Hi All,
I have implemented sleep mode in the firmware. I am using NRF52833 in my project. When the device is in idle state it goes in sleep mode. I am able to wakeup my device through GPIO interrupt. After waking up I have observed that the device is advertising but the timers are not getting initialized again. I have one timer under which I run certain tasks. This timer runs at an interval of 10 seconds. How can we reinitialize the timer after waking up?? I am also using FreeRtos in my project. Please find the attached code below:-
#define AQ_USER_BUTTON NRF_GPIO_PIN_MAP(0,4)
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
//bool erase_bonds;
switch(pin)
case AQ_USER_BUTTON:
NRF_LOG_INFO("ADVERTISING START\r\n");
advertising_start(false);
void gpio_init(void)
ret_code_t err_code;
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(false);
in_config.pull = NRF_GPIO_PIN_PULLUP;
err_code = nrf_drv_gpiote_in_init(AQ_USER_BUTTON, &in_config, in_pin_handler);
nrf_drv_gpiote_in_event_enable(AQ_USER_BUTTON, true);
sleep = 1;
NRF_LOG_INFO("SLEEP MODE ENTER\r\n");
// Prepare wakeup buttons.
// APP_ERROR_CHECK(err_code);
uint32_t err_code;
switch (ble_adv_evt) {
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
The timer configuration is as below:-
err_rc_t init_borrower_task(void)
err_rc_t rc = RESULT_SUCCESS;
do {
/* Start the two tasks as described in the comments at the top of this
file. */
borrower_task_handle = xTaskCreateStatic(
borrower_task, /* Function that implements the task. */
"BORROWER", /* Text name for the task. */
BORROWER_TASK_STACK_SIZE, /* Number of indexes in the borrower_stack array. */
( void * ) 1, /* Parameter passed into the task. */
BORROWER_TASK_PRIORITY,/* Priority at which the task is created. */
borrower_stack, /* Array to use as the task's stack. */
&task_borrower_tcb ); /* Variable to hold the task's data structure. */
if(borrower_task_handle == NULL) {
rc = RESULT_ERROR_FAILURE;
/* Create a queue */
borrower_queue_handle = xQueueCreateStatic( QUEUE_LENGTH,
ITEM_SIZE,
borrower_queue_storage_area,
&xStaticQueue );
if(borrower_queue_handle == NULL) {
max17211_handle = xTimerCreateStatic("Max17211Timer",
10000,
pdTRUE,
( void * ) 0,
max17211_timer_callback,
&max17211_timer);
if( max17211_handle == NULL ) {
/* The timer was not created */
} while(0);
return rc;
void max17211_timer_callback( TimerHandle_t xTimer )
nrf_drv_wdt_feed();
get_max17201_data();
read_bq2429_data();
NRF_LOG_INFO("*******************************************\r\n");
borrower_task_queue_event(BORROWER_TASK_EVT_NOTIF_EN);
I need some help on this.
Thanks & Regards,
Snehal.
