I'm trying to get latch functionality working on two GPIO pins, but cannot seem get the latch register to behave consistently.
I have my GPIOs configured using a custom DTS binding and overlay, something like this:
mbuttons { compatible = "any,spdt-switch"; rmb: switch_0 { ncgpios = <&gpio1 13 0>; nogpios = <&gpio1 12 0>; }; };
In my main code, the flow is roughly as follows:
#define RMB_NODE DT_NODELABEL(rmb) // in main // edit: I tried both low and high sense settings, but expect low to work as I need it to here nrf_gpio_cfg_sense_input(NRF_DT_GPIOS_TO_PSEL(RMB_NODE, nogpios), NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW); nrf_gpio_cfg_sense_input(NRF_DT_GPIOS_TO_PSEL(RMB_NODE, ncgpios), NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW); uint32_t p_mask; while(1) { // I've also tried this one, with p_masks etc // pmask = nrf_gpio_latches_read_and_clear(0, 2, p_masks); // read latch values p_mask = NRF_P1->LATCH; // and clear them NRF_P1->LATCH = p_mask; if (p_mask != 0){ LOG_INF("Event: %d", p_mask); } }
I get the logging statement very rarely when actuating my switch. I have the switch hooked up to a scope, which is showing behavior as I'd expect for an SPDT switch (common is GND, default NC low & NO high, on click switching to NC high and NO low, where high is ~3.4v and low is ~200mv).
A few questions:
1. Is there anything obviously wrong here?
2. Is there a recommended workflow for working with NRF-specific functionality in NCS/Zephyr? I'm using functions from nrf_gpio.h, e.g. nrf_gpio_cfg_sense_input, etc. I couldn't find any documentation on detect/latch configuration in the context of Zephyr/NCS, just GPIOTE (which I don't necessarily need/want to use yet).
