Assigned compressed fabric ID: 0x3D3201B65A89FB29, node ID: 0x000000000001B669
[1657752376.942316][1970:1970] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752376.942335][1970:1970] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752376.942352][1970:1970] CHIP:TS: Retaining current Last Known Good Time
[1657752376.943946][1970:1970] CHIP:FP: Metadata for Fabric 0x3 persisted to storage.
[1657752376.954317][1970:1970] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752376.957199][1970:1970] CHIP:CTL: Joined the fabric at index 3. Compressed fabric ID is: 0x0000000000000000
[1657752377.033210][1970:1976] CHIP:DL: CHIP task running
[1657752377.033351][1970:1976] CHIP:CTL: Setting attestation nonce to random value
[1657752377.033504][1970:1976] CHIP:CTL: Setting CSR nonce to random value
[1657752377.036695][1970:1976] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752377.036728][1970:1976] CHIP:CTL: Starting commissioning discovery over BLE
[1657752377.036760][1970:1976] CHIP:CTL: Starting commissioning discovery over DNS-SD
[1657752377.037069][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752377.037702][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752377.037735][1970:1976] CHIP:DIS: mDNS broadcast had only partial success: 8 successes and 2 failures.
[1657752377.038011][1970:1977] CHIP:DL: TRACE: Bluez mainloop starting Thread
[1657752377.038431][1970:1973] CHIP:DL: TRACE: Bus acquired for name C-07b2
[1657752377.049881][1970:1976] CHIP:DL: PlatformBlueZInit init success
[1657752377.055880][1970:1973] CHIP:BLE: BLE removing known devices.
[1657752377.057376][1970:1973] CHIP:BLE: BLE initiating scan.
[1657752377.812119][1970:1976] CHIP:DL: Long dispatch time: 774 ms, for event type 2
[1657752377.850872][1970:1973] CHIP:BLE: Device 66:DB:45:2B:A1:BA does not look like a CHIP device.
[1657752377.856569][1970:1973] CHIP:BLE: Device FC:58:FA:8B:4D:4B does not look like a CHIP device.
[1657752377.879525][1970:1973] CHIP:BLE: Device 50:01:00:00:01:2E does not look like a CHIP device.
[1657752377.881215][1970:1973] CHIP:BLE: Device 66:B5:C2:5B:4A:5F does not look like a CHIP device.
[1657752377.882733][1970:1973] CHIP:BLE: Device 7C:0A:3F:99:31:F9 does not look like a CHIP device.
[1657752378.025532][1970:1973] CHIP:BLE: Device 71:3D:2F:2A:AC:F0 does not look like a CHIP device.
[1657752378.027943][1970:1973] CHIP:BLE: Device 7B:D3:38:94:29:5A does not look like a CHIP device.
[1657752378.037893][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752378.038741][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752378.038787][1970:1976] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752378.039852][1970:1973] CHIP:BLE: Device F8:9A:FA:3C:7B:E4 does not look like a CHIP device.
[1657752378.277114][1970:1973] CHIP:BLE: Device 5A:4B:3A:A2:83:8F does not look like a CHIP device.
[1657752378.386483][1970:1973] CHIP:BLE: Device 54:96:94:3A:78:70 does not look like a CHIP device.
[1657752378.431936][1970:1973] CHIP:BLE: Device 5C:56:CA:2B:F8:30 does not look like a CHIP device.
[1657752378.483268][1970:1973] CHIP:BLE: Device 53:EE:CB:63:79:6D does not look like a CHIP device.
[1657752378.548415][1970:1973] CHIP:BLE: Device 42:E7:91:48:90:9B does not look like a CHIP device.
[1657752378.679448][1970:1973] CHIP:BLE: Device 57:E4:C4:C9:EC:08 does not look like a CHIP device.
[1657752378.681175][1970:1973] CHIP:BLE: Device 34:E0:1A:FC:91:D4 does not look like a CHIP device.
[1657752378.876036][1970:1973] CHIP:BLE: Device 77:37:77:08:E4:12 does not look like a CHIP device.
[1657752379.111460][1970:1973] CHIP:BLE: New device scanned: DF:84:4E:3B:47:6F
[1657752379.111543][1970:1973] CHIP:BLE: Device discriminator match. Attempting to connect.
[1657752379.116259][1970:1973] CHIP:BLE: Scan complete notification without an active scan.
[1657752379.552347][1970:1973] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
[1657752380.040417][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752380.041726][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752380.041804][1970:1976] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752380.736130][1970:1973] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
[1657752381.633532][1970:1973] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
[1657752382.347258][1970:1973] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
[1657752383.399842][1970:1973] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
[1657752383.400117][1970:1976] CHIP:DL: HandlePlatformSpecificBLEEvent 16386
[1657752383.400201][1970:1976] CHIP:CTL: Commissioning discovery over BLE failed: ../../src/platform/Linux/bluez/Helper.cpp:1775: CHIP Error 0x000000AC: Internal error
[1657752383.400261][1970:1976] CHIP:-: ../../src/platform/Linux/bluez/Helper.cpp:1775: CHIP Error 0x000000AC: Internal error at ../../src/controller/SetUpCodePairer.cpp:270
[1657752384.041587][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752384.042884][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752384.043019][1970:1976] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752392.044202][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752392.046348][1970:1976] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752392.046426][1970:1976] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752407.053852][1970:1976] CHIP:CTL: Discovery timed out
[1657752407.053939][1970:1976] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752407.053995][1970:1976] CHIP:TOO: Secure Pairing Failed
[1657752407.054614][1970:1970] CHIP:CTL: Shutting down the commissioner
[1657752407.054688][1970:1970] CHIP:CTL: Shutting down the controller
[1657752407.054746][1970:1970] CHIP:CTL: Shutting down the commissioner
[1657752407.054793][1970:1970] CHIP:CTL: Shutting down the controller
[1657752407.054841][1970:1970] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1657752407.054887][1970:1970] CHIP:FP: Forgetting fabric 0x1
[1657752407.054949][1970:1970] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752407.055339][1970:1970] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752407.055394][1970:1970] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752407.055475][1970:1970] CHIP:CTL: Shutting down the commissioner
[1657752407.055522][1970:1970] CHIP:CTL: Shutting down the controller
[1657752407.055565][1970:1970] CHIP:IN: Expiring all sessions for fabric 0x2!!
[1657752407.055607][1970:1970] CHIP:FP: Forgetting fabric 0x2
[1657752407.055657][1970:1970] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752407.055982][1970:1970] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752407.056037][1970:1970] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752407.056105][1970:1970] CHIP:CTL: Shutting down the commissioner
[1657752407.056152][1970:1970] CHIP:CTL: Shutting down the controller
[1657752407.056194][1970:1970] CHIP:IN: Expiring all sessions for fabric 0x3!!
[1657752407.056236][1970:1970] CHIP:FP: Forgetting fabric 0x3
[1657752407.056285][1970:1970] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752407.056543][1970:1970] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752407.056594][1970:1970] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752407.056652][1970:1970] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1657752407.057742][1970:1970] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752407.057800][1970:1970] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752407.057843][1970:1970] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752407.057885][1970:1970] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752407.057929][1970:1970] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1657752407.058086][1970:1970] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1657752407.058513][1970:1970] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-o2a0kc)
[1657752407.059508][1970:1970] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752407.059608][1970:1970] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1657752407.059660][1970:1970] CHIP:DL: Inet Layer shutdown
[1657752407.059747][1970:1970] CHIP:DL: BLE shutdown
[1657752407.062040][1970:1970] CHIP:DL: System Layer shutdown
[1657752407.062292][1970:1970] CHIP:TOO: Run command failure: ../../examples/chip-tool/commands/pairing/PairingCommand.cpp:151: CHIP Error 0x00000003: Incorrect state
[1657752409.785223][1983:1983] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1657752409.785700][1983:1983] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1657752409.785849][1983:1983] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1657752409.785947][1983:1983] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1657752409.786231][1983:1983] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-H6SeR8)
[1657752409.786706][1983:1983] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752409.786742][1983:1983] CHIP:DL: NVS set: chip-counters/reboot-count = 2 (0x2)
[1657752409.787443][1983:1983] CHIP:DL: Got Ethernet interface: eth0
[1657752409.788017][1983:1983] CHIP:DL: Found the primary Ethernet interface:eth0
[1657752409.788515][1983:1983] CHIP:DL: Got WiFi interface: wlan0
[1657752409.790625][1983:1983] CHIP:DL: Found the primary WiFi interface:wlan0
[1657752409.790684][1983:1983] CHIP:IN: UDP::Init bind&listen port=0
[1657752409.790795][1983:1983] CHIP:IN: UDP::Init bound to port=44091
[1657752409.790815][1983:1983] CHIP:IN: UDP::Init bind&listen port=0
[1657752409.790893][1983:1983] CHIP:IN: UDP::Init bound to port=54164
[1657752409.790920][1983:1983] CHIP:IN: BLEBase::Init - setting/overriding transport
[1657752409.790942][1983:1983] CHIP:IN: TransportMgr initialized
[1657752409.790972][1983:1983] CHIP:FP: Initializing FabricTable from persistent storage
[1657752409.791239][1983:1983] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752409.792072][1983:1983] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x0D0D872986F5DBB4, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1657752409.792676][1983:1983] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x371042A6B8C55FE8, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
[1657752409.793034][1983:1983] CHIP:FP: Fabric index 0x3 was retrieved from storage. Compressed FabricId 0x3D3201B65A89FB29, FabricId 0x0000000000000003, NodeId 0x000000000001B669, VendorId 0xFFF1
[1657752409.795917][1983:1983] CHIP:ZCL: Using ZAP configuration...
[1657752409.797104][1983:1983] CHIP:DL: MDNS failed to join multicast group on eth0 for address type IPv4: ../../src/inet/UDPEndPointImplSockets.cpp:772: Inet Error 0x00000110: Address not found
[1657752409.799084][1983:1983] CHIP:DL: MDNS failed to join multicast group on wpan0 for address type IPv4: ../../src/inet/UDPEndPointImplSockets.cpp:772: Inet Error 0x00000110: Address not found
[1657752409.799913][1983:1983] CHIP:CTL: System State Initialized...
[1657752409.799985][1983:1983] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752409.800018][1983:1983] CHIP:CTL: Setting attestation nonce to random value
[1657752409.800075][1983:1983] CHIP:CTL: Setting CSR nonce to random value
[1657752409.800160][1983:1983] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752409.800185][1983:1983] CHIP:CTL: Setting attestation nonce to random value
[1657752409.800223][1983:1983] CHIP:CTL: Setting CSR nonce to random value
[1657752409.802693][1983:1983] CHIP:CTL: Generating NOC
[1657752409.803921][1983:1983] CHIP:FP: Validating NOC chain
[1657752409.805551][1983:1983] CHIP:FP: NOC chain validation successful
[1657752409.805704][1983:1983] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1657752409.805735][1983:1983] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752409.805755][1983:1983] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752409.805772][1983:1983] CHIP:TS: Retaining current Last Known Good Time
[1657752409.810021][1983:1983] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1657752409.812186][1983:1983] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752409.814032][1983:1983] CHIP:CTL: Joined the fabric at index 1. Compressed fabric ID is: 0x0000000000000000
[1657752409.814149][1983:1983] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752409.814185][1983:1983] CHIP:CTL: Setting attestation nonce to random value
[1657752409.814246][1983:1983] CHIP:CTL: Setting CSR nonce to random value
[1657752409.815124][1983:1983] CHIP:CTL: Generating NOC
[1657752409.816553][1983:1983] CHIP:FP: Validating NOC chain
[1657752409.818673][1983:1983] CHIP:FP: NOC chain validation successful
[1657752409.818864][1983:1983] CHIP:FP: Updated fabric at index: 0x2, Node ID: 0x000000000001B669
[1657752409.818904][1983:1983] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752409.818929][1983:1983] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752409.818951][1983:1983] CHIP:TS: Retaining current Last Known Good Time
[1657752409.824428][1983:1983] CHIP:FP: Metadata for Fabric 0x2 persisted to storage.
[1657752409.826622][1983:1983] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752409.828487][1983:1983] CHIP:CTL: Joined the fabric at index 2. Compressed fabric ID is: 0x0000000000000000
[1657752409.828599][1983:1983] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752409.828635][1983:1983] CHIP:CTL: Setting attestation nonce to random value
[1657752409.828693][1983:1983] CHIP:CTL: Setting CSR nonce to random value
[1657752409.829556][1983:1983] CHIP:CTL: Generating NOC
[1657752409.830666][1983:1983] CHIP:FP: Validating NOC chain
[1657752409.832408][1983:1983] CHIP:FP: NOC chain validation successful
[1657752409.832574][1983:1983] CHIP:FP: Updated fabric at index: 0x3, Node ID: 0x000000000001B669
[1657752409.832606][1983:1983] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752409.832629][1983:1983] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752409.832647][1983:1983] CHIP:TS: Retaining current Last Known Good Time
[1657752409.836669][1983:1983] CHIP:FP: Metadata for Fabric 0x3 persisted to storage.
[1657752409.838575][1983:1983] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752409.840526][1983:1983] CHIP:CTL: Joined the fabric at index 3. Compressed fabric ID is: 0x0000000000000000
[1657752409.879575][1983:1988] CHIP:DL: CHIP task running
[1657752409.879800][1983:1988] CHIP:CTL: Setting attestation nonce to random value
[1657752409.879977][1983:1988] CHIP:CTL: Setting CSR nonce to random value
[1657752409.880105][1983:1988] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752409.880128][1983:1988] CHIP:CTL: Starting commissioning discovery over BLE
[1657752409.880157][1983:1988] CHIP:CTL: Starting commissioning discovery over DNS-SD
[1657752409.880461][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752409.881327][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752409.881362][1983:1988] CHIP:DIS: mDNS broadcast had only partial success: 8 successes and 2 failures.
[1657752409.881617][1983:1989] CHIP:DL: TRACE: Bluez mainloop starting Thread
[1657752409.881883][1983:1986] CHIP:DL: TRACE: Bus acquired for name C-07bf
[1657752409.895010][1983:1988] CHIP:DL: PlatformBlueZInit init success
[1657752409.905480][1983:1986] CHIP:BLE: BLE removing known devices.
[1657752409.908700][1983:1986] CHIP:BLE: BLE initiating scan.
[1657752409.938500][1983:1986] CHIP:BLE: Device 66:B5:C2:5B:4A:5F does not look like a CHIP device.
[1657752409.953570][1983:1986] CHIP:BLE: Device 4C:8E:52:D4:BE:A3 does not look like a CHIP device.
[1657752409.961800][1983:1986] CHIP:BLE: Device FC:58:FA:8B:4D:4B does not look like a CHIP device.
[1657752409.970896][1983:1986] CHIP:BLE: Device 7B:B7:68:40:C0:8C does not look like a CHIP device.
[1657752410.029005][1983:1986] CHIP:BLE: Device 50:01:00:00:01:2E does not look like a CHIP device.
[1657752410.032800][1983:1986] CHIP:BLE: Device 5C:56:CA:2B:F8:30 does not look like a CHIP device.
[1657752410.072013][1983:1986] CHIP:BLE: Device 53:EE:CB:63:79:6D does not look like a CHIP device.
[1657752410.081062][1983:1986] CHIP:BLE: Device 54:96:94:3A:78:70 does not look like a CHIP device.
[1657752410.107036][1983:1986] CHIP:BLE: Device 5C:05:92:56:43:66 does not look like a CHIP device.
[1657752410.138800][1983:1986] CHIP:BLE: Device 42:E7:91:48:90:9B does not look like a CHIP device.
[1657752410.141156][1983:1986] CHIP:BLE: Device F8:9A:FA:3C:7B:E4 does not look like a CHIP device.
[1657752410.236911][1983:1986] CHIP:BLE: Device 7B:D3:38:94:29:5A does not look like a CHIP device.
[1657752410.409508][1983:1986] CHIP:BLE: Device 6B:C0:21:04:FB:01 does not look like a CHIP device.
[1657752410.429226][1983:1986] CHIP:BLE: Device 66:DB:45:2B:A1:BA does not look like a CHIP device.
[1657752410.473471][1983:1986] CHIP:BLE: Device 57:E4:C4:C9:EC:08 does not look like a CHIP device.
[1657752410.476147][1983:1986] CHIP:BLE: Device 34:E0:1A:FC:91:D4 does not look like a CHIP device.
[1657752410.555955][1983:1986] CHIP:BLE: Device E4:79:38:33:55:EB does not look like a CHIP device.
[1657752410.557485][1983:1986] CHIP:BLE: Device 1A:40:BD:C5:11:6B does not look like a CHIP device.
[1657752410.809194][1983:1986] CHIP:BLE: Device 51:6E:FC:D2:F2:31 does not look like a CHIP device.
[1657752410.876226][1983:1986] CHIP:BLE: Device 76:75:34:3F:F6:4E does not look like a CHIP device.
[1657752410.881695][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752410.882685][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752410.882734][1983:1988] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752411.185409][1983:1986] CHIP:BLE: Device 69:A6:EA:56:02:E4 does not look like a CHIP device.
[1657752411.276895][1983:1986] CHIP:BLE: Device 7C:0A:3F:99:31:F9 does not look like a CHIP device.
[1657752411.415264][1983:1986] CHIP:BLE: Device 77:37:77:08:E4:12 does not look like a CHIP device.
[1657752411.718630][1983:1986] CHIP:BLE: New device scanned: DF:84:4E:3B:47:6F
[1657752411.718710][1983:1986] CHIP:BLE: Device discriminator match. Attempting to connect.
[1657752411.722673][1983:1986] CHIP:BLE: Scan complete notification without an active scan.
[1657752412.883988][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752412.885319][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752412.885399][1983:1988] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752414.347505][1983:1986] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
[1657752416.227441][1983:1986] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
[1657752416.888142][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752416.889501][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752416.889653][1983:1988] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752419.018729][1983:1986] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
[1657752421.721300][1983:1988] CHIP:DL: HandlePlatformSpecificBLEEvent 16386
[1657752421.721406][1983:1988] CHIP:CTL: Commissioning discovery over BLE failed: ../../src/platform/Linux/BLEManagerImpl.cpp:63: CHIP Error 0x00000032: Timeout
[1657752421.721464][1983:1988] CHIP:-: ../../src/platform/Linux/BLEManagerImpl.cpp:63: CHIP Error 0x00000032: Timeout at ../../src/controller/SetUpCodePairer.cpp:270
[1657752421.721539][1983:1986] CHIP:DL: FAIL: ConnectDevice : Operation was cancelled (19)
[1657752421.721774][1983:1988] CHIP:DL: HandlePlatformSpecificBLEEvent 16386
[1657752424.891601][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752424.893855][1983:1988] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752424.894005][1983:1988] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752426.947609][1983:1986] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752426.947791][1983:1986] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752426.947829][1983:1986] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752426.947854][1983:1986] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752426.947893][1983:1986] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752426.947918][1983:1986] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752426.947956][1983:1986] CHIP:DL: New BLE connection 0xffff94031890, device DF:84:4E:3B:47:6F, path /org/bluez/hci0/dev_DF_84_4E_3B_47_6F
[1657752426.948217][1983:1988] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
[1657752439.894425][1983:1988] CHIP:CTL: Discovery timed out
[1657752439.894513][1983:1988] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752439.894563][1983:1988] CHIP:TOO: Secure Pairing Failed
[1657752439.895386][1983:1983] CHIP:CTL: Shutting down the commissioner
[1657752439.895457][1983:1983] CHIP:CTL: Shutting down the controller
[1657752439.895520][1983:1983] CHIP:CTL: Shutting down the commissioner
[1657752439.895560][1983:1983] CHIP:CTL: Shutting down the controller
[1657752439.895596][1983:1983] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1657752439.895633][1983:1983] CHIP:FP: Forgetting fabric 0x1
[1657752439.895725][1983:1983] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752439.896126][1983:1983] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752439.896185][1983:1983] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752439.896301][1983:1983] CHIP:CTL: Shutting down the commissioner
[1657752439.896353][1983:1983] CHIP:CTL: Shutting down the controller
[1657752439.896399][1983:1983] CHIP:IN: Expiring all sessions for fabric 0x2!!
[1657752439.896441][1983:1983] CHIP:FP: Forgetting fabric 0x2
[1657752439.896492][1983:1983] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752439.896770][1983:1983] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752439.896822][1983:1983] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752439.896903][1983:1983] CHIP:CTL: Shutting down the commissioner
[1657752439.896952][1983:1983] CHIP:CTL: Shutting down the controller
[1657752439.896995][1983:1983] CHIP:IN: Expiring all sessions for fabric 0x3!!
[1657752439.897037][1983:1983] CHIP:FP: Forgetting fabric 0x3
[1657752439.897089][1983:1983] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752439.897355][1983:1983] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752439.897408][1983:1983] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752439.897466][1983:1983] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1657752439.898570][1983:1983] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752439.898624][1983:1983] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752439.898669][1983:1983] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752439.898710][1983:1983] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752439.898747][1983:1983] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1657752439.898901][1983:1983] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1657752439.899323][1983:1983] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-PuBAO7)
[1657752439.900382][1983:1983] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752439.900485][1983:1983] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1657752439.900539][1983:1983] CHIP:DL: Inet Layer shutdown
[1657752439.900584][1983:1983] CHIP:DL: BLE shutdown
[1657752439.905635][1983:1983] CHIP:DL: System Layer shutdown
[1657752439.905883][1983:1983] CHIP:TOO: Run command failure: ../../examples/chip-tool/commands/pairing/PairingCommand.cpp:151: CHIP Error 0x00000003: Incorrect state
[1657752442.354863][1995:1995] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1657752442.355326][1995:1995] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1657752442.355466][1995:1995] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1657752442.355556][1995:1995] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1657752442.355881][1995:1995] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-kzpJx1)
[1657752442.356358][1995:1995] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752442.356395][1995:1995] CHIP:DL: NVS set: chip-counters/reboot-count = 3 (0x3)
[1657752442.357304][1995:1995] CHIP:DL: Got Ethernet interface: eth0
[1657752442.357662][1995:1995] CHIP:DL: Found the primary Ethernet interface:eth0
[1657752442.357970][1995:1995] CHIP:DL: Got WiFi interface: wlan0
[1657752442.360009][1995:1995] CHIP:DL: Found the primary WiFi interface:wlan0
[1657752442.360067][1995:1995] CHIP:IN: UDP::Init bind&listen port=0
[1657752442.360148][1995:1995] CHIP:IN: UDP::Init bound to port=38520
[1657752442.360180][1995:1995] CHIP:IN: UDP::Init bind&listen port=0
[1657752442.360259][1995:1995] CHIP:IN: UDP::Init bound to port=56285
[1657752442.360284][1995:1995] CHIP:IN: BLEBase::Init - setting/overriding transport
[1657752442.360299][1995:1995] CHIP:IN: TransportMgr initialized
[1657752442.360347][1995:1995] CHIP:FP: Initializing FabricTable from persistent storage
[1657752442.360589][1995:1995] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752442.361095][1995:1995] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x0D0D872986F5DBB4, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1657752442.361570][1995:1995] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x371042A6B8C55FE8, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
[1657752442.361992][1995:1995] CHIP:FP: Fabric index 0x3 was retrieved from storage. Compressed FabricId 0x3D3201B65A89FB29, FabricId 0x0000000000000003, NodeId 0x000000000001B669, VendorId 0xFFF1
[1657752442.364354][1995:1995] CHIP:ZCL: Using ZAP configuration...
[1657752442.365611][1995:1995] CHIP:DL: MDNS failed to join multicast group on eth0 for address type IPv4: ../../src/inet/UDPEndPointImplSockets.cpp:772: Inet Error 0x00000110: Address not found
[1657752442.368364][1995:1995] CHIP:DL: MDNS failed to join multicast group on wpan0 for address type IPv4: ../../src/inet/UDPEndPointImplSockets.cpp:772: Inet Error 0x00000110: Address not found
[1657752442.369294][1995:1995] CHIP:CTL: System State Initialized...
[1657752442.369372][1995:1995] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752442.369406][1995:1995] CHIP:CTL: Setting attestation nonce to random value
[1657752442.369481][1995:1995] CHIP:CTL: Setting CSR nonce to random value
[1657752442.369609][1995:1995] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752442.369645][1995:1995] CHIP:CTL: Setting attestation nonce to random value
[1657752442.369700][1995:1995] CHIP:CTL: Setting CSR nonce to random value
[1657752442.372641][1995:1995] CHIP:CTL: Generating NOC
[1657752442.374372][1995:1995] CHIP:FP: Validating NOC chain
[1657752442.376152][1995:1995] CHIP:FP: NOC chain validation successful
[1657752442.376294][1995:1995] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1657752442.376344][1995:1995] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752442.376361][1995:1995] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752442.376375][1995:1995] CHIP:TS: Retaining current Last Known Good Time
[1657752442.385070][1995:1995] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1657752442.387886][1995:1995] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752442.389915][1995:1995] CHIP:CTL: Joined the fabric at index 1. Compressed fabric ID is: 0x0000000000000000
[1657752442.390034][1995:1995] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752442.390071][1995:1995] CHIP:CTL: Setting attestation nonce to random value
[1657752442.390134][1995:1995] CHIP:CTL: Setting CSR nonce to random value
[1657752442.391041][1995:1995] CHIP:CTL: Generating NOC
[1657752442.392247][1995:1995] CHIP:FP: Validating NOC chain
[1657752442.394067][1995:1995] CHIP:FP: NOC chain validation successful
[1657752442.394332][1995:1995] CHIP:FP: Updated fabric at index: 0x2, Node ID: 0x000000000001B669
[1657752442.394368][1995:1995] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752442.394390][1995:1995] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752442.394409][1995:1995] CHIP:TS: Retaining current Last Known Good Time
[1657752442.397006][1995:1995] CHIP:FP: Metadata for Fabric 0x2 persisted to storage.
[1657752442.399041][1995:1995] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752442.408765][1995:1995] CHIP:CTL: Joined the fabric at index 2. Compressed fabric ID is: 0x0000000000000000
[1657752442.408922][1995:1995] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752442.408976][1995:1995] CHIP:CTL: Setting attestation nonce to random value
[1657752442.409063][1995:1995] CHIP:CTL: Setting CSR nonce to random value
[1657752442.410380][1995:1995] CHIP:CTL: Generating NOC
[1657752442.412119][1995:1995] CHIP:FP: Validating NOC chain
[1657752442.414935][1995:1995] CHIP:FP: NOC chain validation successful
[1657752442.415191][1995:1995] CHIP:FP: Updated fabric at index: 0x3, Node ID: 0x000000000001B669
[1657752442.415243][1995:1995] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752442.415278][1995:1995] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752442.415307][1995:1995] CHIP:TS: Retaining current Last Known Good Time
[1657752442.418796][1995:1995] CHIP:FP: Metadata for Fabric 0x3 persisted to storage.
[1657752442.420992][1995:1995] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752442.422929][1995:1995] CHIP:CTL: Joined the fabric at index 3. Compressed fabric ID is: 0x0000000000000000
[1657752442.458313][1995:2000] CHIP:DL: CHIP task running
[1657752442.458446][1995:2000] CHIP:CTL: Setting attestation nonce to random value
[1657752442.458591][1995:2000] CHIP:CTL: Setting CSR nonce to random value
[1657752442.458705][1995:2000] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752442.458727][1995:2000] CHIP:CTL: Starting commissioning discovery over BLE
[1657752442.458758][1995:2000] CHIP:CTL: Starting commissioning discovery over DNS-SD
[1657752442.459039][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752442.460001][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752442.460048][1995:2000] CHIP:DIS: mDNS broadcast had only partial success: 8 successes and 2 failures.
[1657752442.460380][1995:2001] CHIP:DL: TRACE: Bluez mainloop starting Thread
[1657752442.460637][1995:1998] CHIP:DL: TRACE: Bus acquired for name C-07cb
[1657752442.483779][1995:2000] CHIP:DL: PlatformBlueZInit init success
[1657752442.498197][1995:1998] CHIP:BLE: BLE removing known devices.
[1657752444.855848][1995:1998] CHIP:BLE: BLE initiating scan.
[1657752444.878813][1995:2000] CHIP:DL: Long dispatch time: 2419 ms, for event type 2
[1657752444.879435][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752444.880207][1995:1998] CHIP:BLE: New device scanned: DF:84:4E:3B:47:6F
[1657752444.880290][1995:1998] CHIP:BLE: Device discriminator match. Attempting to connect.
[1657752444.881420][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752444.881502][1995:2000] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752444.886102][1995:1998] CHIP:BLE: Scan complete notification without an active scan.
[1657752444.888657][1995:1998] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.freedesktop.DBus.Error.UnknownObject: Method "Connect" with signature "" on interface "org.bluez.Device1" doesn't exist
 (41)
[1657752444.888844][1995:2000] CHIP:DL: HandlePlatformSpecificBLEEvent 16386
[1657752444.888886][1995:2000] CHIP:CTL: Commissioning discovery over BLE failed: ../../src/platform/Linux/bluez/Helper.cpp:1775: CHIP Error 0x000000AC: Internal error
[1657752444.888937][1995:2000] CHIP:-: ../../src/platform/Linux/bluez/Helper.cpp:1775: CHIP Error 0x000000AC: Internal error at ../../src/controller/SetUpCodePairer.cpp:270
[1657752446.880158][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752446.881568][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752446.881644][1995:2000] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752450.884473][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752450.886000][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752450.886078][1995:2000] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752458.889103][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752458.890380][1995:2000] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752458.890452][1995:2000] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752472.473497][1995:2000] CHIP:CTL: Discovery timed out
[1657752472.473586][1995:2000] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752472.473640][1995:2000] CHIP:TOO: Secure Pairing Failed
[1657752472.474292][1995:1995] CHIP:CTL: Shutting down the commissioner
[1657752472.474364][1995:1995] CHIP:CTL: Shutting down the controller
[1657752472.474423][1995:1995] CHIP:CTL: Shutting down the commissioner
[1657752472.474469][1995:1995] CHIP:CTL: Shutting down the controller
[1657752472.474513][1995:1995] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1657752472.474557][1995:1995] CHIP:FP: Forgetting fabric 0x1
[1657752472.474620][1995:1995] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752472.475021][1995:1995] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752472.475077][1995:1995] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752472.475151][1995:1995] CHIP:CTL: Shutting down the commissioner
[1657752472.475197][1995:1995] CHIP:CTL: Shutting down the controller
[1657752472.475238][1995:1995] CHIP:IN: Expiring all sessions for fabric 0x2!!
[1657752472.475280][1995:1995] CHIP:FP: Forgetting fabric 0x2
[1657752472.475332][1995:1995] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752472.475597][1995:1995] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752472.475645][1995:1995] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752472.475753][1995:1995] CHIP:CTL: Shutting down the commissioner
[1657752472.475803][1995:1995] CHIP:CTL: Shutting down the controller
[1657752472.475843][1995:1995] CHIP:IN: Expiring all sessions for fabric 0x3!!
[1657752472.475885][1995:1995] CHIP:FP: Forgetting fabric 0x3
[1657752472.475933][1995:1995] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752472.476201][1995:1995] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752472.476250][1995:1995] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752472.476307][1995:1995] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1657752472.477405][1995:1995] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752472.477462][1995:1995] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752472.477503][1995:1995] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752472.477545][1995:1995] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752472.477588][1995:1995] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1657752472.477747][1995:1995] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1657752472.478146][1995:1995] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-Ebu9m2)
[1657752472.479141][1995:1995] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752472.479244][1995:1995] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1657752472.479296][1995:1995] CHIP:DL: Inet Layer shutdown
[1657752472.479340][1995:1995] CHIP:DL: BLE shutdown
[1657752472.482467][1995:1995] CHIP:DL: System Layer shutdown
[1657752472.482743][1995:1995] CHIP:TOO: Run command failure: ../../examples/chip-tool/commands/pairing/PairingCommand.cpp:151: CHIP Error 0x00000003: Incorrect state
[1657752492.953606][2004:2004] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1657752492.954075][2004:2004] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1657752492.954215][2004:2004] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1657752492.954307][2004:2004] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1657752492.954613][2004:2004] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-8naLEI)
[1657752492.955086][2004:2004] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752492.955124][2004:2004] CHIP:DL: NVS set: chip-counters/reboot-count = 4 (0x4)
[1657752492.955643][2004:2004] CHIP:DL: Got Ethernet interface: eth0
[1657752492.955976][2004:2004] CHIP:DL: Found the primary Ethernet interface:eth0
[1657752492.956724][2004:2004] CHIP:DL: Got WiFi interface: wlan0
[1657752492.958763][2004:2004] CHIP:DL: Found the primary WiFi interface:wlan0
[1657752492.958827][2004:2004] CHIP:IN: UDP::Init bind&listen port=0
[1657752492.958928][2004:2004] CHIP:IN: UDP::Init bound to port=40468
[1657752492.958951][2004:2004] CHIP:IN: UDP::Init bind&listen port=0
[1657752492.959021][2004:2004] CHIP:IN: UDP::Init bound to port=52091
[1657752492.959039][2004:2004] CHIP:IN: BLEBase::Init - setting/overriding transport
[1657752492.959055][2004:2004] CHIP:IN: TransportMgr initialized
[1657752492.959086][2004:2004] CHIP:FP: Initializing FabricTable from persistent storage
[1657752492.959292][2004:2004] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752492.959848][2004:2004] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x0D0D872986F5DBB4, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1657752492.960199][2004:2004] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x371042A6B8C55FE8, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
[1657752492.960533][2004:2004] CHIP:FP: Fabric index 0x3 was retrieved from storage. Compressed FabricId 0x3D3201B65A89FB29, FabricId 0x0000000000000003, NodeId 0x000000000001B669, VendorId 0xFFF1
[1657752492.962752][2004:2004] CHIP:ZCL: Using ZAP configuration...
[1657752492.964071][2004:2004] CHIP:DL: MDNS failed to join multicast group on eth0 for address type IPv4: ../../src/inet/UDPEndPointImplSockets.cpp:772: Inet Error 0x00000110: Address not found
[1657752492.966471][2004:2004] CHIP:DL: MDNS failed to join multicast group on wpan0 for address type IPv4: ../../src/inet/UDPEndPointImplSockets.cpp:772: Inet Error 0x00000110: Address not found
[1657752492.967437][2004:2004] CHIP:CTL: System State Initialized...
[1657752492.967524][2004:2004] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752492.967562][2004:2004] CHIP:CTL: Setting attestation nonce to random value
[1657752492.967630][2004:2004] CHIP:CTL: Setting CSR nonce to random value
[1657752492.967765][2004:2004] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752492.967797][2004:2004] CHIP:CTL: Setting attestation nonce to random value
[1657752492.967846][2004:2004] CHIP:CTL: Setting CSR nonce to random value
[1657752492.970740][2004:2004] CHIP:CTL: Generating NOC
[1657752492.972175][2004:2004] CHIP:FP: Validating NOC chain
[1657752492.974115][2004:2004] CHIP:FP: NOC chain validation successful
[1657752492.974253][2004:2004] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1657752492.974282][2004:2004] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752492.974300][2004:2004] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752492.974316][2004:2004] CHIP:TS: Retaining current Last Known Good Time
[1657752492.978386][2004:2004] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1657752492.980613][2004:2004] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752492.982570][2004:2004] CHIP:CTL: Joined the fabric at index 1. Compressed fabric ID is: 0x0000000000000000
[1657752492.982673][2004:2004] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752492.982704][2004:2004] CHIP:CTL: Setting attestation nonce to random value
[1657752492.982770][2004:2004] CHIP:CTL: Setting CSR nonce to random value
[1657752492.984321][2004:2004] CHIP:CTL: Generating NOC
[1657752492.985793][2004:2004] CHIP:FP: Validating NOC chain
[1657752492.987956][2004:2004] CHIP:FP: NOC chain validation successful
[1657752492.988149][2004:2004] CHIP:FP: Updated fabric at index: 0x2, Node ID: 0x000000000001B669
[1657752492.988195][2004:2004] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752492.988219][2004:2004] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752492.988239][2004:2004] CHIP:TS: Retaining current Last Known Good Time
[1657752492.998141][2004:2004] CHIP:FP: Metadata for Fabric 0x2 persisted to storage.
[1657752493.003991][2004:2004] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752493.005968][2004:2004] CHIP:CTL: Joined the fabric at index 2. Compressed fabric ID is: 0x0000000000000000
[1657752493.006085][2004:2004] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752493.006122][2004:2004] CHIP:CTL: Setting attestation nonce to random value
[1657752493.006183][2004:2004] CHIP:CTL: Setting CSR nonce to random value
[1657752493.007089][2004:2004] CHIP:CTL: Generating NOC
[1657752493.008644][2004:2004] CHIP:FP: Validating NOC chain
[1657752493.011171][2004:2004] CHIP:FP: NOC chain validation successful
[1657752493.011399][2004:2004] CHIP:FP: Updated fabric at index: 0x3, Node ID: 0x000000000001B669
[1657752493.011444][2004:2004] CHIP:TS: Last Known Good Time: 2022-07-13T18:42:46
[1657752493.011475][2004:2004] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1657752493.011502][2004:2004] CHIP:TS: Retaining current Last Known Good Time
[1657752493.014508][2004:2004] CHIP:FP: Metadata for Fabric 0x3 persisted to storage.
[1657752493.017368][2004:2004] CHIP:TS: Committing Last Known Good Time to storage: 2022-07-13T18:42:46
[1657752493.019432][2004:2004] CHIP:CTL: Joined the fabric at index 3. Compressed fabric ID is: 0x0000000000000000
[1657752493.054004][2004:2009] CHIP:DL: CHIP task running
[1657752493.054166][2004:2009] CHIP:CTL: Setting attestation nonce to random value
[1657752493.054351][2004:2009] CHIP:CTL: Setting CSR nonce to random value
[1657752493.054486][2004:2009] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752493.054514][2004:2009] CHIP:CTL: Starting commissioning discovery over BLE
[1657752493.054550][2004:2009] CHIP:CTL: Starting commissioning discovery over DNS-SD
[1657752493.054885][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752493.055651][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752493.055731][2004:2009] CHIP:DIS: mDNS broadcast had only partial success: 8 successes and 2 failures.
[1657752493.056311][2004:2010] CHIP:DL: TRACE: Bluez mainloop starting Thread
[1657752493.056432][2004:2007] CHIP:DL: TRACE: Bus acquired for name C-07d4
[1657752493.071967][2004:2009] CHIP:DL: PlatformBlueZInit init success
[1657752493.085603][2004:2007] CHIP:BLE: BLE removing known devices.
[1657752493.087340][2004:2007] CHIP:BLE: BLE initiating scan.
[1657752493.811908][2004:2009] CHIP:DL: Long dispatch time: 756 ms, for event type 2
[1657752493.837921][2004:2007] CHIP:BLE: Device 53:EE:CB:63:79:6D does not look like a CHIP device.
[1657752493.861374][2004:2007] CHIP:BLE: Device 5D:CB:48:F9:3B:1F does not look like a CHIP device.
[1657752493.893548][2004:2007] CHIP:BLE: Device 50:01:00:00:01:2E does not look like a CHIP device.
[1657752493.893945][2004:2007] CHIP:BLE: Device FC:58:FA:8B:4D:4B does not look like a CHIP device.
[1657752493.902524][2004:2007] CHIP:BLE: Device 66:B5:C2:5B:4A:5F does not look like a CHIP device.
[1657752493.911154][2004:2007] CHIP:BLE: Device 61:43:32:A4:B1:18 does not look like a CHIP device.
[1657752493.912676][2004:2007] CHIP:BLE: Device 7B:D3:38:94:29:5A does not look like a CHIP device.
[1657752493.937573][2004:2007] CHIP:BLE: Device 54:96:94:3A:78:70 does not look like a CHIP device.
[1657752493.978726][2004:2007] CHIP:BLE: Device 7B:B7:68:40:C0:8C does not look like a CHIP device.
[1657752493.979093][2004:2007] CHIP:BLE: Device 1A:40:BD:C5:11:6B does not look like a CHIP device.
[1657752494.054920][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752494.056396][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752494.056463][2004:2009] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752494.161644][2004:2007] CHIP:BLE: Device 5C:05:92:56:43:66 does not look like a CHIP device.
[1657752494.172595][2004:2007] CHIP:BLE: Device 5C:56:CA:2B:F8:30 does not look like a CHIP device.
[1657752494.276034][2004:2007] CHIP:BLE: Device 7C:0A:3F:99:31:F9 does not look like a CHIP device.
[1657752494.345511][2004:2007] CHIP:BLE: Device 42:E7:91:48:90:9B does not look like a CHIP device.
[1657752494.348386][2004:2007] CHIP:BLE: Device F8:9A:FA:3C:7B:E4 does not look like a CHIP device.
[1657752494.436317][2004:2007] CHIP:BLE: Device 34:E0:1A:FC:91:D4 does not look like a CHIP device.
[1657752494.519657][2004:2007] CHIP:BLE: Device 69:A6:EA:56:02:E4 does not look like a CHIP device.
[1657752494.685478][2004:2007] CHIP:BLE: Device 57:E4:C4:C9:EC:08 does not look like a CHIP device.
[1657752494.848274][2004:2007] CHIP:BLE: Device 4C:8E:52:D4:BE:A3 does not look like a CHIP device.
[1657752494.945641][2004:2007] CHIP:BLE: Device 66:DB:45:2B:A1:BA does not look like a CHIP device.
[1657752494.948038][2004:2007] CHIP:BLE: Device CB:EB:C4:74:02:65 does not look like a CHIP device.
[1657752495.427106][2004:2007] CHIP:BLE: Device 76:75:34:3F:F6:4E does not look like a CHIP device.
[1657752495.429572][2004:2007] CHIP:BLE: Device F8:E1:7F:E0:82:06 does not look like a CHIP device.
[1657752495.665894][2004:2007] CHIP:BLE: Device 7C:0A:3F:49:DF:27 does not look like a CHIP device.
[1657752496.021631][2004:2007] CHIP:BLE: Device 6B:C0:21:04:FB:01 does not look like a CHIP device.
[1657752496.056172][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752496.057590][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752496.057669][2004:2009] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752496.192121][2004:2007] CHIP:BLE: New device scanned: DF:84:4E:3B:47:6F
[1657752496.192204][2004:2007] CHIP:BLE: Device discriminator match. Attempting to connect.
[1657752496.196975][2004:2007] CHIP:BLE: Scan complete notification without an active scan.
[1657752498.840603][2004:2007] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
[1657752500.060521][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752500.061835][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752500.061910][2004:2009] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752502.379191][2004:2007] CHIP:DL: ConnectDevice complete
[1657752503.041706][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752503.041888][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752503.041934][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752503.041964][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752503.042016][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0001
[1657752503.042046][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752503.042108][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0001
[1657752503.042155][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752503.042223][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0001
[1657752503.042253][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752503.042355][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752503.042404][2004:2007] CHIP:DL: Char1 /org/bluez/hci0/dev_DF_84_4E_3B_47_6F/service0010
[1657752503.042467][2004:2007] CHIP:DL: New BLE connection 0xffffa0038300, device DF:84:4E:3B:47:6F, path /org/bluez/hci0/dev_DF_84_4E_3B_47_6F
[1657752503.042690][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
[1657752503.042740][2004:2009] CHIP:CTL: Discovered device to be commissioned over BLE
[1657752503.042784][2004:2009] CHIP:CTL: Attempting PASE connection to BLE
[1657752503.042839][2004:2009] CHIP:IN: BleConnectionComplete: endPoint 0xaaaac67da288
[1657752503.043152][2004:2009] CHIP:IN: SecureSession[0xffff94005f00]: Allocated Type:1 LSID:35411
[1657752503.043202][2004:2009] CHIP:SC: Assigned local session key ID 35411
[1657752503.043300][2004:2009] CHIP:SC: Including MRP parameters in PBKDF param request
[1657752503.043401][2004:2009] CHIP:IN: Prepared unauthenticated message 0xffffa98d7f28 to 0x0000000000000000 (0)  of type 0x20 and protocolId (0, 0) on exchange 54529i with MessageCounter:258070661.
[1657752503.043461][2004:2009] CHIP:IN: Sending unauthenticated msg 0xffffa98d7f28 with MessageCounter:258070661 to 0x0000000000000000 at monotonic time: 0000000000191AB3 msec
[1657752503.043503][2004:2009] CHIP:IN: Message appended to BLE send queue
[1657752503.043534][2004:2009] CHIP:SC: Sent PBKDF param request
[1657752503.043564][2004:2009] CHIP:CTL: Commission called for node ID 0x0000000000000001
[1657752504.182173][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1657752504.328648][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1657752504.328731][2004:2009] CHIP:BLE: subscribe complete, ep = 0xaaaac67da288
[1657752504.328995][2004:2007] CHIP:DL: Indication received, conn = 0xffffa0038300
[1657752504.329320][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1657752504.329383][2004:2009] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1657752504.329437][2004:2009] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1657752504.329497][2004:2009] CHIP:BLE: local and remote recv window size = 5
[1657752504.329756][2004:2009] CHIP:IN: BLE EndPoint 0xaaaac67da288 Connection Complete
[1657752504.474124][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1657752504.574278][2004:2007] CHIP:DL: Indication received, conn = 0xffffa0038300
[1657752504.574532][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1657752504.574807][2004:2009] CHIP:EM: Received message of type 0x21 with protocolId (0, 0) and MessageCounter:227647507 on exchange 54529i
[1657752504.574912][2004:2009] CHIP:EM: Found matching exchange: 54529i, Delegate: 0xffff9401d9f0
[1657752504.575016][2004:2009] CHIP:SC: Received PBKDF param response
[1657752504.575141][2004:2009] CHIP:SC: Peer assigned session ID 32888
[1657752504.575252][2004:2009] CHIP:SC: Found MRP parameters in the message
[1657752504.587566][2004:2009] CHIP:IN: Prepared unauthenticated message 0xffffa98d79f8 to 0x0000000000000000 (0)  of type 0x22 and protocolId (0, 0) on exchange 54529i with MessageCounter:258070662.
[1657752504.587624][2004:2009] CHIP:IN: Sending unauthenticated msg 0xffffa98d79f8 with MessageCounter:258070662 to 0x0000000000000000 at monotonic time: 00000000001920BB msec
[1657752504.587985][2004:2009] CHIP:SC: Sent spake2p msg1
[1657752504.669075][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1657752506.621922][2004:2007] CHIP:DL: Indication received, conn = 0xffffa0038300
[1657752506.622201][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1657752506.622404][2004:2009] CHIP:EM: Received message of type 0x23 with protocolId (0, 0) and MessageCounter:227647508 on exchange 54529i
[1657752506.622534][2004:2009] CHIP:EM: Found matching exchange: 54529i, Delegate: 0xffff9401d9f0
[1657752506.622654][2004:2009] CHIP:SC: Received spake2p msg2
[1657752506.626501][2004:2009] CHIP:IN: Prepared unauthenticated message 0xffffa98d7b38 to 0x0000000000000000 (0)  of type 0x24 and protocolId (0, 0) on exchange 54529i with MessageCounter:258070663.
[1657752506.626603][2004:2009] CHIP:IN: Sending unauthenticated msg 0xffffa98d7b38 with MessageCounter:258070663 to 0x0000000000000000 at monotonic time: 00000000001928B2 msec
[1657752506.626784][2004:2009] CHIP:SC: Sent spake2p msg3
[1657752506.716655][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1657752506.815727][2004:2007] CHIP:DL: Indication received, conn = 0xffffa0038300
[1657752506.815978][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1657752506.816233][2004:2009] CHIP:EM: Received message of type 0x40 with protocolId (0, 0) and MessageCounter:227647509 on exchange 54529i
[1657752506.816346][2004:2009] CHIP:EM: Found matching exchange: 54529i, Delegate: 0xffff9401d9f0
[1657752506.816572][2004:2009] CHIP:SC: SecureSession[0xffff94005f00]: Moving from state 'kEstablishing' --> 'kActive'
[1657752506.816668][2004:2009] CHIP:IN: SecureSession[0xffff94005f00]: Activated - Type:1 LSID:35411
[1657752506.816712][2004:2009] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:35411 PSID:32888!
[1657752506.816785][2004:2009] CHIP:CTL: Remote device completed SPAKE2+ handshake
[1657752506.816868][2004:2009] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1657752506.816913][2004:2009] CHIP:TOO: Pairing Success
[1657752506.816953][2004:2009] CHIP:TOO: PASE establishment successful
[1657752506.817052][2004:2009] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1657752506.817104][2004:2009] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
[1657752506.817142][2004:2009] CHIP:CTL: Sending request for commissioning information
[1657752506.817256][2004:2009] CHIP:DMG: SendReadRequest ReadClient[0xffffa0035b10]: Sending Read Request
[1657752506.817544][2004:2009] CHIP:IN: Prepared secure message 0xffffa98d7348 to 0xFFFFFFFB00000000 (0)  of type 0x2 and protocolId (0, 1) on exchange 54530i with MessageCounter:137041521.
[1657752506.817626][2004:2009] CHIP:IN: Sending encrypted msg 0xffffa98d7348 with MessageCounter:137041521 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000192971 msec
[1657752506.817799][2004:2009] CHIP:DMG: MoveToState ReadClient[0xffffa0035b10]: Moving to [AwaitingIn]
[1657752507.009073][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1657752507.110281][2004:2007] CHIP:DL: Indication received, conn = 0xffffa0038300
[1657752507.110531][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1657752507.253363][2004:2007] CHIP:DL: Indication received, conn = 0xffffa0038300
[1657752507.253621][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1657752507.253907][2004:2009] CHIP:EM: Received message of type 0x5 with protocolId (0, 1) and MessageCounter:4752760 on exchange 54530i
[1657752507.253970][2004:2009] CHIP:EM: Found matching exchange: 54530i, Delegate: 0xffffa0035b10
[1657752507.254199][2004:2009] CHIP:DMG: ReportDataMessage =
[1657752507.254308][2004:2009] CHIP:DMG: {
[1657752507.254354][2004:2009] CHIP:DMG: 	AttributeReportIBs =
[1657752507.254421][2004:2009] CHIP:DMG: 	[
[1657752507.254471][2004:2009] CHIP:DMG: 		AttributeReportIB =
[1657752507.254588][2004:2009] CHIP:DMG: 		{
[1657752507.254668][2004:2009] CHIP:DMG: 			AttributeDataIB =
[1657752507.254761][2004:2009] CHIP:DMG: 			{
[1657752507.254830][2004:2009] CHIP:DMG: 				DataVersion = 0x7afebd43,
[1657752507.254937][2004:2009] CHIP:DMG: 				AttributePathIB =
[1657752507.255049][2004:2009] CHIP:DMG: 				{
[1657752507.255129][2004:2009] CHIP:DMG: 					Endpoint = 0x0,
[1657752507.255246][2004:2009] CHIP:DMG: 					Cluster = 0x31,
[1657752507.255329][2004:2009] CHIP:DMG: 					Attribute = 0x0000_0003,
[1657752507.255405][2004:2009] CHIP:DMG: 				}
[1657752507.255486][2004:2009] CHIP:DMG:
[1657752507.255564][2004:2009] CHIP:DMG: 				Data = 20,
[1657752507.255635][2004:2009] CHIP:DMG: 			},
[1657752507.255760][2004:2009] CHIP:DMG:
[1657752507.255819][2004:2009] CHIP:DMG: 		},
[1657752507.255902][2004:2009] CHIP:DMG:
[1657752507.255953][2004:2009] CHIP:DMG: 		AttributeReportIB =
[1657752507.256023][2004:2009] CHIP:DMG: 		{
[1657752507.256079][2004:2009] CHIP:DMG: 			AttributeDataIB =
[1657752507.256150][2004:2009] CHIP:DMG: 			{
[1657752507.256223][2004:2009] CHIP:DMG: 				DataVersion = 0x4b25a87b,
[1657752507.256295][2004:2009] CHIP:DMG: 				AttributePathIB =
[1657752507.256370][2004:2009] CHIP:DMG: 				{
[1657752507.256448][2004:2009] CHIP:DMG: 					Endpoint = 0x0,
[1657752507.256527][2004:2009] CHIP:DMG: 					Cluster = 0x28,
[1657752507.256608][2004:2009] CHIP:DMG: 					Attribute = 0x0000_0004,
[1657752507.256684][2004:2009] CHIP:DMG: 				}
[1657752507.256764][2004:2009] CHIP:DMG:
[1657752507.256841][2004:2009] CHIP:DMG: 				Data = 32773,
[1657752507.256912][2004:2009] CHIP:DMG: 			},
[1657752507.256988][2004:2009] CHIP:DMG:
[1657752507.257044][2004:2009] CHIP:DMG: 		},
[1657752507.257129][2004:2009] CHIP:DMG:
[1657752507.257179][2004:2009] CHIP:DMG: 		AttributeReportIB =
[1657752507.257249][2004:2009] CHIP:DMG: 		{
[1657752507.257306][2004:2009] CHIP:DMG: 			AttributeDataIB =
[1657752507.257377][2004:2009] CHIP:DMG: 			{
[1657752507.257450][2004:2009] CHIP:DMG: 				DataVersion = 0x4b25a87b,
[1657752507.257521][2004:2009] CHIP:DMG: 				AttributePathIB =
[1657752507.257595][2004:2009] CHIP:DMG: 				{
[1657752507.257672][2004:2009] CHIP:DMG: 					Endpoint = 0x0,
[1657752507.257752][2004:2009] CHIP:DMG: 					Cluster = 0x28,
[1657752507.257966][2004:2009] CHIP:DMG: 					Attribute = 0x0000_0002,
[1657752507.258045][2004:2009] CHIP:DMG: 				}
[1657752507.258125][2004:2009] CHIP:DMG:
[1657752507.258203][2004:2009] CHIP:DMG: 				Data = 65521,
[1657752507.258274][2004:2009] CHIP:DMG: 			},
[1657752507.258350][2004:2009] CHIP:DMG:
[1657752507.258408][2004:2009] CHIP:DMG: 		},
[1657752507.258488][2004:2009] CHIP:DMG:
[1657752507.258537][2004:2009] CHIP:DMG: 		AttributeReportIB =
[1657752507.258607][2004:2009] CHIP:DMG: 		{
[1657752507.258664][2004:2009] CHIP:DMG: 			AttributeDataIB =
[1657752507.258734][2004:2009] CHIP:DMG: 			{
[1657752507.258807][2004:2009] CHIP:DMG: 				DataVersion = 0xfa8c2bf4,
[1657752507.258874][2004:2009] CHIP:DMG: 				AttributePathIB =
[1657752507.258949][2004:2009] CHIP:DMG: 				{
[1657752507.259025][2004:2009] CHIP:DMG: 					Endpoint = 0x0,
[1657752507.259104][2004:2009] CHIP:DMG: 					Cluster = 0x30,
[1657752507.259184][2004:2009] CHIP:DMG: 					Attribute = 0x0000_0003,
[1657752507.259259][2004:2009] CHIP:DMG: 				}
[1657752507.259338][2004:2009] CHIP:DMG:
[1657752507.259416][2004:2009] CHIP:DMG: 				Data = 0,
[1657752507.259487][2004:2009] CHIP:DMG: 			},
[1657752507.259564][2004:2009] CHIP:DMG:
[1657752507.259608][2004:2009] CHIP:DMG: 		},
[1657752507.259647][2004:2009] CHIP:DMG:
[1657752507.259686][2004:2009] CHIP:DMG: 		AttributeReportIB =
[1657752507.259766][2004:2009] CHIP:DMG: 		{
[1657752507.259796][2004:2009] CHIP:DMG: 			AttributeDataIB =
[1657752507.259831][2004:2009] CHIP:DMG: 			{
[1657752507.259868][2004:2009] CHIP:DMG: 				DataVersion = 0xfa8c2bf4,
[1657752507.259904][2004:2009] CHIP:DMG: 				AttributePathIB =
[1657752507.260069][2004:2009] CHIP:DMG: 				{
[1657752507.260126][2004:2009] CHIP:DMG: 					Endpoint = 0x0,
[1657752507.260164][2004:2009] CHIP:DMG: 					Cluster = 0x30,
[1657752507.260202][2004:2009] CHIP:DMG: 					Attribute = 0x0000_0002,
[1657752507.260265][2004:2009] CHIP:DMG: 				}
[1657752507.260321][2004:2009] CHIP:DMG:
[1657752507.260367][2004:2009] CHIP:DMG: 				Data = 0,
[1657752507.260405][2004:2009] CHIP:DMG: 			},
[1657752507.260444][2004:2009] CHIP:DMG:
[1657752507.260472][2004:2009] CHIP:DMG: 		},
[1657752507.260515][2004:2009] CHIP:DMG:
[1657752507.260557][2004:2009] CHIP:DMG: 		AttributeReportIB =
[1657752507.260725][2004:2009] CHIP:DMG: 		{
[1657752507.260762][2004:2009] CHIP:DMG: 			AttributeDataIB =
[1657752507.260826][2004:2009] CHIP:DMG: 			{
[1657752507.260865][2004:2009] CHIP:DMG: 				DataVersion = 0xfa8c2bf4,
[1657752507.260900][2004:2009] CHIP:DMG: 				AttributePathIB =
[1657752507.260933][2004:2009] CHIP:DMG: 				{
[1657752507.260990][2004:2009] CHIP:DMG: 					Endpoint = 0x0,
[1657752507.261035][2004:2009] CHIP:DMG: 					Cluster = 0x30,
[1657752507.261078][2004:2009] CHIP:DMG: 					Attribute = 0x0000_0001,
[1657752507.261116][2004:2009] CHIP:DMG: 				}
[1657752507.261155][2004:2009] CHIP:DMG:
[1657752507.261203][2004:2009] CHIP:DMG: 				Data =
[1657752507.261248][2004:2009] CHIP:DMG: 				{
[1657752507.261314][2004:2009] CHIP:DMG: 					0x0 = 60,
[1657752507.261362][2004:2009] CHIP:DMG: 				},
[1657752507.261399][2004:2009] CHIP:DMG: 			},
[1657752507.261440][2004:2009] CHIP:DMG:
[1657752507.261479][2004:2009] CHIP:DMG: 		},
[1657752507.261531][2004:2009] CHIP:DMG:
[1657752507.261556][2004:2009] CHIP:DMG: 		AttributeReportIB =
[1657752507.261593][2004:2009] CHIP:DMG: 		{
[1657752507.261652][2004:2009] CHIP:DMG: 			AttributeDataIB =
[1657752507.261702][2004:2009] CHIP:DMG: 			{
[1657752507.261739][2004:2009] CHIP:DMG: 				DataVersion = 0xfa8c2bf4,
[1657752507.261775][2004:2009] CHIP:DMG: 				AttributePathIB =
[1657752507.261812][2004:2009] CHIP:DMG: 				{
[1657752507.261850][2004:2009] CHIP:DMG: 					Endpoint = 0x0,
[1657752507.261889][2004:2009] CHIP:DMG: 					Cluster = 0x30,
[1657752507.261930][2004:2009] CHIP:DMG: 					Attribute = 0x0000_0000,
[1657752507.261968][2004:2009] CHIP:DMG: 				}
[1657752507.262008][2004:2009] CHIP:DMG:
[1657752507.262043][2004:2009] CHIP:DMG: 				Data = 0,
[1657752507.262079][2004:2009] CHIP:DMG: 			},
[1657752507.262117][2004:2009] CHIP:DMG:
[1657752507.262145][2004:2009] CHIP:DMG: 		},
[1657752507.262185][2004:2009] CHIP:DMG:
[1657752507.262209][2004:2009] CHIP:DMG: 		AttributeReportIB =
[1657752507.262245][2004:2009] CHIP:DMG: 		{
[1657752507.262274][2004:2009] CHIP:DMG: 			AttributeDataIB =
[1657752507.262306][2004:2009] CHIP:DMG: 			{
[1657752507.262342][2004:2009] CHIP:DMG: 				DataVersion = 0x7afebd43,
[1657752507.262378][2004:2009] CHIP:DMG: 				AttributePathIB =
[1657752507.262415][2004:2009] CHIP:DMG: 				{
[1657752507.262453][2004:2009] CHIP:DMG: 					Endpoint = 0x0,
[1657752507.262493][2004:2009] CHIP:DMG: 					Cluster = 0x31,
[1657752507.262533][2004:2009] CHIP:DMG: 					Attribute = 0x0000_FFFC,
[1657752507.262570][2004:2009] CHIP:DMG: 				}
[1657752507.262610][2004:2009] CHIP:DMG:
[1657752507.262644][2004:2009] CHIP:DMG: 				Data = 2,
[1657752507.262680][2004:2009] CHIP:DMG: 			},
[1657752507.262718][2004:2009] CHIP:DMG:
[1657752507.262746][2004:2009] CHIP:DMG: 		},
[1657752507.262780][2004:2009] CHIP:DMG:
[1657752507.262804][2004:2009] CHIP:DMG: 	],
[1657752507.262868][2004:2009] CHIP:DMG:
[1657752507.262895][2004:2009] CHIP:DMG: 	SuppressResponse = true,
[1657752507.262921][2004:2009] CHIP:DMG: 	InteractionModelRevision = 1
[1657752507.262944][2004:2009] CHIP:DMG: }
[1657752507.264329][2004:2009] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
[1657752507.264370][2004:2009] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
[1657752507.264402][2004:2009] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
[1657752507.264425][2004:2009] CHIP:CTL: Arming failsafe (60 seconds)
[1657752507.264538][2004:2009] CHIP:DMG: ICR moving to [AddingComm]
[1657752507.264584][2004:2009] CHIP:DMG: ICR moving to [AddedComma]
[1657752507.264981][2004:2009] CHIP:IN: Prepared secure message 0xffffa98d7128 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 54531i with MessageCounter:137041522.
[1657752507.265039][2004:2009] CHIP:IN: Sending encrypted msg 0xffffa98d7128 with MessageCounter:137041522 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000192B31 msec
[1657752507.265217][2004:2009] CHIP:DMG: ICR moving to [CommandSen]
[1657752507.594314][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1657752507.595880][2004:2007] CHIP:DL: Indication received, conn = 0xffffa0038300
[1657752507.596139][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1657752507.596394][2004:2009] CHIP:EM: Received message of type 0x9 with protocolId (0, 1) and MessageCounter:4752761 on exchange 54531i
[1657752507.596462][2004:2009] CHIP:EM: Found matching exchange: 54531i, Delegate: 0xffff94019400
[1657752507.596542][2004:2009] CHIP:DMG: ICR moving to [ResponseRe]
[1657752507.596642][2004:2009] CHIP:DMG: InvokeResponseMessage =
[1657752507.596695][2004:2009] CHIP:DMG: {
[1657752507.596745][2004:2009] CHIP:DMG: 	suppressResponse = false,
[1657752507.596797][2004:2009] CHIP:DMG: 	InvokeResponseIBs =
[1657752507.596867][2004:2009] CHIP:DMG: 	[
[1657752507.596928][2004:2009] CHIP:DMG: 		InvokeResponseIB =
[1657752507.597009][2004:2009] CHIP:DMG: 		{
[1657752507.597070][2004:2009] CHIP:DMG: 			CommandDataIB =
[1657752507.597140][2004:2009] CHIP:DMG: 			{
[1657752507.597206][2004:2009] CHIP:DMG: 				CommandPathIB =
[1657752507.597278][2004:2009] CHIP:DMG: 				{
[1657752507.597352][2004:2009] CHIP:DMG: 					EndpointId = 0x0,
[1657752507.597427][2004:2009] CHIP:DMG: 					ClusterId = 0x30,
[1657752507.597512][2004:2009] CHIP:DMG: 					CommandId = 0x1,
[1657752507.597590][2004:2009] CHIP:DMG: 				},
[1657752507.597671][2004:2009] CHIP:DMG:
[1657752507.597742][2004:2009] CHIP:DMG: 				CommandFields =
[1657752507.597819][2004:2009] CHIP:DMG: 				{
[1657752507.597894][2004:2009] CHIP:DMG: 					0x0 = 0,
[1657752507.597979][2004:2009] CHIP:DMG: 					0x1 = "",
[1657752507.598060][2004:2009] CHIP:DMG: 				},
[1657752507.598124][2004:2009] CHIP:DMG: 			},
[1657752507.598206][2004:2009] CHIP:DMG:
[1657752507.598264][2004:2009] CHIP:DMG: 		},
[1657752507.598336][2004:2009] CHIP:DMG:
[1657752507.598387][2004:2009] CHIP:DMG: 	],
[1657752507.598451][2004:2009] CHIP:DMG:
[1657752507.598502][2004:2009] CHIP:DMG: 	InteractionModelRevision = 1
[1657752507.598552][2004:2009] CHIP:DMG: },
[1657752507.598687][2004:2009] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1657752507.604315][2004:2009] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1657752507.604394][2004:2009] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
[1657752507.604443][2004:2009] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1657752507.604500][2004:2009] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
[1657752507.604545][2004:2009] CHIP:CTL: Setting Regulatory Config
[1657752507.604588][2004:2009] CHIP:CTL: Device does not support configurable regulatory location
[1657752507.604704][2004:2009] CHIP:DMG: ICR moving to [AddingComm]
[1657752507.604772][2004:2009] CHIP:DMG: ICR moving to [AddedComma]
[1657752507.604948][2004:2009] CHIP:IN: Prepared secure message 0xffffa98d6cb8 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 54532i with MessageCounter:137041523.
[1657752507.605036][2004:2009] CHIP:IN: Sending encrypted msg 0xffffa98d6cb8 with MessageCounter:137041523 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000192C85 msec
[1657752507.605238][2004:2009] CHIP:DMG: ICR moving to [CommandSen]
[1657752507.605361][2004:2009] CHIP:DMG: ICR moving to [AwaitingDe]
[1657752508.061533][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on eth0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752508.062824][2004:2009] CHIP:DIS: Warning: Attempt to mDNS broadcast failed on docker0:  ../../src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
[1657752508.062887][2004:2009] CHIP:DIS: mDNS broadcast had only partial success: 6 successes and 2 failures.
[1657752508.110513][2004:2007] CHIP:DL: Bluez disconnected
[1657752508.110596][2004:2007] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1657752508.110915][2004:2009] CHIP:IN: Clearing BLE pending packets.
[1657752508.111318][2004:2009] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1657752508.111384][2004:2009] CHIP:BLE: no endpoint for BLE sent data ack
[1657752524.077581][2004:2009] CHIP:DIS: Timeout waiting for mDNS resolution.
[1657752537.618410][2004:2009] CHIP:DMG: Time out! failed to receive invoke command response from Exchange: 54532i
[1657752537.618524][2004:2009] CHIP:CTL: Received failure response ../../src/app/CommandSender.cpp:214: CHIP Error 0x00000032: Timeout
[1657752537.618624][2004:2009] CHIP:CTL: Error on commissioning step 'ConfigRegulatory': '../../src/app/CommandSender.cpp:214: CHIP Error 0x00000032: Timeout'
[1657752537.618674][2004:2009] CHIP:CTL: Failed to perform commissioning step 4
[1657752537.618728][2004:2009] CHIP:CTL: Going from commissioning step 'ConfigRegulatory' with lastErr = '../../src/app/CommandSender.cpp:214: CHIP Error 0x00000032: Timeout' -> 'Cleanup'
[1657752537.618800][2004:2009] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = '../../src/app/CommandSender.cpp:214: CHIP Error 0x00000032: Timeout'
[1657752537.618851][2004:2009] CHIP:CTL: Expiring failsafe on proxy 0xffff9401d9a0
[1657752537.618984][2004:2009] CHIP:DMG: ICR moving to [AddingComm]
[1657752537.619048][2004:2009] CHIP:DMG: ICR moving to [AddedComma]
[1657752537.619241][2004:2009] CHIP:IN: Prepared secure message 0xffffa98d7878 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 54533i with MessageCounter:137041524.
[1657752537.619331][2004:2009] CHIP:IN: Sending encrypted msg 0xffffa98d7878 with MessageCounter:137041524 to 0xFFFFFFFB00000000 (0) at monotonic time: 000000000019A1C3 msec
[1657752537.619402][2004:2009] CHIP:IN: Message appended to BLE send queue
[1657752537.619454][2004:2009] CHIP:DMG: ICR moving to [CommandSen]
[1657752537.619517][2004:2009] CHIP:DMG: ICR moving to [AwaitingDe]
[1657752543.049198][2004:2009] CHIP:DIS: Closing all BLE connections
[1657752543.049364][2004:2009] CHIP:TOO: Pairing Failure: ../../src/controller/CHIPDeviceController.cpp:1406: CHIP Error 0x00000032: Timeout
[1657752543.049995][2004:2004] CHIP:CTL: Shutting down the commissioner
[1657752543.050065][2004:2004] CHIP:CTL: Shutting down the controller
[1657752543.050125][2004:2004] CHIP:CTL: Shutting down the commissioner
[1657752543.050171][2004:2004] CHIP:CTL: Shutting down the controller
[1657752543.050215][2004:2004] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1657752543.050261][2004:2004] CHIP:FP: Forgetting fabric 0x1
[1657752543.050323][2004:2004] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752543.050717][2004:2004] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752543.050773][2004:2004] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752543.050851][2004:2004] CHIP:CTL: Shutting down the commissioner
[1657752543.050900][2004:2004] CHIP:CTL: Shutting down the controller
[1657752543.050944][2004:2004] CHIP:IN: Expiring all sessions for fabric 0x2!!
[1657752543.050988][2004:2004] CHIP:FP: Forgetting fabric 0x2
[1657752543.051038][2004:2004] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752543.051306][2004:2004] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752543.051356][2004:2004] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752543.051421][2004:2004] CHIP:CTL: Shutting down the commissioner
[1657752543.051468][2004:2004] CHIP:CTL: Shutting down the controller
[1657752543.051510][2004:2004] CHIP:IN: Expiring all sessions for fabric 0x3!!
[1657752543.051554][2004:2004] CHIP:FP: Forgetting fabric 0x3
[1657752543.051604][2004:2004] CHIP:TS: Pending Last Known Good Time: 2022-07-13T18:42:46
[1657752543.051919][2004:2004] CHIP:TS: Previous Last Known Good Time: 2022-07-13T18:42:46
[1657752543.051970][2004:2004] CHIP:TS: Reverted Last Known Good Time to previous value
[1657752543.052030][2004:2004] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1657752543.053023][2004:2004] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752543.053072][2004:2004] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752543.053111][2004:2004] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752543.053146][2004:2004] CHIP:DMG: IM WH moving to [Uninitialized]
[1657752543.053184][2004:2004] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1657752543.053322][2004:2004] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1657752543.053680][2004:2004] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-CKzcVH)
[1657752543.054579][2004:2004] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1657752543.054672][2004:2004] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1657752543.054719][2004:2004] CHIP:DL: Inet Layer shutdown
[1657752543.054759][2004:2004] CHIP:DL: BLE shutdown
[1657752543.057415][2004:2004] CHIP:DL: System Layer shutdown
[1657752543.057581][2004:2004] CHIP:IN: SecureSession[0xffff94005f00]: MarkForEviction Type:1 LSID:35411
[1657752543.057632][2004:2004] CHIP:SC: SecureSession[0xffff94005f00]: Moving from state 'kActive' --> 'kPendingEviction'
Segmentation fault
Logs from the 52840DK:
uart:~$ I: 227 [DL]BLE address: DF:84:4E:3B:47:6F
I: SoftDevice Controller build revision:
I: 33 78 2a 18 20 f5 61 61 |3x*. .aa
I: a6 8b 77 60 62 83 39 2a |..w`b.9*
I: 7c f1 14 e4             ||...
I: 253 [DL]OpenThread started: OK
I: 256 [DL]Setting OpenThread device type to ROUTER
I: 263 [SVR]Server initializing...
D: 266 [DIS]Init fabric pairing table with server storage
I: 272 [DMG]AccessControl: initializing
I: 275 [DMG]Examples::AccessControlDelegate::Init
I: 280 [DMG]AccessControl: setting
I: 283 [DMG]DefaultAclStorage: initializing
I: 287 [DMG]DefaultAclStorage: 0 entries loaded
I: 291 [ZCL]Using ZAP configuration...
I: 296 [DMG]AccessControlCluster: initializing
I: 300 [ZCL]Initiating Admin Commissioning cluster.
D: 305 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to fa8c2bf4
I: 311 [ZCL]OpCreds: Initiating OpCreds cluster by writing fabrics list from fabric table.
D: 319 [DIS]Add fabric pairing table delegate
D: 324 [DMG]Endpoint 0, Cluster 0x0000_0004 update version to 68b850e8
E: 330 [ZCL]DeviceInfoProvider is not registered
E: 334 [ZCL]Trying to write invalid Calendar Type
E: 339 [ZCL]Failed to write calendar type with error: 0x87
D: 344 [DMG]Endpoint 1, Cluster 0x0000_0004 update version to 2df8198d
D: 350 [DMG]Endpoint 1, Cluster 0x0000_0006 update version to a15f8c4f
I: 357 [ZCL]Cluster OnOff: attribute OnOff set to 0
D: 361 [DMG]Endpoint 1, Cluster 0x0000_0008 update version to ea42a106
I: 368 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
D: 374 [IN]UDP::Init bind&listen port=5540
E: 378 [IN]SO_REUSEPORT failed: 109
D: 381 [IN]UDP::Init bound to port=5540
D: 385 [IN]BLEBase::Init - setting/overriding transport
D: 390 [IN]TransportMgr initialized
D: 397 [DIS]Add fabric pairing table delegate
D: 402 [DL]Using Thread extended MAC for hostname.
D: 411 [SC]Assigned local session key ID 32888
D: 415 [SC]Waiting for PBKDF param request
D: 419 [DL]CHIPoBLE advertising set to on
I: 422 [DIS]Updating services using commissioning mode 1
D: 428 [DL]Using Thread extended MAC for hostname.
D: 432 [DL]Using Thread extended MAC for hostname.
I: 438 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15
E: 446 [DIS]Failed to advertise commissionable node: Error CHIP:0x00000003
D: 453 [DIS]Scheduling discovery timeout in 900s
E: 457 [DIS]Failed to finalize service update: Error CHIP:0x0000001C
I: 464 [DIS]Updating services using commissioning mode 1
D: 469 [DL]Using Thread extended MAC for hostname.
D: 474 [DL]Using Thread extended MAC for hostname.
I: 479 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15
E: 487 [DIS]Failed to advertise commissionable node: Error CHIP:0x00000003
D: 494 [DIS]Scheduling discovery timeout in 900s
E: 499 [DIS]Failed to finalize service update: Error CHIP:0x0000001C
I: 505 [DIS]Delaying proxy of operational discovery: missing delegate
I: 511 [IN]CASE Server enabling CASE session setups
I: 516 [SVR]Joining Multicast groups
D: 519 [ZCL]Emitting StartUp event
D: 522 [EVL]LogEvent event number: 0x00000000000A0000 priority: 2, endpoint id:  0x0 cluster id: 0x0000_0028 event id: 0x0 Sys timestamp: 0x000000000000020A
D: 536 [ZCL]GeneralDiagnosticsDelegate: OnDeviceRebooted
D: 541 [DMG]Endpoint 0, Cluster 0x0000_0033 update version to f40b7e3b
D: 548 [EVL]LogEvent event number: 0x00000000000A0001 priority: 2, endpoint id:  0x0 cluster id: 0x0000_0033 event id: 0x3 Sys timestamp: 0x0000000000000224
I: 562 [SVR]Server Listening...
I: 565 [DL]Device Configuration:
I: 568 [DL]  Serial Number: TEST_SN
I: 571 [DL]  Vendor Id: 65521 (0xFFF1)
I: 575 [DL]  Product Id: 32773 (0x8005)
I: 579 [DL]  Hardware Version: 0
I: 582 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 588 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 595 [DL]  Manufacturing Date: (not set)
I: 599 [DL]  Device Type: 65535 (0xFFFF)
I: 604 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00]
I: 608 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 615 [SVR]https://dhrishi.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00
I: 623 [SVR]Manual pairing code: [34970112332]
I: 628 [DL]CHIP task running
I: 634 [DL]CHIPoBLE advertising started
I: 639 [DL]NFC Tag emulation started
I: 30639 [DL]CHIPoBLE advertising mode changed to slow
I: 55201 [DL]BLE connection established (ConnId: 0x00)
I: 55206 [DL]Current number of connections: 1/1
I: 55211 [DL]CHIPoBLE advertising stopped
I: 55215 [DL]NFC Tag emulation stopped
I: 75263 [DL]BLE GAP connection terminated (reason 0x13)
I: 75268 [DL]Current number of connections: 0/1
I: 75275 [DL]CHIPoBLE advertising started
I: 75279 [DL]NFC Tag emulation started
I: 105278 [DL]CHIPoBLE advertising mode changed to slow
I: 132658 [DL]BLE connection established (ConnId: 0x00)
I: 132663 [DL]Current number of connections: 1/1
I: 132667 [DL]CHIPoBLE advertising stopped
I: 132671 [DL]NFC Tag emulation stopped
D: 134507 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 134513 [BLE]local and remote recv window sizes = 5
I: 134518 [BLE]selected BTP version 4
I: 134521 [BLE]using BTP fragment sizes rx 244 / tx 244.
D: 134653 [DL]ConnId: 0x00, New CCCD value: 0x0001
D: 134658 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 6)
D: 134664 [IN]BLE EndPoint 0x20009ac8 Connection Complete
I: 134670 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
D: 134849 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 134855 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 134861 [EM]Received message of type 0x20 with protocolId (0, 0) and MessageCounter:258070661 on exchange 54529r
D: 134871 [EM]Handling via exchange: 54529r, Delegate: 0x20005940
D: 134877 [SC]Received PBKDF param request
D: 134881 [SC]Peer assigned session ID 35411
D: 134885 [SC]Found MRP parameters in the message
D: 134890 [SC]Including MRP parameters in PBKDF param response
I: 134896 [IN]Prepared unauthenticated message 0x2002d878 to 0x0000000000000000 (0)  of type 0x21 and protocolId (0, 0) on exchange 54529r with MessageCounter:227647507.
I: 134911 [IN]Sending unauthenticated msg 0x2002d878 with MessageCounter:227647507 to 0x0000000000000000 at monotonic time: 0000000000020EFF msec
D: 134924 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 140)
D: 134931 [SC]Sent PBKDF param response
D: 135044 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 135050 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 135056 [EM]Received message of type 0x22 with protocolId (0, 0) and MessageCounter:258070662 on exchange 54529r
D: 135066 [EM]Found matching exchange: 54529r, Delegate: 0x20005940
D: 135072 [SC]Received spake2p msg1
I: 136986 [IN]Prepared unauthenticated message 0x2002d808 to 0x0000000000000000 (0)  of type 0x23 and protocolId (0, 0) on exchange 54529r with MessageCounter:227647508.
I: 137001 [IN]Sending unauthenticated msg 0x2002d808 with MessageCounter:227647508 to 0x0000000000000000 at monotonic time: 0000000000021729 msec
D: 137014 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 132)
D: 137020 [SC]Sent spake2p msg2
E: 137023 [DL]Long dispatch time: 1973 ms, for event type 16388
D: 137091 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 137097 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 137103 [EM]Received message of type 0x24 with protocolId (0, 0) and MessageCounter:258070663 on exchange 54529r
D: 137113 [EM]Found matching exchange: 54529r, Delegate: 0x20005940
D: 137119 [SC]Received spake2p msg3
D: 137123 [SC]Sending status report. Protocol code 0, exchange 54529
I: 137129 [IN]Prepared unauthenticated message 0x2002d898 to 0x0000000000000000 (0)  of type 0x40 and protocolId (0, 0) on exchange 54529r with MessageCounter:227647509.
I: 137145 [IN]Sending unauthenticated msg 0x2002d898 with MessageCounter:227647509 to 0x0000000000000000 at monotonic time: 00000000000217B8 msec
D: 137157 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 35)
D: 137165 [IN]New secure session created for device <FFFFFFFB00000000, 0>, LSID:32888 PSID:35411!
I: 137174 [SVR]Commissioning completed session establishment step
I: 137180 [DIS]Updating services using commissioning mode 0
D: 137185 [DL]Using Thread extended MAC for hostname.
D: 137191 [DL]Using Thread extended MAC for hostname.
I: 137196 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15
E: 137205 [DIS]Failed to advertise extended commissionable node: Error CHIP:0x00000003
D: 137213 [DIS]Scheduling extended discovery timeout in 900s
E: 137218 [DIS]Failed to finalize service update: Error CHIP:0x0000001C
D: 137225 [DL]CHIPoBLE advertising set to off
I: 137242 [SVR]Device completed Rendezvous process
E: 137247 [DL]Long dispatch time: 150 ms, for event type 16388
D: 137287 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 137292 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 137299 [EM]Received message of type 0x2 with protocolId (0, 1) and MessageCounter:137041521 on exchange 54530r
D: 137310 [EM]Handling via exchange: 54530r, Delegate: 0x200078bc
D: 137315 [IM]Received Read request
D: 137321 [DMG]IM RH moving to [GeneratingReports]
D: 137326 [DMG]Building Reports for ReadHandler with LastReportGeneration = 0 DirtyGeneration = 0
D: 137334 [DMG]<RE:Run> Cluster 31, Attribute 3 is dirty
D: 137340 [DMG]Reading attribute: Cluster=0x0000_0031 Endpoint=0 AttributeId=0x0000_0003 (expanded=1)
D: 137349 [DMG]<RE:Run> Cluster 28, Attribute 4 is dirty
D: 137354 [DMG]Reading attribute: Cluster=0x0000_0028 Endpoint=0 AttributeId=0x0000_0004 (expanded=0)
D: 137363 [DMG]<RE:Run> Cluster 28, Attribute 2 is dirty
D: 137368 [DMG]Reading attribute: Cluster=0x0000_0028 Endpoint=0 AttributeId=0x0000_0002 (expanded=0)
D: 137377 [DMG]<RE:Run> Cluster 30, Attribute 3 is dirty
D: 137383 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0003 (expanded=0)
D: 137392 [DMG]<RE:Run> Cluster 30, Attribute 2 is dirty
D: 137397 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0002 (expanded=0)
D: 137406 [DMG]<RE:Run> Cluster 30, Attribute 1 is dirty
D: 137411 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0001 (expanded=0)
D: 137420 [DMG]<RE:Run> Cluster 30, Attribute 0 is dirty
D: 137425 [DMG]Reading attribute: Cluster=0x0000_0030 Endpoint=0 AttributeId=0x0000_0000 (expanded=0)
D: 137435 [DMG]<RE:Run> Cluster 31, Attribute fffc is dirty
D: 137440 [DMG]Reading attribute: Cluster=0x0000_0031 Endpoint=0 AttributeId=0x0000_FFFC (expanded=1)
D: 137449 [DMG]<RE> Sending report (payload has 224 bytes)...
I: 137457 [IN]Prepared secure message 0x2002da40 to 0xFFFFFFFB00000000 (0)  of type 0x5 and protocolId (0, 1) on exchange 54530r with MessageCounter:4752760.
I: 137471 [IN]Sending encrypted msg 0x2002da40 with MessageCounter:4752760 to 0xFFFFFFFB00000000 (0) at monotonic time: 00000000000218FE msec
D: 137484 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 244)
D: 137490 [DMG]<RE> OnReportConfirm: NumReports = 0
D: 137495 [DMG]<RE> ReportsInFlight = 0 with readHandler 0, RE has no more messages
D: 137502 [DMG]IM RH moving to [AwaitingDestruction]
D: 137507 [DMG]All ReadHandler-s are clean, clear GlobalDirtySet
D: 137578 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 137583 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 17)
D: 137676 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 137871 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 137878 [EM]Received message of type 0x8 with protocolId (0, 1) and MessageCounter:137041522 on exchange 54531r
D: 137888 [EM]Handling via exchange: 54531r, Delegate: 0x200078bc
D: 137895 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
D: 137903 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to fa8c2bf5
D: 137910 [DMG]ICR moving to [ Preparing]
D: 137913 [DMG]ICR moving to [AddingComm]
D: 137917 [DMG]ICR moving to [AddedComma]
D: 137921 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 137928 [IN]Prepared secure message 0x2002d908 to 0xFFFFFFFB00000000 (0)  of type 0x9 and protocolId (0, 1) on exchange 54531r with MessageCounter:4752761.
I: 137943 [IN]Sending encrypted msg 0x2002d908 with MessageCounter:4752761 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000021AD6 msec
D: 137955 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 71)
D: 137962 [DMG]ICR moving to [CommandSen]
D: 137965 [DMG]ICR moving to [AwaitingDe]
D: 138081 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 138087 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 138094 [EM]Received message of type 0x8 with protocolId (0, 1) and MessageCounter:137041523 on exchange 54532r
D: 138104 [EM]Handling via exchange: 54532r, Delegate: 0x200078bc
D: 138110 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0002
D: 138121 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to fa8c2bf6
D: 138127 [DMG]ICR moving to [ Preparing]
D: 138131 [DMG]ICR moving to [AddingComm]
D: 138135 [DMG]ICR moving to [AddedComma]
D: 138139 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 138146 [IN]Prepared secure message 0x2002d908 to 0xFFFFFFFB00000000 (0)  of type 0x9 and protocolId (0, 1) on exchange 54532r with MessageCounter:4752762.
I: 138160 [IN]Sending encrypted msg 0x2002d908 with MessageCounter:4752762 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000021BB0 msec
D: 138173 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 71)
D: 138179 [DMG]ICR moving to [CommandSen]
D: 138183 [DMG]ICR moving to [AwaitingDe]
I: 138531 [DL]BLE GAP connection terminated (reason 0x08)
D: 138536 [IN]Clearing BLE pending packets.
I: 138540 [BLE]Releasing end point's BLE connection back to application.
I: 138546 [DL]Closing BLE GATT connection (ConnId 00)
I: 138551 [DL]Current number of connections: 0/1
E: 197902 [SVR]Failsafe timer expired
E: 197906 [SVR]Commissioning failed (attempt 1): Error CHIP:0x00000032
D: 197914 [SC]Assigned local session key ID 32889
D: 197918 [SC]Waiting for PBKDF param request
D: 197922 [DL]CHIPoBLE advertising set to on
I: 197926 [DIS]Updating services using commissioning mode 1
D: 197932 [DL]Using Thread extended MAC for hostname.
D: 197937 [DL]Using Thread extended MAC for hostname.
I: 197942 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15
E: 197951 [DIS]Failed to advertise commissionable node: Error CHIP:0x00000003
D: 197958 [DIS]Scheduling discovery timeout in 900s
E: 197963 [DIS]Failed to finalize service update: Error CHIP:0x0000001C
I: 197970 [ZCL]OpCreds: Call to FailSafeCleanup
D: 197974 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to fa8c2bf7
D: 197980 [ZCL]Failsafe timeout, tell platform driver to revert network credentials.
I: 197994 [DL]CHIPoBLE advertising started
I: 197999 [DL]NFC Tag emulation started
I: 227997 [DL]CHIPoBLE advertising mode changed to slow
I: 900409 [SVR]Closing pairing window
I: 900413 [DIS]Updating services using commissioning mode 0
D: 900418 [DL]Using Thread extended MAC for hostname.
D: 900423 [DL]Using Thread extended MAC for hostname.
I: 900429 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15
E: 900438 [DIS]Failed to advertise extended commissionable node: Error CHIP:0x00000003
D: 900446 [DIS]Scheduling extended discovery timeout in 900s
E: 900451 [DIS]Failed to finalize service update: Error CHIP:0x0000001C
D: 900457 [DL]CHIPoBLE advertising set to off
I: 900462 [DL]CHIPoBLE advertising stopped
I: 900466 [DL]NFC Tag emulation stopped
Versions
Everything was downloaded today
matter commit b682834e
ot-br-posix commit d839abf5
ot-nrf528xx commit 24f53468
nrfSDK v2.0.0
OS: Ubuntu 20.04 LTS (desktop for PC, server for Raspberry Pi 4)
Additional
About a month ago I successfully joined these two devices. I wiped them and ttried to do it again now and it doen't seem to work.
Also, the dongle is not recognised by vscode.
Also, I cannot use the NRF Programmer tool for the dongle, since it only gives me `Error when fetching device versions: readFwInfo error (Origin: "Error when starting nrfdl_fw_read_info")`
    I have picked up your case and will try to to see if I can recreate the issue. I will hopefully come back with an answer within two working days (friday/monday). In the meanwhile, please let me know if you manage to resolve the issue yourself
    Andreas
  • Hi again,
    I have not been able to recreate your issue yet, but based on
    we believe there could be an issue with the RPi Bluetooth adapter. Some workarounds does involve trying to connect multiple time, but we do not believe that to be sufficient in all cases. Usually it is worth making sure that  rpi-bluetooth and bluez apt packages are up to date. In some cases restarting the BLE adapter and/or bluez helps (you can do the latter with sudo systemctl restart bluetooth . If nothing helps, you can use an external BLE adapter. For example, you can program Zephyr's HCI USB sample onto a nRF52840 DK/Dongle and use it as a BLE adapter (https://docs.zephyrproject.org/2.7.0/samples/bluetooth/hci_usb/README.html).
    Let me know if this fixes your issue or not and I will report that feedback back to the Matter developers
    Andreas
  • I'm trying this again today, seeing similar results.
    To mix things up, I thought I'd build and flash the board on my pi instead of my pc. Following this guide, I failed at step 6 with
    ~/ot-nrf528xx$ pip install -U nrfutil
    Collecting nrfutil
      Using cached nrfutil-6.1.6.tar.gz (844 kB)
    Requirement already satisfied, skipping upgrade: click in /usr/lib/python3/dist-packages (from nrfutil) (7.0)
    Collecting crcmod
      Using cached crcmod-1.7.tar.gz (89 kB)
    Collecting ecdsa
      Using cached ecdsa-0.18.0-py2.py3-none-any.whl (142 kB)
    Collecting intelhex
      Using cached intelhex-2.3.0-py2.py3-none-any.whl (50 kB)
    Collecting libusb1==1.9.3
      Using cached libusb1-1.9.3-py3-none-any.whl (60 kB)
    ERROR: Could not find a version that satisfies the requirement pc_ble_driver_py>=0.16.4 (from nrfutil) (from versions: 0.1.0, 0.2.0, 0.3.0, 0.4.0, 0.5.0, 0.6.0, 0.6.1, 0.6.2, 0.8.0, 0.8.1, 0.9.0, 0.9.1, 0.10.0, 0.11.0, 0.11.1, 0.11.2, 0.11.3, 0.11.4)
    ERROR: No matching distribution found for pc_ble_driver_py>=0.16.4 (from nrfutil)
    I saw somesone suggest uninstalling and reinstalling pc-ble-driver-py, so I
    ~/ot-nrf528xx$ pip uninstall pc-ble-driver-py
    WARNING: Skipping pc-ble-driver-py as it is not installed.
    Interesting. Anyway...
    ~/ot-nrf528xx$ pip install pc-ble-driver-py
    Collecting pc-ble-driver-py
      Downloading pc_ble_driver_py-0.11.4.tar.gz (8.0 MB)
         |████████████████████████████████| 8.0 MB 72 kB/s
    Processing /home/ubuntu/.cache/pip/wheels/8e/70/28/3d6ccd6e315f65f245da085482a2e1c7d14b90b30f239e2cf4/future-0.18.2-py3-none-any.whl
    Collecting wrapt
      Downloading wrapt-1.14.1-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (81 kB)
         |████████████████████████████████| 81 kB 1.9 MB/s
    Building wheels for collected packages: pc-ble-driver-py
      Building wheel for pc-ble-driver-py (setup.py) ... done
      Created wheel for pc-ble-driver-py: filename=pc_ble_driver_py-0.11.4-py3-none-any.whl size=8095775 sha256=456d8f95a3b916b5c2028789e97d6fc99055f08b2e04a482c0e2128265c5eabc
      Stored in directory: /home/ubuntu/.cache/pip/wheels/39/f5/9a/55f39f0f091a0f6c315e332ec1c909c52e2819bc2972c2494a
    Successfully built pc-ble-driver-py
    Installing collected packages: future, wrapt, pc-ble-driver-py
    Successfully installed future-0.18.2 pc-ble-driver-py-0.11.4 wrapt-1.14.1
    With the ble driver installed, time to install nrfUtil
    ~/ot-nrf528xx$ python3 -m pip install -U nrfutil
    Defaulting to user installation because normal site-packages is not writeable
    Collecting nrfutil
      Preparing metadata (setup.py) ... done
    Requirement already satisfied: click in /usr/lib/python3/dist-packages (from nrfutil) (7.0)
    Collecting crcmod
    Collecting ecdsa
    Collecting intelhex
    Collecting nrfutil
      Downloading nrfutil-6.1.5.tar.gz (844 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 844.9/844.9 kB 5.1 MB/s eta 0:00:00
      Downloading nrfutil-6.1.4.tar.gz (844 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 844.8/844.8 kB 5.5 MB/s eta 0:00:00
      Using cached nrfutil-6.1.3.tar.gz (844 kB)
      Downloading nrfutil-6.1.2.tar.gz (844 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 844.1/844.1 kB 5.0 MB/s eta 0:00:00
    Collecting libusb1
      Downloading libusb1-3.0.0-py3-none-any.whl (62 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 62.1/62.1 kB 2.0 MB/s eta 0:00:00
    Collecting nrfutil
      Downloading nrfutil-6.1.1.tar.gz (841 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 841.8/841.8 kB 6.1 MB/s eta 0:00:00
      Downloading nrfutil-6.1.0.tar.gz (842 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 842.7/842.7 kB 6.1 MB/s eta 0:00:00
      Downloading nrfutil-6.0.1.tar.gz (843 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 843.9/843.9 kB 5.6 MB/s eta 0:00:00
      Downloading nrfutil-5.2.0.tar.gz (850 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 850.7/850.7 kB 6.1 MB/s eta 0:00:00
    Collecting behave~=1.0
      Downloading behave-1.2.6-py2.py3-none-any.whl (136 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 136.8/136.8 kB 2.8 MB/s eta 0:00:00
    Collecting ecdsa~=0.13.0
      Downloading ecdsa-0.13.3-py2.py3-none-any.whl (52 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 52.1/52.1 kB 2.0 MB/s eta 0:00:00
    Collecting enum34~=1.0
      Downloading enum34-1.1.10-py3-none-any.whl (11 kB)
    Requirement already satisfied: pc_ble_driver_py~=0.11.4 in /home/ubuntu/.local/lib/python3.8/site-packages (from nrfutil) (0.11.4)
    Collecting piccata~=1.0
      Downloading piccata-1.0.1.tar.gz (16 kB)
    Collecting protobuf~=3.6
      Downloading protobuf-3.20.1-cp38-cp38-manylinux2014_aarch64.whl (918 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 918.1/918.1 kB 5.6 MB/s eta 0:00:00
    Requirement already satisfied: pyserial~=3.0 in /usr/lib/python3/dist-packages (from nrfutil) (3.4)
    Collecting pyspinel==1.0.0a3
      Downloading pyspinel-1.0.0a3.tar.gz (49 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 49.3/49.3 kB 2.2 MB/s eta 0:00:00
    Collecting pyyaml~=4.2b1
      Downloading PyYAML-4.2b4.tar.gz (262 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 262.6/262.6 kB 5.7 MB/s eta 0:00:00
    Requirement already satisfied: six~=1.9 in /usr/lib/python3/dist-packages (from nrfutil) (1.14.0)
    Collecting tqdm~=4.25
      Downloading tqdm-4.64.0-py2.py3-none-any.whl (78 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 78.4/78.4 kB 1.6 MB/s eta 0:00:00
    Collecting ipaddress
      Downloading ipaddress-1.0.23-py2.py3-none-any.whl (18 kB)
    Collecting parse-type>=0.4.2
      Downloading parse_type-0.6.0-py2.py3-none-any.whl (32 kB)
    Collecting parse>=1.8.2
      Downloading parse-1.19.0.tar.gz (30 kB)
    Requirement already satisfied: future in /home/ubuntu/.local/lib/python3.8/site-packages (from pc_ble_driver_py~=0.11.4->nrfutil) (0.18.2)
    Requirement already satisfied: wrapt in /home/ubuntu/.local/lib/python3.8/site-packages (from pc_ble_driver_py~=0.11.4->nrfutil) (1.14.1)
    Building wheels for collected packages: nrfutil, pyspinel, crcmod, piccata, pyyaml, parse
      Building wheel for nrfutil (setup.py) ... done
      Created wheel for nrfutil: filename=nrfutil-5.2.0-py3-none-any.whl size=911037 sha256=16df52e67645a9a45bdddb62de631e3e7261814ef1c3ff9858c849840e25b199
      Stored in directory: /home/ubuntu/.cache/pip/wheels/c1/af/f7/f240c7018b692e93fa9abef5a4dba5bd2a5a00c59e56865210
      Building wheel for pyspinel (setup.py) ... done
      Created wheel for pyspinel: filename=pyspinel-1.0.0a3-py3-none-any.whl size=55513 sha256=5f3504731139bd762e4af3406f3fa5ac12b1a142ff0d322a6f9316f70e1c0f91
      Stored in directory: /home/ubuntu/.cache/pip/wheels/ec/98/96/276b3f2eec4cc409698d0fe171051e1cbe8d883e5ba15756b3
      Building wheel for crcmod (setup.py) ... done
      Created wheel for crcmod: filename=crcmod-1.7-cp38-cp38-linux_aarch64.whl size=35610 sha256=b06b8c9832201c8cd27796e402495f92935c53fffd7bce583deac0f3eb38d972
      Stored in directory: /home/ubuntu/.cache/pip/wheels/ca/5a/02/f3acf982a026f3319fb3e798a8dca2d48fafee7761788562e9
      Building wheel for piccata (setup.py) ... done
      Created wheel for piccata: filename=piccata-1.0.1-py3-none-any.whl size=20727 sha256=842092972829e731740502813c50ea1eee5a55efa5ff80c8ee3dc70eae5d8804
      Stored in directory: /home/ubuntu/.cache/pip/wheels/a4/68/01/a92750aef1de0fe3b435d16aa508ae116bffb2b1ef6eb0dc77
      Building wheel for pyyaml (setup.py) ... done
      Created wheel for pyyaml: filename=PyYAML-4.2b4-cp38-cp38-linux_aarch64.whl size=43031 sha256=cda77494b76d6bc019a009233779b049349a18186dc46e43b21e83e1f5395089
      Stored in directory: /home/ubuntu/.cache/pip/wheels/3f/db/67/c44d262205f8f6105abf4c0aff6045a176d94e1011e85dde88
      Building wheel for parse (setup.py) ... done
      Created wheel for parse: filename=parse-1.19.0-py3-none-any.whl size=24580 sha256=cd8e0315b7a280e4bd6fd7758ab8e001852397cf70d712495edc09ac6b8d286b
      Stored in directory: /home/ubuntu/.cache/pip/wheels/e5/33/1f/68392720485b3ecf125a69e700baaab7624616deedea2fa6e2
    Successfully built nrfutil pyspinel crcmod piccata pyyaml parse
    Installing collected packages: parse, libusb1, ipaddress, intelhex, enum34, ecdsa, crcmod, tqdm, pyyaml, pyspinel, protobuf, piccata, parse-type, behave, nrfutil
    Successfully installed behave-1.2.6 crcmod-1.7 ecdsa-0.13.3 enum34-1.1.10 intelhex-2.3.0 ipaddress-1.0.23 libusb1-1.9.3 nrfutil-5.2.0 parse-1.19.0 parse-type-0.6.0 piccata-1.0.1 protobuf-3.20.1 pyspinel-1.0.0a3 pyyaml-4.2b4 tqdm-4.64.0
    Great! Now I can use nrfUtil to build this thing.
    ~/ot-nrf528xx$ nrfutil pkg generate --hw-version 52 --sd-req=0x00 \
    >     --application build/bin/ot-rcp.hex \
    >     --application-version 1 build/bin/ot-rcp.zip
    |You are not providing a signature key, which means the DFU     |
    |files will not be signed, and are vulnerable to tampering.     |
    |This is only compatible with a signature-less bootloader and is|
    |not suitable for production environments.                      |
      File "/home/ubuntu/.local/bin/nrfutil", line 8, in <module>
        sys.exit(cli())
      File "/usr/lib/python3/dist-packages/click/core.py", line 764, in __call__
        return self.main(*args, **kwargs)
      File "/usr/lib/python3/dist-packages/click/core.py", line 717, in main
        rv = self.invoke(ctx)
      File "/usr/lib/python3/dist-packages/click/core.py", line 1137, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "/usr/lib/python3/dist-packages/click/core.py", line 956, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "/usr/lib/python3/dist-packages/click/core.py", line 555, in invoke
        return callback(*args, **kwargs)
      File "/home/ubuntu/.local/lib/python3.8/site-packages/nordicsemi/__main__.py", line 867, in generate
        package.generate_package(zipfile_path)
      File "/home/ubuntu/.local/lib/python3.8/site-packages/nordicsemi/dfu/package.py", line 403, in generate_package
        for key, firmware_data in self.firmwares_data.iteritems():
    AttributeError: 'dict' object has no attribute 'iteritems'
    It would seem someone expects python2, and someone else has python3.
    python2 and python3 are installed on the pi. Not sure how to get this command to work.
    Looking at the failure logs I'm getting from pairing attempts, the very last line intrigues me.
    [1658163090.255000][25638:25638] CHIP:TOO: Run command failure: ../../src/controller/AutoCommissioner.cpp:204: CHIP Error 0x0000002F: Invalid argument
    I see a similar message at the bottom of this guide (green box), but in my case, the dongle is indeed /dev/ttyACM0. I replugged it anyway, but there was no change.
  • Now, after reflashing the dongle, I am back at the previous error:
    [1658169487.273242][2552:2555] CHIP:DL: FAIL: ConnectDevice : GDBus.Error:org.bluez.Error.Failed: Software caused connection abort (36)
    [1658169487.273525][2552:2557] CHIP:DL: HandlePlatformSpecificBLEEvent 16386
    [1658169487.273607][2552:2557] CHIP:CTL: Commissioning discovery over BLE failed: ../../src/platform/Linux/bluez/Helper.cpp:1775: CHIP Error 0x000000AC: Internal error
    [1658169515.132848][2552:2552] CHIP:TOO: Run command failure: ../../examples/chip-tool/commands/pairing/PairingCommand.cpp:151: CHIP Error 0x00000003: Incorrect state
    I have verified that bluetooth seems to be working tho.
    $ sudo apt-get upgrade pi-bluetooth
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    pi-bluetooth is already the newest version (0.1.15ubuntu0~20.04.1).
    Calculating upgrade... Done
    The following package was automatically installed and is no longer required:
      libfwupdplugin1
    Use 'sudo apt autoremove' to remove it.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    $ sudo apt-get upgrade bluez
    bluez is already the newest version (5.53-0ubuntu3.6).
      libfwupdplugin1
    $ sudo service bluetooth status
    ● bluetooth.service - Bluetooth service
         Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
         Active: active (running) since Mon 2022-07-18 18:25:15 UTC; 16min ago
           Docs: man:bluetoothd(8)
       Main PID: 2314 (bluetoothd)
         Status: "Running"
          Tasks: 1 (limit: 4435)
         CGroup: /system.slice/bluetooth.service
                 └─2314 /usr/lib/bluetooth/bluetoothd
    Jul 18 18:25:15 ubuntu systemd[1]: Starting Bluetooth service...
    Jul 18 18:25:15 ubuntu bluetoothd[2314]: Bluetooth daemon 5.53
    Jul 18 18:25:15 ubuntu systemd[1]: Started Bluetooth service.
    Jul 18 18:25:15 ubuntu bluetoothd[2314]: Starting SDP server
    Jul 18 18:25:15 ubuntu bluetoothd[2314]: Bluetooth management interface 1.14 initialized
    $ sudo bluetoothctl
    Agent registered
    [CHG] Controller E4:5F:01:AE:C9:43 Pairable: yes
    [bluetooth]# scan on
    Discovery started
    [CHG] Controller E4:5F:01:AE:C9:43 Discovering: yes
    [CHG] Device 5E:6B:F7:31:0B:02 RSSI: -70
    [CHG] Device 5E:6B:F7:31:0B:02 ManufacturerData Key: 0x004c
    [CHG] Device 5E:6B:F7:31:0B:02 ManufacturerData Value:
      0c 0e 00 4f 41 30 66 b4 80 6e 23 67 52 ec 3e 4d  ...OA0f..n#gR.>M
      10 06 4e 1d 64 e3 97 28                          ..N.d..(
    [NEW] Device 50:01:00:00:01:2E Flash-012E
    [CHG] Device 7D:8C:74:DF:19:3D RSSI: -58
    [CHG] Device 7D:8C:74:DF:19:3D TxPower: 12
    [CHG] Device 7D:8C:74:DF:19:3D ManufacturerData Key: 0x004c
    [CHG] Device 7D:8C:74:DF:19:3D ManufacturerData Value:
      10 06 5b 1d 8c de fe a8                          ..[.....
    As well, otbr seems fine.
    $ sudo service otbr-agent status
    ● otbr-agent.service - OpenThread Border Router Agent
         Loaded: loaded (/lib/systemd/system/otbr-agent.service; enabled; vendor preset: enabled)
         Active: active (running) since Mon 2022-07-18 18:20:09 UTC; 21min ago
        Process: 2099 ExecStartPre=/usr/sbin/service mdns start (code=exited, status=0/SUCCESS)
       Main PID: 2106 (otbr-agent)
         CGroup: /system.slice/otbr-agent.service
                 └─2106 /usr/sbin/otbr-agent -I wpan0 -B wlan0 spinel+hdlc+uart:///dev/ttyACM0 trel://wlan0
    Jul 18 18:41:18 ubuntu otbr-agent[2106]: 00:21:09.494 [I] MeshForwarder-:     src:[fe80:0:0:0:b023:fc87:27d8:74ca]:19788
    Jul 18 18:41:18 ubuntu otbr-agent[2106]: 00:21:09.495 [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    Jul 18 18:41:24 ubuntu otbr-agent[2106]: 00:21:15.418 [I] Mle-----------: Send Advertisement (ff02:0:0:0:0:0:0:1)
    Jul 18 18:41:24 ubuntu otbr-agent[2106]: 00:21:15.424 [I] MeshForwarder-: Sent IPv6 UDP msg, len:90, chksum:9805, ecn:no, to:0xffff, sec:no, prio:net
    Jul 18 18:41:24 ubuntu otbr-agent[2106]: 00:21:15.424 [I] MeshForwarder-:     src:[fe80:0:0:0:b023:fc87:27d8:74ca]:19788
    Jul 18 18:41:24 ubuntu otbr-agent[2106]: 00:21:15.424 [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    Jul 18 18:41:39 ubuntu otbr-agent[2106]: 00:21:30.559 [I] Mle-----------: Send Announce on channel 26
    Jul 18 18:41:39 ubuntu otbr-agent[2106]: 00:21:30.566 [I] MeshForwarder-: Sent IPv6 UDP msg, len:83, chksum:eb65, ecn:no, to:0xffff, sec:yes, prio:net
    Jul 18 18:41:39 ubuntu otbr-agent[2106]: 00:21:30.566 [I] MeshForwarder-:     src:[fe80:0:0:0:b023:fc87:27d8:74ca]:19788
    Jul 18 18:41:39 ubuntu otbr-agent[2106]: 00:21:30.566 [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
  • Ok, I decided to wipe the pi and start over. Same result. However, I see that I'm using BT v5.53, when the chip-tool guide says to use v5.55+ (which requires Ubuntu 22+). So I wiped the pi again and installed Ubuntu 22 64bit ARM.
    Setup was slightly painful. Mostly I followed the guides, but had to install a few extra things to get matter to build.
    apt-get update
    apt install python3.10-venv
    apt-get install libgtk-3-dev
    apt-get install python-dev-is-python3
    Finally, everything was built with the requisite BT version.
    $ bluetoothctl version
    Version 5.64
    Well, it turns out that bluetooth on the RPi just has a million and one problems. I've now encountered many more errors that sound like `failed to connect - some bluetooth error`.
    It seems this hardware setup is not going to work. Time to abandon ship and build a virtual one.
