Can't proproly recive commands form mobil
I'm just trying to make a simple communicatión between my nrf52 dk and my mobil using Serial Bluetooth Terminal app. I took the ble_app_uart example and I added a function that turn on or off the Led 2 if the DK recives a 'a' or a 's', but I don't know why it didn't work, and I can't find out where is the error.
The only thing I changed is the for loop for a while loop, where I added the idle_state_handle function and the function I developed
static void communication(void)
	uint8_t command;
	while(app_uart_get(&command) != NRF_SUCCESS);
	if(command == 'a')
		bsp_board_led_on(1);
		printf("Leds turned on!!\r\n");
	else if(command == 's')
		bsp_board_led_off(1);
		printf("Leds turned off!!\r\n");
		printf("Invalid command!!\r\n");
  • I suggest to contine the debugging, for new development you should check out the nRF Connect SDK.
    Start with https://academy.nordicsemi.com/ and the follow up with https://webinars.nordicsemi.com/developing-bluetooth-low-energy-6
  • Okay, I finaly solve it. In the nus_data_handler function I implement this code for the reciving command part:
    static void nus_data_handler(ble_nus_evt_t * p_evt) // data handler
    	char letra = 0;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
    			letra = p_evt->params.rx_data.p_data[i];
    			if(letra == 97)
    				bsp_board_led_on(3);
    			if(letra == 98)
    				bsp_board_led_off(3);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
    			while (app_uart_put('\n') == NRF_ERROR_BUSY);
    And then, to send messages to the DK I implement this one:
    static void send_command(uint8_t data_array[BLE_NUS_MAX_DATA_LEN]) // data sending
    	uint32_t err_code;
    	idle_state_handle();
    	uint16_t length = 0; // data_array length
    	for(int i=0; i<BLE_NUS_MAX_DATA_LEN; i++)
    		if(data_array[i] != 0)
    			length ++;
      if ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_RESOURCES) && (err_code != NRF_ERROR_NOT_FOUND))
