Issues with configuring PSM on the nRF9160
I'm currently attempting to get the nRF 9160 to enter PSM mode when not transmitting along with the asset_tracker_v2 application just so we can do some power consumption measurements for the 9160. However, I'm running into an issue where the nRF9160 seems to stop transmitting to nRF Cloud whenever I've set up the PSM mode.
To enable PSM mode I've included lte_lc_psm_req(true); in main.c. I've also tried an alternative implementation by defining the following function and calling setup_psm(); in the main, to the same effect.
void setup_psm(void)
	char psm_settings[] = CONFIG_LTE_PSM_REQ_RPTAU;
	printk("PSM bits: %c%c%c\n", psm_settings[0], psm_settings[1],
	       psm_settings[2]);
	printk("PSM Interval: %c%c%c%c%c\n", psm_settings[3], psm_settings[4],
	       psm_settings[5], psm_settings[6], psm_settings[7]);
	int err = lte_lc_psm_req(true);
	if (err < 0) {
		printk("Error setting PSM: %d Errno: %d\n", err, errno);
The following is the output on the terminal when I run the modified asset_tracker_v2 application:
*** Booting Zephyr OS build v3.0.99-ncs1  ***
Attempting to boot slot 0.
Attempting to boot from address 0x8200.
Verifying signature against key 0.
Hash: 0x0c...0d
Firmware signature verified.
Firmware version 1
Booting (0x8200).
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Swap type: none
I: Swap type: none
I: Bootloader chainload address offset: 0x28000
I: Jumping to the first image slot
APPLICATION START!
[00:00:00.508,209]
[1;31m<err> settings: set-value failure. key: data_module/config error(40)
[0m
[00:00:00.516,876]
[0m<inf> app_event_manager: APP_EVT_START
[0m
[00:00:00.517,700]
[0m<inf> app_event_manager: DATA_EVT_CONFIG_INIT
[0m
[00:00:00.518,218]
[0m<inf> app_event_manager: APP_EVT_ACTIVITY_DETECTION_DISABLE
[0m
[00:00:00.573,120]
[0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
[0m
%CESQ: 57,2,8,1
+CEREG: 2,"2042","00378F1E",7
+CSCON: 1
%CESQ: 52,2,11,1
[00:00:03.878,112]
[0m<inf> app_event_manager: MODEM_EVT_LTE_DISCONNECTED
[0m
[00:00:03.878,692]
[0m<inf> app_event_manager: MODEM_EVT_LTE_CELL_UPDATE
[0m
%XTIME: ,"22708190509240","01"
%MDMEV: SEARCH STATUS 2
+CEREG: 5,"2042","00378F1E",7,,,"11100000","11100000"
AT+COPS=3,2
OK
AT+COPS?
+COPS: 0,2,"23415",7
OK
AT%XCBAND
%XCBAND: 20
OK
AT+CGDCONT?
+CGDCONT: 0,"IP","wlapn.com","10.111.7.191",0,0
OK
AT+CGACT?
+CGACT: 0,1
OK
[00:00:04.906,524]
[0m<inf> app_event_manager: DATA_EVT_DATE_TIME_OBTAINED
[0m
[00:00:05.326,995]
[0m<inf> app_event_manager: MODEM_EVT_LTE_CONNECTED
[0m
[00:00:05.327,575]
[0m<inf> app_event_manager: MODEM_EVT_LTE_PSM_UPDATE
[0m
[00:00:05.328,857]
[1;33m<wrn> cloud_module: Cloud connection establishment in progress
[0m
[00:00:05.328,887]
[1;33m<wrn> cloud_module: New connection attempt in 32 seconds if not successful
[0m
[00:00:05.329,040]
[0m<inf> app_event_manager: CLOUD_EVT_CONNECTING
[0m
[00:00:09.040,008]
[0m<inf> app_event_manager: CLOUD_EVT_CONFIG_RECEIVED
[0m
[00:00:09.047,302]
[0m<inf> app_event_manager: DATA_EVT_CONFIG_SEND
[0m
[00:00:09.048,034]
[0m<inf> app_event_manager: CLOUD_EVT_DATA_SEND_QOS
[0m
[00:00:09.829,315]
[0m<inf> app_event_manager: CLOUD_EVT_CONNECTED
[0m
[00:00:09.830,505]
[0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, MOD_STAT)
[0m
[00:00:09.832,061]
[0m<inf> app_event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED
[0m
[00:00:09.940,216]
[0m<inf> app_event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY
[0m
[00:00:09.991,821]
[0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY
[0m
%NCELLMEAS: 0,"00378F1E","23415","2042",64,6300,104,57,13,9585,6300,103,59,16,0,9453
[00:00:10.105,285]
[0m<inf> app_event_manager: MODEM_EVT_BATTERY_DATA_READY
[0m
[00:00:10.115,173]
[0m<inf> app_event_manager: MODEM_EVT_NEIGHBOR_CELLS_DATA_READY
[0m
[00:00:10.116,088]
[0m<inf> app_event_manager: DATA_EVT_DATA_READY
[0m
[00:00:10.120,391]
[0m<inf> app_event_manager: DATA_EVT_NEIGHBOR_CELLS_DATA_SEND
[0m
[00:00:10.130,828]
[0m<inf> app_event_manager: DATA_EVT_DATA_SEND_BATCH
[0m
[00:00:10.131,591]
[0m
[00:00:10.131,866]
[0m
%CESQ: 50,2,16,2
%CESQ: 48,2,11,1
%NCELLMEAS: 0,"00378F1E","23415","2042",65,6300,104,56,9,30057,6300,103,58,14,0,26955
[00:00:30.518,280]
[0m<inf> app_event_manager: APP_EVT_DATA_GET_ALL
[0m
[00:00:30.518,951]
[0m<inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, NEIGHBOR_CELLS, GNSS)
[0m
[00:00:30.519,866]
[0m
[00:00:30.576,690]
[0m
[00:00:30.656,005]
[0m
[00:00:30.672,119]
[0m
%CESQ: 46,2,6,0
+CSCON: 0
%CESQ: 57,2,14,2
+CEREG: 5,"2042","00378F14",7,,,"11100000","11100000"
AT+COPS=3,2
OK
AT+COPS?
OK
AT%XCBAND
%XCBAND: 20
OK
%CESQ: 52,2,13,1
AT+CGDCONT?
OK
AT+CGACT?
+CGACT: 0,1
OK
[00:00:38.913,330]
[0m
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,55,11,59676,0
[00:01:00.518,280]
[0m
[00:01:00.518,951]
[0m
[00:01:00.519,805]
[0m
[00:01:00.600,769]
[0m
[00:01:00.673,858]
[0m
[00:01:00.688,293]
[0m
%CESQ: 53,2,8,1
%CESQ: 53,2,13,1
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,53,17,89756,0
[00:01:30.518,280]
[0m
[00:01:30.518,951]
[0m
[00:01:30.519,805]
[0m
[00:01:30.600,036]
[0m
[00:01:30.679,443]
[0m
[00:01:30.693,054]
[0m
%CESQ: 53,2,18,2
%CESQ: 53,2,13,1
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,52,15,119836,0
[00:02:00.518,280]
[0m
[00:02:00.518,951]
[0m
[00:02:00.519,805]
[0m
[00:02:00.600,250]
[0m<inf> app_event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_NOT_READY
[0m
[00:02:00.673,309]
[0m
[00:02:00.687,896]
[0m
%CESQ: 51,2,8,1
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,51,9,149916,0
[00:02:30.518,280]
[0m
[00:02:30.518,951]
[0m
[00:02:30.519,805]
[0m
[00:02:30.606,384]
[0m
[00:02:30.673,339]
[0m
[00:02:30.687,744]
[0m
%CESQ: 51,2,13,1
%CESQ: 46,2,9,1
%CESQ: 48,2,3,0
%NCELLMEAS: 0,"00378F14","23415","2042",65535,6300,103,48,6,179996,0
%CESQ: 48,2,8,1
active_wait_timeout is currently set to be 30 seconds
The PSM TAU setting is 10000001 and the requested active time is 00100001.
