Issues with configuring PSM on the nRF9160
I'm currently attempting to get the nRF 9160 to enter PSM mode when not transmitting along with the asset_tracker_v2 application just so we can do some power consumption measurements for the 9160. However, I'm running into an issue where the nRF9160 seems to stop transmitting to nRF Cloud whenever I've set up the PSM mode.
To enable PSM mode I've included lte_lc_psm_req(true); in main.c. I've also tried an alternative implementation by defining the following function and calling setup_psm(); in the main, to the same effect.
void setup_psm(void)
	char psm_settings[] = CONFIG_LTE_PSM_REQ_RPTAU;
	printk("PSM bits: %c%c%c\n", psm_settings[0], psm_settings[1],
	       psm_settings[2]);
	printk("PSM Interval: %c%c%c%c%c\n", psm_settings[3], psm_settings[4],
	       psm_settings[5], psm_settings[6], psm_settings[7]);
	int err = lte_lc_psm_req(true);
	if (err < 0) {
		printk("Error setting PSM: %d Errno: %d\n", err, errno);
The following is the output on the terminal when I run the modified asset_tracker_v2 application:
*** Booting Zephyr OS build v3.0.99-ncs1  ***
Attempting to boot slot 0.
Attempting to boot from address 0x8200.
Verifying signature against key 0.
Hash: 0x0c...0d
Firmware signature verified.
Firmware version 1
Booting (0x8200).
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Swap type: none
I: Swap type: none
I: Bootloader chainload address offset: 0x28000
I: Jumping to the first image slot
APPLICATION START!
[00:00:00.508,209]
[1;31m<err> settings: set-value failure. key: data_module/config error(40)
[0m
[00:00:00.516,876]
[0m<inf> app_event_manager: APP_EVT_START
[0m
[00:00:00.517,700]
[0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT
[0m
[00:00:00.518,218]
[0m<inf> app_event_manager: APP_EVT_ACTIVITY_DETECTION_DISABLE
[0m
[00:00:00.573,120]
[0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
[0m
%CESQ: 57,2,8,1
+CEREG: 2,"2042","00378F1E",7
+CSCON: 1
%CESQ: 52,2,11,1
[00:00:03.878,112]
[0m<inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED
[0m
[00:00:03.878,692]
[0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
[0m
%XTIME: ,"22708190509240","01"
%MDMEV: SEARCH STATUS 2
+CEREG: 5,"2042","00378F1E",7,,,"11100000","11100000"
AT+COPS=3,2
OK
AT+COPS?
+COPS: 0,2,"23415",7
OK
AT%XCBAND
%XCBAND: 20
OK
AT+CGDCONT?
+CGDCONT: 0,"IP","wlapn.com","10.111.7.191",0,0
OK
AT+CGACT?
+CGACT: 0,1
OK
[00:00:04.906,524]
[0m<inf> app_event_manager: DATA_EVT_DATE_TIME_OBTAINED
[0m
[00:00:05.326,995]
[0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
[0m
[00:00:05.327,575]
[0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
[0m
[00:00:05.328,857]
[1;33m<wrn> cloud_module: Cloud connection establishment in progress
[0m
[00:00:05.328,887]
[1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful
[0m
[00:00:05.329,040]
[0m<inf> app_event_manager: CLOUD_EVT_CONNECTING
[0m
[00:00:09.040,008]
[0m<inf> app_event_manager: CLOUD_EVT_CONFIG_RECEIVED
[0m
[00:00:09.047,302]
[0m<inf> app_event_manager: DATA_EVT_CONFIG_SEND
[0m
[00:00:09.048,034]
[0m<inf> app_event_manager: CLOUD_EVT_DATA_SEND_QOS
[0m
[00:00:09.829,315]
[0m<inf> app_event_manager: CLOUD_EVT_CONNECTED
[0m
[00:00:09.830,505]
[0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, MOD_STAT)
[0m
[00:00:09.832,061]
[0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED
[0m
[00:00:09.940,216]
[0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY
[0m
[00:00:09.991,821]
[0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY
[0m
%NCELLMEAS: 0,"00378F1E","23415","2042",64,6300,104,57,13,9585,6300,103,59,16,0,9453
[00:00:10.105,285]
[0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY
[0m
[00:00:10.115,173]
[0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY
[0m
[00:00:10.116,088]
[0m<inf> app_event_manager: DATA_EVT_DATA_READY
[0m
[00:00:10.120,391]
[0m<inf> app_event_manager: DATA_EVT_NEIGHBOR_CELLS_DATA_SEND
[0m
[00:00:10.130,828]
[0m<inf> app_event_manager: DATA_EVT_DATA_SEND_BATCH
[0m
[00:00:10.131,591]
[0m
[00:00:10.131,866]
[0m
%CESQ: 50,2,16,2
%CESQ: 48,2,11,1
%NCELLMEAS: 0,"00378F1E","23415","2042",65,6300,104,56,9,30057,6300,103,58,14,0,26955
[00:00:30.518,280]
[0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL
[0m
[00:00:30.518,951]
[0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)
[0m
[00:00:30.519,866]
[0m
[00:00:30.576,690]
[0m
[00:00:30.656,005]
[0m
[00:00:30.672,119]
[0m
%CESQ: 46,2,6,0
+CSCON: 0
%CESQ: 57,2,14,2
+CEREG: 5,"2042","00378F14",7,,,"11100000","11100000"
AT+COPS=3,2
OK
AT+COPS?
OK
AT%XCBAND
%XCBAND: 20
OK
%CESQ: 52,2,13,1
AT+CGDCONT?
OK
AT+CGACT?
+CGACT: 0,1
OK
[00:00:38.913,330]
[0m
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,55,11,59676,0
[00:01:00.518,280]
[0m
[00:01:00.518,951]
[0m
[00:01:00.519,805]
[0m
[00:01:00.600,769]
[0m
[00:01:00.673,858]
[0m
[00:01:00.688,293]
[0m
%CESQ: 53,2,8,1
%CESQ: 53,2,13,1
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,53,17,89756,0
[00:01:30.518,280]
[0m
[00:01:30.518,951]
[0m
[00:01:30.519,805]
[0m
[00:01:30.600,036]
[0m
[00:01:30.679,443]
[0m
[00:01:30.693,054]
[0m
%CESQ: 53,2,18,2
%CESQ: 53,2,13,1
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,52,15,119836,0
[00:02:00.518,280]
[0m
[00:02:00.518,951]
[0m
[00:02:00.519,805]
[0m
[00:02:00.600,250]
[0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY
[0m
[00:02:00.673,309]
[0m
[00:02:00.687,896]
[0m
%CESQ: 51,2,8,1
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,51,9,149916,0
[00:02:30.518,280]
[0m
[00:02:30.518,951]
[0m
[00:02:30.519,805]
[0m
[00:02:30.606,384]
[0m
[00:02:30.673,339]
[0m
[00:02:30.687,744]
[0m
%CESQ: 51,2,13,1
%CESQ: 46,2,9,1
%CESQ: 48,2,3,0
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,48,6,179996,0
%CESQ: 48,2,8,1
active_wait_timeout is currently set to be 30 seconds
The PSM TAU setting is 10000001 and the requested active time is 00100001.
    Could you check what Tau values you are actually getting from the network? The actual values that are given can be observed in callbacks from the Link controller i.e here.
    Elfving
    I double checked the TAU values and they seem to be in line with what I had set, though the problem still persists. I have attached the log of the initial few seconds below.
    If it's of any interest, CONFIG_LOG_DEFAULT_LEVEL=4 was enabled in the prof.conf file.
    APPLICATION START!
    PSM bits: 110
    PSM Interval: 00001
    PSM Set Up!
    [00:00:00.518,676]
    [0m
    [00:00:00.574,645]
    [0m
    [00:00:01.511,413]
    [0m
    [00:00:01.511,962]
    [0m
    %CESQ: 53,2,7,1
    +CEREG: 2,"2042","00378F14",7
    +CSCON: 1
    [00:00:03.903,289]
    [0m
    [00:00:03.903,930]
    [0m
    %XTIME: ,"22700231759140","01"
    AT+COPS=3,2
    OK
    AT+COPS?
    OK
    AT%XCBAND
    %XCBAND: 20
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    [00:00:05.000,701]
    [0m
    [00:00:05.535,705]
    [0m
    [00:00:05.536,346]
    [0m
    [00:00:05.537,689]
    [0m
    [00:00:05.537,719]
    [0m
    [00:00:05.537,872]
    [0m
    [00:00:10.529,998]
    [0m
    [00:00:10.535,491]
    [1;33m<wrn> data_module: New Active wait timeout: 30
    [0m
    [00:00:10.536,926]
    [0m<inf> app_event_manager: DATA_EVT_CONFIG_READY
    [0m
    [00:00:10.537,475]
    [0m
    [00:00:10.539,764]
    [0m
    [00:00:10.540,679]
    [0m
    [00:00:11.524,230]
    [0m
    [00:00:11.525,390]
    [0m
    [00:00:11.526,947]
    [0m
    [00:00:1%NCELLMEAS: 0,"00378F14","23415","2042",80,6300,103,59,19,11296,6300,104,56,13,0,11350
    1.599,426]
    [0m<dbg> modem_info: parse_ip_addresses: Device has 1 IP addresses
    [0m
    [00:00:11.599,700]
    [0m<dbg> modem_info: parse_ip_addresses: IP address found: 10.111.7.191
    [0m
    [00:00:11.600,616]
    [0m
    [00:00:11.600,891]
    [0m
    [00:00:11.703,735]
    [0m
    [00:00:11.706,970]
    [0m
    [00:00:11.707,244]
    [0m
    [00:00:11.755,554]
    [0m
    [00:00:11.758,575]
    [0m
    [00:00:11.758,850]
    [0m
    [00:00:11.807,861]
    [0m
    [00:00:11.818,206]
    [0m
    [00:00:11.915,008]
    [0m
    [00:00:11.919,128]
    [0m
    [00:00:11.929,931]
    [0m
    [00:00:11.930,816]
    [0m
    [00:00:11.931,091]
    [0m
  • CEREG is telling us you're not getting PSM from the network.
    Could you run CPSMS?
    Elfving
  • Hi, below is the log from when I ram CPSMS:
    Booting (0x8200).
    I: Swap type: none
    I: Swap type: none
    APPLICATION START!
    PSM bits: 101
    PSM Interval: 00001
    PSM Set Up!
    [00:00:00.511,352]
    [0m
    [00:00:00.518,646]
    [0m
    [00:00:00.519,470]
    [0m
    [00:00:00.519,989]
    [0m
    [00:00:00.574,798]
    [0m
    %CESQ: 55,2,8,1
    +CSCON: 1
    %CESQ: 56,2,16,2
    [00:00:03.874,053]
    [0m
    [00:00:03.874,664]
    [0m
    %XTIME: ,"22702231130040","01"
    AT+COPS=3,2
    OK
    AT+COPS?
    OK
    AT%XCBAND
    [00:00:05.012,878]
    [0m
    [00:00:05.489,288]
    [0m
    [00:00:05.489,929]
    [0m
    [00:00:05.491,363]
    [0m
    [00:00:05.491,363]
    [0m
    [00:00:05.491,546]
    [0m
    %XCBAND: 20
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    [00:00:09.252,441]
    [0m
    [00:00:09.259,857]
    [0m
    [00:00:09.260,589]
    [0m
    [00:00:10.203,460]
    [0m
    [00:00:10.204,620]
    [0m
    [00:00:10.206,146]
    [0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_DATA_READY
    [0m
    [00:00:10.210,174]
    [0m
    [00:00:10.210,449]
    [0m
    [00:00:10.211,425]
    [0m
    [00:00:10.211,700]
    [0m
    %NCELLMEAS: 0,"00378F14","23415","2042",81,6300,103,63,23,9987,6300,104,58,12,0,9855
    [00:00:10.379,943]
    [0m
    [00:00:10.382,873]
    [0m
    [00:00:10.383,148]
    [0m
    [00:00:10.432,098]
    [0m
    [00:00:10.435,180]
    [0m
    [00:00:10.435,455]
    [0m
    [00:00:10.484,039]
    [0m
    [00:00:10.494,262]
    [0m
    [00:00:10.495,086]
    [0m
    [00:00:10.499,328]
    [0m
    [00:00:10.501,800]
    [1;31m<err> cloud_codec: Value of button is 0
    [0m
    [00:00:10.501,861]
    [0m
    [00:00:10.501,922]
    [0m
    [00:00:10.519,653]
    [0m
    [00:00:10.520,416]
    [0m
    [00:00:10.520,690]
    [0m
    AT+CEREG?
    +CEREG: 5,5,"2042","00378F14",7,,,"11100000","11100000"
    OK
    AT+COPS=3,2
    OK
    AT+COPS?
    OK
    AT%XCBAND
    %XCBAND: 20
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    AT+CPSMS?
    +CPSMS: 1,,,"10100001","00001010"
    OK
    CPSMS seems to indicate that PSM is enabled and with the correct tau and active time settings..?
    Yeah, looks like PSM should be requested in the modem at least (not necessarily enabled, as that is something the network would do). And as CEREG told us, it doesn't enable PSM.
    The values doesn't look correct to me. +CPSMS: 1,,,"10100001","00001010", so Tau is set to a minute and RAT is at 20s. I thought you wanted 10 minutes and 30 sec?
    And could you try to request a longer Tau value and see if that helps getting you PSM from the network? This Tau value is extremely low, maybe that is why the network doesn't even bother enabling PSM. The network would want to minimize the load after all.
    Elfving
